楼主: 27hh
[进阶教程] 闲置安卓手机安装HA变身智能家居中枢,及网关接入教程
发表于 2018-3-11 20:51:55 | 显示全部楼层
安卓手机浑身都是宝,按这个贴子把手机自己的摄像头/声音/传感器也都接入HA了:
https://bbs.hassbian.com/thread-393-1-1.html
发表于 2018-3-12 16:10:10 | 显示全部楼层
旧手机来一把 谢谢楼主
发表于 2018-3-12 18:31:18 来自手机 | 显示全部楼层
想用手机的蓝牙把小米的花花草草仪接入HA。
但在Ubuntu下看不到蓝牙设备, hciconfig命令返回空:
mapgps@localhost:~$ hciconfig
mapgps@localhost:~$
hciconfig命令是在装了bluez之后才有的。
(sudo apt-get install bluez )
有接过蓝牙设备的吗?分享一下。
发表于 2018-3-12 20:11:30 | 显示全部楼层
刚注意到安装蓝牙驱动时出错了:
mapgps@localhost:~$ sudo apt-get install bluez
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following NEW packages will be installed:
  bluez
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/771 kB of archives.
After this operation, 2812 kB of additional disk space will be used.
Selecting previously unselected package bluez.
(Reading database ... 68021 files and directories currently installed.)
Preparing to unpack .../bluez_5.37-0ubuntu5_armhf.deb ...
Unpacking bluez (5.37-0ubuntu5) ...
Processing triggers for ureadahead (0.100.0-19) ...
Processing triggers for systemd (229-4ubuntu4) ...
Processing triggers for dbus (1.10.6-1ubuntu3) ...
Failed to open connection to "system" message bus: Failed to connect to socket /var/run/dbus/system_bus_socket: Connection refused
Processing triggers for man-db (2.7.5-1) ...
Setting up bluez (5.37-0ubuntu5) ...
Running in chroot, ignoring request.
 * Reloading system message bus config...                                                 Failed to open connection to "system" message bus: Failed to connect to socket /var/run/dbus/system_bus_socket: Connection refused
invoke-rc.d: initscript dbus, action "force-reload" failed.
发表于 2018-3-12 21:24:24 | 显示全部楼层
很好很强大,多谢分享
发表于 2018-3-12 21:25:19 | 显示全部楼层
看看学习学习
发表于 2018-3-13 00:20:04 | 显示全部楼层
楼主辛苦,小白提问,请教大家:
在2.2.1各种小准备环节,执行更新pip命令,出现黄色提示,如何解决?
27hh
教程狂人论坛风云人物
 楼主| 发表于 2018-3-13 00:52:22 来自手机 | 显示全部楼层
jackwang99 发表于 2018-3-13 00:20
楼主辛苦,小白提问,请教大家:
好像是不用理会,看看后面没错误就行。
发表于 2018-3-13 11:56:08 | 显示全部楼层
不错,这样就可以把旧手机利用起来了
发表于 2018-3-13 12:42:55 | 显示全部楼层
27hh 发表于 2018-3-13 00:52
好像是不用理会,看看后面没错误就行。
谢谢楼主答复。
如果不理会,“安装 homeassistant 环节,执行 pip3 install -U homeassistant 时,提示Python3 版本低。
GMT+8, 2025-12-20 15:53 , Processed in 1.275142 second(s), 13 queries , MemCached On.
