楼主: neroxps
HASSIO 安装一键脚本
 火...   [复制链接]
发表于 2020-11-26 10:06:33 | 显示全部楼层
啥情况? curl安装不成功?
正在处理用于 libc-bin (2.28-10+rpi1) 的触发器 ...
正在处理用于 systemd (241-7~deb10u4+rpi1) 的触发器 ...
正在处理用于 man-db (2.8.5-2) 的触发器 ...
正在处理用于 dbus (1.12.20-0+deb10u1) 的触发器 ...
正在处理用于 hicolor-icon-theme (0.17-2) 的触发器 ...
在处理时有错误发生:
auditd
E: Sub-process /usr/bin/dpkg returned an error code (1)
################# 发到论坛时,请把上方日志也一并粘贴发送 ################
Distributor ID: Raspbian
Description:    Raspbian GNU/Linux 10 (buster)
Release:        10
Codename:       buster
Linux version 5.4.51-v7+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1333 SMP Mon Aug 10 16:45:19 BST 2020
Linux raspberrypi 5.4.51-v7+ #1333 SMP Mon Aug 10 16:45:19 BST 2020 armv7l GNU/Linux
\033[0;31m[ERROR]: 安装curl失败,请将检查上方安装错误信息。\033[0m
相关问题可以访问https://bbs.iobroker.cn或者加QQ群776817275咨询
 楼主| 发表于 2020-11-26 10:22:36 | 显示全部楼层
michlu 发表于 2020-11-26 10:06
啥情况? curl安装不成功?
因为树莓派系统内核默认没有开启 auditd 所以 apt 的时候会报错.导致 apt 安装出错,脚本退出
我没有树莓派,没法调试如何开启  auditd 内核.请自行Google下
发表于 2020-12-1 14:34:40 | 显示全部楼层
开始 hassio 安装流程。(如出现 [Warning] 请忽略,无须理会)
[warn]
[warn] If you want more control over your own system, run
[warn] Home Assistant as a VM or run Home Assistant Core
[warn] via a Docker container.
[warn]
[warn] If you want to abort, hit ctrl+c within 10 seconds...
[warn]
[warn] ModemManager service is enabled. This might cause issue when using serial devices.
[info] Creating NetworkManager configuration
[warn] Changes are needed to the /etc/network/interfaces file
[info] If you have modified the network on the host manualy, those can now be overwritten
[info] If you do not overwrite this now you need to manually adjust it later
[info] Do you want to proceed with that? [N/y]
y
[info] Replacing /etc/network/interfaces
[info] Restarting NetworkManager
[info] Install supervisor Docker container
请问楼主这是什么情况啊
sdvd
发表于 2020-12-1 15:02:57 | 显示全部楼层
感谢分享,学习一下
发表于 2020-12-3 10:48:10 | 显示全部楼层
楼主我这边遇到个问题,发在论坛上求助了,    如果您有时间,能帮忙看一眼吗。 再此谢过了。
https://bbs.hassbian.com/thread-11427-1-1.html 这是我在论坛内发的求助,谢谢您。
发表于 2020-12-5 15:08:26 | 显示全部楼层
求助:设备nanapi neo3 ,已经安装docker,更新:系统换Armbian_20.11_Nanopineo3_focal_current_5.9.10_minimal.img  跳过更换系统源+骑墙,顺利完成!感谢大佬
/etc/apt/sources.list/ 手动设置了
deb http://mirrors.ustc.edu.cn/debian stretch main contrib non-free
deb http://mirrors.ustc.edu.cn/debian stretch-updates main contrib non-free
deb http://mirrors.ustc.edu.cn/debian stretch-backports main contrib non-free
deb http://mirrors.ustc.edu.cn/debian-security/ stretch/updates main contrib non-free
(5).是否需要设置 hassio 数据保存路径(默认:/usr/share/hassio)
请输入 yes 或 no (默认:no):n
hassio 数据路径为默认路径: /usr/share/hassio
# 1. 是否将系统源切换为清华源: 否
# 2. 是否将用户添加至 Docker 用户组:   是,添加用户为 systemd-coredump
# 3. 是否将 Docker 源切换至国内源:     是,切换源选择:
# 4. 您的设备类型为:                   qemuarm-64
# 5. 您的 hassio 数据路径为:           /usr/share/hassio
请确认以上信息,继续请按任意键,如需修改请输入 Ctrl+C 结束任务重新执行脚本。
[info]: 跳过切换系统源。
[info]: 安装 hassio 必要依赖.....
Ign:1 http://mirrors.ustc.edu.cn/debian stretch InRelease
Hit:2 http://mirrors.ustc.edu.cn/debian stretch-updates InRelease
Hit:3 http://mirrors.ustc.edu.cn/debian stretch-backports InRelease
Hit:4 http://mirrors.ustc.edu.cn/debian-security stretch/updates InRelease
Hit:5 http://mirrors.ustc.edu.cn/debian stretch Release
Get:6 https://armbian.systemonachip.net/apt buster InRelease [18.3 kB]
Get:8 https://armbian.systemonachip.net/apt buster/main armhf Packages [592 kB]
Get:9 https://armbian.systemonachip.net/apt buster/main arm64 Packages [695 kB]
Get:13 https://armbian.systemonachip.net/apt buster/main armhf Contents (deb) [15.5 MB]
Get:14 https://armbian.systemonachip.net/apt buster/main arm64 Contents (deb) [10.4 MB]
Get:15 https://armbian.systemonachip.net/apt buster/buster-utils arm64 Packages [6,789 B]
Get:16 https://armbian.systemonachip.net/apt buster/buster-utils armhf Packages [6,801 B]
Get:17 https://armbian.systemonachip.net/apt buster/buster-utils arm64 Contents (deb) [8,531 B]
Get:18 https://armbian.systemonachip.net/apt buster/buster-utils armhf Contents (deb) [8,535 B]
Get:19 https://armbian.systemonachip.net/apt buster/buster-desktop armhf Contents (deb) [96.1 kB]
Fetched 27.4 MB in 48s (575 kB/s)
Reading package lists... Done
Building dependency tree
Reading state information... Done
4 packages can be upgraded. Run 'apt list --upgradable' to see them.
curl is already the newest version (7.64.0-4+deb10u1).
jq is already the newest version (1.5+dfsg-2+b1).
net-tools is already the newest version (1.60+git20180626.aebd88e-1).
network-manager is already the newest version (1.14.6-2+deb10u1).
qrencode is already the newest version (4.0.2-1).
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
apparmor : Depends: libapparmor-perl but it is not going to be installed
apparmor-utils : Depends: libapparmor-perl but it is not going to be installed
                  Depends: python3-apparmor (= 2.11.0-3+deb9u2) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Distributor ID: Debian
Description:    Debian GNU/Linux 10 (buster)
Release:        10
Codename:       buster
Linux version 5.9.10-rockchip64 (root@beast) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #20.11 SMP PREEMPT Mon Nov 23 13:36:07 CET 2020
Linux nanopineo3 5.9.10-rockchip64 #20.11 SMP PREEMPT Mon Nov 23 13:36:07 CET 2020 aarch64 GNU/Linux
发表于 2020-12-9 00:20:22 | 显示全部楼层
root@aml:~# ./install.sh
(1). 是否将系统源切换为清华源(目前支持 Debian Ubuntu Raspbian 三款系统)
请输入 y or n(默认 yes):y
(2). 在你系统内找到 systemd-coredump 用户,是否将其添加至 docker 用户组。
请输入 yes 或者 no (默认 yes):y
将systemd-coredump用户添加至 docker 用户组。
(3).是否需要替换 docker 默认源?
请输入 yes 或者 no(默认:yes):y
(4).请选择你设备类型(默认:qemux86)
    [1]: intel-nuc: 英特尔的nuc小主机
    [2]: odroid-c2: 韩国odroid-c2
    [3]: odroid-xu: 韩国odroid-xu
    [4]: orangepi-prime: 香橙派
    [5]: qemuarm: 通用arm设备(例如斐讯N1)
    [6]: qemux86: 通用X86(普通的PC机电脑)
    [7]: raspberrypi: 树莓派一代
    [8]: raspberrypi2: 树莓派二代
    [9]: raspberrypi3: 树莓派三代
    [10]: raspberrypi4: 树莓派四代
    [11]: tinker: 华硕tinker
输入数字 (1-11):5
你选择了 qemuarm
# 1. 是否将系统源切换为清华源: 是
[info]: 切换系统网络源.....
发现 armbian 源,替换清华源,如需要恢复请自行到 /etc/apt/sources.list.d/ 文件夹中删除后缀名 ".bak"
Hit:1 http://mirrors.tuna.tsinghua.edu.cn/debian buster InRelease
Hit:2 https://mirrors.aliyun.com/kubernetes/apt kubernetes-xenial InRelease
Hit:3 http://mirrors.tuna.tsinghua.edu.cn/debian buster-updates InRelease
Hit:4 http://mirrors.tuna.tsinghua.edu.cn/debian buster-backports InRelease
Hit:5 http://mirrors.tuna.tsinghua.edu.cn/debian-security buster/updates InRelease
Hit:6 http://mirrors.tuna.tsinghua.edu.cn/armbian buster InRelease
Hit:7 https://download.docker.com/linux/debian buster InRelease
Hit:1 https://mirrors.aliyun.com/kubernetes/apt kubernetes-xenial InRelease
Hit:2 http://mirrors.tuna.tsinghua.edu.cn/debian buster InRelease
apparmor is already the newest version (2.13.2-10).
apparmor-utils is already the newest version (2.13.2-10).
auditd is already the newest version (1:2.8.4-3).
avahi-daemon is already the newest version (0.7-4+b1).
socat is already the newest version (1.7.3.2-2).
The following packages were automatically installed and are no longer required:
  libltdl7 libnspr4 libnss3 runc tini
Use 'apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 4 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up auditd (1:2.8.4-3) ...
Job for auditd.service failed because the control process exited with error code.
See "systemctl status auditd.service" and "journalctl -xe" for details.
invoke-rc.d: initscript auditd, action "start" failed.
* auditd.service - Security Auditing Service
   Loaded: loaded (/lib/systemd/system/auditd.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Wed 2020-12-09 00:19:39 CST; 46ms ago
     Docs: man:auditd(8)
           https://github.com/linux-audit/audit-documentation
  Process: 26474 ExecStart=/sbin/auditd (code=exited, status=1/FAILURE)
Dec 09 00:19:39 aml systemd[1]: Starting Security Auditing Service...
Dec 09 00:19:39 aml auditd[26475]: Error - audit support not in kernel
Dec 09 00:19:39 aml auditd[26475]: Cannot open netlink audit socket
Dec 09 00:19:39 aml auditd[26475]: The audit daemon is exiting.
Dec 09 00:19:39 aml auditd[26474]: Cannot daemonize (Success)
Dec 09 00:19:39 aml auditd[26474]: The audit daemon is exiting.
Dec 09 00:19:39 aml systemd[1]: auditd.service: Control process exited, code=exited, status=1/FAILURE
Dec 09 00:19:39 aml systemd[1]: auditd.service: Failed with result 'exit-code'.
Dec 09 00:19:39 aml systemd[1]: Failed to start Security Auditing Service.
dpkg: error processing package auditd (--configure):
installed auditd package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
auditd
Release:        10
Codename:        buster
Linux version 5.3.8-aml-OC-BonusCloud (adou@ubuntu) (gcc version 7.4.1 20181213 [linaro-7.4-2019.02 revision 56ec6f6b99cc167ff0c2f8e1a2eed33b1edc85d4] (Linaro GCC 7.4-2019.02)) #6 SMP Mon Nov 11 18:32:45 PST 2019
Linux aml 5.3.8-aml-OC-BonusCloud #6 SMP Mon Nov 11 18:32:45 PST 2019 armv7l GNU/Linux
发表于 2020-12-10 10:33:43 | 显示全部楼层
请问出现了这种情况应如何处理呢?
[warn]
[warn]
[warn]
[warn] Docker is using json-file and not 'journald' as the logging driver, this is not supported.
y
Unit hassio-supervisor.service could not be found.
Distributor ID: Ubuntu
Description:    Ubuntu 18.04.5 LTS
Release:        18.04
Codename:       bionic
Linux version 5.4.0-42-generic (buildd@lgw01-amd64-019) (gcc version 7.5.0 (Ubuntu 7.5.0-3ubuntu1~18.04)) #46~18.04.1-Ubuntu SMP Fri Jul 10 07:09:27 UTC 2020
Linux tomhsh-Founder-PC 5.4.0-42-generic #46~18.04.1-Ubuntu SMP Fri Jul 10 07:09:27 UTC 2020 i686 i686 i686 GNU/Linux
安装 hassio 失败,请将上方安装信息发送到论坛询问。脚本退出...
发表于 2020-12-11 00:16:06 | 显示全部楼层
Description:        Ubuntu 14.04.6 LTS
Release:        14.04
Codename:        trusty
Linux version 3.13.0-170-generic (buildd@lcy01-amd64-001) (gcc version 4.8.4 (Ubuntu 4.8.4-2ubuntu1~14.04.4) ) #220-Ubuntu SMP Thu May 9 12:40:49 UTC 2019
Linux ubuntu 3.13.0-170-generic #220-Ubuntu SMP Thu May 9 12:40:49 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
\033[0;33m [ERROR]: 由于无法确定系统版本,故请手动切换系统源,切换方法参考清华源使用方法:http://mirrors.ustc.edu.cn/help/\033[0m
这应该怎么解决?
发表于 2020-12-12 03:38:40 | 显示全部楼层
楼主,求助,重启后打不开,系统全新安装(debian10.7),hassio只设置了登录,错误已标黄。root@debian-server:~# docker logs -f hassio_supervisor
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] udev.sh: executing...
[15:43:57] INFO: Update udev information
[cont-init.d] udev.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[15:43:58] INFO: Starting local supervisor watchdog...
20-12-13 15:43:58 INFO (MainThread) [__main__] Initializing Supervisor setup
20-12-13 15:43:58 INFO (MainThread) [supervisor.docker.network] Can't find Supervisor network, creating a new network
20-12-13 15:43:59 INFO (MainThread) [supervisor.bootstrap] Initializing Supervisor Sentry
20-12-13 15:43:59 WARNING (MainThread) [supervisor.utils.dt] Can't fetch freegeoip data: Cannot connect to host ip-api.com:80 ssl:default [       Connect call failed ('0.0.0.0', 80)]
20-12-13 15:43:59 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: qemux86-64
20-12-13 15:43:59 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor homeassistant/amd64-hassio-supervisor with ver       sion 2020.12.6
20-12-13 15:43:59 INFO (SyncWorker_0) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
20-12-13 15:43:59 INFO (SyncWorker_0) [supervisor.docker.interface] Cleanup images: ['homeassistant/qemux86-64-homeassistant:0.118.5', 'hom       eassistant/qemux86-64-homeassistant:latest']
20-12-13 15:44:01 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
20-12-13 15:44:01 WARNING (MainThread) [supervisor.resolution.evaluations.docker_configuration] Docker logging driver json-file is not supp       orted!
20-12-13 15:44:01 WARNING (MainThread) [supervisor.resolution.evaluations.base] The configuration of Docker is not supported (more-info: ht       tps://www.home-assistant.io/more-info/unsupported/docker_configuration)
20-12-13 15:44:01 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
20-12-13 15:44:01 INFO (MainThread) [__main__] Setting up Supervisor
20-12-13 15:44:01 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
20-12-13 15:44:07 WARNING (MainThread) [supervisor.dbus.rauc] Host has no rauc support. OTA updates have been disabled.
20-12-13 15:44:07 INFO (MainThread) [supervisor.host.info] Updating local host information
20-12-13 15:44:07 INFO (MainThread) [supervisor.host.services] Updating service information
20-12-13 15:44:07 INFO (MainThread) [supervisor.host.network] Updating local network information
20-12-13 15:44:07 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
20-12-13 15:44:07 INFO (MainThread) [supervisor.host] Host information reload completed
20-12-13 15:44:07 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
20-12-13 15:44:07 INFO (MainThread) [supervisor.host.services] Reloading local service hassio-apparmor.service
20-12-13 15:44:07 INFO (SyncWorker_0) [supervisor.docker.interface] Found homeassistant/amd64-hassio-dns versions: ['2020.12.6', 'latest']
20-12-13 15:44:07 INFO (MainThread) [supervisor.plugins.dns] No CoreDNS plugin Docker image homeassistant/amd64-hassio-dns found.
20-12-13 15:44:07 INFO (MainThread) [supervisor.plugins.dns] Running setup for CoreDNS plugin
20-12-13 15:44:07 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
20-12-13 15:44:08 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image homeassistant/amd64-hassio-dns with tag 2020.1       1.0.
20-12-13 15:44:18 INFO (MainThread) [supervisor.plugins.dns] CoreDNS plugin now installed
20-12-13 15:44:18 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
20-12-13 15:44:19 INFO (SyncWorker_0) [supervisor.docker.dns] Starting DNS homeassistant/amd64-hassio-dns with version 2020.11.0 - 172.30.3       2.3
20-12-13 15:44:19 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
20-12-13 15:44:19 INFO (SyncWorker_0) [supervisor.docker.interface] Found homeassistant/amd64-hassio-audio versions: ['2020.12.6', 'latest'       , '2020.11.0']
20-12-13 15:44:19 INFO (MainThread) [supervisor.plugins.audio] No Audio plugin Docker image homeassistant/amd64-hassio-audio found.
20-12-13 15:44:19 INFO (MainThread) [supervisor.plugins.audio] Setup Audio plugin
20-12-13 15:44:19 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image homeassistant/amd64-hassio-audio with tag 17.
20-12-13 15:44:51 INFO (MainThread) [supervisor.plugins.audio] Audio plugin now installed
20-12-13 15:44:51 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
20-12-13 15:44:51 INFO (SyncWorker_0) [supervisor.docker.audio] Starting Audio homeassistant/amd64-hassio-audio with version 17 - 172.30.32       .4
20-12-13 15:44:51 INFO (SyncWorker_0) [supervisor.docker.interface] Found homeassistant/amd64-hassio-cli versions: ['2020.12.6', 'latest',        '2020.11.0', '17']
20-12-13 15:44:51 INFO (MainThread) [supervisor.plugins.cli] No cli plugin Docker image homeassistant/amd64-hassio-cli found.
20-12-13 15:44:51 INFO (MainThread) [supervisor.plugins.cli] Running setup for CLI plugin
20-12-13 15:44:51 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image homeassistant/amd64-hassio-cli with tag 2020.1       1.1.
20-12-13 15:44:56 INFO (MainThread) [supervisor.plugins.cli] CLI plugin is now installed
20-12-13 15:44:56 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
20-12-13 15:44:57 INFO (SyncWorker_0) [supervisor.docker.cli] Starting CLI homeassistant/amd64-hassio-cli with version 2020.11.1 - 172.30.3       2.5
20-12-13 15:44:57 INFO (SyncWorker_0) [supervisor.docker.interface] Found homeassistant/amd64-hassio-observer versions: ['2020.12.6', 'late       st', '2020.11.1', '2020.11.0', '17']
20-12-13 15:44:57 INFO (MainThread) [supervisor.plugins.observer] No observer plugin Docker image homeassistant/amd64-hassio-observer found       .
20-12-13 15:44:57 INFO (MainThread) [supervisor.plugins.observer] Running setup for observer plugin
20-12-13 15:44:57 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image homeassistant/amd64-hassio-observer with tag 2       020.10.1.
20-12-13 15:45:01 INFO (MainThread) [supervisor.plugins.observer] observer plugin now installed
20-12-13 15:45:01 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin
20-12-13 15:45:02 INFO (SyncWorker_0) [supervisor.docker.observer] Starting Observer homeassistant/amd64-hassio-observer with version 2020.       10.1 - 172.30.32.6
20-12-13 15:45:02 INFO (SyncWorker_1) [supervisor.docker.interface] Found homeassistant/amd64-hassio-multicast versions: ['2020.12.6', 'lat       est', '2020.11.1', '2020.11.0', '2020.10.1', '17']
20-12-13 15:45:02 INFO (MainThread) [supervisor.plugins.multicast] No Multicast plugin Docker image homeassistant/amd64-hassio-multicast fo       und.
20-12-13 15:45:02 INFO (MainThread) [supervisor.plugins.multicast] Running setup for Multicast plugin
20-12-13 15:45:02 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image homeassistant/amd64-hassio-multicast with tag        3.
20-12-13 15:45:05 INFO (MainThread) [supervisor.plugins.multicast] Multicast plugin is now installed
20-12-13 15:45:06 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
20-12-13 15:45:06 INFO (SyncWorker_1) [supervisor.docker.multicast] Starting Multicast homeassistant/amd64-hassio-multicast with version 3        - Host
20-12-13 15:45:06 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
20-12-13 15:45:07 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
20-12-13 15:45:07 INFO (SyncWorker_0) [supervisor.docker.interface] Found homeassistant/qemux86-64-homeassistant versions: ['2020.12.6', 'l       atest', '2020.11.1', '2020.11.0', '2020.10.1', '3', '17']
20-12-13 15:45:07 INFO (MainThread) [supervisor.homeassistant.core] No Home Assistant Docker image homeassistant/qemux86-64-homeassistant f       ound.
20-12-13 15:45:07 INFO (MainThread) [supervisor.homeassistant.core] Setting up Home Assistant landingpage
20-12-13 15:45:07 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image homeassistant/qemux86-64-homeassistant with ta       g landingpage.
20-12-13 15:45:12 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
20-12-13 15:45:12 INFO (MainThread) [supervisor.homeassistant] Update pulse/client.config: /data/tmp/homeassistant_pulse
20-12-13 15:45:12 INFO (SyncWorker_0) [supervisor.docker.homeassistant] Starting Home Assistant homeassistant/qemux86-64-homeassistant with        version landingpage
20-12-13 15:45:12 INFO (MainThread) [supervisor.hassos] No Home Assistant Operating System found
20-12-13 15:45:12 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/hassio-addons/repository repository
20-12-13 15:45:12 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/home-assistant/addons repository
20-12-13 15:45:17 INFO (MainThread) [supervisor.store] Loading add-ons from store: 66 all - 66 new - 0 remove
20-12-13 15:45:17 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
20-12-13 15:45:17 INFO (MainThread) [supervisor.snapshots] Found 0 snapshot files
20-12-13 15:45:17 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
20-12-13 15:45:17 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
20-12-13 15:45:17 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
20-12-13 15:45:17 INFO (MainThread) [supervisor.resolution.check] System checks complete
20-12-13 15:45:17 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
20-12-13 15:45:18 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
20-12-13 15:45:18 INFO (MainThread) [__main__] Running Supervisor
20-12-13 15:45:18 WARNING (MainThread) [supervisor.core] System running in a unsupported environment!
20-12-13 15:45:18 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
20-12-13 15:45:18 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' starting 0 add-ons
20-12-13 15:45:18 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' starting 0 add-ons
20-12-13 15:45:18 INFO (MainThread) [supervisor.core] Skiping start of Home Assistant
20-12-13 15:45:18 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.APPLICATION' starting 0 add-ons
20-12-13 15:45:18 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
20-12-13 15:45:18 INFO (MainThread) [supervisor.misc.hwmon] Started Supervisor hardware monitor
20-12-13 15:45:18 INFO (MainThread) [supervisor.core] Supervisor is up and running
20-12-13 15:45:18 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
20-12-13 15:45:18 INFO (MainThread) [supervisor.host.info] Updating local host information
20-12-13 15:45:18 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image homeassistant/qemux86-64-homeassistant:landingpage to ho       meassistant/qemux86-64-homeassistant:0.118.5
20-12-13 15:45:18 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image homeassistant/qemux86-64-homeassistant with ta       g 0.118.5.
20-12-13 15:45:18 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
20-12-13 15:45:18 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
20-12-13 15:45:18 INFO (MainThread) [supervisor.host.services] Updating service information
20-12-13 15:45:18 INFO (MainThread) [supervisor.host.network] Updating local network information
20-12-13 15:45:18 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
20-12-13 15:45:18 INFO (MainThread) [supervisor.host] Host information reload completed
20-12-13 15:46:25 INFO (SyncWorker_1) [supervisor.docker.interface] Stopping homeassistant application
20-12-13 15:46:28 INFO (SyncWorker_1) [supervisor.docker.interface] Cleaning homeassistant application
20-12-13 15:46:28 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant docker now installed
20-12-13 15:46:28 INFO (MainThread) [supervisor.homeassistant.core] Starting Home Assistant
20-12-13 15:46:28 INFO (MainThread) [supervisor.homeassistant] Update pulse/client.config: /data/tmp/homeassistant_pulse
20-12-13 15:46:29 INFO (SyncWorker_2) [supervisor.docker.homeassistant] Starting Home Assistant homeassistant/qemux86-64-homeassistant with        version 0.118.5
20-12-13 15:46:29 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
20-12-13 15:46:34 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
20-12-13 15:46:34 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
20-12-13 15:46:34 INFO (SyncWorker_3) [supervisor.docker.interface] Cleanup images: ['homeassistant/amd64-hassio-supervisor:2020.12.6', 'ho       meassistant/amd64-hassio-supervisor:latest']
20-12-13 15:46:34 INFO (SyncWorker_3) [supervisor.docker.interface] Cleanup images: ['homeassistant/amd64-hassio-cli:2020.11.1']
20-12-13 15:46:34 INFO (SyncWorker_3) [supervisor.docker.interface] Cleanup images: ['homeassistant/qemux86-64-homeassistant:landingpage']
20-12-13 15:46:34 INFO (SyncWorker_3) [supervisor.docker.interface] Cleanup images: ['homeassistant/amd64-hassio-dns:2020.11.0']
20-12-13 15:46:34 INFO (SyncWorker_3) [supervisor.docker.interface] Cleanup images: ['homeassistant/amd64-hassio-observer:2020.10.1']
20-12-13 15:46:34 INFO (SyncWorker_3) [supervisor.docker.interface] Cleanup images: ['homeassistant/amd64-hassio-multicast:3']
20-12-13 15:46:34 INFO (SyncWorker_3) [supervisor.docker.interface] Cleanup images: ['homeassistant/amd64-hassio-audio:17']
20-12-13 15:48:35 INFO (SyncWorker_0) [supervisor.docker.interface] Stopping homeassistant application
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
20-12-13 15:48:44 INFO (MainThread) [supervisor.misc.scheduler] Shutting down scheduled tasks
20-12-13 15:48:44 INFO (MainThread) [supervisor.api] Stopping API on 172.30.32.2
20-12-13 15:48:44 INFO (MainThread) [supervisor.misc.hwmon] Stopped Supervisor hardware monitor
20-12-13 15:48:44 INFO (MainThread) [supervisor.core] Supervisor is down - 0
20-12-13 15:48:44 INFO (MainThread) [__main__] Closing Supervisor
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
GMT+8, 2025-12-15 12:50 , Processed in 0.060664 second(s), 10 queries , MemCached On.
