楼主: neroxps
HASSIO 安装一键脚本
 火...   [复制链接]
发表于 2020-12-18 10:12:08 | 显示全部楼层
按大佬的脚本出现如下错误 ,怎么解决?
# 1. 是否将系统源切换为清华源: 是
# 2. 是否将用户添加至 Docker 用户组:   是,添加用户为 willis
# 3. 是否将 Docker 源切换至国内源:     是,切换源选择:
# 4. 您的设备类型为:                   qemux86-64
# 5. 您的 hassio 数据路径为:           /usr/share/hassio
请确认以上信息,继续请按任意键,如需修改请输入 Ctrl+C 结束任务重新执行脚本。
[info]: 切换系统网络源.....
Hit:1 http://mirrors.tuna.tsinghua.edu.cn/ubuntu bionic InRelease
Hit:2 https://mirrors.ustc.edu.cn/docker-ce/linux/ubuntu artful InRelease
Hit:3 http://mirrors.tuna.tsinghua.edu.cn/ubuntu bionic-updates InRelease
Hit:4 http://mirrors.tuna.tsinghua.edu.cn/ubuntu bionic-backports InRelease
Hit:5 http://mirrors.tuna.tsinghua.edu.cn/ubuntu bionic-security InRelease
Reading package lists... Done
Building dependency tree
Reading state information... Done
5 packages can be upgraded. Run 'apt list --upgradable' to see them.
[info]: 安装 hassio 必要依赖.....
auditd is already the newest version (1:2.8.2-1ubuntu1).
net-tools is already the newest version (1.60+git20161116.90da8a0-1ubuntu1).
socat is already the newest version (1.7.3.2-2ubuntu2).
jq is already the newest version (1.5+dfsg-2).
qrencode is already the newest version (3.4.4-1build1).
apparmor is already the newest version (2.12-4ubuntu5.1).
apparmor-utils is already the newest version (2.12-4ubuntu5.1).
avahi-daemon is already the newest version (0.7-3.1ubuntu1.2).
curl is already the newest version (7.58.0-2ubuntu3.12).
network-manager is already the newest version (1.10.6-2ubuntu1.5).
0 upgraded, 0 newly installed, 0 to remove and 5 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up auditd (1:2.8.2-1ubuntu1) ...
Job for auditd.service failed because the control process exited with error code.
See "systemctl status auditd.service" and "journalctl -xe" for details.
invoke-rc.d: initscript auditd, action "start" failed.
* auditd.service - Security Auditing Service
   Loaded: loaded (/lib/systemd/system/auditd.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Fri 2020-12-18 02:10:54 UTC; 8ms ago
     Docs: man:auditd(8)
           https://github.com/linux-audit/audit-documentation
  Process: 6060 ExecStart=/sbin/auditd (code=exited, status=1/FAILURE)
Dec 18 02:10:54 HAASIO systemd[1]: Starting Security Auditing Service...
Dec 18 02:10:54 HAASIO auditd[6060]: Cannot change priority (Operation not permitted)
Dec 18 02:10:54 HAASIO auditd[6060]: The audit daemon is exiting.
Dec 18 02:10:54 HAASIO systemd[1]: auditd.service: Control process exited, code=exited status=1
Dec 18 02:10:54 HAASIO systemd[1]: auditd.service: Failed with result 'exit-code'.
Dec 18 02:10:54 HAASIO systemd[1]: Failed to start Security Auditing Service.
dpkg: error processing package auditd (--configure):
installed auditd package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
auditd
E: Sub-process /usr/bin/dpkg returned an error code (1)
################# 发到论坛时,请把上方日志也一并粘贴发送 ################
Distributor ID: Ubuntu
Description:    Ubuntu 18.04.5 LTS
Release:        18.04
Codename:       bionic
Linux version 5.4.34-1-pve (build@pve) (gcc version 8.3.0 (Debian 8.3.0-6)) #1 SMP PVE 5.4.34-2 (Thu, 07 May 2020 10:02:02 +0200)
Linux HAASIO 5.4.34-1-pve #1 SMP PVE 5.4.34-2 (Thu, 07 May 2020 10:02:02 +0200) x86_64 x86_64 x86_64 GNU/Linux
\033[0;31m[ERROR]: 安装curl失败,请将检查上方安装错误信息。\033[0m
发表于 2020-12-22 16:49:34 | 显示全部楼层
好像一直报错,怒装hassos了
 楼主| 发表于 2020-12-22 19:56:30 | 显示全部楼层
吖龟籽 发表于 2020-12-22 16:49
好像一直报错,怒装hassos了
请问报错日志是什么?
发表于 2020-12-22 20:12:25 | 显示全部楼层
neroxps 发表于 2020-12-22 19:56
请问报错日志是什么?
其中一个是[supervisor.dbus.network] Version '1.10.6' of NetworkManager is not supporte,用的是ubuntu 18.04服务器版,没界面的,还有一个错误忘记了,安装不了插件,最后为了尽快开始部署,就直接vm跑hassos
 楼主| 发表于 2020-12-22 20:16:08 | 显示全部楼层
吖龟籽 发表于 2020-12-22 20:12
其中一个是[supervisor.dbus.network] Version '1.10.6' of NetworkManager is not supporte,用的是ubun ...
哦 Ubuntu 服务器版本我之后没测试过,官方要求增加了 NetworkManager 所以默认的 NetworkManager 配置如果出错,因为我的脚本还是套用官方一键脚本,这个问题我已经识别了,后期看看测试下把这个问题修复了。
不过这个脚本其实主要还是方便我自己,所以时效性并没有那么迅速~谅解。
发表于 2020-12-22 20:39:47 | 显示全部楼层
neroxps 发表于 2020-12-22 20:16
哦 Ubuntu 服务器版本我之后没测试过,官方要求增加了 NetworkManager 所以默认的 NetworkManager 配置如 ...
我看了很多资料,大概也是这个情况,因为ubuntu服务版实际好像不用调用NM作网络的,没事,谢谢你的付出!
 楼主| 发表于 2020-12-22 21:00:32 | 显示全部楼层
吖龟籽 发表于 2020-12-22 20:39
我看了很多资料,大概也是这个情况,因为ubuntu服务版实际好像不用调用NM作网络的,没事,谢谢你的付出! ...
是因为 hassio 依赖要用,其实不用 networkmanages 也没关系,就是硬件那边看不到网络信息而已~我感觉没啥用哈哈
发表于 2020-12-24 20:34:45 | 显示全部楼层
hassio 数据路径为默认路径: /usr/share/hassio
# 1. 是否将系统源切换为清华源: 否
# 2. 是否将用户添加至 Docker 用户组:   是,添加用户为 systemd-coredump
# 4. 您的设备类型为:                   qemuarm
[info]: 跳过切换系统源。
Ign:2 https://mirrors.tuna.tsinghua.edu.cn/debian stretch InRelease
Hit:3 https://mirrors.tuna.tsinghua.edu.cn/debian stretch-updates InRelease
Hit:4 https://mirrors.tuna.tsinghua.edu.cn/debian stretch-backports InRelease
Hit:5 https://mirrors.tuna.tsinghua.edu.cn/debian-security stretch/updates InRelease
Hit:6 https://mirrors.tuna.tsinghua.edu.cn/debian stretch Release
Get:1 https://minio.k-space.ee/armbian/apt buster InRelease [18.3 kB]
Fetched 18.3 kB in 14s (1,283 B/s)
All packages are up to date.
curl is already the newest version (7.64.0-4+deb10u1).
jq is already the newest version (1.5+dfsg-2+b1).
net-tools is already the newest version (1.60+git20180626.aebd88e-1).
network-manager is already the newest version (1.14.6-2+deb10u1).
qrencode is already the newest version (4.0.2-1).
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
apparmor : Depends: libapparmor-perl but it is not going to be installed
apparmor-utils : Depends: libapparmor-perl but it is not going to be installed
                  Depends: python3-apparmor (= 2.11.0-3+deb9u2) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Distributor ID: Debian
Description:    Debian GNU/Linux 10 (buster)
Release:        10
Codename:       buster
Linux version 5.9.14-sunxi (root@beast) (arm-linux-gnueabihf-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 2.32.0.20190321) #20.11.3 SMP Fri Dec 11 20:31:12 CET 2020
Linux orangepilite 5.9.14-sunxi #20.11.3 SMP Fri Dec 11 20:31:12 CET 2020 armv7l GNU/Linux
\033[0;31m[ERROR]: 安装curl socat jq avahi-daemon net-tools network-manager qrencode apparmor apparmor-utils失败,请将检查上方安装错误信息。\033[0m
相关问题可以访问https://bbs.iobroker.cn或者加QQ群776817275咨询
这样的信息,应该怎样处理呢?
发表于 2020-12-26 17:12:58 | 显示全部楼层
升级脚本404什么情况?
pi@raspberrypi:~ $ sudo wget https://code.aliyun.com/neroxps/ ... r/hassio_upgrade.sh
--2020-12-26 16:23:57--  https://code.aliyun.com/neroxps/ ... r/hassio_upgrade.sh
正在解析主机 code.aliyun.com (code.aliyun.com)... 120.55.150.20
正在连接 code.aliyun.com (code.aliyun.com)|120.55.150.20|:443... 已连接。
已发出 HTTP 请求,正在等待回应... 404 Not Found
2020-12-26 16:23:58 错误 404:Not Found。
 楼主| 发表于 2020-12-26 17:53:36 | 显示全部楼层
sllguy 发表于 2020-12-26 17:12
升级脚本404什么情况?
pi@raspberrypi:~ $ sudo wget https://code.aliyun.com/neroxps/hassio_install/r ...
upgrade 脚本已经去掉,没用了
GMT+8, 2025-12-15 12:52 , Processed in 0.305576 second(s), 16 queries , MemCached On.
