楼主: neroxps
HASSIO 安装一键脚本
 火...   [复制链接]
 楼主| 发表于 2019-2-18 12:04:11 | 显示全部楼层
丢你老鼠 发表于 2019-2-17 18:46
安装到一半 显示这样了。
[code]: Docker 安装成功。
添加用户 pi 到 Docker 用户组
排除网络问题
发表于 2019-2-18 13:18:06 | 显示全部楼层
网络正常哦 是不是要链接VPN弄?
发表于 2019-2-18 13:24:06 | 显示全部楼层
大佬可以发下QQ联系您指导下吗?
 楼主| 发表于 2019-2-18 14:14:42 | 显示全部楼层
丢你老鼠 发表于 2019-2-18 13:18
网络正常哦 是不是要链接VPN弄?
可能你的dns对 https://registry.docker-cn.com docker 官方的中国镜像有影响。
参考这篇文章切换docker 镜像源 https://docker_practice.gitee.io/install/mirror.html
加官方群可以找到我。7533213
发表于 2019-2-20 15:50:10 | 显示全部楼层
[info]: 切换系统网络源.....
备份系统源文件为 /etc/apt/sources.list.bak
Hit:1 http://mirrors.ustc.edu.cn/raspbian/raspbian stretch InRelease
Hit:2 http://mirrors.ustc.edu.cn/archive.raspberrypi.org/debian stretch InRelease
Get:3 http://archive.raspberrypi.org/debian stretch InRelease [25.4 kB]
Get:5 http://archive.raspberrypi.org/debian stretch/ui armhf Packages [42.0 kB]
Get:4 http://59.80.44.99/archive.raspberrypi.org/debian stretch/main armhf Packages [212 kB]
Err:4 http://59.80.44.99/archive.raspberrypi.org/debian stretch/main armhf Packages
  Hash Sum mismatch
  Hashes of expected file:
   - Filesize:211928 [weak]
   - SHA256:f65e5a57507f5b2061df613e461295a337cc23446228a3669d6c09830204615f
   - SHA1:9cb56c689f7b78efdda0a5f80548caaf2721eff7 [weak]
   - MD5Sum:8f32675c7d6b4e5d24872127bf483b65 [weak]
  Hashes of received file:
   - SHA256:d3beb17e70ad2a9ce388cadcdda02c6e113f75b25a2d5f0b56f2e1471b617d25
   - SHA1:cb1470756908457524231971fbf135085f5c4252 [weak]
   - MD5Sum:1dc118eb33143b6a702c47b2ad0f8682 [weak]
   - Filesize:211916 [weak]
  Last modification reported: Wed, 13 Feb 2019 13:05:30 +0000
  Release file created at: Tue, 19 Feb 2019 16:32:59 +0000
Fetched 237 kB in 10s (22.2 kB/s)
Reading package lists... Done
E: Failed to fetch http://59.80.44.99/archive.raspb ... y-armhf/Packages.gz  Hash Sum mismatch
E: Some index files failed to download. They have been ignored, or old ones used instead.
Distributor ID: Raspbian
Description:    Raspbian GNU/Linux 9.4 (stretch)
Release:        9.4
Codename:       stretch
Linux version 4.14.79-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1159 SMP Sun Nov 4 17:50:20 GMT 2018
Linux raspberrypi 4.14.79-v7+ #1159 SMP Sun Nov 4 17:50:20 GMT 2018 armv7l GNU/Linux
[ERROR]: 系统源切换错误,请检查网络连接是否正常,脚本退出
用了n次都正常 刚刚报错了,,,
 楼主| 发表于 2019-2-20 16:00:55 | 显示全部楼层
撸大师 发表于 2019-2-20 15:50
: 切换系统网络源.....
Hit:1 http://mirrors.ustc.edu.cn/ra ...
网络问题
发表于 2019-2-21 16:17:10 | 显示全部楼层
折腾了4天都是百折腾做了无限个重复错误
终于搭建好了 接下来学习添加设备了。 送上个图
 楼主| 发表于 2019-2-21 17:26:11 | 显示全部楼层
丢你老鼠 发表于 2019-2-21 16:17
折腾了4天都是百折腾做了无限个重复错误
恭喜,所以你应该丢掉百度拥抱google
发表于 2019-2-22 00:19:57 | 显示全部楼层
从 hub.docker.com 下载 homeassistant/raspberrypi3-homeassistant:0.88.0......
Cannot connect to the Docker daemon at unix:///var/run/docker.sock. Is the docke         r daemon running?
[ERROR]: 从 docker 下载 homeassistant/raspberrypi3-homeassistant:0.88.0 失败,请         检查上方失败信息。
請問怎解
 楼主| 发表于 2019-2-22 08:24:53 | 显示全部楼层
Cannot connect to the D ...
docker 运行失败?上方还有什么日志没有
GMT+8, 2025-12-15 15:17 , Processed in 1.339832 second(s), 6 queries , MemCached On.
