楼主: involute
[插件集成] 晚来的饭,接近产品品质的魅族遥控器软硬件解决方案
 楼主| 发表于 2021-9-4 02:23:37 | 显示全部楼层
固件与集成发布3.0Beta更新,自顶一下
发表于 2021-9-4 16:19:56 | 显示全部楼层
Using 'COM3' as serial port.
Connecting....
Detecting chip type... ESP32
Connecting......
Chip Info:
 - Chip Family: ESP32
 - Chip Model: ESP32D0WDQ6 (revision 1)
 - Number of Cores: 2
 - Max CPU Frequency: 240MHz
 - Has Bluetooth: YES
 - Has Embedded Flash: NO
 - Has Factory-Calibrated ADC: YES
 - MAC Address: 94:B9:7E:EA:9C:2C
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
 - Flash Size: 4MB
Unexpected error: Error while retrieving firmware file 'https://raw.githubusercontent.com/espressif/arduino-esp32/1.0.4/tools/sdk/bin/bootloader_dio_40m.bin': ('Connection aborted.', ConnectionResetError(10054, '远程主机强迫关闭了一个现有的连接。', None, 10054, None))
试了好几次,搭了梯子还是提示这个,直接复制到浏览器里是能下载的,我该怎么办
智能家居&单板滑雪痴迷爱好者
发表于 2021-9-4 16:39:25 | 显示全部楼层
tangxingjie1991 发表于 2021-9-4 16:19
试了好几次,搭了梯子还是提示这个,直接复制到浏览器里是能下载的,我该怎么办 ...
看我之前发的一个帖子,专门说这个问题的
发表于 2021-9-4 18:36:12 | 显示全部楼层
XCray 发表于 2021-9-4 16:39
看我之前发的一个帖子,专门说这个问题的
感谢 已成功刷入
发表于 2021-9-4 19:02:52 | 显示全部楼层
这么厉害的东西,肯定支持,也欣赏LZ这种开放的心态
发表于 2021-9-4 20:52:42 | 显示全部楼层
LZ,有个问题,我版本都选的是0.3.0,ESP32刷完也没问题,wifi配置也没问题,就homeassistant怎么也连不上,手动也不行
ESPHome-Flasher日志
homeassistant日志
Logger: aiohttp.server
Source: custom_components/meizu_remoter_gateway/config_flow.py:58
First occurred: 下午8:48:39 (1 occurrences)
Last logged: 下午8:48:39
Error handling request
  File "/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py", line 422, in _handle_request
    resp = await self._request_handler(request)
  File "/usr/local/lib/python3.8/site-packages/aiohttp/web_app.py", line 499, in _handle
    resp = await handler(request)
  File "/usr/local/lib/python3.8/site-packages/aiohttp/web_middlewares.py", line 118, in impl
    return await handler(request)
  File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 56, in security_filter_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 18, in request_context_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 72, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 127, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 129, in handle
    result = await result
  File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 169, in post
    return await super().post(request, flow_id)
  File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 60, in wrapper
    result = await method(view, request, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 106, in post
    result = await self._flow_mgr.async_configure(flow_id, data)
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 155, in async_configure
    result = await self._async_handle_step(flow, cur_step["step_id"], user_input)
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 213, in _async_handle_step
    result: Dict = await getattr(flow, method)(user_input)
  File "/config/custom_components/meizu_remoter_gateway/config_flow.py", line 58, in async_step_user
    return self.async_create_entry(
TypeError: async_create_entry() got an unexpected keyword argument 'options'
 楼主| 发表于 2021-9-4 21:46:56 来自手机 | 显示全部楼层
acdxxx188 发表于 2021-9-4 20:52
LZ,有个问题,我版本都选的是0.3.0,ESP32刷完也没问题,wifi配置也没问题,就homeassistant怎么也连不上 ...
说明一下你的HA版本
 楼主| 发表于 2021-9-4 22:13:59 | 显示全部楼层
我倾向于是你的HA版本过于古老了,配置的时候还不支持options,虽然我不知道具体什么时间支持的,但印象中最少最少有半年了。
所以你的HA是至少半年前的版本?
ptsa 手机认证
发表于 2021-9-5 00:17:34 | 显示全部楼层
O1CN01ppAZOd1OVDsEfvjde_!!0-item_pic.jpg 在这个上刷了 0.3.0的固件
3.png 但是就是找不到蓝牙。 手机可以找到魅族遥控器 这个蓝牙
 楼主| 发表于 2021-9-5 00:52:50 | 显示全部楼层
ptsa 发表于 2021-9-5 00:17
在这个上刷了 0.3.0的固件
但是就是找不到蓝牙。 手机可以找到魅族遥控器 这个蓝牙 ...
你凑近了吗?
还有就是你别的设备连着遥控器(比如用手机),那他就不可能被找到。
GMT+8, 2026-1-14 13:03 , Processed in 1.238353 second(s), 8 queries , MemCached On.
