楼主: lse
基于斐讯K3硬件和HomeAssistant软件打造免费的智能家居
 火.. [复制链接]
发表于 2018-5-23 19:51:17 | 显示全部楼层
楼主,不知道是不是K3版本的区别,我这边剧好你说的固件,软件中心安装完后,显示K3的空间就只有20M了,所以完全无法用你的命令直接安装,不知道有没有直接安装到U盘的方法,望指导,网上查了好多liunx下的命令,都尝试失败。
发表于 2018-5-23 19:57:17 | 显示全部楼层
楼主,第四步就没有空间了咋办,其它插件都没装,复位重新安装也是这样,/root/.homeassistant/depss是空的
  File "/opt/lib/python3.6/site-packages/pip/basecommand.py", line 215, in main
    status = self.run(options, args)
  File "/opt/lib/python3.6/site-packages/pip/commands/install.py", line 342, in run
    prefix=options.prefix_path,
  File "/opt/lib/python3.6/site-packages/pip/req/req_set.py", line 784, in install
    **kwargs
  File "/opt/lib/python3.6/site-packages/pip/req/req_install.py", line 851, in install
    self.move_wheel_files(self.source_dir, root=root, prefix=prefix)
  File "/opt/lib/python3.6/site-packages/pip/req/req_install.py", line 1064, in move_wheel_files
    isolated=self.isolated,
  File "/opt/lib/python3.6/site-packages/pip/wheel.py", line 345, in move_wheel_files
    clobber(source, lib_dir, True)
  File "/opt/lib/python3.6/site-packages/pip/wheel.py", line 323, in clobber
    shutil.copyfile(srcfile, destfile)
  File "/shutil.py", line 122, in copyfile
OSError: [Errno 28] No space left on device
发表于 2018-5-23 20:25:02 | 显示全部楼层
不熟悉的还是不要用K3安装了. 麻烦的很,后面还是不知道有多少问题.
lse 手机认证
 楼主| 发表于 2018-5-24 13:50:36 | 显示全部楼层
宝剑航天涯 发表于 2018-5-23 19:57
楼主,第四步就没有空间了咋办,其它插件都没装,复位重新安装也是这样,/root/.homeassistant/depss是空的 ...
EMMC的空间确实不够用,
需要插个U盘,参考前面的帖子建立符号链接,
把内容安装到U盘上去。
发表于 2018-5-24 21:51:58 | 显示全部楼层
lse 发表于 2018-5-12 21:41
K3自身的EMMC空间剩余81MB,HomeAssistant是可以装下的,不过运行起来会略微紧张。
麻烦打听一下openVPN是怎么安装的?
发表于 2018-5-25 21:31:15 | 显示全部楼层
麻烦楼主帮我看下怎么解决,第4步都安装成功了,第5步出现了错误
2018-05-25 21:10:20 ERROR (MainThread) [homeassistant.setup] Error during setup of component frontend
  File "/opt/lib/python3.6/site-packages/homeassistant/setup.py", line 142, in _async_setup_component
    result = await component.async_setup(hass, processed_config)
  File "/opt/lib/python3.6/site-packages/homeassistant/components/frontend/__init__.py", line 327, in async_setup
    import hass_frontend
ModuleNotFoundError: No module named 'hass_frontend'
2018-05-25 21:10:20 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=persistent_no                                    tification, service=create, service_data=title=Invalid config, message=The following components and platforms could                                     not be set up:
- [frontend](https://home-assistant.io/components/frontend/)
Please check your config., notification_id=invalid_config, service_call_id=17980144-2>
2018-05-25 21:10:20 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=persisten                                    t_notification.invalid_config, old_state=None, new_state=<state persistent_notification.invalid_config=notifying; ti                                    tle=Invalid config, message=The following components and platforms could not be set up:
Please check your config. @ 2018-05-25T21:10:20.239222+08:00>>
2018-05-25 21:10:20 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=                                    17980144-2>
^CTraceback (most recent call last):
  File "/runpy.py", line 193, in _run_module_as_main
  File "/runpy.py", line 85, in _run_code
  File "/opt/lib/python3.6/site-packages/homeassistant/__main__.py", line 376, in <module>
    sys.exit(main())
  File "/opt/lib/python3.6/site-packages/homeassistant/__main__.py", line 368, in main
    exit_code = setup_and_run_hass(config_dir, args)
  File "/opt/lib/python3.6/site-packages/homeassistant/__main__.py", line 273, in setup_and_run_hass
    log_no_color=args.log_no_color)
  File "/opt/lib/python3.6/site-packages/homeassistant/bootstrap.py", line 179, in from_config_file
    log_rotate_days, log_file, log_no_color)
  File "/base_events.py", line 454, in run_until_complete
  File "/base_events.py", line 421, in run_forever
  File "/base_events.py", line 1390, in _run_once
  File "/selectors.py", line 445, in select
KeyboardInterrupt
^CException ignored in: <module 'threading' from '/opt/lib/python3.6/threading.pyc'>
  File "/threading.py", line 1294, in _shutdown
  File "/threading.py", line 1056, in join
  File "/threading.py", line 1072, in _wait_for_tstate_lock
KeyboardInterrupt
发表于 2018-5-25 21:31:27 | 显示全部楼层
R_X 发表于 2018-5-12 13:45
京东买售后好 叠加券返利 大概1700+能买到
转转1600能买到 找销量高信誉好的到时候都是返1999
联壁金融激 ...
哥,那个加速券怎么搞啊??是不是加速券,加速返现啊?12个月返现有的等了。另外,那个买k2p/m1是不是再激活k3就不需要返现了?求私信知道谢谢。
R_X
发表于 2018-5-25 22:57:56 | 显示全部楼层
yjb89 发表于 2018-5-25 21:31
哥,那个加速券怎么搞啊??是不是加速券,加速返现啊?12个月返现有的等了。另外,那个买k2p/m1是不是再 ...
加速券主要途径是连壁投资  还有其他方法 百度吧
k2p/m1是为了利用新用户资格  免投资
具体你百度查下攻略
发表于 2018-5-25 23:11:50 | 显示全部楼层
我装好了,添加了那个S30homeassistant,可是重启路由后又打不开了,怎么解决呢
发表于 2018-5-26 08:13:26 | 显示全部楼层
具体你百度查下攻 ...
谢谢哥啦
GMT+8, 2026-1-19 12:58 , Processed in 0.223833 second(s), 19 queries , MemCached On.
