楼主: xcy1231
[插件集成] 格力云控 局域网协议 中央空调 插件 重新发布
 火.. [复制链接]
hyq
发表于 2023-6-10 20:58:55 | 显示全部楼层
pdcpgf 发表于 2023-6-8 23:20
新版不能用的参考下面方法改一下就可以了
大佬!第二个找不到!麻烦指导一下!谢谢!
发表于 2023-6-17 21:41:17 | 显示全部楼层
外联设置温度传感器不起作用
hyq
发表于 2023-6-17 22:34:05 | 显示全部楼层
我还一直以为是我自己没设置对!
Logger: homeassistant
Source: components/gree/climate.py:157
First occurred: 22:27:08 (8 occurrences)
Last logged: 22:34:08
Error doing job: Task exception was never retrieved
  File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 229, in _handle_refresh_interval
    await self._async_refresh(log_failures=True, scheduled=True)
  File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 374, in _async_refresh
    self.async_update_listeners()
  File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 164, in async_update_listeners
    update_callback()
  File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 431, in _handle_coordinator_update
    self.async_write_ha_state()
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 590, in async_write_ha_state
    self._async_write_ha_state()
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 656, in _async_write_ha_state
    attr.update(self.state_attributes or {})
  File "/usr/src/homeassistant/homeassistant/components/climate/__init__.py", line 297, in state_attributes
    self.current_temperature,
  File "/usr/src/homeassistant/homeassistant/components/gree/climate.py", line 157, in current_temperature
    return self.coordinator.device.current_temperature
  File "/usr/local/lib/python3.11/site-packages/greeclimate/device.py", line 392, in current_temperature
    return self._convert_to_units(prop - TEMP_OFFSET, bit)
TypeError: unsupported operand type(s) for -: 'str' and 'int'
发表于 2023-6-28 15:37:07 | 显示全部楼层
pdcpgf 发表于 2023-4-4 10:09
加上gree2就不能重启了
请问解决了吗
 楼主| 发表于 2023-7-7 10:26:36 | 显示全部楼层
zhuzezhong0501 发表于 2023-5-12 10:26
新版HA只要重启后空调全部离线,需要重置云控设备重新配网才能用,有遇到跟我一样的吗 ...
最新版试试
 楼主| 发表于 2023-7-7 10:26:52 | 显示全部楼层
ysdlyr 发表于 2023-5-29 00:16
我的也是如此,只要HA重启,空调就全部离线,等大佬修复吧
最新版试试吧
发表于 2023-7-12 15:29:50 | 显示全部楼层
小白请教:一是fake_server后面的IP地址是谁的IP地址?是新建的一个假IP还是什么?如果这个IP地址是新建的,网段是否要求和内网一致?二是如何在openwrt上将内网```dis.gree.com```域名指向fake server的ip?另外,HA服务器的IP是homeassistant的ip地址吗?小白对这些不明白,请大神指点,谢谢。
 楼主| 发表于 2023-7-15 19:37:49 | 显示全部楼层
ysdlyr 发表于 2023-7-12 15:29
小白请教:一是fake_server后面的IP地址是谁的IP地址?是新建的一个假IP还是什么?如果这个IP地址是新建的 ...
fake_server填的就是你的homeassistant服务器所在的ip,dns指向的话一般各大路由系统都可以修改host,或者把你homeassistant服务器的dns地址指向自建dns服务器,在dns服务器修改,详细的自己百度下呗
发表于 2023-7-16 11:14:24 | 显示全部楼层
xcy1231 发表于 2023-7-15 19:37
fake_server填的就是你的homeassistant服务器所在的ip,dns指向的话一般各大路由系统都可以修改host,或 ...
谢谢大神的指点,总算弄成功了,再次衷心感谢
发表于 2023-7-24 23:14:10 | 显示全部楼层
请问为什么我配置之后还是显示此设备无法通过UI添加。已经在con文件里面配置了
GMT+8, 2025-12-16 19:38 , Processed in 0.147831 second(s), 12 queries , MemCached On.
