楼主: mypal
[技术讨论] 大金空调DS-AIR及『金制空气』接入HA
发表于 2021-9-18 21:41:53 | 显示全部楼层
感谢楼主大佬的分享,终于把空调接进来了,但是大金送的空气传感器还是获取不到
发表于 2021-9-24 21:34:38 | 显示全部楼层
楼主首先感谢您提供大金接入ha的功能支持。但是我使用上遇到一个问题,因为我有两台主机,也就是两个网关,但是只能输入一次个ip地址,添加一个后第二个又没办法添加,不知道如何解决,谢谢,希望得到您的指导。
发表于 2021-9-27 17:44:02 | 显示全部楼层
请问下,我用这个插件接入到homeassistant了,但是homekit里找不到啊
 楼主| 发表于 2021-9-30 10:36:55 | 显示全部楼层
homeassistant有的话,那就不是插件的问题了,你需要研究下空调如何接入到HomeKit
发表于 2021-10-1 23:02:50 | 显示全部楼层
mypal 发表于 2021-9-30 10:36
homeassistant有的话,那就不是插件的问题了,你需要研究下空调如何接入到HomeKit ...
现在接入成功了,但是运行了几天,homeassistant运行不起来了,删除插件,homeassistant又可以运行了,这个不知道是什么问题,重新安装了插件也不行,把homeassistant完全删除配置,又可以运行了。
发表于 2021-10-4 19:30:11 | 显示全部楼层
2021-10-04 11:19:44 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration ds_air which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
群晖下docker的homeassistant,运行一天又启动不了了。
发表于 2021-10-4 19:31:53 | 显示全部楼层
2021-10-04 11:20:58 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: ds_air
2021-10-04 11:21:58 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: ds_air
2021-10-04 11:22:58 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: ds_air
2021-10-04 11:23:58 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: ds_air
2021-10-04 11:24:47 ERROR (MainThread) [aiohttp.server] Error handling request
  File "/usr/local/lib/python3.9/site-packages/aiohttp/web_protocol.py", line 422, in _handle_request
    resp = await self._request_handler(request)
  File "/usr/local/lib/python3.9/site-packages/aiohttp/web_app.py", line 499, in _handle
    resp = await handler(request)
  File "/usr/local/lib/python3.9/site-packages/aiohttp/web_middlewares.py", line 119, in impl
    return await handler(request)
  File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 60, in security_filter_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 89, in forwarded_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 24, in request_context_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 78, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 144, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 135, in handle
    result = await result
  File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 190, in post
    return await super().post(request)
  File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 63, in wrapper
    result = await method(view, request, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 72, in post
    result = await self._flow_mgr.async_init(
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 153, in async_init
    flow, result = await task
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 171, in _async_init
    flow = await self.async_create_flow(handler, context=context, data=data)
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1429, in async_create_flow
    return cast(OptionsFlow, HANDLERS[entry.domain].async_get_options_flow(entry))
  File "/config/custom_components/ds_air/config_flow.py", line 81, in async_get_options_flow
    return DsAirOptionsFlowHandler(config_entry)
  File "/config/custom_components/ds_air/config_flow.py", line 93, in __init__
    self._climates = list(map(lambda state: state.alias, Service.get_aircons()))
  File "/config/custom_components/ds_air/ds_air_service/service.py", line 197, in get_aircons
    return Service._new_aircons+Service._aircons+Service._bathrooms
TypeError: unsupported operand type(s) for +: 'NoneType' and 'NoneType'
2021-10-04 11:24:53 WARNING (MainThread) [homeassistant.bootstrap] Setup timed out for stage 2 - moving forward
2021-10-04 11:28:16 ERROR (MainThread) [aiohttp.server] Error handling request
2021-10-04 11:28:18 ERROR (MainThread) [aiohttp.server] Error handling request
 楼主| 发表于 2021-10-10 15:37:18 | 显示全部楼层
mengduo 发表于 2021-10-4 19:31
2021-10-04 11:19:44 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration ds_a ...
还有其他的报错没?要不你加一下QQ群693698416,需要定位下你的具体问题
 楼主| 发表于 2021-10-10 15:44:52 | 显示全部楼层
可以尝试下1.3.1版本
发表于 2021-11-1 10:12:39 | 显示全部楼层
谢谢楼主的分享,大让人惊喜了。本来觉得要买淘宝上那种2K左右的第三方控制器的
还想请教楼主一个问题,不知道DTA117D611能支持吗?
准备上大金,JS给我的配置单上是这个网关,谢谢
GMT+8, 2026-2-4 11:09 , Processed in 0.203242 second(s), 13 queries , MemCached On.
