楼主: neroxps
HASSIO 安装一键脚本
 火...   [复制链接]
发表于 2019-10-10 20:50:10 | 显示全部楼层
安装到这里 就出错了  看systemctl docker 启动是fail的
发表于 2019-10-10 20:51:23 | 显示全部楼层
● docker.service - Docker Application Container Engine
   Loaded: loaded (/lib/systemd/system/docker.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Thu 2019-10-10 20:50:26 CST; 9s ago
     Docs: https://docs.docker.com
  Process: 20414 ExecStart=/usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock (code=exited, status=1
Main PID: 20414 (code=exited, status=1/FAILURE)
      CPU: 618ms
Oct 10 20:50:24 cubietruck systemd[1]: docker.service: Failed with result 'exit-code'.
Oct 10 20:50:26 cubietruck systemd[1]: docker.service: Service hold-off time over, scheduling restart.
Oct 10 20:50:26 cubietruck systemd[1]: Stopped Docker Application Container Engine.
Oct 10 20:50:26 cubietruck systemd[1]: docker.service: Start request repeated too quickly.
Oct 10 20:50:26 cubietruck systemd[1]: Failed to start Docker Application Container Engine.
Oct 10 20:50:27 cubietruck systemd[1]: docker.service: Unit entered failed state.
Oct 10 20:50:27 cubietruck systemd[1]: docker.service: Failed with result 'exit-code'.
发表于 2019-10-10 20:52:43 | 显示全部楼层
再运行脚本 也直接跳过docker
zwzm
发表于 2019-10-12 10:57:08 | 显示全部楼层
请确认以上信息,继续请按任意键,如需修改请输入 Ctrl+C 结束任务重新执行脚本。
[info]: 切换系统网络源.....
备份系统源文件为 /etc/apt/sources.list.bak
获取:1 https://mirror.azure.cn/docker-ce/linux/raspbian buster InRelease [29.7 kB]
命中:2 http://archive.raspberrypi.org/debian buster InRelease
错误:3 http://mirrors.ustc.edu.cn/raspbian/raspbian buster InRelease
  连接失败 [IP: 202.141.176.110 80]
获取:4 http://mirrors.ustc.edu.cn/archive.raspberrypi.org/debian buster InRelease [25.1 kB]
获取:5 http://mirrors.ustc.edu.cn/archive.raspberrypi.org/debian buster/main armhf Packages [259 kB]
错误:5 http://mirrors.ustc.edu.cn/archive.raspberrypi.org/debian buster/main armhf Packages
  文件尺寸不符(258701 != 258711)。您使用的镜像正在同步中? [IP: 183.203.52.201 80]
  Hashes of expected file:
   - Filesize:258711 [weak]
   - SHA256:fde5e164ddc432adf8507b3f4a16b100ab521ff32447f6438a687242752ea8c9
   - SHA1:d45781c7c0f0de52e8ab8e382222de468de13c85 [weak]
   - MD5Sum:8b2cbbc3785311b43b504fa340ca128b [weak]
  Release file created at: Fri, 11 Oct 2019 14:24:14 +0000
已下载 54.8 kB,耗时 1分 24秒 (656 B/s)
正在读取软件包列表... 完成
W: 无法下载 http://mirrors.ustc.edu.cn/raspb ... ts/buster/InRelease  连接失败 [IP: 202.141.176.110 80]
E: 无法下载 http://183.203.52.201/cache/mirr ... 396198d20d7eee61cc7  文件尺寸不符(258701 != 258711)。您使用的镜像正在同步中? [IP: 183.203.52.201 80]
W: 部分索引文件下载失败。如果忽略它们,那将转而使用旧的索引文件。
################# 发到论坛时,请把上方日志也一并粘贴发送 ################
Distributor ID:        Raspbian
Description:        Raspbian GNU/Linux 10 (buster)
Release:        10
Codename:        buster
Linux version 4.19.75-v7+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1270 SMP Tue Sep 24 18:45:11 BST 2019
Linux raspberrypi 4.19.75-v7+ #1270 SMP Tue Sep 24 18:45:11 BST 2019 armv7l GNU/Linux
[ERROR]: 系统源切换错误,请检查网络连接是否正常,脚本退出
发表于 2019-10-13 22:37:06 | 显示全部楼层
安装了这个脚本的docker,怎么安装Portainer?我装了却打不开,进不到管理页面~
发表于 2019-10-18 23:24:10 | 显示全部楼层
这个好,超级方便阿
发表于 2019-10-19 14:40:57 | 显示全部楼层
Err:5 https://mirrors.ustc.edu.cn/docker-ce/linux/raspbian buster/stable armhf Packages
  File has unexpected size (3514 != 1749). Mirror sync in progress? [IP: 202.38.95.110 443]
   - Filesize:1749 [weak]
   - SHA512:75357e78cb7bcd155223392d1002e87d75f7f1ebbe0139729d1b55eed97bd21572ba51823d70b771           8b2bf69d8473a30ddf53a638345abb909c0a8e6b66d8d940
   - SHA256:04855ce8dbe979471385811ea59483d31a516ffe8a64e59c0d1be031bd11837c
   - SHA1:f26116b78bd63be458b64edcf876f12b4e803f63 [weak]
   - MD5Sum:8dd1f344cb4d8fd2600f66dac4fe00ea [weak]
  Release file created at: Sat, 17 Aug 2019 05:04:51 +0000
Fetched 29.7 kB in 2s (11.9 kB/s)
Reading package lists... Done
E: Failed to fetch https://mirrors.ustc.edu.cn/dock ... ists/buster/stable/           binary-armhf/Packages.bz2  File has unexpected size (3514 != 1749). Mirror sync in progress?            [IP: 202.38.95.110 443]
    - SHA512:75357e78cb7bcd155223392d1002e87d75f7f1ebbe0139729d1b55eed97bd21572ba51823d70b77           18b2bf69d8473a30ddf53a638345abb909c0a8e6b66d8d940
E: Some index files failed to download. They have been ignored, or old ones used instead.
Release:        10
Codename:       buster
Linux version 4.19.75-v7l+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22           .0-88-g8460611)) #1270 SMP Tue Sep 24 18:51:41 BST 2019
Linux raspberrypi 4.19.75-v7l+ #1270 SMP Tue Sep 24 18:51:41 BST 2019 armv7l GNU/Linux
发表于 2019-10-20 21:18:45 | 显示全部楼层
[info]: 安装 Docker 引擎.....
# Executing docker install script, commit:
+ sh -c apt-get update -qq >/dev/null
E: 仓库 “https://mirror.azure.cn/docker-ce/linux/ubuntu eoan Release” 没有 Release 文件。
Distributor ID:        Ubuntu
Description:        Ubuntu 19.10
Release:        19.10
Codename:        eoan
Linux version 5.3.0-18-generic (buildd@lcy01-amd64-027) (gcc version 9.2.1 20190909 (Ubuntu 9.2.1-8ubuntu1)) #19-Ubuntu SMP Tue Oct 8 20:14:06 UTC 2019
Linux ubuntu 5.3.0-18-generic #19-Ubuntu SMP Tue Oct 8 20:14:06 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
\033[0;31m[ERROR]: Docker 安装失败,请检查上方安装错误信息。 你也可以选择通过搜索引擎,搜索你系统安装docker的方法,安装后重新执行脚本。\033[0m
大神,这是什么问题呢?
 楼主| 发表于 2019-10-21 12:55:43 | 显示全部楼层
liuxinsc 发表于 2019-10-20 21:18
: 安装 Docker 引擎.....
+ sh -c apt-get update -qq >/dev ...
脚本不支持 19.10
自己手动安装好 docker 再运行脚本,跳过 docker 安装
ELS6
发表于 2019-10-21 22:14:08 | 显示全部楼层
[info]: Docker 安装成功。
添加用户 l 到 Docker 用户组
[info]: 切换 Docker 源为国内源....
[info]: 切换国内源完成
[info]: 安装 hassio......
从 hub.docker.com 下载 homeassistant/qemux86-64-homeassistant:0.100.2......
Error response from daemon: Get https://registry-1.docker.io/v2/ ... /manifests/0.100.2: Get https://auth.docker.io/token?sco ... registry.docker.io: net/http: TLS handshake timeout
[ERROR]: 从 docker 下载 homeassistant/qemux86-64-homeassistant:0.100.2 失败,请检查上方失败信息。
GMT+8, 2025-12-17 06:36 , Processed in 0.397533 second(s), 18 queries , MemCached On.
