楼主: neroxps
HASSIO 安装一键脚本
 火...   [复制链接]
发表于 2019-8-16 16:49:24 | 显示全部楼层
一键安装支持0.97吗?
发表于 2019-8-16 17:05:42 | 显示全部楼层
jccg315 发表于 2019-8-16 16:49
一键安装支持0.97吗?
可以的,自动下载最新版本安装,我下午安装的就是 0.97.2 版的。
发表于 2019-8-18 20:45:08 | 显示全部楼层
########################### hassio log ###########################
19-08-18 12:35:59 INFO (MainThread) [__main__] Initialize Hass.io setup
19-08-18 12:36:00 INFO (SyncWorker_0) [hassio.docker.supervisor] Attach to Supervisor homeassistant/aarch64-hassio-supervisor with version 180
19-08-18 12:36:00 INFO (SyncWorker_0) [hassio.docker.supervisor] Connect Supervisor to Hass.io Network
19-08-18 12:36:01 INFO (SyncWorker_0) [hassio.docker.interface] Cleanup images: ['homeassistant/aarch64-hassio-supervisor:173']
19-08-18 12:36:01 INFO (MainThread) [__main__] Setup HassIO
19-08-18 12:36:02 INFO (SyncWorker_1) [hassio.docker.interface] Attach to homeassistant/aarch64-hassio-dns with version 1
19-08-18 12:36:02 INFO (MainThread) [hassio.dns] Update resolv from Supervisor
19-08-18 12:36:02 INFO (MainThread) [hassio.misc.forwarder] Start DNS port forwarding to 172.30.32.3
19-08-18 12:36:02 INFO (MainThread) [hassio.dns] Start CoreDNS plugin
19-08-18 12:36:02 INFO (SyncWorker_1) [hassio.docker.interface] Clean hassio_dns application
19-08-18 12:36:13 INFO (SyncWorker_1) [hassio.docker.dns] Start DNS homeassistant/aarch64-hassio-dns with version 1
19-08-18 12:36:13 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.systemd1 on /org/freedesktop/systemd1
19-08-18 12:36:13 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
19-08-18 12:36:13 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.hostname1 on /org/freedesktop/hostname1
19-08-18 12:36:13 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
19-08-18 12:36:13 INFO (MainThread) [hassio.utils.gdbus] Introspect de.pengutronix.rauc on /
19-08-18 12:36:14 ERROR (MainThread) [hassio.utils.gdbus] DBus return error: b'Error: GDBus.Errorrg.freedesktop.DBus.Error.ServiceUnknown: The name de.pengutronix.rauc was not provided by any .service files\n'
19-08-18 12:36:14 WARNING (MainThread) [hassio.dbus.rauc] Can't connect to rauc
19-08-18 12:36:14 INFO (MainThread) [hassio.host.info] Update local host information
19-08-18 12:36:14 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
19-08-18 12:36:14 INFO (MainThread) [hassio.host.services] Update service information
19-08-18 12:36:14 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
19-08-18 12:36:14 INFO (MainThread) [hassio.host.apparmor] Load AppArmor Profiles: {'hassio-supervisor'}
19-08-18 12:36:14 INFO (MainThread) [hassio.host.apparmor] AppArmor is not enabled on host
19-08-18 12:36:14 INFO (SyncWorker_0) [hassio.docker.interface] Attach to homeassistant/qemux86-64-homeassistant with version 0.97.2
19-08-18 12:36:14 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/git/a0d7b954 repository
19-08-18 12:36:14 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/core repository
19-08-18 12:36:15 INFO (MainThread) [hassio.store] Load add-ons from store: 59 all - 59 new - 0 remove
19-08-18 12:36:15 INFO (MainThread) [hassio.addons] Found 0 installed add-ons
19-08-18 12:36:15 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json
19-08-18 12:36:16 INFO (MainThread) [hassio.snapshots] Found 0 snapshot files
19-08-18 12:36:16 INFO (MainThread) [hassio.discovery] Load 0 messages
19-08-18 12:36:16 INFO (MainThread) [hassio.ingress] Load 0 ingress session
19-08-18 12:36:16 INFO (MainThread) [__main__] Run Hass.io
19-08-18 12:36:16 INFO (MainThread) [hassio.api] Start API on 172.30.32.2
19-08-18 12:36:16 INFO (MainThread) [hassio.addons] Phase 'initialize' start 0 add-ons
19-08-18 12:36:16 INFO (MainThread) [hassio.core] Hass.io reboot detected
19-08-18 12:36:16 INFO (MainThread) [hassio.tasks] All core tasks are scheduled
19-08-18 12:36:16 INFO (MainThread) [hassio.core] Hass.io is up and running
19-08-18 12:36:31 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant Docker!
19-08-18 12:36:31 INFO (SyncWorker_1) [hassio.docker.interface] Start homeassistant/qemux86-64-homeassistant
19-08-18 12:36:39 ERROR (MainThread) [hassio.homeassistant] Home Assistant has crashed!
19-08-18 12:36:39 ERROR (MainThread) [hassio.tasks] Watchdog Home Assistant reanimation fails!
########################### homeassistant log ###########################
[FATAL tini (7)] exec /bin/entry.sh failed: Exec format error
[FATAL tini (6)] exec /bin/entry.sh failed: Exec format error
[FATAL tini (8)] exec /bin/entry.sh failed: Exec format error
homeassistant 启动超时,请检查上方日志...
发表于 2019-8-18 20:47:05 | 显示全部楼层
19-08-18 12:35:59 INFO (MainThrea ...
求助这是怎么回事的错?
 楼主| 发表于 2019-8-19 09:34:31 | 显示全部楼层
lovemay3 发表于 2019-8-18 20:47
求助这是怎么回事的错?
你选错容器了
发表于 2019-8-20 11:22:07 | 显示全部楼层
大佬,raw.githubusercontent.com打不开了....sh文件也获取不到了
发表于 2019-8-20 11:34:47 | 显示全部楼层
出现错误了
正在设置 libjq1:i386 (1.5+dfsg-2+b1) ...
正在设置 jq (1.5+dfsg-2+b1) ...
正在处理用于 man-db (2.8.5-2) 的触发器 ...
正在处理用于 libc-bin (2.28-10) 的触发器 ...
[info]: 安装 Docker 引擎.....
# Executing docker install script, commit:
+ sh -c apt-get update -qq >/dev/null
+ sh -c apt-get install -y -qq apt-transport-https ca-certificates curl >/dev/null
+ sh -c curl -fsSL "https://mirror.azure.cn/docker-ce/linux/debian/gpg" | apt-key add -qq - >/dev/null
Warning: apt-key output should not be parsed (stdout is not a terminal)
+ sh -c echo "deb [arch=i386] https://mirror.azure.cn/docker-ce/linux/debian buster stable" > /etc/apt/sources.list.d/docker.list
+ [ -n  ]
+ sh -c apt-get install -y -qq --no-install-recommends docker-ce >/dev/null
E: 软件包 docker-ce 没有可安装候选
Distributor ID: Debian
Description:    Debian GNU/Linux 10 (buster)
Release:        10
Codename:       buster
Linux version 4.19.0-5-686-pae ([email protected]) (gcc version 8.3.0 (Debian 8.3.0-6)) #1 SMP Debian 4.19.37-5+deb10u2 (2019-08-08)
Linux debian10 4.19.0-5-686-pae #1 SMP Debian 4.19.37-5+deb10u2 (2019-08-08) i686 GNU/Linux
\033[0;31m[ERROR]: Docker 安装失败,请检查上方安装错误信息。 你也可以选择通过搜索引擎,搜索你系统安装docker的方法,安装后重新执行脚本。\033[0m
发表于 2019-8-20 11:43:49 | 显示全部楼层
我感觉是我网的问题,GitHub断断续续的打不开,过几天换个网络环境再试试,不行就先把docker装上,再用脚本
发表于 2019-8-21 13:53:54 | 显示全部楼层
marshmallow 发表于 2019-8-20 11:34
出现错误了
找到问题了,我这个2G内存的软路由,刷了32位的debian10,网上查了很多资料,在32位Debian10上装docker始终出错,好像很多源都没有32位debian10的docker了,,,
重新刷了64位的Debian10,还是用以前的方法一下就把docker装上了,这个docker弄了我好几天......
另外谢谢楼主这么好的脚本,省了很多事,谢谢啦
发表于 2019-8-22 14:56:31 | 显示全部楼层
ubuntu 18.04 server版本运行是完美的
GMT+8, 2025-10-27 15:30 , Processed in 0.153494 second(s), 11 queries , MemCached On.
