楼主: jedmeng
控客设备插件2.0版发布
 火.. [复制链接]
发表于 2018-11-25 22:50:06 | 显示全部楼层
好像安装不了,好像什么版本不对,请问怎么解决
2018-11-25 22:42:55 WARNING (MainThread) [homeassistant.loader] You are using a custom component for switch.konke which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2018-11-25 22:42:55 INFO (MainThread) [homeassistant.loader] Loaded map from homeassistant.components.map
2018-11-25 22:42:55 INFO (MainThread) [homeassistant.setup] Setting up map
2018-11-25 22:42:55 INFO (MainThread) [homeassistant.setup] Setup of domain map took 0.0 seconds.
2018-11-25 22:42:55 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.yr
2018-11-25 22:42:55 INFO (MainThread) [homeassistant.setup] Setup of domain updater took 0.2 seconds.
2018-11-25 22:42:55 INFO (MainThread) [homeassistant.setup] Setting up script
2018-11-25 22:42:55 INFO (MainThread) [homeassistant.setup] Setup of domain script took 0.0 seconds.
2018-11-25 22:42:55 INFO (MainThread) [homeassistant.setup] Setting up conversation
2018-11-25 22:42:55 INFO (MainThread) [homeassistant.setup] Setup of domain conversation took 0.0 seconds.
2018-11-25 22:42:55 INFO (MainThread) [homeassistant.setup] Setting up config
2018-11-25 22:42:55 INFO (MainThread) [homeassistant.setup] Setting up cloud
2018-11-25 22:42:55 INFO (MainThread) [homeassistant.setup] Setup of domain cloud took 0.0 seconds.
2018-11-25 22:42:55 INFO (MainThread) [homeassistant.setup] Setting up logbook
2018-11-25 22:42:55 INFO (MainThread) [homeassistant.setup] Setup of domain logbook took 0.0 seconds.
2018-11-25 22:42:55 INFO (MainThread) [homeassistant.setup] Setting up automation
2018-11-25 22:42:55 INFO (MainThread) [homeassistant.setup] Setup of domain automation took 0.0 seconds.
2018-11-25 22:42:55 INFO (MainThread) [homeassistant.setup] Setting up tts
2018-11-25 22:42:55 INFO (MainThread) [homeassistant.setup] Setting up switch
2018-11-25 22:42:55 INFO (MainThread) [homeassistant.loader] Loaded config.entity_registry from homeassistant.components.config.entity_registry
2018-11-25 22:42:55 INFO (MainThread) [homeassistant.loader] Loaded config.auth from homeassistant.components.config.auth
2018-11-25 22:42:55 INFO (MainThread) [homeassistant.loader] Loaded config.group from homeassistant.components.config.group
2018-11-25 22:42:55 INFO (MainThread) [homeassistant.loader] Loaded config.hassbian from homeassistant.components.config.hassbian
2018-11-25 22:42:55 INFO (MainThread) [homeassistant.loader] Loaded config.script from homeassistant.components.config.script
2018-11-25 22:42:55 INFO (MainThread) [homeassistant.loader] Loaded config.core from homeassistant.components.config.core
2018-11-25 22:42:55 INFO (MainThread) [homeassistant.loader] Loaded config.config_entries from homeassistant.components.config.config_entries
2018-11-25 22:42:55 INFO (MainThread) [homeassistant.loader] Loaded config.customize from homeassistant.components.config.customize
2018-11-25 22:42:55 INFO (MainThread) [homeassistant.loader] Loaded config.automation from homeassistant.components.config.automation
2018-11-25 22:42:55 INFO (MainThread) [homeassistant.loader] Loaded config.device_registry from homeassistant.components.config.device_registry
2018-11-25 22:42:55 INFO (MainThread) [homeassistant.loader] Loaded config.auth_provider_homeassistant from homeassistant.components.config.auth_provider_homeassistant
2018-11-25 22:42:55 INFO (MainThread) [homeassistant.setup] Setup of domain config took 0.1 seconds.
2018-11-25 22:42:55 INFO (SyncWorker_24) [homeassistant.util.package] Attempting install of pykonkeio>=2.1.7
2018-11-25 22:42:57 INFO (MainThread) [homeassistant.setup] Setup of domain sensor took 2.2 seconds.
2018-11-25 22:42:57 ERROR (SyncWorker_24) [homeassistant.util.package] Unable to install package pykonkeio>=2.1.7: Could not find a version that satisfies the requirement pykonkeio>=2.1.7 (from versions: 1.0.0, 1.0.1, 1.0.2, 1.0.3, 1.0.4, 1.0.5, 1.0.6)
No matching distribution found for pykonkeio>=2.1.7
2018-11-25 22:42:57 ERROR (MainThread) [homeassistant.requirements] Not initializing switch.konke because could not install requirement pykonkeio>=2.1.7
2018-11-25 22:42:57 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform switch.konke: Could not install all requirements.
 楼主| 发表于 2018-11-26 12:19:43 | 显示全部楼层
2018-11-25 22:42:55 WARNING (MainThread) [homeassistan ...
pip换过源没?如果不是官方源的话换先回去试试
发表于 2018-11-26 21:00:13 | 显示全部楼层
谢谢楼主,换回官方源pypi.python.org可以了
发表于 2018-11-26 21:45:59 | 显示全部楼层
2018-11-26 21:43:39 ERROR (Thread-15) [homeassistant.util.package] Unable to install package pykonkeio>=2.1.7: Failed building wheel for pycryptodome
python-jose-cryptodome 1.3.2 has requirement pycryptodome<3.4.0,>=3.3.1, but you'll have pycryptodome 3.7.1 which is incompatible.
Command "/usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-ptr8s0f5/pycryptodome/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-onu20zrv/install-record.txt --single-version-externally-managed --prefix  --compile --user --prefix=" failed with error code 1 in /tmp/pip-install-ptr8s0f5/pycryptodome/
2018-11-26 21:43:39 ERROR (MainThread) [homeassistant.requirements] Not initializing switch.konke because could not install requirement pykonkeio>=2.1.7
大神,求助
发表于 2018-11-27 10:54:36 | 显示全部楼层
出错求解,但是可以正常控制
 楼主| 发表于 2018-11-27 21:04:21 | 显示全部楼层
dsyulgz 发表于 2018-11-27 10:54
出错求解,但是可以正常控制
看这报错应该是配置文件写错了吧,检查一下/config/configuration.yaml第87行第1个字符,把tab改成空格
发表于 2018-11-27 21:11:40 | 显示全部楼层
zhouxineric 发表于 2018-11-26 21:45
2018-11-26 21:43:39 ERROR (Thread-15) [homeassistant.util.package] Unable to install package pykonke ...
我也是 要降级 等楼主修复
发表于 2018-11-28 09:52:44 | 显示全部楼层
google了半天 总算解决了 进容器安装
sudo docker exec -i -t homeassistant /bin/bash
pip3 install pykonkeio
希望对你有用
发表于 2018-11-28 14:10:13 | 显示全部楼层
如图,配置完成后,开关显示不可用,是我少了那一步操作么环境:
OS:Windows 2012 R2
PY:python3.7.1
HASS:0.82.1
我感觉我脑子要坏了
发表于 2018-11-28 22:15:41 | 显示全部楼层
pip3 install pyk ...
不折腾了,我还是用猫精吧
GMT+8, 2026-2-1 15:03 , Processed in 1.707337 second(s), 13 queries , MemCached On.
