楼主: jedmeng
控客设备插件2.0版发布
 火.. [复制链接]
发表于 2018-12-4 10:18:31 | 显示全部楼层
问一下 你的小kmini 接入ha了吗?
流水无味
灌水之王
发表于 2018-12-4 12:41:39 | 显示全部楼层
老的插件一直可以用的,
发表于 2018-12-4 15:23:18 | 显示全部楼层
jedmeng 发表于 2018-12-2 22:51
这部分配置看着没问题,贴一下完整的配置和log看看
你好,请问有空帮忙看看是不是插件的问题
 楼主| 发表于 2018-12-5 15:34:07 | 显示全部楼层
goldstep 发表于 2018-12-4 09:54
神啊, 有空帮忙看看啊,
1. 重启HA
2. 贴完整的log和配置
3. 同样的话说一次就够
4. 最近没空,不确定什么时候能回复
5. 所有代码都是开源的
发表于 2018-12-7 16:41:55 | 显示全部楼层
jedmeng 发表于 2018-12-5 15:34
1. 重启HA
2. 贴完整的log和配置
3. 同样的话说一次就够
1、配置了插件或修改了package文件,重启ha常识,但是该报错的地方依旧报错
2、通过爬论坛回帖,了解到了你这个插件还需要单独ikonkeIO,莫非你这个插件没有集成进来,我自己根据提示安装相关依赖,依然报错:
贴上详细日志,期待你有空协助排查,多谢
About
Home Assistant
0.82.1
Path to configuration.yaml: /config
92 Loaded Components
Press the button to load the full Home Assistant log.
Log Details (ERROR)
Fri Dec 07 2018 16:37:02 GMT+0800 (中国标准时间)
Unable to install package pykonkeio>=2.1.7: Failed building wheel for pycryptodome
python-jose-cryptodome 1.3.2 has requirement pycryptodome<3.4.0,>=3.3.1, but you'll have pycryptodome 3.7.2 which is incompatible.
pyrebase4 4.2.0 has requirement oauth2client==4.1.2, but you'll have oauth2client 4.0.0 which is incompatible.
broadlink 0.9 has requirement pycryptodome==3.4.11, but you'll have pycryptodome 3.7.2 which is incompatible.
Command "/usr/local/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-l4hngeh3/pycryptodome/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-v6_26aza/install-record.txt --single-version-externally-managed --prefix  --compile --user --prefix=" failed with error code 1 in /tmp/pip-install-l4hngeh3/pycryptodome/
You are using pip version 18.0, however version 18.1 is available.
You should consider upgrading via the 'pip install --upgrade pip' command.
发表于 2018-12-10 14:51:58 | 显示全部楼层
请问你的问题解决了吗。我遇到跟你一样的问题
gzh
发表于 2018-12-10 15:31:08 | 显示全部楼层
问题没有解决
发表于 2018-12-10 16:22:49 | 显示全部楼层
我也是,在群里我发了问题日志,
初步分析是缺少依赖,即便是安装了对应的依赖,也无济于事,
报错我没看懂,反正是不能用,郁闷ing
三木大神帮我分析的是:
“python-jose-cryptodome 1.3.2 需要pycryptodome<3.4.0,>=3.3.1
broadlink 0.9 需要pycryptodome==3.4.11
你安装了pycryptodome 3.7.2,没有一个条件是满足的
本身这2个的需求就已经是矛盾了,不能共存”
这样来看,我家用了broadlink的智能遥控设备,应该是konke的插件跟博联的红外遥控插件存在冲突, 所以现在我懒得折腾了
发表于 2018-12-11 13:50:54 | 显示全部楼层
神啊, 有空帮忙看看啊,
我和你情况类似 x86+contos7+docker+hass.io
2018-12-11 05:50:54 ERROR (MainThread) [homeassistant.loader] Unable to find component switch.konke
配置文件检查也不通过
Platform not found: switch.konke
#48的方法在容器里安装了pykonkeio
SSH里看到确实安装了
然而就是不启动,我朋友和我一样的  就可以,唯一的区别是装HA的硬件平台不同,我拿他的配置文件替换进来也不行
昨天为了搞这个 Docker也搞到启动不了 折腾了好久
发表于 2018-12-11 14:24:44 | 显示全部楼层
2018-12-11 05:50:54 ERROR (MainThread) [homeassistant.loa ...
解决了,但是原因不清楚,来记录一下首先是我目录名字弄错了,custom写成了costum。。。 不过我印象里是复制新建目录的,当时就是怕自己拼错
其次是我在放konke.py插件进去之前,就手动在容器里安装 pykonkeio 了,也确认安装成功了
但还是报错 重新安装这个好了 miniK pro可用!
另外 日志最详细是通过portainer的log看的  耐心看就能发现问题
GMT+8, 2026-2-1 13:41 , Processed in 0.563872 second(s), 12 queries , MemCached On.
