楼主: likaci
[技术探讨] 水星监控摄像头 MIPC251C-4 接入 HA, 云台控制脚本
 楼主| 发表于 2019-8-1 23:09:14 | 显示全部楼层
sangood 发表于 2019-8-1 21:52
感谢楼主,也入了一个放门口了。楼主能抓下 触发报警声音的 命令吗?就是app里面有个手动报警的命令。 ...
应该就这些了, 有些参数还挺复杂
//手动报警
{"method":"do","msg_alarm":{"manual_msg_alarm":{"action":"start"}}}
{"method":"do","msg_alarm":{"manual_msg_alarm":{"action":"stop"}}}
//绿色led开关
{"method":"set","led":{"config":{"enabled":"off"}}}
{"method":"set","led":{"config":{"enabled":"on"}}}
//智能追踪 摄像机追随移动物体
{"method":"set","target_track":{"target_track_info":{"enabled":"on"}}}
{"method":"set","target_track":{"target_track_info":{"enabled":"off"}}}
//检测到移动物体时报警
{"method":"set","msg_alarm":{"chn1_msg_alarm_info":{"enabled":"on","alarm_type":"0","alarm_mode":["sound"]}}}
{"method":"set","msg_alarm":{"chn1_msg_alarm_info":{"enabled":"on","alarm_type":"0","alarm_mode":["light"]}}}
{"method":"set","msg_alarm":{"chn1_msg_alarm_info":{"enabled":"on","alarm_type":"0","alarm_mode":["sound","light"]}}}
{"method":"set","msg_alarm_plan":{"chn1_msg_alarm_plan":{"enabled":"on","alarm_plan_1":"0000-0000%2c127"}}}
//移动侦测 与 侦测灵敏度
{"method":"set","motion_detection":{"motion_det":{"enabled":"off"}}}
{"method":"set","motion_detection":{"motion_det":{"enabled":"on"}}}
{"method":"set","motion_detection":{"motion_det":{"digital_sensitivity":"20"}}}
{"method":"set","motion_detection":{"motion_det":{"digital_sensitivity":"50"}}}
{"method":"set","motion_detection":{"motion_det":{"digital_sensitivity":"80"}}}
//是否录制与录制计划
{"method":"set","record_plan":{"chn1_channel":{"enabled":"off","monday":"%5b%220000-2400%3a2%22%5d","tuesday":"%5b%220000-2400%3a2%22%5d","wednesday":"%5b%220000-2400%3a2%22%5d","thursday":"%5b%220000-2400%3a2%22%5d","friday":"%5b%220000-2400%3a2%22%5d","saturday":"%5b%220000-2400%3a2%22%5d","sunday":"%5b%220000-2400%3a2%22%5d"}}}
{"method":"set","record_plan":{"chn1_channel":{"enabled":"on","monday":"%5b%220000-2400%3a2%22%5d","tuesday":"%5b%220000-2400%3a2%22%5d","wednesday":"%5b%220000-2400%3a2%22%5d","thursday":"%5b%220000-2400%3a2%22%5d","friday":"%5b%220000-2400%3a2%22%5d","saturday":"%5b%220000-2400%3a2%22%5d","sunday":"%5b%220000-2400%3a2%22%5d"}}}
//重启与定时重启
{"method":"do","system":{"reboot":"null"}}
{"method":"set","timing_reboot":{"reboot":{"enabled":"off","day":"7","time":"03%3a00%3a00"}}}
{"method":"set","timing_reboot":{"reboot":{"enabled":"on","day":"7","time":"03%3a00%3a00"}}}
//云台重置
{"method":"do","motor":{"manual_cali":"null"}}
//个性语音提示
{"method":"set","greeter":{"chn1_greeter_ctrl":{"enabled":"on"}}}
{"method":"set","greeter":{"chn1_greeter_ctrl":{"enabled":"off"}}}
//音量
{"method":"set","greeter":{"chn1_greeter_audio":{"enter_volume":"77","leave_volume":"77"}}}
//播放语音
{"method":"do","greeter":{"test_audio":{"force":"1"}}} 播放默认语音
{"method":"do","greeter":{"test_audio":{"id":"4096","force":"1"}}} 播放指定语音
//id
//0 无
//12288 你好
//4096-4104 依次为 你好欢迎光临 .....
//设置进入或离开语音
{"method":"set","greeter":{"chn1_greeter_audio":{"enter_audio_id":"0"}}} 无
{"method":"set","greeter":{"chn1_greeter_audio":{"leave_audio_id":"4104"}}}
发表于 2019-8-2 09:11:32 | 显示全部楼层
likaci 发表于 2019-8-1 23:09
应该就这些了, 有些参数还挺复杂
太感谢了!
发表于 2019-8-3 08:47:39 | 显示全部楼层
大佬威武……
发表于 2019-8-18 11:05:56 | 显示全部楼层
樓主請問概然水星這個攝影機用了TP LINK 的代碼, 那我可否套用在TP LINK 的攝像機中呢? 家中有一個TL-IPC42E-4 ,  如果樓主推測不行的話我可否获取 stok 然後把mipcc.py 中相關的stok 改掉套用在這支攝影機呢?
发表于 2019-8-21 10:11:31 | 显示全部楼层
先Mark过几天摄像头就到了
 楼主| 发表于 2019-8-23 11:25:42 | 显示全部楼层
下載王下載王 发表于 2019-8-18 11:05
樓主請問概然水星這個攝影機用了TP LINK 的代碼, 那我可否套用在TP LINK 的攝像機中呢? 家中有一個TL-IPC42 ...
不妨试一试, 水星和 tp 的登录认证是一样的, 可能具体的指令不一样.
发表于 2019-8-25 16:01:07 | 显示全部楼层
接入是没问题,但是控制好像用楼主的脚本怎么也弄不了,楼主能更详细指教一下吗?
发表于 2019-8-25 17:01:55 | 显示全部楼层
直接打python mipcc.py admin password url data....进终端里面可以让云台转动,但是怎么把它作为按钮加到HA里面呢?
发表于 2019-8-27 15:06:11 | 显示全部楼层
这么超值?我擦。mark,学习了。
发表于 2019-8-27 16:34:47 | 显示全部楼层
xieahui 发表于 2019-7-29 15:23
预置点也有了 问下能局域网直接http抓图吗?
上次看到拼西西上了 没买怕接入不了 ...
买了吗   接入了没
GMT+8, 2025-12-14 09:18 , Processed in 0.406296 second(s), 12 queries , MemCached On.
