楼主: zsqduke
[快速入门] 2021年最新N1安装HA Supervised教程(官方支持版本)
发表于 2021-12-9 20:47:58 | 显示全部楼层
下载速度太慢怎么办啊?
发表于 2021-12-10 14:58:33 | 显示全部楼层
这个,系统写入emmc,HA装在U盘可以的吗??
 楼主| 发表于 2021-12-10 16:21:13 | 显示全部楼层
不可以zsbd
发表于 2021-12-10 16:53:03 | 显示全部楼层
请问楼主这个如何复制系统到emmc?我扩容了n1的emmc,足够运行
 楼主| 发表于 2021-12-10 20:31:21 来自手机 | 显示全部楼层
我也没试过。如果我是你的话我会可以参考一下网上其他教程里面那个命令
发表于 2021-12-10 20:39:52 | 显示全部楼层
zsqduke 发表于 2021-12-10 20:31
我也没试过。如果我是你的话我会可以参考一下网上其他教程里面那个命令 ...
在你的哪一步就可以先复制到emmc了,设置完账号密码是不是就可以先复制了
发表于 2021-12-10 20:41:05 | 显示全部楼层
root@arm-64:~# dpkg -i homeassistant-supervised.deb
Selecting previously unselected package homeassistant-supervised.
(Reading database ... 34724 files and directories currently installed.)
Preparing to unpack homeassistant-supervised.deb ...
[warn]
[warn] If you want more control over your own system, run
[warn] Home Assistant as a VM or run Home Assistant Core
[warn] via a Docker container.
[warn]
Adding 'diversion of /etc/NetworkManager/NetworkManager.conf to /etc/NetworkManager/NetworkManager.conf.real by homeassistant-supervised'
Adding 'diversion of /etc/NetworkManager/system-connections/default to /etc/NetworkManager/system-connections/default.real by homeassistant-supervised'
Adding 'diversion of /etc/docker/daemon.json to /etc/docker/daemon.json.real by homeassistant-supervised'
Adding 'diversion of /etc/network/interfaces to /etc/network/interfaces.real by homeassistant-supervised'
Unpacking homeassistant-supervised (1.0.2) ...
dpkg: dependency problems prevent configuration of homeassistant-supervised:
homeassistant-supervised depends on docker-ce; however:
  Package docker-ce is not installed.
homeassistant-supervised depends on apparmor; however:
  Package apparmor is not installed.
homeassistant-supervised depends on os-agent; however:
  Package os-agent is not configured yet.
dpkg: error processing package homeassistant-supervised (--install):
dependency problems - leaving unconfigured
Errors were encountered while processing:
最后一步执行完就这样了。
发表于 2021-12-11 13:16:25 | 显示全部楼层
有成功的吗?最后的代码是 If you want more control over your own system, run
翻译完是
如果您想要对自己的系统进行更多控制,请运行
家庭助理作为虚拟机或运行家庭助理核心
通过Docker容器。
发表于 2021-12-11 15:17:05 | 显示全部楼层
发表于 2021-12-11 15:35:04 | 显示全部楼层
mccding 发表于 2021-12-6 20:50
楼主大大 有个问题第一步就卡到了 写完盘 修改好文件启动就卡在starting kernel
你解决这个问题了吗?我也碰到这样了。。。
GMT+8, 2026-1-8 15:04 , Processed in 1.581691 second(s), 13 queries , MemCached On.
