楼主: riceball
自制开源ESPHome通用蓝牙网关(ESP32)
ljw 手机认证
发表于 2022-5-21 22:23:41 来自手机 | 显示全部楼层
riceball 发表于 2022-5-21 15:17
没有出现过这个问题, 看看是docker的问题,还是蓝牙适配器硬件的瓶颈: 无法持续扫描
ESP32就存在这样的硬 ...
我的是树莓派3b,可能也会有这样的问题了
活跃会员教程狂人卓越贡献
发表于 2022-5-27 14:07:21 | 显示全部楼层
这个可以添加小米筒灯等蓝牙mesh的设备嘛?
发表于 2022-6-19 10:55:20 | 显示全部楼层
烧录时报错了,请教下是什么问题
INFO Reading configuration /config/bluetooth-gateway.yaml...
WARNING The selected Arduino framework version is not the recommended one. If there are connectivity or build issues please remove the manual version.
INFO Generating C++ source...
INFO Compiling app...
Processing blegateway1 (board: esp32dev; framework: arduino; platform: https://github.com/tasmota/platform-espressif32/releases/download/v2.0.2.3/platform-espressif32-2.0.2.3.zip)
FILESYSTEM  spiffs
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
 - tool-mklittlefs 1.203.210628 (2.3)
 - tool-mkspiffs 2.230.0 (2.30)
 - toolchain-xtensa-esp32 8.4.0+2021r2-patch2
Dependency Graph
|-- <AsyncTCP-esphome> 1.2.2
|-- <WiFi> 2.0.0
|-- <FS> 2.0.0
|-- <Update> 2.0.0
|-- <ESPAsyncWebServer-esphome> 2.1.0
|-- <DNSServer> 2.0.0
|-- <ESPmDNS> 2.0.0
Compiling .pioenvs/blegateway1/src/esphome/components/ble_gateway/ble_gateway.cpp.o
Compiling .pioenvs/blegateway1/src/esphome/components/esp32/gpio_idf.cpp.o
Compiling .pioenvs/blegateway1/src/esphome/components/esp32/preferences.cpp.o
Compiling .pioenvs/blegateway1/src/esphome/components/esp32_ble_tracker/esp32_ble_tracker.cpp.o
Compiling .pioenvs/blegateway1/src/esphome/components/homeassistant/binary_sensor/homeassistant_binary_sensor.cpp.o
src/esphome/components/ble_gateway/ble_gateway.cpp: In member function 'virtual bool esphome::ble_gateway::BLEGateway::parse_device(const esphome::esp32_ble_tracker::ESPBTDevice&)':
src/esphome/components/ble_gateway/ble_gateway.cpp:62:56: error: 'const class esphome::esp32_ble_tracker::ESPBTDevice' has no member named 'get_scan_result'
     auto packet = scan_result_to_hci_packet_hex(device.get_scan_result());
*** [.pioenvs/blegateway1/src/esphome/components/ble_gateway/ble_gateway.cpp.o] Error 1
========================= [FAILED] Took 10.87 seconds =========================
 楼主| 发表于 2022-6-19 21:22:23 | 显示全部楼层
怪物json 发表于 2022-6-19 10:55
烧录时报错了,请教下是什么问题
该配置文件是仅限 ESP32-C3 主板, 如果是ESP32主板 要修改: 移除所有的特有的配置,
发表于 2022-6-25 23:25:34 | 显示全部楼层
必须收藏
发表于 2022-6-29 08:49:15 | 显示全部楼层
要先安装好ble_monitor,再进行configuration.yaml配置,否则会装不上
发表于 2022-7-3 23:43:38 | 显示全部楼层
想问一下 esp32已经接入Hass了  但是Hass主机没有蓝牙也没有蓝牙适配器的,怎么将温湿度计通过esp32接入,温湿度计已经刷了ATC固件,esp32也能扫到它的mac,但是Hass发现不了温湿度计
 楼主| 发表于 2022-7-4 13:04:16 | 显示全部楼层
kkkkllll08 发表于 2022-7-3 23:43
想问一下 esp32已经接入Hass了  但是Hass主机没有蓝牙也没有蓝牙适配器的,怎么将温湿度计通过esp32接入, ...
看文档仔细些:     "配置好蓝牙网关后, 如果要添加新的蓝牙设备请在Passive BLE Monitor 集成上添加."
发表于 2022-7-4 23:34:03 | 显示全部楼层
你好,这个能在windows下刷入吗?楼主能给个视频教程吗
发表于 2022-7-5 21:05:31 | 显示全部楼层
ESP32就存在这样的硬 ...
连接wifi困难,是否有建议的scan_parameters参数值
GMT+8, 2026-1-14 09:32 , Processed in 1.707575 second(s), 11 queries , MemCached On.
