楼主: neroxps
HASSIO 安装一键脚本
 火...   [复制链接]
发表于 2019-3-4 14:04:35 | 显示全部楼层
阿库拉玛塔塔 发表于 2019-3-4 13:20
你好请问这是什么情况,刷过好几次系统了每次都到这步报错
Cannot connect to the Docker daemon at unix:/ ...
重启了之后好了~
 楼主| 发表于 2019-3-4 15:05:41 | 显示全部楼层
重启下 再运行脚本试试?我没树莓派,好像几个人都有这个问题。
xtrs
发表于 2019-3-5 00:34:47 | 显示全部楼层
[info]: 安装 Docker 引擎.....
# Executing docker install script, commit: UNKNOWN
+ sh -c apt-get update -qq >/dev/null
+ sh -c apt-get install -y -qq apt-transport-https ca-certificates curl >/dev/null
+ sh -c curl -fsSL "https://mirrors.aliyun.com/docker-ce/linux/raspbian/gpg" | apt-key add -qq - >/dev/null
Warning: apt-key output should not be parsed (stdout is not a terminal)
+ sh -c echo "deb [arch=armhf] [url=https://mirrors.aliyun.com/docker-ce/linux/raspbian]https://mirrors.aliyun.com/docker-ce/linux/raspbian[/url] stretch edge" > /etc/apt/sources.list.d/docker.list
+ sh -c apt-get install -y -qq --no-install-recommends docker-ce >/dev/null
If you would like to use Docker as a non-root user, you should now consider
adding your user to the "docker" group with something like:
  sudo usermod -aG docker your-user
Remember that you will have to log out and back in for this to take effect!
WARNING: Adding a user to the "docker" group will grant the ability to run
         containers which can be used to obtain root privileges on the
         docker host.
         Refer to [url=https://docs.docker.com/engine/security/security/#docker-daemon-attack-surface]https://docs.docker.com/engine/s ... emon-attack-surface[/url]
         for more information.
** DOCKER ENGINE - ENTERPRISE **
Test drive additional security features by activating Docker Engine - Enterprise.
  * Leverage FIPS 140-2 validated encryption
  * Run only trusted images with digital signature enforcement
** Learn more at [url=https://dockr.ly/engine1]https://dockr.ly/engine1[/url] **
ACTIVATE your own engine to Docker Engine - Enterprise using:
  sudo docker engine activate
Distributor ID: Raspbian
Description:    Raspbian GNU/Linux 9.8 (stretch)
Release:    9.8
Codename:   stretch
Linux version 4.14.79+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1159 Sun Nov 4 17:28:08 GMT 2018
Linux raspberrypi 4.14.79+ #1159 Sun Nov 4 17:28:08 GMT 2018 armv6l GNU/Linux
\033[0;31m[ERROR]: Docker 安装失败,请检查上方安装错误信息。 你也可以选择通过搜索引擎,搜索你系统安装docker的方法,安装后重新执行脚本。
请教,谢谢,重启重安2次都是这样,树莓1,get.docker.com可连通。
 楼主| 发表于 2019-3-5 09:34:29 | 显示全部楼层
xtrs 发表于 2019-3-5 00:34
[code]: 安装 Docker 引擎.....
我今天排查下,可能是get.docker.com 的脚本改了?还是脚本有bug
发表于 2019-3-5 10:40:46 | 显示全部楼层
很好  学习了
 楼主| 发表于 2019-3-5 11:20:21 | 显示全部楼层
你输入 systemctl status  docker 看看docker 启动了没
 楼主| 发表于 2019-3-5 11:27:23 | 显示全部楼层
应该是升级了内核之后,没重启,导致docker 启动失败。
 楼主| 发表于 2019-3-5 12:10:01 | 显示全部楼层
bug 已经修复~重新安装即可
故障是由于 系统更新后未重启造成 docker 安装失败
nemo 手机认证
发表于 2019-3-6 09:04:56 | 显示全部楼层
这个好 按这个试试
nemo 手机认证
发表于 2019-3-6 22:16:18 | 显示全部楼层
安装失败 求大神指点
GMT+8, 2026-1-12 11:14 , Processed in 1.703794 second(s), 12 queries , MemCached On.
