楼主: neroxps
HASSIO 安装一键脚本
 火...   [复制链接]
发表于 2019-1-29 11:05:40 | 显示全部楼层
各位,这个装完后4g内存够用吗?
 楼主| 发表于 2019-1-29 13:30:30 | 显示全部楼层
[email protected] 发表于 2019-1-29 11:05
各位,这个装完后4g内存够用吗?
2G都够
发表于 2019-1-29 14:16:30 | 显示全部楼层
安装成功。前来支持一下大神
我就是六神
活跃会员教程狂人灌水之王
发表于 2019-2-2 10:43:41 | 显示全部楼层
2月份 好用了~~
发表于 2019-2-7 19:59:54 | 显示全部楼层
請教大佬
是怎麼回事
等待 homeassistant 启动.............................................................................................................................................................................................................................................................................................................fail
########################### Docker images ###########################
REPOSITORY                                 TAG                 IMAGE ID            CREATED             SIZE
homeassistant/raspberrypi3-homeassistant   0.87.0              8989ca6afca9        10 hours ago        1.05GB
homeassistant/raspberrypi3-homeassistant   latest              8989ca6afca9        10 hours ago        1.05GB
homeassistant/raspberrypi3-homeassistant   0.86.4              c3d9625ac427        9 days ago          1.06GB
homeassistant/armhf-addon-samba            8                   c2a9f3ff8143        3 months ago        44.6MB
homeassistant/armhf-addon-samba            latest              c2a9f3ff8143        3 months ago        44.6MB
homeassistant/armhf-addon-duckdns          1.5                 cb72747cebc7        7 months ago        17.4MB
homeassistant/armhf-addon-duckdns          latest              cb72747cebc7        7 months ago        17.4MB
########################### Docker ps ###########################
CONTAINER ID        IMAGE                               COMMAND             CREATED             STATUS                     PORTS               NAMES
6214a297dce0        homeassistant/armhf-addon-duckdns   "/run.sh"           8 hours ago         Exited (255) 5 hours ago                       addon_core_duckdns
########################### hassio log ###########################
Error: No such container: hassio_supervisor
########################### homeassistant log ###########################
Error: No such container: homeassistant
homeassistant 启动超时,请检查上方日志....
发表于 2019-2-15 14:57:35 | 显示全部楼层
[已解决]reboot一下就好了N大,安装到最后提示启动错误,日志如下,看不懂这个错误提示应该怎样修正啊……
19-02-15 06:32:35 ERROR (MainThread) [hassio.utils.gdbus] DBus return error: b'Error: GDBus.Errorrg.freedesktop.DBus.Error.ServiceUnknown: The name de.pengutronix.rauc was not provided by any .service files\n'
19-02-15 06:34:16 ERROR (MainThread) [hassio.utils.gdbus] DBus return error: b'Error: GDBus.Errorrg.freedesktop.DBus.Error.ServiceUnknown: The name de.pengutronix.rauc was not provided by any .service files\n'
hass和hassio-supervisor的图像都成功下载了。
19-02-15 06:32:33 INFO (MainThread) [__main__] Initialize Hass.io setup
19-02-15 06:32:33 INFO (MainThread) [__main__] Setup HassIO
19-02-15 06:32:33 INFO (SyncWorker_0) [hassio.docker.supervisor] Attach to Supervisor homeassistant/armhf-hassio-supervisor with version 143
19-02-15 06:32:34 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.systemd1 on /org/freedesktop/systemd1
19-02-15 06:32:35 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
19-02-15 06:32:35 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.hostname1 on /org/freedesktop/hostname1
19-02-15 06:32:35 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
19-02-15 06:32:35 INFO (MainThread) [hassio.utils.gdbus] Introspect de.pengutronix.rauc on /
19-02-15 06:32:35 ERROR (MainThread) [hassio.utils.gdbus] DBus return error: b'Error: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name de.pengutronix.rauc was not provided by any .service files\n'
19-02-15 06:32:35 WARNING (MainThread) [hassio.dbus.rauc] Can't connect to rauc
19-02-15 06:32:35 INFO (MainThread) [hassio.host.info] Update local host information
19-02-15 06:32:35 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
19-02-15 06:32:35 INFO (MainThread) [hassio.host.services] Update service information
19-02-15 06:32:35 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
19-02-15 06:32:35 INFO (MainThread) [hassio.host.apparmor] Load AppArmor Profiles: set()
19-02-15 06:32:35 INFO (MainThread) [hassio.host.apparmor] AppArmor is not enabled on host
19-02-15 06:32:35 INFO (SyncWorker_1) [hassio.docker.interface] Attach to image homeassistant/raspberrypi3-homeassistant with version 0.87.1
19-02-15 06:32:35 INFO (MainThread) [hassio.addons.git] Load add-on /data/addons/git/a0d7b954 repository
19-02-15 06:32:35 INFO (MainThread) [hassio.addons.git] Load add-on /data/addons/core repository
19-02-15 06:32:36 INFO (MainThread) [hassio.addons] Load add-ons: 53 all - 53 new - 0 remove
19-02-15 06:32:36 INFO (MainThread) [hassio.updater] Fetch update data from [url=https://s3.amazonaws.com/hassio-version/stable.json]https://s3.amazonaws.com/hassio-version/stable.json[/url]
19-02-15 06:32:46 WARNING (MainThread) [hassio.updater] Can't fetch versions from [url=https://s3.amazonaws.com/hassio-version/stable.json:]https://s3.amazonaws.com/hassio-version/stable.json:[/url]
19-02-15 06:32:46 INFO (MainThread) [hassio.snapshots] Found 0 snapshot files
19-02-15 06:32:46 INFO (MainThread) [hassio.discovery] Load 0 messages
19-02-15 06:32:46 INFO (MainThread) [__main__] Run Hass.io
19-02-15 06:32:46 INFO (MainThread) [hassio.misc.dns] Start DNS port forwarding for host add-ons
19-02-15 06:32:47 INFO (MainThread) [hassio.api] Start API on 172.30.32.2
19-02-15 06:32:47 INFO (MainThread) [hassio.addons] Startup initialize run 0 add-ons
19-02-15 06:32:47 INFO (MainThread) [hassio.core] Hass.io reboot detected
19-02-15 06:32:47 INFO (MainThread) [hassio.tasks] All core tasks are scheduled
19-02-15 06:32:47 INFO (MainThread) [hassio.core] Hass.io is up and running
19-02-15 06:34:03 INFO (MainThread) [__main__] Stopping Hass.io
19-02-15 06:34:03 INFO (MainThread) [hassio.api] Stop API on 172.30.32.2
19-02-15 06:34:03 INFO (MainThread) [hassio.misc.dns] Stop DNS forwarding
19-02-15 06:34:03 INFO (MainThread) [hassio.core] Hass.io is down
19-02-15 06:34:03 INFO (MainThread) [__main__] Close Hass.io
19-02-15 06:34:15 INFO (MainThread) [__main__] Initialize Hass.io setup
19-02-15 06:34:15 INFO (MainThread) [__main__] Setup HassIO
19-02-15 06:34:15 INFO (SyncWorker_0) [hassio.docker.supervisor] Attach to Supervisor homeassistant/armhf-hassio-supervisor with version 143
19-02-15 06:34:15 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.systemd1 on /org/freedesktop/systemd1
19-02-15 06:34:15 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
19-02-15 06:34:15 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.hostname1 on /org/freedesktop/hostname1
19-02-15 06:34:16 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
19-02-15 06:34:16 INFO (MainThread) [hassio.utils.gdbus] Introspect de.pengutronix.rauc on /
19-02-15 06:34:16 ERROR (MainThread) [hassio.utils.gdbus] DBus return error: b'Error: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name de.pengutronix.rauc was not provided by any .service files\n'
19-02-15 06:34:16 WARNING (MainThread) [hassio.dbus.rauc] Can't connect to rauc
19-02-15 06:34:16 INFO (MainThread) [hassio.host.info] Update local host information
19-02-15 06:34:16 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
19-02-15 06:34:16 INFO (MainThread) [hassio.host.services] Update service information
19-02-15 06:34:16 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
19-02-15 06:34:16 INFO (MainThread) [hassio.host.apparmor] Load AppArmor Profiles: set()
19-02-15 06:34:16 INFO (MainThread) [hassio.host.apparmor] AppArmor is not enabled on host
19-02-15 06:34:16 INFO (SyncWorker_1) [hassio.docker.interface] Attach to image homeassistant/raspberrypi3-homeassistant with version 0.87.1
19-02-15 06:34:16 INFO (MainThread) [hassio.addons.git] Load add-on /data/addons/git/a0d7b954 repository
19-02-15 06:34:16 INFO (MainThread) [hassio.addons.git] Load add-on /data/addons/core repository
19-02-15 06:34:16 INFO (MainThread) [hassio.addons] Load add-ons: 53 all - 53 new - 0 remove
19-02-15 06:34:16 INFO (MainThread) [hassio.updater] Fetch update data from [url=https://s3.amazonaws.com/hassio-version/stable.json]https://s3.amazonaws.com/hassio-version/stable.json[/url]
19-02-15 06:34:27 WARNING (MainThread) [hassio.updater] Can't fetch versions from [url=https://s3.amazonaws.com/hassio-version/stable.json:]https://s3.amazonaws.com/hassio-version/stable.json:[/url]
19-02-15 06:34:27 INFO (MainThread) [hassio.snapshots] Found 0 snapshot files
19-02-15 06:34:27 INFO (MainThread) [hassio.discovery] Load 0 messages
19-02-15 06:34:27 INFO (MainThread) [__main__] Run Hass.io
19-02-15 06:34:27 INFO (MainThread) [hassio.misc.dns] Start DNS port forwarding for host add-ons
19-02-15 06:34:28 INFO (MainThread) [hassio.api] Start API on 172.30.32.2
19-02-15 06:34:28 INFO (MainThread) [hassio.addons] Startup initialize run 0 add-ons
19-02-15 06:34:28 INFO (MainThread) [hassio.core] Hass.io reboot detected
19-02-15 06:34:28 INFO (MainThread) [hassio.tasks] All core tasks are scheduled
19-02-15 06:34:28 INFO (MainThread) [hassio.core] Hass.io is up and running
 楼主| 发表于 2019-2-16 08:36:45 | 显示全部楼层
ipop256 发表于 2019-2-7 19:59
請教大佬
是怎麼回事
选错架构
 楼主| 发表于 2019-2-16 08:37:39 | 显示全部楼层
不用管
发表于 2019-2-17 18:43:28 | 显示全部楼层
大佬 我想咨询一下 新买的树莓派 安装了Raspbian  是不是直接运行你这个脚本就等于安装了整套HomeAssistant的了?
发表于 2019-2-17 18:46:57 | 显示全部楼层
安装到一半 显示这样了。
[info]: Docker 安装成功。
添加用户 pi 到 Docker 用户组
[info]: 切换 Docker 源为国内源....
[info]: 切换国内源完成
[info]: 安装 hassio......
从 hub.docker.com 下载 homeassistant/qemux86-homeassistant:0.87.1......
Error response from daemon: Get [url]https://registry-1.docker.io/v2/homeassistant/qemux86-homeassistant/manifests/0.87.1:[/url] Get [url]https://auth.docker.io/token?scope=repository%3Ahomeassistant%2Fqemux86-homeassistant%3Apull&service=registry.docker.io:[/url] net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)
[ERROR]: 从 docker 下载 homeassistant/qemux86-homeassistant:0.87.1 失败,请检查上方失败信息。
root@raspberrypi:/home/pi#
GMT+8, 2025-12-15 15:19 , Processed in 1.262844 second(s), 9 queries , MemCached On.
