楼主: involute
[插件集成] 晚来的饭,接近产品品质的魅族遥控器软硬件解决方案
 楼主| 发表于 2021-9-9 20:58:36 | 显示全部楼层
liqx 发表于 2021-9-9 19:07
service: meizu_remoter_gateway.bind_threshold
data:
  serial_no: 1B32A94
看你楼下的图片就知道了
发表于 2021-9-9 22:18:54 | 显示全部楼层
involute 发表于 2021-9-9 15:22
看一下顶楼及2楼的9月9日更新,增加了一个调整绑定信号阈值的服务,调整一下阈值看看,默认是-30dBm,可 ...
谢谢 终于可以了
[22:16:58]I (1757428) Kernel: Bind RSSI threshold set to -38
[22:17:13]I (1771788) GATTDevice: Start binding mode
[22:17:13]I (1771788) GATTDevice: BLE devices scanning
[22:17:13]I (1771788) Kernel: Binding mode started
[22:17:22]I (1781378) GATTDevice: Nearly device found - 魅族遥控器
[22:17:22]I (1781388) GATTDevice: Nearly device found - Noname device
[22:17:22]I (1781388) Kernel: Found a new device at 68:3e:34:cc:e1:4, prepare to pairing
[22:17:22]I (1781408) Kernel: Saved 2 addres to nvs storage total 12 bytes
[22:17:22]I (1781408) MEIZURemoter: Begin update device at 68:3e:34:cc:e1:4
[22:17:22]I (1781418) Kernel: Binding mode stoped
[22:17:26]I (1785238) MEIZURemoter: Device at 68:3e:34:cc:e1:4 was updated
[22:17:26]I (1785238) Kernel: successful to update device at 68:3e:34:cc:e1:4: {"manufacturer":"Meizu","model":"R16","fireware":"v_3.0.10.23","temperature":31.29,"humidity":70.46,"battery":100,"voltage":3.0,"rssi":-44}
[22:17:42]I (1801188) MEIZURemoter: Begin update device at 68:3e:34:cc:e1:4
[22:17:44]I (1802688) MEIZURemoter: Device at 68:3e:34:cc:e1:4 was updated
[22:17:44]I (1802688) Kernel: successful to update device at 68:3e:34:cc:e1:4: {"manufacturer":"Meizu","model":"R16","fireware":"v_3.0.10.23","temperature":31.25,"humidity":72.30,"battery":100,"voltage":3.0,"rssi":-56}
[22:17:44]I (1802708) MEIZURemoter: Begin update device at 68:3e:34:cc:dc:64
[22:17:46]I (1805458) MEIZURemoter: Device at 68:3e:34:cc:dc:64 was updated
[22:17:46]I (1805458) Kernel: successful to update device at 68:3e:34:cc:dc:64: {"manufacturer":"Meizu","model":"R16","fireware":"v_3.0.10.23","temperature":30.63,"humidity":71.07,"battery":100,"voltage":3.0,"rssi":-85}
 楼主| 发表于 2021-9-9 23:48:08 | 显示全部楼层
data:
  serial_no: 1B32A94
送佛送到西,我还是给你说清楚一点吧,相关参数换成你自己的。
 楼主| 发表于 2021-9-9 23:56:19 | 显示全部楼层
恭喜,-85那个要注意了,太远了有点。已经在失联边缘,如果连续更新失败5次,就会停止更新这个设备,得拿回来重新配对了。
liqx
发表于 2021-9-10 06:33:06 | 显示全部楼层
involute 发表于 2021-9-9 20:58
看你楼下的图片就知道了
谢谢,这回知道了
终于成功了,谢谢大佬。
不知道能否在网关中添加已配对设备查询功能。
 楼主| 发表于 2021-9-10 13:00:50 | 显示全部楼层
liqx 发表于 2021-9-10 06:33
谢谢,这回知道了
终于成功了,谢谢大佬。
出现在HA中的就是已配对的,不用再额外查询了吧。
847 手机认证
发表于 2021-9-10 15:33:09 来自手机 | 显示全部楼层
大佬你好  我在淘宝买的esp32-C3-S32刷入后无法启动,ttl一直提示boot  wrong chip     请问是不是开发版买错了
智能家居&单板滑雪痴迷爱好者
发表于 2021-9-10 16:49:51 | 显示全部楼层
i神,esp32固件不打算开源么?
 楼主| 发表于 2021-9-10 20:20:04 | 显示全部楼层
847 发表于 2021-9-10 15:33
大佬你好  我在淘宝买的esp32-C3-S32刷入后无法启动,ttl一直提示boot  wrong chip     请问是不是开发版买 ...
没用过这块开发板,不知特性如何。据我所知ESP32-C系列芯片都是单核的,可能是与这个固件不兼容。
 楼主| 发表于 2021-9-10 20:25:26 | 显示全部楼层
XCray 发表于 2021-9-10 16:49
i神,esp32固件不打算开源么?
有开源打算,目前还在整理代码。
GMT+8, 2025-12-22 13:54 , Processed in 1.552096 second(s), 10 queries , MemCached On.
