楼主: zsqduke
[快速入门] 2021年最新N1安装HA Supervised教程(官方支持版本)
 楼主| 发表于 2021-11-17 16:46:20 | 显示全部楼层
lai95588 发表于 2021-11-17 09:37
楼主,python3的版本多少,做了升级吗?
没有注意。不需要单独升级
yuri
发表于 2021-11-17 21:44:02 | 显示全部楼层
感谢 前两天刚装了  有个问题就是 装完之后所剩空间太少了 过几天就满了  怎么清理日志文件啊
 楼主| 发表于 2021-11-17 22:04:13 | 显示全部楼层
yuri 发表于 2021-11-17 21:44
感谢 前两天刚装了  有个问题就是 装完之后所剩空间太少了 过几天就满了  怎么清理日志文件啊 ...
清理日志也不是长久之计。还是弄个16G u盘跑吧
发表于 2021-11-18 11:31:27 | 显示全部楼层
yuanchg 发表于 2021-11-1 17:29
这个好这个好,我装的就没有商店那个,只是家里只有这个才有上网环境,不然没办法科学呀 ...
想工网 你就得穿透了。
发表于 2021-11-18 11:32:40 | 显示全部楼层
感谢分享,目前我还是docker版本的。自我感觉够用。
发表于 2021-11-18 11:57:58 | 显示全部楼层
更新成国内源应该也是可以吧
发表于 2021-11-18 12:12:09 来自手机 | 显示全部楼层
感谢无私分享
发表于 2021-11-18 14:21:20 | 显示全部楼层
skasoka 发表于 2021-11-6 17:56
你用的是楼主提供的固件吗?
不是,用的不带桌面的
发表于 2021-11-20 16:50:19 | 显示全部楼层
root@Armbian-N1:~# apt remove homeassistant-supervised
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
The following packages will be REMOVED:
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database ... 36387 files and directories currently installed.)
Removing homeassistant-supervised (1.0.2) ...
[info] Undo divert on remove
Removing 'diversion of /etc/NetworkManager/NetworkManager.conf to /etc/NetworkManager/NetworkManager.conf.real by homeassistant-supervised'
Removing 'diversion of /etc/NetworkManager/system-connections/default to /etc/NetworkManager/system-connections/default.real by homeassistant-supervised'
Removing 'diversion of /etc/docker/daemon.json to /etc/docker/daemon.json.real by homeassistant-supervised'
Removing 'diversion of /etc/network/interfaces to /etc/network/interfaces.real by homeassistant-supervised'
root@Armbian-N1:~# dpkg -i homeassistant-supervised.deb
Selecting previously unselected package homeassistant-supervised.
(Reading database ... 36373 files and directories currently installed.)
Preparing to unpack homeassistant-supervised.deb ...
[warn]
[warn] If you want more control over your own system, run
[warn] Home Assistant as a VM or run Home Assistant Core
[warn] via a Docker container.
[warn]
Adding 'diversion of /etc/NetworkManager/NetworkManager.conf to /etc/NetworkManager/NetworkManager.conf.real by homeassistant-supervised'
Adding 'diversion of /etc/NetworkManager/system-connections/default to /etc/NetworkManager/system-connections/default.real by homeassistant-supervised'
Adding 'diversion of /etc/docker/daemon.json to /etc/docker/daemon.json.real by homeassistant-supervised'
Adding 'diversion of /etc/network/interfaces to /etc/network/interfaces.real by homeassistant-supervised'
Unpacking homeassistant-supervised (1.0.2) ...
Setting up homeassistant-supervised (1.0.2) ...
[info] Restarting NetworkManager
[info] Restarting docker service
PING version.home-assistant.io (172.67.68.90) 56(84) bytes of data.
64 bytes from 172.67.68.90 (172.67.68.90): icmp_seq=1 ttl=54 time=77.5 ms
--- version.home-assistant.io ping statistics ---
1 packets transmitted, 1 received, 0% packet loss, time 0ms
rtt min/avg/max/mdev = 77.472/77.472/77.472/0.000 ms
[info] Install supervisor Docker container
Error response from daemon: Get "https://registry-1.docker.io/v2/homeassistant/aarch64-hassio-supervisor/manifests/sha256:a97e123edd9edaed02bc0fe024aed810c971632e8bb58158e077a2bea7fb2959": EOF
dpkg: error processing package homeassistant-supervised (--install):
installed homeassistant-supervised package post-installation script subprocess returned errorexit status 1
Errors were encountered while processing:
出现这种错误怎么解决?
发表于 2021-11-23 19:17:57 | 显示全部楼层
请教下这样用U盘来长期使用的话稳定不?
GMT+8, 2026-1-7 11:40 , Processed in 0.102680 second(s), 11 queries , MemCached On.
