楼主: neroxps
HASSIO 安装一键脚本
 火...   [复制链接]
 楼主| 发表于 2019-9-5 09:33:10 | 显示全部楼层
lqj003 发表于 2019-9-5 08:10
我也遇到了这种情况,直接选数字都是输入错误,只有默认回车可以继续... ...
已修复
 楼主| 发表于 2019-9-5 09:36:55 | 显示全部楼层
wktm 发表于 2019-9-4 22:02
(4).请选择你设备类型(默认:qemux86)
    [1]: intel-nuc: 英特尔的nuc小主机
    [2]: odroid-c2: 韩国 ...
已修复
发表于 2019-9-5 23:12:38 | 显示全部楼层
########################### homeassistant log ###########################
2019-09-05 08:32:06 INFO (SyncWorker_4) [homeassistant.loader] Loaded script from homeassistant.components.script
2019-09-05 08:32:06 INFO (SyncWorker_0) [homeassistant.loader] Loaded group from homeassistant.components.group
2019-09-05 08:32:06 INFO (SyncWorker_1) [homeassistant.loader] Loaded automation from homeassistant.components.automation
2019-09-05 08:32:06 INFO (SyncWorker_2) [homeassistant.loader] Loaded tts from homeassistant.components.tts
2019-09-05 08:32:06 INFO (SyncWorker_3) [homeassistant.loader] Loaded hassio from homeassistant.components.hassio
2019-09-05 08:32:06 INFO (SyncWorker_7) [homeassistant.loader] Loaded default_config from homeassistant.components.default_config
2019-09-05 08:32:06 INFO (SyncWorker_6) [homeassistant.loader] Loaded persistent_notification from homeassistant.components.persistent_notification
2019-09-05 08:32:06 INFO (SyncWorker_8) [homeassistant.loader] Loaded homeassistant from homeassistant.components.homeassistant
2019-09-05 08:32:06 INFO (SyncWorker_11) [homeassistant.loader] Loaded webhook from homeassistant.components.webhook
2019-09-05 08:32:06 INFO (SyncWorker_4) [homeassistant.loader] Loaded http from homeassistant.components.http
2019-09-05 08:32:06 INFO (MainThread) [homeassistant.setup] Setting up persistent_notification
2019-09-05 08:32:06 INFO (MainThread) [homeassistant.setup] Setup of domain persistent_notification took 0.0 seconds.
2019-09-05 08:32:06 INFO (MainThread) [homeassistant.setup] Setting up homeassistant
2019-09-05 08:32:06 INFO (MainThread) [homeassistant.setup] Setup of domain homeassistant took 0.0 seconds.
2019-09-05 08:32:06 INFO (SyncWorker_9) [homeassistant.loader] Loaded cloud from homeassistant.components.cloud
2019-09-05 08:32:06 INFO (SyncWorker_10) [homeassistant.loader] Loaded panel_custom from homeassistant.components.panel_custom
2019-09-05 08:32:06 INFO (SyncWorker_5) [homeassistant.loader] Loaded frontend from homeassistant.components.frontend
2019-09-05 08:32:06 INFO (SyncWorker_15) [homeassistant.loader] Loaded api from homeassistant.components.api
2019-09-05 08:32:06 INFO (SyncWorker_1) [homeassistant.loader] Loaded config from homeassistant.components.config
2019-09-05 08:32:06 INFO (SyncWorker_3) [homeassistant.loader] Loaded auth from homeassistant.components.auth
2019-09-05 08:32:06 INFO (SyncWorker_6) [homeassistant.loader] Loaded lovelace from homeassistant.components.lovelace
2019-09-05 08:32:06 INFO (SyncWorker_11) [homeassistant.loader] Loaded onboarding from homeassistant.components.onboarding
2019-09-05 08:32:06 INFO (SyncWorker_16) [homeassistant.loader] Loaded system_log from homeassistant.components.system_log
2019-09-05 08:32:06 INFO (SyncWorker_17) [homeassistant.loader] Loaded websocket_api from homeassistant.components.websocket_api
2019-09-05 08:32:06 INFO (SyncWorker_9) [homeassistant.loader] Loaded history from homeassistant.components.history
2019-09-05 08:32:06 INFO (SyncWorker_14) [homeassistant.loader] Loaded recorder from homeassistant.components.recorder
2019-09-05 08:32:06 INFO (SyncWorker_19) [homeassistant.loader] Loaded logbook from homeassistant.components.logbook
2019-09-05 08:32:06 INFO (SyncWorker_5) [homeassistant.loader] Loaded map from homeassistant.components.map
2019-09-05 08:32:06 INFO (SyncWorker_15) [homeassistant.loader] Loaded mobile_app from homeassistant.components.mobile_app
2019-09-05 08:32:06 INFO (SyncWorker_1) [homeassistant.loader] Loaded person from homeassistant.components.person
2019-09-05 08:32:06 INFO (SyncWorker_8) [homeassistant.loader] Loaded ssdp from homeassistant.components.ssdp
2019-09-05 08:32:06 INFO (SyncWorker_4) [homeassistant.loader] Loaded sun from homeassistant.components.sun
2019-09-05 08:32:06 INFO (SyncWorker_13) [homeassistant.loader] Loaded system_health from homeassistant.components.system_health
2019-09-05 08:32:06 INFO (SyncWorker_0) [homeassistant.loader] Loaded updater from homeassistant.components.updater
2019-09-05 08:32:06 INFO (SyncWorker_18) [homeassistant.loader] Loaded zeroconf from homeassistant.components.zeroconf
2019-09-05 08:32:06 INFO (MainThread) [homeassistant.bootstrap] Setting up {'system_log'}
2019-09-05 08:32:06 INFO (MainThread) [homeassistant.setup] Setting up http
2019-09-05 08:32:06 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.0 seconds.
2019-09-05 08:32:06 INFO (MainThread) [homeassistant.setup] Setting up system_log
2019-09-05 08:32:06 INFO (MainThread) [homeassistant.setup] Setup of domain system_log took 0.0 seconds.
2019-09-05 08:32:06 INFO (MainThread) [homeassistant.setup] Setting up recorder
2019-09-05 08:32:08 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 2.1 seconds.
2019-09-05 08:32:09 INFO (MainThread) [homeassistant.setup] Setting up updater
2019-09-05 08:32:09 INFO (MainThread) [homeassistant.setup] Setup of domain updater took 0.0 seconds.
2019-09-05 08:32:09 INFO (MainThread) [homeassistant.setup] Setting up group
2019-09-05 08:32:09 INFO (MainThread) [homeassistant.setup] Setup of domain group took 0.0 seconds.
2019-09-05 08:32:09 INFO (MainThread) [homeassistant.setup] Setting up sun
2019-09-05 08:32:09 INFO (MainThread) [homeassistant.setup] Setup of domain sun took 0.4 seconds.
2019-09-05 08:32:09 INFO (MainThread) [homeassistant.setup] Setting up lovelace
2019-09-05 08:32:09 INFO (MainThread) [homeassistant.setup] Setup of domain lovelace took 0.0 seconds.
2019-09-05 08:32:10 INFO (MainThread) [homeassistant.setup] Setting up ssdp
2019-09-05 08:32:10 INFO (MainThread) [homeassistant.setup] Setup of domain ssdp took 0.0 seconds.
2019-09-05 08:32:11 INFO (MainThread) [homeassistant.setup] Setting up person
2019-09-05 08:32:11 INFO (MainThread) [homeassistant.setup] Setting up system_health
2019-09-05 08:32:11 INFO (MainThread) [homeassistant.setup] Setup of domain system_health took 0.0 seconds.
2019-09-05 08:32:11 INFO (SyncWorker_3) [homeassistant.loader] Loaded binary_sensor from homeassistant.components.binary_sensor
2019-09-05 08:32:11 INFO (MainThread) [homeassistant.setup] Setting up auth
2019-09-05 08:32:11 INFO (MainThread) [homeassistant.setup] Setup of domain auth took 0.0 seconds.
2019-09-05 08:32:11 INFO (MainThread) [homeassistant.setup] Setting up websocket_api
2019-09-05 08:32:11 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.0 seconds.
2019-09-05 08:32:11 INFO (MainThread) [homeassistant.setup] Setting up history
2019-09-05 08:32:11 INFO (MainThread) [homeassistant.setup] Setup of domain history took 0.0 seconds.
2019-09-05 08:32:11 INFO (MainThread) [homeassistant.setup] Setting up webhook
2019-09-05 08:32:11 INFO (MainThread) [homeassistant.setup] Setup of domain webhook took 0.0 seconds.
2019-09-05 08:32:11 INFO (SyncWorker_6) [homeassistant.loader] Loaded google_translate from homeassistant.components.google_translate
2019-09-05 08:32:12 INFO (MainThread) [homeassistant.setup] Setting up api
2019-09-05 08:32:12 INFO (MainThread) [homeassistant.setup] Setting up config
2019-09-05 08:32:12 INFO (MainThread) [homeassistant.setup] Setting up script
2019-09-05 08:32:12 INFO (MainThread) [homeassistant.setup] Setup of domain script took 0.0 seconds.
2019-09-05 08:32:13 INFO (MainThread) [homeassistant.setup] Setting up binary_sensor
2019-09-05 08:32:13 INFO (MainThread) [homeassistant.setup] Setup of domain binary_sensor took 0.0 seconds.
2019-09-05 08:32:13 INFO (MainThread) [homeassistant.setup] Setting up tts
2019-09-05 08:32:13 INFO (MainThread) [homeassistant.setup] Setup of domain api took 0.3 seconds.
2019-09-05 08:32:13 INFO (SyncWorker_16) [homeassistant.components.tts] Create cache dir /config/tts.
2019-09-05 08:32:13 INFO (MainThread) [homeassistant.setup] Setup of domain person took 2.2 seconds.
2019-09-05 08:32:13 INFO (MainThread) [homeassistant.setup] Setting up onboarding
2019-09-05 08:32:13 INFO (MainThread) [homeassistant.setup] Setting up cloud
2019-09-05 08:32:15 INFO (MainThread) [homeassistant.setup] Setting up automation
2019-09-05 08:32:15 INFO (MainThread) [homeassistant.setup] Setup of domain automation took 0.0 seconds.
2019-09-05 08:32:15 INFO (MainThread) [homeassistant.setup] Setting up mobile_app
2019-09-05 08:32:15 INFO (MainThread) [homeassistant.setup] Setup of domain config took 2.8 seconds.
2019-09-05 08:32:15 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.updater
2019-09-05 08:32:15 INFO (MainThread) [homeassistant.setup] Setting up zeroconf
2019-09-05 08:32:15 INFO (MainThread) [homeassistant.setup] Setup of domain mobile_app took 0.2 seconds.
2019-09-05 08:32:16 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new binary_sensor.updater entity: binary_sensor.updater
2019-09-05 08:32:16 INFO (MainThread) [homeassistant.setup] Setup of domain tts took 2.9 seconds.
2019-09-05 08:32:16 INFO (SyncWorker_5) [homeassistant.loader] Loaded notify from homeassistant.components.notify
2019-09-05 08:32:16 INFO (MainThread) [homeassistant.setup] Setup of domain onboarding took 2.9 seconds.
2019-09-05 08:32:16 INFO (MainThread) [homeassistant.setup] Setting up notify
2019-09-05 08:32:16 INFO (MainThread) [homeassistant.setup] Setup of domain notify took 0.0 seconds.
2019-09-05 08:32:16 INFO (MainThread) [homeassistant.setup] Setting up frontend
2019-09-05 08:32:16 INFO (MainThread) [homeassistant.setup] Setup of domain frontend took 0.0 seconds.
2019-09-05 08:32:16 INFO (MainThread) [homeassistant.components.notify] Setting up notify.mobile_app
2019-09-05 08:32:16 INFO (MainThread) [homeassistant.setup] Setup of domain cloud took 2.5 seconds.
2019-09-05 08:32:16 INFO (MainThread) [homeassistant.setup] Setting up panel_custom
2019-09-05 08:32:16 INFO (MainThread) [homeassistant.setup] Setup of domain panel_custom took 0.0 seconds.
2019-09-05 08:32:16 INFO (MainThread) [homeassistant.setup] Setting up map
2019-09-05 08:32:16 INFO (MainThread) [homeassistant.setup] Setup of domain map took 0.0 seconds.
2019-09-05 08:32:16 INFO (MainThread) [homeassistant.setup] Setting up logbook
2019-09-05 08:32:16 INFO (MainThread) [homeassistant.setup] Setup of domain logbook took 0.0 seconds.
2019-09-05 08:32:16 INFO (MainThread) [homeassistant.setup] Setting up hassio
2019-09-05 08:32:16 INFO (MainThread) [homeassistant.setup] Setup of domain zeroconf took 0.9 seconds.
2019-09-05 08:32:18 INFO (MainThread) [homeassistant.setup] Setting up default_config
2019-09-05 08:32:18 INFO (SyncWorker_11) [homeassistant.loader] Loaded stream from homeassistant.components.stream
2019-09-05 08:32:18 INFO (MainThread) [homeassistant.setup] Setting up stream
2019-09-05 08:32:18 INFO (MainThread) [homeassistant.setup] Setup of domain stream took 0.0 seconds.
2019-09-05 08:32:18 INFO (MainThread) [homeassistant.setup] Setup of domain default_config took 0.3 seconds.
2019-09-05 08:32:18 INFO (MainThread) [homeassistant.setup] Setup of domain hassio took 2.2 seconds.
2019-09-05 08:32:20 INFO (MainThread) [homeassistant.bootstrap] Home Assistant initialized in 15.08s
2019-09-05 08:32:20 INFO (MainThread) [homeassistant.core] Starting Home Assistant
2019-09-05 08:32:20 INFO (MainThread) [homeassistant.core] Timer:starting
2019-09-05 09:32:12 INFO (MainThread) [homeassistant.components.updater] Submitted analytics to Home Assistant servers. Information submitted includes {}
2019-09-05 09:32:12 INFO (MainThread) [homeassistant.components.updater] You are on the latest version (0.98.3) of Home Assistant
2019-09-05 13:32:56 INFO (MainThread) [homeassistant.components.stream] Stopped stream workers.
Unable to find configuration. Creating default one in /config
Config directory: /config
2019-09-05 13:34:14 ERROR (SyncWorker_0) [homeassistant.util.yaml.loader] mapping values are not allowed here
  in "/config/configuration.yaml", line 3, column 15
2019-09-05 13:34:14 ERROR (MainThread) [homeassistant.bootstrap] Error loading /config/configuration.yaml: mapping values are not allowed here
2019-09-05 13:34:14 INFO (MainThread) [homeassistant.core] Starting Home Assistant
2019-09-05 13:34:14 INFO (MainThread) [homeassistant.core] Timer:starting
2019-09-05 21:59:41 ERROR (SyncWorker_0) [homeassistant.util.yaml.loader] mapping values are not allowed here
2019-09-05 21:59:41 ERROR (MainThread) [homeassistant.bootstrap] Error loading /config/configuration.yaml: mapping values are not allowed here
2019-09-05 21:59:41 INFO (MainThread) [homeassistant.core] Starting Home Assistant
2019-09-05 21:59:41 INFO (MainThread) [homeassistant.core] Timer:starting
请问这个是什么问题
 楼主| 发表于 2019-9-6 17:46:18 | 显示全部楼层
2019-09-05 08:32:06 INFO  ...
wktm 手机认证
发表于 2019-9-9 00:43:57 | 显示全部楼层
今天用树莓派3B+ 一键安装了一天,三个源 阿里 七牛 163 没有一个能安装成功的,很是奇怪
7e9e45add54f: Downloading  1.805MB/29.1MB
112a39fd22ee: Download complete
e952bdb273c3: Downloading  3.527MB/3.527MB
7e9e45add54f: Downloading  3.005MB/29.1MB
a25396ea7a57: Downloading  524.3kB/51MB
886f1deb2927: Download complete
fc6cfdc6cffe: Downloading  507.1kB/4.056MB
a25396ea7a57: Downloading  1.047MB/51MB
664c284b297c: Waiting
fc6cfdc6cffe: Downloading  2.436MB/2.436MB
b3831bfbcca2: Waiting
e4e079d867cc: Pulling fs layer
d2b68d70edad: Pulling fs layer
301d3c5317dc: Pulling fs layer
e4e079d867cc: Waiting
d2b68d70edad: Waiting
301d3c5317dc: Waiting
f4055b39f340: Waiting
read tcp 192.168.1.103:44906->104.18.125.25:443: read: connection reset by peer
[ERROR]: 从 docker 下载 homeassistant/raspberrypi3-homeassistant:0.98.4 失败,请检查上方失败信息。
root@raspberrypi:~#
root@raspberrypi:~#
root@raspberrypi:~#
root@raspberrypi:~#
 楼主| 发表于 2019-9-9 09:58:15 | 显示全部楼层
7e9e45add54f: D ...
那么你就应该排查下你自己网络问题
wktm 手机认证
发表于 2019-9-9 10:32:42 | 显示全部楼层
neroxps 发表于 2019-9-9 09:58
那么你就应该排查下你自己网络问题
谢谢@neroxps  的确是我的网络问题,已经解决,用163的十杯咖啡时间搞定
发表于 2019-9-9 16:15:59 | 显示全部楼层
我碰到的问题可能比较基础
我用exsi 安装sever版的ubuntu18.04
运行一键安装脚本显示的提示都是◇菱形乱码,百度了一下中文支持,安装了语言包,还是不行。
瞎猜着运行了一下,目前还在下载。
最后一个输入的字符串是什么?
 楼主| 发表于 2019-9-10 08:12:40 | 显示全部楼层
reedlxm 发表于 2019-9-9 16:15
我碰到的问题可能比较基础
运行一键安装脚本显示的提示都是◇菱形乱码 ...
装的时候选中文就好了。或装GUI版本把
发表于 2019-9-10 09:56:22 | 显示全部楼层
开始 hassio 安装流程。(如出现 [Warning] 请忽略,无须理会)
[Warning] No AppArmor support on host.
[Info] Install supervisor Docker container
[Info] Install supervisor startup scripts
Unit hassio-supervisor.service could not be found.
################# 发到论坛时,请把上方日志也一并粘贴发送 ################
Distributor ID:        Raspbian
Description:        Raspbian GNU/Linux 10 (buster)
Release:        10
Codename:        buster
Linux version 4.19.57-v7+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1244 SMP Thu Jul 4 18:45:25 BST 2019
Linux raspberrypi 4.19.57-v7+ #1244 SMP Thu Jul 4 18:45:25 BST 2019 armv7l GNU/Linux
安装 hassio 失败,请将上方安装信息发送到论坛询问。脚本退出...
请问下这个怎么处理呢?
GMT+8, 2025-12-17 06:44 , Processed in 0.074204 second(s), 12 queries , MemCached On.
