楼主: mypal
[技术讨论] 大金空调DS-AIR及『金制空气』接入HA
发表于 2022-9-14 10:48:19 | 显示全部楼层
接入了,但是homekit上面显示空调测到的室温都是21度
发表于 2022-9-21 09:21:02 来自手机 | 显示全部楼层
你好,楼主,各位大神,求指点!关于大金空调,金制空气app,空调自带局域网智能网关,如何接入homeassistant现在最重要的问题,大金给我配了一个本地网关,所以暂时没有换VRF,不能实现统一管理,希望得到帮助,感谢!
发表于 2022-10-21 16:21:44 | 显示全部楼层
新网关DTA117D611实测可用,使用中出现的问题跟楼上各位一样,不过能用,看起来跟DTA117C611的表象一样。
发表于 2022-11-4 21:11:06 | 显示全部楼层
重启后突然就连接不上了,重装插件也无法解决。。
Error handling request Traceback (most recent call last): File "/usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py", line 435, in _handle_request resp = await request_handler(request) File "/usr/local/lib/python3.10/site-packages/aiohttp/web_app.py", line 504, in _handle resp = await handler(request) File "/usr/local/lib/python3.10/site-packages/aiohttp/web_middlewares.py", line 117, in impl return await handler(request) File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 60, in security_filter_middleware return await handler(request) File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 100, in forwarded_middleware return await handler(request) File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware return await handler(request) File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 82, in ban_middleware return await handler(request) File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 236, in auth_middleware return await handler(request) File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 136, in handle result = await result File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 218, in post return await super().post(request) File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 73, in wrapper result = await method(view, request, data, *args, **kwargs) File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 71, in post result = await self._flow_mgr.async_init( File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 225, in async_init flow, result = await task File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 243, in _async_init flow = await self.async_create_flow(handler, context=context, data=data) File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1625, in async_create_flow return HANDLERS[entry.domain].async_get_options_flow(entry) File "/config/custom_components/ds_air/config_flow.py", line 81, in async_get_options_flow return DsAirOptionsFlowHandler(config_entry) File "/config/custom_components/ds_air/config_flow.py", line 93, in __init__ self._climates = list(map(lambda state: state.alias, Service.get_aircons())) File "/config/custom_components/ds_air/ds_air_service/service.py", line 204, in get_aircons return Service._new_aircons+Service._aircons+Service._bathrooms TypeError: unsupported operand type(s) for +: 'NoneType' and 'NoneType'
发表于 2022-11-6 14:12:36 | 显示全部楼层
Error handling request Traceback (most recent call l ...
和你一样的报错,未升级HA和OS版本,只是重启以后就无法加载了
发表于 2022-11-6 15:26:57 | 显示全部楼层
已经有不少人出现类似的错误了, 我在 Github 上提了 issue, 但是似乎作者消失了。。。
https://github.com/mypal/ha-dsair/issues/36
发表于 2022-11-9 21:27:48 | 显示全部楼层
我是一直在初始化中。。。进不去了,也是重启之后,重装也没用
发表于 2022-11-11 14:55:32 | 显示全部楼层
大佬,,dsair没法用了。。重启后一直在初始化中。。。求修复
发表于 2022-11-11 20:26:22 | 显示全部楼层
求修复,重启后没法用了
发表于 2022-11-12 13:53:10 | 显示全部楼层
zengchao 发表于 2022-5-17 15:06
基于mypal大神的代码修改了一下,现在在homekit上可以调整风速了,有需要的私我。 ...
大神麻烦分享一下给我吧!感谢。
另外请问怎么找网关的ip呢?我顺着设备背部贴着的MAC,在DHCP终端里搜,没看到呢
GMT+8, 2025-12-18 08:31 , Processed in 1.280625 second(s), 11 queries , MemCached On.
