楼主: neroxps
HASSIO 安装一键脚本
 火...   [复制链接]
发表于 2019-8-23 09:34:22 | 显示全部楼层
Distributor ID: Raspbian
Description:    Raspbian GNU/Linux 10 (buster)
Release:        10
Codename:       buster
Linux version 4.19.57-v7+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1244 SMP Thu Jul 4 18:45:25 BST 2019
Linux raspberrypi 4.19.57-v7+ #1244 SMP Thu Jul 4 18:45:25 BST 2019 armv7l GNU/Linux
安装 hassio 失败,请将上方安装信息发送到论坛询问。脚本退出...
 楼主| 发表于 2019-8-23 09:35:26 | 显示全部楼层
Desc ...
System version  上面的东西也要发出来
发表于 2019-8-24 08:33:03 | 显示全部楼层
大佬昨天有事情耽误了,今天树莓派重新装系统刷机 安装集成显示错误如下,请指点!
[info]: Docker 安装成功。
添加用户 systemd-coredump 到 Docker 用户组
[info]: 切换 Docker 源为国内源....
[info]: 切换国内源完成
[info]: 安装 hassio......
从 hub.docker.com 下载 homeassistant/raspberrypi3-homeassistant:0.97.2......
0.97.2: Pulling from homeassistant/raspberrypi3-homeassistant
fd0f3c17efd4: Pull complete
456c0c9b2393: Pull complete
103b3a34fc72: Pull complete
116e100cc2bd: Pull complete
9f4a973c6a60: Pull complete
4bf4ff396cbd: Pull complete
925b9466a525: Pull complete
0a8e278e218e: Pull complete
2fa8f745d59e: Pull complete
cf31115a3144: Pull complete
334c55be9713: Pull complete
9034d561a996: Pull complete
932b933e694a: Pull complete
e34aa3b438b4: Pull complete
75012029f9e8: Pull complete
bccb7e54aa92: Pull complete
b0415c1f3969: Pull complete
cee796f047b1: Pull complete
d9be38489861: Pull complete
97da72d5ef62: Pull complete
bc0eccdc2d05: Pull complete
6ae962a71c7c: Pull complete
Digest: sha256:770809f2754b1b5d192389753d839db9b4449fde56e37d630debd78b7b2a28a7
Status: Downloaded newer image for homeassistant/raspberrypi3-homeassistant:0.97.2
docker.io/homeassistant/raspberrypi3-homeassistant:0.97.2
开始 hassio 安装流程。(如出现 [Warning] 请忽略,无须理会)
[Error] No NetworkManager support on host.
Unit hassio-supervisor.service could not be found.
Release:        10
Codename:       buster
root@raspberrypi:/home/pi#
 楼主| 发表于 2019-8-24 09:00:04 | 显示全部楼层
: Docker 安装成功 ...
hassio 新增了一个依赖导致安装不通过,已修复。
发表于 2019-8-24 09:06:38 | 显示全部楼层
好的,我重新跑一下看看哈,谢谢大佬解答。
发表于 2019-8-25 16:39:23 | 显示全部楼层
Distributor ID:        Debian
Description:        Debian GNU/Linux 10 (buster)
Release:        10
Codename:        buster
Linux version 5.2.1-aml-g12 (root@vbox) (gcc version 7.4.1 20181213 [linaro-7.4-2019.02 revision 56ec6f6b99cc167ff0c2f8e1a2eed33b1edc85d4] (Linaro GCC 7.4-2019.02)) #5.94 SMP PREEMPT Wed Aug 21 13:48:33 MSK 2019
Linux N1-594 5.2.1-aml-g12 #5.94 SMP PREEMPT Wed Aug 21 13:48:33 MSK 2019 aarch64 GNU/Linux
n1最新版5.94 armbian安装失败
发表于 2019-8-25 16:43:03 | 显示全部楼层
大佬好,请帮我看一看这是怎么回事?
Job for docker.service failed because the control process exited with error code        . See "systemctl status docker.service" and "journalctl -xe" for details.
invoke-rc.d: initscript docker, action "start" failed.
dpkg: error processing package docker-ce (--configure):
subprocess installed post-installation script returned error exit status 1
Errors were encountered while processing:
docker-ce
E: Sub-process /usr/bin/dpkg returned an error code (1)
Distributor ID: Ubuntu
Description:    Ubuntu 16.04 LTS
Release:        16.04
Codename:       xenial
Linux version 2.6.32-042stab127.2 ([email protected]) (gcc version 4        .4.6 20120305 (Red Hat 4.4.6-4) (GCC) ) #1 SMP Thu Jan 4 16:41:44 MSK 2018
Linux AccomplishedWilling-VM 2.6.32-042stab127.2 #1 SMP Thu Jan 4 16:41:44 MSK 2        018 x86_64 x86_64 x86_64 GNU/Linux
\033[0;31m[ERROR]: 安装curl失败,请将检查上方安装错误信息。\033[0m
root@AccomplishedWilling-VM:/# systemctl status docker.service
● docker.service - Docker Application Container Engine
   Loaded: loaded (/lib/systemd/system/docker.service; enabled; vendor preset: enabled)
   Active: failed (Result: start-limit-hit) since Sun 2019-08-25 16:26:31 CST; 9min ago
     Docs: https://docs.docker.com
  Process: 16783 ExecStart=/usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock (code=exited, status=1/FAILURE)
Main PID: 16783 (code=exited, status=1/FAILURE)
Aug 25 16:26:29 AccomplishedWilling-VM systemd[1]: Failed to start Docker Application Container Engine.
Aug 25 16:26:29 AccomplishedWilling-VM systemd[1]: docker.service: Unit entered failed state.
Aug 25 16:26:29 AccomplishedWilling-VM systemd[1]: docker.service: Failed with result 'exit-code'.
Aug 25 16:26:31 AccomplishedWilling-VM systemd[1]: docker.service: Service hold-off time over, scheduling restart.
Aug 25 16:26:31 AccomplishedWilling-VM systemd[1]: Stopped Docker Application Container Engine.
Aug 25 16:26:31 AccomplishedWilling-VM systemd[1]: docker.service: Start request repeated too quickly.
Aug 25 16:26:31 AccomplishedWilling-VM systemd[1]: Failed to start Docker Application Container Engine.
Aug 25 16:26:31 AccomplishedWilling-VM systemd[1]: docker.service: Unit entered failed state.
Aug 25 16:26:31 AccomplishedWilling-VM systemd[1]: docker.service: Failed with result 'start-limit-hit'.
发表于 2019-8-26 02:32:57 | 显示全部楼层
我是2b+,已经顺利装好ha启动了。
但是反馈一下,用官网下载buster,1g多的版本,会卡在百分之97不动,卡了1个小时都没反应,然后下了lite的版本来刷,还是卡在百分之98不动,后来是断电重启后再执行一次脚本,安装又很顺利。是我遇到bug了?
发表于 2019-8-26 21:45:38 | 显示全部楼层
19-08-26 13:38:44 ERROR (MainThread) [hassio.homeassistant] Home Assistant has crashed!
19-08-26 13:38:44 ERROR (MainThread) [hassio.tasks] Watchdog Home Assistant reanimation fails!
########################### homeassistant log ###########################
[FATAL tini (6)] exec /bin/entry.sh failed: Exec format error
[FATAL tini (7)] exec /bin/entry.sh failed: Exec format error
homeassistant 启动超时,请检查上方日志....
启动不 起来 请教大神!!!!
 楼主| 发表于 2019-8-27 07:58:59 | 显示全部楼层
19-08-26 13: ...
选错容器。
GMT+8, 2025-12-18 15:05 , Processed in 1.454588 second(s), 17 queries , MemCached On.
