楼主: involute
[插件集成] 晚来的饭,接近产品品质的魅族遥控器软硬件解决方案
 楼主| 发表于 2021-9-5 22:06:50 | 显示全部楼层
hncdbai 发表于 2021-9-5 21:53
目前连接了4个,感谢大神。
发现一个问题,HA重启后有一定机率连接不上网关。  网关断电再插也不管用。 ...
集成和固件用的0.3.0的版本?HA是什么版本?
发表于 2021-9-5 22:12:46 | 显示全部楼层
集成和固件用的0.3.0的版本。Home Assistant 2021.9.3
Using 'COM4' as serial port.
Showing logs:
[21:57:16]I (184460) SocketServer: The client at 192.168.123.7:55294 is disconnected
[21:59:12]I (301280) MEIZURemoter: Begin update device at 68:3e:34:cc:de:1b
[21:59:15]I (304030) MEIZURemoter: Device at 68:3e:34:cc:de:1b was updated
[21:59:15]I (304030) Kernel: successful to update device at 68:3e:34:cc:de:1b: {"manufacturer":"Meizu","model":"R16","fireware":"v_3.0.10.23","temperature":34.71,"humidity":59.39,"battery":100,"voltage":3.0,"rssi":-48}
[21:59:15]I (304040) MEIZURemoter: Begin update device at 68:3e:34:cc:d8:9b
[21:59:22]I (310440) MEIZURemoter: Device at 68:3e:34:cc:d8:9b was updated
[21:59:22]I (310440) Kernel: successful to update device at 68:3e:34:cc:d8:9b: {"manufacturer":"Meizu","model":"R16","fireware":"v_3.0.10.23","temperature":29.98,"humidity":71.65,"battery":90,"voltage":2.9,"rssi":-82}
[21:59:22]I (310450) MEIZURemoter: Begin update device at 68:3e:34:cc:d3:84
[21:59:25]I (313660) MEIZURemoter: Device at 68:3e:34:cc:d3:84 was updated
[21:59:25]I (313660) Kernel: successful to update device at 68:3e:34:cc:d3:84: {"manufacturer":"Meizu","model":"R16","fireware":"v_3.0.10.23","temperature":29.63,"humidity":71.89,"battery":100,"voltage":3.0,"rssi":-66}
[21:59:25]I (313680) MEIZURemoter: Begin update device at 68:3e:34:cc:d3:43
[21:59:26]lld_pdu_get_tx_flush_nb HCI packet count mismatch (0, 1)
[21:59:26]W (314550) BT_HCI: DiscCmpl evt: hdl=1, rsn=0x8
[21:59:26]E (314560) MEIZURemoter: Can not connect to device at 68:3e:34:cc:d3:43
[21:59:26]E (314560) Kernel: Failed to update device at 68:3e:34:cc:d3:43 for 1 times
[22:04:12]I (601280) MEIZURemoter: Begin update device at 68:3e:34:cc:de:1b
[22:04:14]I (602820) MEIZURemoter: Device at 68:3e:34:cc:de:1b was updated
[22:04:14]I (602820) Kernel: successful to update device at 68:3e:34:cc:de:1b: {"manufacturer":"Meizu","model":"R16","fireware":"v_3.0.10.23","temperature":34.46,"humidity":59.54,"battery":100,"voltage":3.0,"rssi":-43}
[22:04:14]I (602830) MEIZURemoter: Begin update device at 68:3e:34:cc:d8:9b
[22:04:19]I (607560) MEIZURemoter: Device at 68:3e:34:cc:d8:9b was updated
[22:04:19]I (607570) Kernel: successful to update device at 68:3e:34:cc:d8:9b: {"manufacturer":"Meizu","model":"R16","fireware":"v_3.0.10.23","temperature":29.91,"humidity":71.59,"battery":90,"voltage":2.9,"rssi":-93}
[22:04:19]I (607580) MEIZURemoter: Begin update device at 68:3e:34:cc:d3:84
[22:04:19]lld_pdu_get_tx_flush_nb HCI packet count mismatch (0, 1)
[22:04:19]W (607700) BT_HCI: DiscCmpl evt: hdl=0, rsn=0x3e
[22:04:21]I (609660) MEIZURemoter: Device at 68:3e:34:cc:d3:84 was updated
[22:04:21]I (609670) Kernel: successful to update device at 68:3e:34:cc:d3:84: {"manufacturer":"Meizu","model":"R16","fireware":"v_3.0.10.23","temperature":29.60,"humidity":72.00,"battery":100,"voltage":3.0,"rssi":-63}
[22:04:21]I (609680) MEIZURemoter: Begin update device at 68:3e:34:cc:d3:43
[22:04:24]I (613100) MEIZURemoter: Device at 68:3e:34:cc:d3:43 was updated
[22:04:24]I (613100) Kernel: successful to update device at 68:3e:34:cc:d3:43: {"manufacturer":"Meizu","model":"R16","fireware":"v_3.0.10.23","temperature":30.21,"humidity":71.01,"battery":100,"voltage":3.0,"rssi":-91}
[22:09:12]I (901280) MEIZURemoter: Begin update device at 68:3e:34:cc:de:1b
[22:09:14]I (902510) MEIZURemoter: Device at 68:3e:34:cc:de:1b was updated
[22:09:14]I (902510) Kernel: successful to update device at 68:3e:34:cc:de:1b: {"manufacturer":"Meizu","model":"R16","fireware":"v_3.0.10.23","temperature":34.20,"humidity":60.00,"battery":100,"voltage":3.0,"rssi":-43}
[22:09:14]I (902520) MEIZURemoter: Begin update device at 68:3e:34:cc:d8:9b
[22:09:16]I (904630) MEIZURemoter: Device at 68:3e:34:cc:d8:9b was updated
[22:09:16]I (904630) Kernel: successful to update device at 68:3e:34:cc:d8:9b: {"manufacturer":"Meizu","model":"R16","fireware":"v_3.0.10.23","temperature":29.84,"humidity":71.62,"battery":90,"voltage":2.9,"rssi":-83}
[22:09:16]I (904640) MEIZURemoter: Begin update device at 68:3e:34:cc:d3:84
[22:09:17]I (906360) MEIZURemoter: Device at 68:3e:34:cc:d3:84 was updated
[22:09:17]I (906370) Kernel: successful to update device at 68:3e:34:cc:d3:84: {"manufacturer":"Meizu","model":"R16","fireware":"v_3.0.10.23","temperature":29.64,"humidity":72.04,"battery":100,"voltage":3.0,"rssi":-68}
[22:09:17]I (906380) MEIZURemoter: Begin update device at 68:3e:34:cc:d3:43
[22:09:19]I (908170) MEIZURemoter: Device at 68:3e:34:cc:d3:43 was updated
[22:09:19]I (908170) Kernel: successful to update device at 68:3e:34:cc:d3:43: {"manufacturer":"Meizu","model":"R16","fireware":"v_3.0.10.23","temperature":30.21,"humidity":71.04,"battery":100,"voltage":3.0,"rssi":-82}
[22:09:20]lld_pdu_get_tx_flush_nb HCI packet count mismatch (0, 1)
[22:09:20]W (909160) BT_HCI: DiscCmpl evt: hdl=0, rsn=0x22
 楼主| 发表于 2021-9-5 22:20:18 | 显示全部楼层
日志看不出什么问题,不过你那个RSSI -9X dBM的信号实在是够差的,这个处于失联的边缘了。
发表于 2021-9-5 22:24:50 | 显示全部楼层
involute 发表于 2021-9-5 22:20
日志看不出什么问题,不过你那个RSSI -9X dBM的信号实在是够差的,这个处于失联的边缘了。 ...
网关要插电脑上看日志,位置有就点远了  ,
刚刚又发现,改动数据刷新时间了造成HA失联的时候,改的刷新时间是没有成功的,HA恢复后,还是没改之前的数据
 楼主| 发表于 2021-9-5 22:26:53 | 显示全部楼层
hncdbai 发表于 2021-9-5 22:24
网关要插电脑上看日志,位置有就点远了
嗯,谢谢反馈,我这边测试看看。
发表于 2021-9-5 23:58:13 | 显示全部楼层
involute 发表于 2021-9-5 22:26
嗯,谢谢反馈,我这边测试看看。
试出来了,只要网关断过电,HA也得重启才行,不然就是连接不了 。 我这边是这样
 楼主| 发表于 2021-9-7 01:53:56 | 显示全部楼层
hncdbai 发表于 2021-9-5 23:58
试出来了,只要网关断过电,HA也得重启才行,不然就是连接不了 。 我这边是这样 ...
集成和固件更新一下0.3.1试试看。
847 手机认证
发表于 2021-9-7 19:58:35 | 显示全部楼层
请问大佬 完整的bin 怎么烧录  我烧录之后 没有wifi
发表于 2021-9-7 20:38:05 | 显示全部楼层
involute 发表于 2021-9-7 01:53
集成和固件更新一下0.3.1试试看。
感谢,更新后正常了
发表于 2021-9-8 13:01:23 | 显示全部楼层
GMT+8, 2026-1-14 13:03 , Processed in 1.766426 second(s), 10 queries , MemCached On.
