楼主: riceball
自制开源ESPHome通用蓝牙网关(ESP32)
发表于 2024-8-6 15:27:46 | 显示全部楼层
rolay8 发表于 2024-5-15 23:02
大佬,请问下,日志扫描到设备了,但是ble monitor下面还是空的
15:01:08][C][wifi:416]:   IP Address: 10 ...
我也是,老版本还可以用,home assistant重装了以后就找不到不到设备了
发表于 2024-12-2 22:49:58 | 显示全部楼层
我在win平台上编译,出现错误,不知道为什么,不知道有人遇到过么。。
src/esphome/components/logger/logger_esp32.cpp: In member function 'void esphome::logger::Logger::pre_setup()':
src/esphome/components/logger/logger_esp32.cpp:123:29: error: 'Serial' was not declared in this scope
         this->hw_serial_ = &Serial;
src/esphome/components/logger/logger_esp32.cpp:123:29: note: suggested alternative: 'Serial1'
                             Serial1
Compiling .pioenvs\blegateway1\src\esphome\components\mdns\mdns_rp2040.cpp.o
src/esphome/components/logger/logger.cpp: In member function 'virtual void esphome::logger::Logger::loop()':
src/esphome/components/logger/logger.cpp:158:17: error: 'Serial' was not declared in this scope
   if (opened == Serial) {
src/esphome/components/logger/logger.cpp:158:17: note: suggested alternative: 'Serial1'
                 Serial1
*** [.pioenvs\blegateway1\src\esphome\components\logger\logger_esp32.cpp.o] Error 1
*** [.pioenvs\blegateway1\src\esphome\components\logger\logger.cpp.o] Error 1
========================= [FAILED] Took 20.60 seconds =========================
发表于 2024-12-26 12:51:07 | 显示全部楼层
执行“esphome compile xxx.yaml”报错:"UnknownPackageError: Could not find the package with 'espressif/toolchain-riscv32-esp @ 8.4.0+2021r2-patch3' requirements for your system 'linux_x86_64'"
解决办法:修改 xxx.yaml中“platform_version: 5.1.1” -》“platform_version: 5.3.0”
发表于 2025-6-14 16:41:06 | 显示全部楼层
接入ha后树莓派自己的蓝牙适配器出了一堆错误,请问应该怎么解决呢
日志记录器: bluetooth_auto_recovery.recover
来源: runner.py:154
首次出现: 16:25:11 (35 次出现)
上次记录: 16:37:16
Could not reset the power state of the Bluetooth adapter hci0 [DC:A6:XX:XX:XX:XX] (0) due to timeout after 5 seconds
Could not cycle the Bluetooth adapter hci0 [DC:A6:XX:XX:XX:XX] (0): [Errno 1] Operation not permitted
Bluetooth management socket connection lost: [Errno 22] Invalid argument
Closing Bluetooth adapter hci0 [DC:A6:XX:XX:XX:XX] failed: [Errno 9] Bad file descriptor
日志记录器: habluetooth.scanner
来源: runner.py:154
首次出现: 16:23:06 (8 次出现)
上次记录: 16:37:06
hci0 (DC:A6:XX:XX:XX:XX): Error stopping scanner: [org.bluez.Error.InProgress] Operation already in progress
发表于 2025-10-12 09:34:35 | 显示全部楼层
学习学习
 楼主| 发表于 2025-10-15 20:57:33 | 显示全部楼层
日志记录器: bluetooth_auto_recovery.r ...
似乎是权限不足
发表于 2025-12-26 06:53:04 | 显示全部楼层
GMT+8, 2026-1-14 09:33 , Processed in 0.056903 second(s), 10 queries , MemCached On.
