查看: 68016|回复: 106
自制开源ESPHome通用蓝牙网关(ESP32)
楼主
发表于 2022-5-6 21:22:35 | 只看该作者 |倒序浏览 |阅读模式
该蓝牙通用网关与https%3A//github.com/custom-components/ble_monitor">Passive BLE Monitor 集成搭配使用.
从而解决因为蓝牙穿墙能力弱导致蓝牙信号无法穿墙的问题,蓝牙通用网关的主要用途有:
  1. 蓝牙信号过不来的就走开源ESPHome通用蓝牙网关,通过wifi信号再到HA上的 https%3A//github.com/custom-components/ble_monitor">Passive BLE Monitor 集成.
  2. 接入只支持Active BLE connection的蓝牙设备
关于蓝牙设备的相关介绍,请参阅: HA智能硬件采购避坑指要(三) 蓝牙篇
硬件很简单,你只需要自备ESP32的主板一枚,建议最好选4M Flash的, 虽然2M的也能刷,但是稍微麻烦些(而且因为闪存小无法支持OTA了). 我选的是ESP-C3-32S(4M)的开发板. 可在某陶上搜索"ESP-C3-32S-Kit"记得问清楚是否4M(2M和4M只差几毛钱).
ESP32-C3是Espressif新出的RISC-V 32位单核处理器(160MHz)支持蓝牙5.0(BLE支持),以前的ESP32是基于蓝牙4.2.
然后准备好ESPHome开发环境,请升级到ESPHome的最新版(至少2022.1版本以后),请不要在arm环境下开发,因为Espressif目前还不支持ESP-C3在arm下的编译.
在Linux环境下安装使用很简单:
sudo apt -y install python3 python3-pip python3-pip-whl
sudo -H pip3 install --upgrade pip
pip3 install --user esphome
# To set this permanently, you can run echo 'export PATH=$PATHHOME/.local/bin' >> $HOME/.bashrc
# You may need to logout and back in for the new group to take effect.
sudo usermod -a -G dialout $USER
好了,刷机的YAMLbluetooth-gateway.yaml配置如下(如果板子不是ESP32-C3请自行调整board参数),记得在相同目录下的secrets.yaml文件中填好参数:
substitutions:
  # Name the device and it's entities
  device: ble_gateway
  device_name: blegateway1
esphome:
  comment: $device
  platformio_options:
    board_build.flash_mode: dio
esp32:
  board: esp32-c3-devkitm-1
  variant: esp32c3
  framework:
    type: arduino
    version: 2.0.2
    platform_version: https://github.com/tasmota/platf ... essif32-2.0.2.3.zip
external_components:
  - source: github://myhomeiot/esphome-components
esp32_ble_tracker:
# Enable logging
logger:
# Enable Home Assistant API
api:
  reboot_timeout: 1h
ota:
  password: !secret ota_password
wifi:
  ssid: !secret wifi_ssid
  # Enable fallback hotspot in case wifi connection fails
  ap:
    ssid: "$device_name Fallback Hotspot"
    password: !secret ap_password
ble_gateway:
  # devices:
  #   - mac_address: 01:23:45:67:89:AB
  #   - mac_address: !secret lywsd03mmc_mac
  on_ble_advertise:
    then:
      - homeassistant.service:
          service: ble_monitor.parse_data
          data:
            packet: !lambda return packet;
            gateway_id: $device_name
      - homeassistant.event:
          event: esphome.on_ble_advertise
          data:
binary_sensor:
  - platform: homeassistant
    entity_id: binary_sensor.ble_gateway
    attribute: discovery
    on_state:
      then:
        lambda: id($device_name).set_discovery(x);
text_sensor:
    attribute: devices
    on_value:
      then:
        lambda: id($device_name).set_devices(x);
  # IP address of device. Not really needed for HA (as HA already knows it), but for showing on the display during startup. The startup screen will leave on if no instance connects to the API.
  - platform: wifi_info
    ip_address:
      name: $device_name IP address
  # ESPHome version used to compile the app
  - platform: version
    name: $device_name ESPHome Version
  # WiFi signals strength sensor
  - platform: wifi_signal
    name: $device_name WiFi Signal Sensor
    update_interval: 60s
USB插上ESP32开发板,看清楚串口号(ls /dev/tty*),一般是/dev/ttyUSB0,然后执行如下语句编译烧录固件:
# choose the port after compiling
esphome run bluetooth-gateway.yaml
至此,通用蓝牙网关的硬件烧录部分完成.
接着,还要在HA上配置与https%3A//github.com/custom-components/ble_monitor">Passive BLE Monitor 集成的搭配部分.
修改HA configuration.yaml文件:
input_boolean:
  ha_started:
    initial: false
  settings_ble_gateway:
    icon: mdi:bluetooth
  settings_ble_gateway_discovery:
    name: BLE Gateway Discovery
    icon: mdi:bluetooth-connect
input_text:
  settings_ble_gateway_add_device:
    name: BLE Gateway Add Device
    initial: ''
template:
  - binary_sensor:
      - name: BLE Gateway Add Device
        state: "{{ (state_attr('binary_sensor.ble_gateway_add_device', 'mac_address')) }}"
        availability: "{{ is_state('input_boolean.ha_started', 'on') }}"
        attributes:
          mac_address: "{{ states('input_text.settings_ble_gateway_add_device') | replace(':', '') | trim }}"
  - binary_sensor:
      - name: BLE Gateway
        icon: mdi:bluetooth
        state: "{{ is_state('input_boolean.settings_ble_gateway', 'on') }}"
        attributes:
          discovery: "{{ is_state('input_boolean.settings_ble_gateway_discovery', 'on') }}"
          devices: "{{ states | selectattr('entity_id', 'search', '^(device_tracker||(binary_)?sensor).ble_') | selectattr('attributes.mac_address', 'defined') | map(attribute='attributes.mac_address') | unique | sort | join('') | replace(':', '') if is_state('binary_sensor.ble_gateway', 'on') }}"
然后修改automations.yaml文件:
- alias: HA Start automation
  initial_state: true
  trigger:
    event: start
  action:
    service: input_boolean.turn_on
    entity_id: input_boolean.ha_started
重启HA即可. 对了记得把刚刚新鲜出炉的蓝牙网关加入进来.
然后该蓝牙网关就会自动转发已发现的并且在https%3A//github.com/custom-components/ble_monitor">Passive BLE Monitor 集成中设备.
如果要添加新的蓝牙设备请在https%3A//github.com/custom-components/ble_monitor">Passive BLE Monitor 集成上添加.
如果想只针对个别设备在指定的蓝牙网关上转发,那么请使用input_text.settings_ble_gateway_add_device添加该设备的MAC地址.
蓝牙网关接收到已注册设备的广播后会同时触发事件esphome.on_ble_advertise发送原始数据.
最后,记得设置input_boolean.settings_ble_gateway为"on",启用蓝牙网关功能.
设置input_boolean.settings_ble_gateway_discovery为"on",启用自动发现功能.
ESPHome 蓝牙网关的日志查看:
  1. 在 PC 上通过直接连接的USB:  esphome logs bluegateway.yaml --device /dev/ttyUSB0
  2. PC 远程查看: esphome logs bluegateway.yaml 选择远程
  3. HA上远程查看: 启用 ESPHome addon, 建一个同名的空配置,点 LOGS .
版本更新
2022-5-9: [Bug] esp-idf 下无法更改 scan_parameters, 使用 Arduino framework now.
2022-5-21: [feat] 新增 启用自动发现开关
参与人数 6金钱 +55 HASS币 +20 收起 理由
czjys + 2 感谢楼主分享!
eric + 8 感谢楼主分享!
sorrypqa + 5 高手,这是高手!
+ 20 + 20 高手,这是高手!
liwei19920307 + 10
dscao + 10 感谢楼主分享!
沙发
发表于 2022-5-6 23:09:33 | 只看该作者
感谢LZ分享
ESP C3的开发板建议慎选,C3是单核RISC-V方案,优势是支持蓝牙5.0,价格更便宜,但是跟之前的ESP32的双核Xtensa还是差别比较大的,包括ESPHOME目前对它的支持还处于in development状态,我自己在编译的过程中遇到过奇奇怪怪的小坑。个人觉得,多花几块钱买普通的ESP32对新手更友好
板凳
 楼主| 发表于 2022-5-7 06:10:07 | 只看该作者
hellkun 发表于 2022-5-6 23:09
感谢LZ分享
ESP C3的开发板建议慎选,C3是单核RISC-V方案,优势是支持蓝牙5.0,价格更便宜,但是跟之前的E ...
既然是用途作为蓝牙网关,当然要选蓝牙5,向下兼容的。
在PC上编译,没问题的,不过一定要记得升级esphome到最新版
地板
发表于 2022-5-7 09:54:41 | 只看该作者
感谢分享 C3确实很好 我很多项目都用的C3 这个项目拓展了蓝牙功能 很棒
5#
 楼主| 发表于 2022-5-7 10:03:34 | 只看该作者
忘记写了,最后要记得设置`input_boolean.settings_ble_gateway`为"on",启用蓝牙网关功能.
发表于 2022-5-7 10:55:58 | 只看该作者
有没购买链接啊,私发我一下吧,怕买错了
智能家居&单板滑雪痴迷爱好者
7#
发表于 2022-5-7 11:37:46 来自手机 | 只看该作者
这个称为“蓝牙网关”不太准确吧?更接近于蓝牙中继器的概念。另外,ble_monitor虽然不错但也有明显的缺点。其实esphome本身已经可以实现很不错的蓝牙网关功能,使用上也更简单。加上自己撸的代码,扩展性也够了。我自己在用的就是花花草草、蓝牙温湿度(内置组件)、体脂秤、燃气灶、门锁、yeelight调光开关(自定义组件)一块esp32搞定
8#
发表于 2022-5-7 13:10:04 | 只看该作者
XCray 发表于 2022-5-7 11:37
这个称为“蓝牙网关”不太准确吧?更接近于蓝牙中继器的概念。另外,ble_monitor虽然不错但也有明显的缺点 ...
X大白嫖一下体脂称+蓝牙温湿度可否?
发表于 2022-5-7 13:42:48 | 只看该作者
esp32蓝牙距离有多远
10#
 楼主| 发表于 2022-5-7 13:47:00 | 只看该作者
1. 是的主要是能中继, 不过也可以说网关: HA上可以不用插蓝牙适配器, 就可以通过这货接入蓝牙设备.
2. ble_monitor 集成的缺陷在哪里? 还请多多指教.
3. 如果有更通用的方式,那自是更好
4. 如果能搞定蓝牙发送指令,未来就是蓝牙的,价格决定一切
GMT+8, 2026-8-20 04:57 , Processed in 0.017824 second(s), 4 queries , Redis On.
