楼主: neroxps
HASSIO 安装一键脚本
 火...   [复制链接]
发表于 2019-9-23 13:13:26 | 显示全部楼层
收藏一下~回家試試~
发表于 2019-9-24 23:31:27 | 显示全部楼层
请教大神如下错误如何处理?
[info]: 发现系统已安装 docker,跳过 docker 安装
[info]: 切换 Docker 源为国内源....
Running in chroot, ignoring request: daemon-reload
Running in chroot, ignoring request: restart
[info]: 切换国内源完成
[info]: 安装 hassio......
从 hub.docker.com 下载 homeassistant/qemuarm-homeassistant:0.99.2......
Cannot connect to the Docker daemon at unix:///var/run/docker.sock. Is the docker daemon running?
[ERROR]: 从 docker 下载 homeassistant/qemuarm-homeassistant:0.99.2 失败,请检查上方失败信息。
 楼主| 发表于 2019-9-25 10:54:53 | 显示全部楼层
longerli 发表于 2019-9-24 23:31
请教大神如下错误如何处理?
docker 并未启动,你自己装过docker 你自己解决
发表于 2019-9-25 18:50:34 | 显示全部楼层
感谢大神的指导!
我又重新安装了一次 还是同样问题
[info]: 安装 Docker 引擎.....
# Executing docker install script, commit:
+ sh -c apt-get update -qq >/dev/null
+ sh -c DEBIAN_FRONTEND=noninteractive apt-get install -y -qq apt-transport-https ca-certificates curl gnupg >/dev/null
+ sh -c curl -fsSL "https://mirror.azure.cn/docker-ce/linux/ubuntu/gpg" | apt-key add -qq - >/dev/null
Warning: apt-key output should not be parsed (stdout is not a terminal)
+ sh -c echo "deb [arch=armhf] https://mirror.azure.cn/docker-ce/linux/ubuntu bionic stable" > /etc/apt/sources.list.d/docker.list
+ [ -n  ]
+ sh -c apt-get install -y -qq --no-install-recommends docker-ce >/dev/null
If you would like to use Docker as a non-root user, you should now consider
adding your user to the "docker" group with something like:
  sudo usermod -aG docker your-user
Remember that you will have to log out and back in for this to take effect!
WARNING: Adding a user to the "docker" group will grant the ability to run
         containers which can be used to obtain root privileges on the
         docker host.
         Refer to https://docs.docker.com/engine/s ... emon-attack-surface
         for more information.
[info]: Docker 安装成功。
添加用户 android 到 Docker 用户组
[info]: 切换国内源完成
发表于 2019-9-25 21:46:47 | 显示全部楼层
前车之鉴,千万不要直接用wifi下载,在用wifi折腾3-4个小时以后,插上网线30分钟搞定了。
 楼主| 发表于 2019-9-26 10:52:37 | 显示全部楼层
longerli 发表于 2019-9-25 18:50
感谢大神的指导!
我又重新安装了一次 还是同样问题
: 安装 Docker 引擎.....
什么系统
发表于 2019-9-26 11:01:36 | 显示全部楼层
Ubuntu 18.04 LTS (GNU/Linux 3.4.113-lineageos-ga160ed5 armv7l)
 楼主| 发表于 2019-9-26 12:06:06 | 显示全部楼层
systemctl start docker
journalctl -u docker 看看有没有什么报错
发表于 2019-9-26 15:48:40 | 显示全部楼层
膜拜大神!感谢分享学习资料
发表于 2019-9-26 18:56:11 | 显示全部楼层
感谢指导!
# systemctl start docker
Running in chroot, ignoring request: start
# journalctl -u docker
No journal files were found.
-- No entries --
GMT+8, 2025-12-17 06:44 , Processed in 0.609295 second(s), 17 queries , MemCached On.
