楼主: whxciotw
[经验分享] 【Zigbee2mqtt】接入HA,Z2m Add-on 及 Assistant Add-on介绍
发表于 2020-8-24 10:18:14 | 显示全部楼层
大佬,这个支持多个z2m网关管理吗?
发表于 2020-9-7 10:48:35 | 显示全部楼层
addon 如何添加其他设备? 有大神会的吗? 貌似找不到devices.js
发表于 2020-11-14 21:30:35 | 显示全部楼层
sirakawa 发表于 2020-1-22 20:02
卧槽?cc2531还有车?
这玩意不是淘宝随便买个就能用了么= =!
你好,CC26X2R1在哪里购买呀?
发表于 2020-11-17 09:23:20 | 显示全部楼层
这些大佬是真滴强!!!
发表于 2020-12-26 02:03:35 来自手机 | 显示全部楼层
首先感谢大佬的教程贴,然后长草买了个z2m的网关,绿米无线单开,显示不匹配无法识别,温湿度计倒是没有问题。求解决办法啊!!
发表于 2020-12-26 02:06:09 来自手机 | 显示全部楼层
型号是无线开关D1单键
发表于 2020-12-26 21:31:16 | 显示全部楼层
同问devices.js在哪儿找呢。树莓派docker安装的hassio 插件装的zigbee2mqtt
PJK 手机认证
发表于 2021-1-11 12:10:15 | 显示全部楼层
配置可以使用一次,重启之后又失灵了请问是什么问题
Zigbee2MQTT:error 2021-01-11 12:05:39: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2021-01-11 12:05:39: Failed to start zigbee
Zigbee2MQTT:error 2021-01-11 12:05:39: Exiting...
Zigbee2MQTT:error 2021-01-11 12:05:39: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
    at ZStackAdapter.<anonymous> (/zigbee2mqtt-1.17.0/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:94:31)
    at Generator.throw (<anonymous>)
    at rejected (/zigbee2mqtt-1.17.0/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:25:65)
npm
ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR!
[email protected] start: `node index.js`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the [email protected] start script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR!     /root/.npm/_logs/2021-01-11T04_05_39_496Z-debug.log
2021-01-11T12:05:42: PM2 log: App [npm:0] exited with code [1] via signal [SIGINT]
2021-01-11T12:05:42: PM2 log: App [npm:0] starting in -fork mode-
2021-01-11T12:05:42: PM2 log: App [npm:0] online
> [email protected] start /zigbee2mqtt-1.17.0
> node index.js
Zigbee2MQTT:info  2021-01-11 12:05:44: Logging to console and directory: '/share/zigbee2mqtt/log/2021-01-11.12-05-43' filename: log.txt
Zigbee2MQTT:info  2021-01-11 12:05:44: Starting Zigbee2MQTT version 1.17.0 (commit #1.17.0)
Zigbee2MQTT:info  2021-01-11 12:05:44: Starting zigbee-herdsman (0.13.46)
版主
 楼主| 发表于 2021-1-11 20:15:43 | 显示全部楼层
xztxy 发表于 2020-12-26 02:06
型号是无线开关D1单键
https://www.zigbee2mqtt.io/devices/QBKG21LM.html
D1单键支持的呀
版主
 楼主| 发表于 2021-1-11 20:17:02 | 显示全部楼层
用samba看,文件在这
GMT+8, 2025-11-30 18:06 , Processed in 1.349313 second(s), 10 queries , MemCached On.
