楼主: 27hh
[进阶教程] 闲置安卓手机安装HA变身智能家居中枢,及网关接入教程
发表于 2018-3-17 23:31:04 | 显示全部楼层
1、
Welcome to Ubuntu 16.04 LTS (GNU/Linux 3.4.0-perf-g6f3bfd0 armv7l)
* Documentation:  https://help.ubuntu.com/
Ubuntu 16.04 LTS [running via Linux Deploy]
Last login: Sat Mar 17 17:11:10 2018 from 192.168.1.3
android@localhost:~$ netstat -t -ln
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN
tcp6       0      0 :::38517                :::*                    LISTEN
tcp6       0      0 :::22                   :::*                    LISTEN
tcp6       0      0 :::3880                 :::*                    LISTEN
2、
(homeassistant) homeassistant@localhost:/home/android$ hass
Config directory: /home/homeassistant/.homeassistant
INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_off>
INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_on>
INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=toggle>
INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=stop>
INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=restart>
INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=check_config>
INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=reload_core_config>
INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=persistent_notification, service=create>
INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=persistent_notification, service=dismiss>
INFO:homeassistant.bootstrap:Home Assistant core initialized
INFO:homeassistant.loaderoaded frontend from homeassistant.components.frontend
INFO:homeassistant.loaderoaded api from homeassistant.components.api
INFO:homeassistant.loaderoaded http from homeassistant.components.http
INFO:homeassistant.loaderoaded websocket_api from homeassistant.components.websocket_api
INFO:homeassistant.loaderoaded system_log from homeassistant.components.system_log
INFO:homeassistant.loaderoaded introduction from homeassistant.components.introduction
INFO:homeassistant.setup:Setting up introduction
INFO:homeassistant.components.introduction:
        Hello, and welcome to Home Assistant!
        We'll hope that we can make all your dreams come true.
        Here are some resources to get started:
         - Configuring Home Assistant:
           https://home-assistant.io/getting-started/configuration/
         - Available components:
           https://home-assistant.io/components/
         - Troubleshooting your configuration:
           https://home-assistant.io/gettin ... ting-configuration/
         - Getting help:
           https://home-assistant.io/help/
        This message is generated by the introduction component. You can
        disable it in configuration.yaml.
INFO:homeassistant.loaderoaded persistent_notification from homeassistant.components.persistent_notification
INFO:homeassistant.setup:Setup of domain introduction took 0.0 seconds.
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=introduction>
INFO:homeassistant.loaderoaded history from homeassistant.components.history
INFO:homeassistant.loaderoaded recorder from homeassistant.components.recorder
INFO:homeassistant.core:Bus:Handling <Event call_service[L]: service_call_id=3048837616-1, domain=persistent_notification, service_data=title=Welcome Home!, message=
- [Configuring Home Assistant](https://home-assistant.io/getting-started/configuration/)
- [Available components](https://home-assistant.io/components/)
- [Troubleshooting your configuration](https://home-assistant.io/docs/configuration/troubleshooting/)
- [Getting help](https://home-assistant.io/help/)
To not see this card popup in the future, edit your config in
`configuration.yaml` and disable the `introduction` component.
, service=create>
INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state persistent_notification.notification=notifying; title=Welcome Home!, message=Here are some resources to get started:
`configuration.yaml` and disable the `introduction` component. @ 2018-03-17T23:24:13.607207+08:00>, old_state=None, entity_id=persistent_notification.notification>
INFO:homeassistant.core:Bus:Handling <Event service_executed[L]: service_call_id=3048837616-1>
INFO:homeassistant.util.package:Attempting install of aiohttp_cors==0.6.0
ERROR:homeassistant.util.package:Unable to install package aiohttp_cors==0.6.0: Could not find a version that satisfies the requirement aiohttp_cors==0.6.0 (from versions: )
No matching distribution found for aiohttp_cors==0.6.0
ERROR:homeassistant.requirements:Not initializing http because could not install requirement aiohttp_cors==0.6.0
ERROR:homeassistant.setup:Setup failed for http: Could not install all requirements.
INFO:homeassistant.core:Bus:Handling <Event call_service[L]: service_call_id=3048837616-2, domain=persistent_notification, service_data=notification_id=invalid_config, title=Invalid config, message=The following components and platforms could not be set up:
- [http](https://home-assistant.io/components/http/)
Please check your config., service=create>
INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state persistent_notification.invalid_config=notifying; title=Invalid config, message=The following components and platforms could not be set up:
Please check your config. @ 2018-03-17T23:24:16.030053+08:00>, old_state=None, entity_id=persistent_notification.invalid_config>
INFO:homeassistant.core:Bus:Handling <Event service_executed[L]: service_call_id=3048837616-2>
ERROR:homeassistant.setup:Unable to setup dependencies of websocket_api. Setup failed for dependencies: http
ERROR:homeassistant.setup:Setup failed for websocket_api: Could not setup all dependencies.
ERROR:homeassistant.setup:Unable to setup dependencies of api. Setup failed for dependencies: http
ERROR:homeassistant.setup:Setup failed for api: Could not setup all dependencies.
ERROR:homeassistant.setup:Unable to setup dependencies of system_log. Setup failed for dependencies: http
ERROR:homeassistant.setup:Setup failed for system_log: Could not setup all dependencies.
INFO:homeassistant.core:Bus:Handling <Event call_service[L]: service_call_id=3048837616-3, domain=persistent_notification, service_data=notification_id=invalid_config, title=Invalid config, message=The following components and platforms could not be set up:
- [websocket-api](https://home-assistant.io/components/websocket_api/)
-----------省略很多行Please check your config.--------------
- [conversation](https://home-assistant.io/components/conversation/)
- [tts](https://home-assistant.io/components/tts/)
- [frontend](https://home-assistant.io/components/frontend/)
- [discovery](https://home-assistant.io/components/discovery/)
- [updater](https://home-assistant.io/components/updater/)
- [config](https://home-assistant.io/components/config/)
- [logbook](https://home-assistant.io/components/logbook/)
- sensor.yr
- [cloud](https://home-assistant.io/components/cloud/)
- [api](https://home-assistant.io/components/api/)
- [system-log](https://home-assistant.io/components/system_log/)
- [recorder](https://home-assistant.io/components/recorder/)
- [history](https://home-assistant.io/components/history/)
Please check your config. @ 2018-03-17T23:24:16.030053+08:00>, entity_id=persistent_notification.invalid_config>
INFO:homeassistant.core:Bus:Handling <Event service_executed[L]: service_call_id=3048837616-16>
INFO:homeassistant.setup:Setup of domain sensor took 7.1 seconds.
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=sensor>
INFO:homeassistant.bootstrap:Home Assistant initialized in 13.13s
INFO:homeassistant.core:Starting Home Assistant core loop
INFO:homeassistant.core:Bus:Handling <Event homeassistant_start[L]>
INFO:homeassistant.core:Timer:starting
发表于 2018-3-17 23:32:07 | 显示全部楼层
MAPGPS 发表于 2018-3-17 19:05
请把"Please check your config"之前的那一段日志信息贴上来。
你可在另外一个终端窗口里输以下命令来查 ...
十分感谢,耐心指点我。
发表于 2018-3-17 23:47:30 | 显示全部楼层
来试一下~
发表于 2018-3-18 00:07:29 | 显示全部楼层
jackwang99 发表于 2018-3-17 23:31
1、
看出错信息, aiohttp_cors的版本要求是0.6.0,可在homeassistant用户环境下指定版本装一下:
pip3 install --trusted-host mirrors.ustc.edu.cn aiohttp_cors==0.6.0
发表于 2018-3-18 00:07:49 | 显示全部楼层
前面还有好多行就不复制了
bash: /srv/homeassistant/bin/activatepip3: No such file or directory
homeassistant@localhost:/home/1$ hass
bash: hass: command not found
我输入hass退出失败是什么意思
我忽略这个问题继续安装出现
[sudo] password for homeassistant:
Sorry, try again.
发表于 2018-3-18 00:12:59 | 显示全部楼层
polofun 发表于 2018-3-18 00:07
前面还有好多行就不复制了
homeas ...
那条命令是 "source /srv/homeassistant/bin/activate"
你怎么把后面那条命令"pip3 ..."给拼一起了? (变成了"activatepip3")
发表于 2018-3-18 00:17:10 | 显示全部楼层
你怎么把后面那条命令"pip3 ..."给拼一起了? (变 ...
那怎么搞,从哪里开始重做?
发表于 2018-3-18 00:19:32 | 显示全部楼层
polofun 发表于 2018-3-18 00:17
那怎么搞,从哪里开始重做?
pip3 install -U homeassistant
发表于 2018-3-18 00:21:16 | 显示全部楼层
(homeassistant) homeassistant@localhost:/home/1$ source /srv/homeassistant/bin/activate
(homeassistant) homeassistant@localhost:/home/1$ pip3 install -U homeassistant
Collecting homeassistant
  The repository located at mirrors.ustc.edu.cn is not a trusted or secure host and is being ignored. If this repository is available via HTTPS it is recommended to use HTTPS instead, otherwise you may silence this warning and allow it anyways with '--trusted-host mirrors.ustc.edu.cn'.
  Could not find a version that satisfies the requirement homeassistant (from versions: )
No matching distribution found for homeassistant
出现了这个
发表于 2018-3-18 00:24:16 | 显示全部楼层
(homeassis ...
改用这个命令行:
pip3 install --trusted-host mirrors.ustc.edu.cn -U homeassistant
GMT+8, 2025-12-20 13:45 , Processed in 0.104269 second(s), 10 queries , MemCached On.
