楼主: neroxps
HASSIO 安装一键脚本
 火...   [复制链接]
发表于 2020-10-11 01:38:25 | 显示全部楼层
Master 发表于 2020-10-8 16:52
After this operation, 0 B of additional disk space will be used.
Setting up auditd (1:2.8.4-3) ...
J ...
https://bbs.hassbian.com/forum.p ... 4520&pid=342362
发表于 2020-10-11 01:49:42 | 显示全部楼层
qjiang 发表于 2020-9-14 15:04
dpkg: 处理软件包 xxx (--configure)时出错 解决办法
第一步:备份
正想發文就找到此篇.....沒錯我就是按照此步驟後再執行安裝腳本解決無法安裝的問題.........
 楼主| 发表于 2020-10-11 17:56:00 | 显示全部楼层
huasangsang 发表于 2020-10-10 23:37
连接网线后:
1. 使用 sudo apt install network-manager network-manager-gnome  安装networkManager
2.  ...
好复杂····还是留给用户自己选择吧。如果不会操作还是自己装 hassos
发表于 2020-10-18 17:43:02 | 显示全部楼层
连接网线后:
2.  ...
需要加入开机启动的命令有哪些
发表于 2020-10-18 18:02:07 | 显示全部楼层
Unpacking socat (1.7.3.2-2) ...
Setting up python3-libapparmor (2.13.2-10) ...
Setting up libqrencode4:armhf (4.0.2-1) ...
Setting up qrencode (4.0.2-1) ...
Setting up libcurl3-gnutls:armhf (7.64.0-4+deb10u1) ...
Setting up dnsmasq-base (2.80-1+rpt1) ...
Setting up libauparse0:armhf (1:2.8.4-3) ...
Setting up libjansson4:armhf (2.12-1) ...
Setting up dns-root-data (2019031302) ...
Setting up apparmor (2.13.2-10) ...
Created symlink /etc/systemd/system/sysinit.target.wants/apparmor.service → /lib/systemd/system/apparmor.service.
Setting up libpcap0.8:armhf (1.8.1-6) ...
Setting up libteamdctl0:armhf (1.28-1) ...
Setting up socat (1.7.3.2-2) ...
Setting up libnm0:armhf (1.14.6-2+deb10u1) ...
Setting up ppp (2.4.7-2+4.1+deb10u1) ...
Created symlink /etc/systemd/system/multi-user.target.wants/pppd-dns.service → /lib/systemd/system/pppd-dns.service.
Setting up libmm-glib0:armhf (1.10.0-1) ...
Setting up libbluetooth3:armhf (5.50-1.2~deb10u1+rpt2) ...
Setting up python3-apparmor (2.13.2-10) ...
Setting up libndp0:armhf (1.6-1) ...
Setting up libonig5:armhf (6.9.1-1) ...
Setting up libgudev-1.0-0:armhf (232-2+rpi1) ...
Setting up libmbim-glib4:armhf (1.18.0-1) ...
Created symlink /etc/systemd/system/multi-user.target.wants/auditd.service → /lib/systemd/system/auditd.service.
Job for auditd.service failed because the control process exited with error code.
See "systemctl status auditd.service" and "journalctl -xe" for details.
invoke-rc.d: initscript auditd, action "start" failed.
● auditd.service - Security Auditing Service
   Loaded: loaded (/lib/systemd/system/auditd.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Sun 2020-10-18 10:55:54 BST; 23ms ago
     Docs: man:auditd(8)
           https://github.com/linux-audit/audit-documentation
  Process: 1649 ExecStart=/sbin/auditd (code=exited, status=1/FAILURE)
Oct 18 10:55:54 raspberrypi systemd[1]: Starting Security Auditing Service...
Oct 18 10:55:54 raspberrypi auditd[1650]: Error - audit support not in kernel
Oct 18 10:55:54 raspberrypi auditd[1650]: Cannot open netlink audit socket
Oct 18 10:55:54 raspberrypi auditd[1650]: The audit daemon is exiting.
Oct 18 10:55:54 raspberrypi auditd[1649]: Cannot daemonize (Success)
Oct 18 10:55:54 raspberrypi systemd[1]: auditd.service: Control process exited, code=exited, status=1/FAILURE
Oct 18 10:55:54 raspberrypi auditd[1649]: The audit daemon is exiting.
Oct 18 10:55:54 raspberrypi systemd[1]: auditd.service: Failed with result 'exit-code'.
Oct 18 10:55:54 raspberrypi systemd[1]: Failed to start Security Auditing Service.
dpkg: error processing package auditd (--configure):
installed auditd package post-installation script subprocess returned error exit status 1
Setting up libjq1:armhf (1.5+dfsg-2+b1) ...
Setting up network-manager (1.14.6-2+deb10u1) ...
Created symlink /etc/systemd/system/dbus-org.freedesktop.nm-dispatcher.service → /lib/systemd/system/NetworkManager-dispatcher.service.
Created symlink /etc/systemd/system/network-online.target.wants/NetworkManager-wait-online.service → /lib/systemd/system/NetworkManager-wait-online.service.
Created symlink /etc/systemd/system/multi-user.target.wants/NetworkManager.service → /lib/systemd/system/NetworkManager.service.
Setting up libmbim-proxy (1.18.0-1) ...
Setting up apparmor-utils (2.13.2-10) ...
Setting up jq (1.5+dfsg-2+b1) ...
Setting up libqmi-glib5:armhf (1.22.0-1.2) ...
Setting up libqmi-proxy (1.22.0-1.2) ...
Setting up modemmanager (1.10.0-1) ...
Created symlink /etc/systemd/system/dbus-org.freedesktop.ModemManager1.service → /lib/systemd/system/ModemManager.service.
Created symlink /etc/systemd/system/multi-user.target.wants/ModemManager.service → /lib/systemd/system/ModemManager.service.
Processing triggers for systemd (241-7~deb10u4+rpi1) ...
Processing triggers for man-db (2.8.5-2) ...
Processing triggers for dbus (1.12.20-0+deb10u1) ...
Processing triggers for libc-bin (2.28-10+rpi1) ...
Errors were encountered while processing:
auditd
E: Sub-process /usr/bin/dpkg returned an error code (1)
################# 发到论坛时,请把上方日志也一并粘贴发送 ################
Distributor ID: Raspbian
Description:    Raspbian GNU/Linux 10 (buster)
Release:        10
Codename:       buster
Linux version 5.4.51-v7l+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1333 SMP Mon Aug 10 16:51:40 BST 2020
Linux raspberrypi 5.4.51-v7l+ #1333 SMP Mon Aug 10 16:51:40 BST 2020 armv7l GNU/Linux
\033[0;31m[ERROR]: 安装curl失败,请将检查上方安装错误信息。\033[0m
相关问题可以访问https://bbs.iobroker.cn或者加QQ群776817275咨询
发表于 2020-10-19 09:59:31 | 显示全部楼层
需要下载 0 B/193 kB 的归档。
解压缩后会消耗 579 kB 的额外空间。
正在选中未选择的软件包 auditd。
(正在读取数据库 ... 系统当前共安装有 155877 个文件和目录。)
准备解压 .../auditd_1%3a2.8.4-3_armhf.deb  ...
正在解压 auditd (1:2.8.4-3) ...
正在设置 auditd (1:2.8.4-3) ...
   Active: failed (Result: exit-code) since Mon 2020-10-19 09:45:19 CST; 38ms ago
     Docs: man:auditd(8)
  Process: 10878 ExecStart=/sbin/auditd (code=exited, status=1/FAILURE)
10月 19 09:45:19 raspberrypi systemd[1]: Starting Security Auditing Service...
10月 19 09:45:19 raspberrypi auditd[10879]: Error - audit support not in kernel
10月 19 09:45:19 raspberrypi auditd[10879]: Cannot open netlink audit socket
10月 19 09:45:19 raspberrypi systemd[1]: auditd.service: Control process exited, code=exited, status=1/FAILURE
10月 19 09:45:19 raspberrypi auditd[10879]: The audit daemon is exiting.
10月 19 09:45:19 raspberrypi systemd[1]: auditd.service: Failed with result 'exit-code'.
10月 19 09:45:19 raspberrypi systemd[1]: Failed to start Security Auditing Service.
dpkg: 处理软件包 auditd (--configure)时出错:
已安装 auditd 软件包 post-installation 脚本 子进程返回错误状态 1
正在处理用于 man-db (2.8.5-2) 的触发器 ...
正在处理用于 systemd (241-7~deb10u4+rpi1) 的触发器 ...
在处理时有错误发生:
auditd
Release:        10
Codename:       buster
Linux version 5.4.51-v7+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1333 SMP Mon Aug 10 16:45:19
BST 2020
Linux raspberrypi 5.4.51-v7+ #1333 SMP Mon Aug 10 16:45:19 BST 2020 armv7l GNU/Linux
树莓派3不支持auditd吗,应该怎么解决
发表于 2020-10-19 17:32:28 | 显示全部楼层
感谢分享,学习一下
发表于 2020-10-20 21:56:47 | 显示全部楼层
zs1024242524 发表于 2020-10-18 17:43
需要加入开机启动的命令有哪些
关掉wlan0网卡
修改wlan0网卡mac地址
启动wlan0网卡
连接wifi
这四条命令
发表于 2020-10-21 18:35:58 | 显示全部楼层
openwrt里的docker怎么样才能安装你的这个hassio ,感谢
 楼主| 发表于 2020-10-22 08:51:08 | 显示全部楼层
请自行解决 hassio 依赖。
你可以参考下官方的一键安装脚本 https://github.com/home-assistan ... master/installer.sh
GMT+8, 2025-12-16 08:28 , Processed in 0.085448 second(s), 11 queries , MemCached On.
