楼主: neroxps
HASSIO 安装一键脚本
 火...   [复制链接]
69
发表于 2020-2-3 20:55:57 | 显示全部楼层
试了多次,都失败,啥情况;
image已经pull了下来,但用 docker run homeassistant/raspberrypi3-homeassistant:0.104.3 时,总是停止在这一步:
msn
发表于 2020-2-7 04:36:34 | 显示全部楼层
也就是说不支持NAS里面容器安装啊
发表于 2020-2-8 20:27:16 | 显示全部楼层
Xshell  (Build N/A)
Copyright (c) 2002 NetSarang Computer, Inc. All rights reserved.
Type `help' to learn how to use Xshell prompt.
[D:\~]$
Connecting to 192.168.1.234:22...
Canceled.
[D:\~]$
[D:\~]$
Connection established.
To escape to local shell, press 'Ctrl+Alt+]'.
Linux raspberrypi 4.19.75-v7+ #1270 SMP Tue Sep 24 18:45:11 BST 2019 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Fri Feb  7 21:51:15 2020
pi@raspberrypi:~ $ sudo -i
root@raspberrypi:~#               apt-get install software-properties-common
E: Could not get lock /var/lib/dpkg/lock-frontend - open (11: Resource temporarily unavailable)
E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), is another process using it?
root@raspberrypi:~#               apt-get update
Hit:1 http://mirrors.aliyun.com/raspbian/raspbian stretch InRelease
Ign:2 http://mirrors.aliyun.com/debian stretch InRelease
Get:3 http://mirrors.aliyun.com/debian stretch Release [118 kB]
Get:4 http://mirrors.aliyun.com/debian stretch Release.gpg [2,365 B]
Ign:4 http://mirrors.aliyun.com/debian stretch Release.gpg
Hit:5 https://download.docker.com/linux/debian buster InRelease
Reading package lists... Done
W: GPG error: http://mirrors.aliyun.com/debian stretch Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 7638D0442B90D010 NO_PUBKEY 04EE7237B7D453EC NO_PUBKEY EF0F382A1A7B6500
E: The repository 'http://mirrors.aliyun.com/debian stretch Release' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
root@raspberrypi:~#               apt-get install -y apparmor-utils apt-transport-https avahi-daemon ca-certificates curl dbus jq network-manager socat
root@raspberrypi:~# curl -fsSL get.docker.com | sh
# Executing docker install script, commit: f45d7c11389849ff46a6b4d94e0dd1ffebca32c1
+ sh -c apt-get update -qq >/dev/null
root@raspberrypi:~# curl -sL "https://raw.githubusercontent.com/home-assistant/hassio-installer/master/hassio_install.sh" | bash -s -- -m raspberrypi3
root@raspberrypi:~# systemctl stop hassio-supervisor.service
Failed to stop hassio-supervisor.service: Unit hassio-supervisor.service not loaded.
root@raspberrypi:~# systemctl status hassio-supervisor.service
Unit hassio-supervisor.service could not be found.
root@raspberrypi:~# wget https://code.aliyun.com/neroxps/ ... w/master/install.sh
--2020-02-08 20:21:35--  https://code.aliyun.com/neroxps/ ... w/master/install.sh
Resolving code.aliyun.com (code.aliyun.com)... 120.55.150.20
Connecting to code.aliyun.com (code.aliyun.com)|120.55.150.20|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: unspecified [text/plain]
Saving to: ‘install.sh.6’
install.sh.6                        [ <=>                                                  ]  22.91K  --.-KB/s    in 0.03s
2020-02-08 20:21:36 (725 KB/s) - ‘install.sh.6’ saved [23463]
root@raspberrypi:~# chmod a+x install.sh
root@raspberrypi:~# ./install.sh
(1). 是否将系统源切换为中科大(USTC)源(目前支持 Debian Ubuntu Raspbian 三款系统)
请输入 y or n(默认 yes):
(2). 找到该系统中有以下用户名
如下方列表未显示你的用户名,请切换回你用户账号后输入 sudo usermod -aG docker $USER 添加用户到 docker 用户组。
    [1]: pi
    [2]: systemd-coredump
    : 跳过
请输入你需要使用 docker 的用户名序号,以加入 docker 用户组:1
将pi用户添加至 docker 用户组。
(3).是否需要替换 docker 默认源?
请输入 yes 或者 no(默认:yes):
1. docker-cn (docker 官方中国镜像源,阿里云提供服务,但流量大可能会卡)
2. 七牛云 docker 镜像源
3. 163 docker 镜像源(无 SSL)
请选择 docker 加速器(默认:七牛云):1
(4).请选择你设备类型(默认:qemux86)
    [1]: intel-nuc: 英特尔的nuc小主机
    [2]: odroid-c2: 韩国odroid-c2
    [3]: odroid-xu: 韩国odroid-xu
    [4]: orangepi-prime: 香橙派
    [5]: qemuarm: 通用arm设备(例如斐讯N1)
    [6]: qemux86: 通用X86(普通的PC机电脑)
    [7]: raspberrypi: 树莓派一代
    [8]: raspberrypi2: 树莓派二代
    [9]: raspberrypi3: 树莓派三代
    [10]: raspberrypi4: 树莓派四代
    [11]: tinker: 华硕tinker
输入数字 (1-11):9
你选择了 raspberrypi3
(5).是否需要设置 hassio 数据保存路径(默认:/usr/share/hassio)
请输入 yes 或 no (默认:no):
hassio 数据路径为默认路径: /usr/share/hassio
# 1. 是否将系统源切换为中科大(USTC)源: 是
# 2. 是否将用户添加至 Docker 用户组:   是,添加用户为 pi
# 3. 是否将 Docker 源切换至国内源:     是,切换源选择:docker-cn
# 4. 您的设备类型为:                   raspberrypi3
# 5. 您的 hassio 数据路径为:           /usr/share/hassio
请确认以上信息,继续请按任意键,如需修改请输入 Ctrl+C 结束任务重新执行脚本。
[info]: 切换系统网络源.....
备份系统源文件为 /etc/apt/sources.list.bak
Ign:1 http://mirrors.aliyun.com/debian stretch InRelease
Get:2 http://mirrors.aliyun.com/debian stretch Release [118 kB]
Get:3 http://mirrors.aliyun.com/debian stretch Release.gpg [2,365 B]
Get:4 http://mirrors.ustc.edu.cn/raspbian/raspbian buster InRelease [15.0 kB]
Get:5 http://mirrors.ustc.edu.cn/archive.raspberrypi.org/debian buster InRelease [25.1 kB]
Ign:3 http://mirrors.aliyun.com/debian stretch Release.gpg
Get:6 http://mirrors.ustc.edu.cn/raspbian/raspbian buster/main armhf Packages [13.0 MB]
Hit:7 https://download.docker.com/linux/debian buster InRelease
Get:8 http://mirrors.ustc.edu.cn/archive.raspberrypi.org/debian buster/main armhf Packages [277 kB]
################# 发到论坛时,请把上方日志也一并粘贴发送 ################
Distributor ID:        Raspbian
Description:        Raspbian GNU/Linux 10 (buster)
Release:        10
Codename:        buster
Linux version 4.19.75-v7+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1270 SMP Tue Sep 24 18:45:11 BST 2019
Linux raspberrypi 4.19.75-v7+ #1270 SMP Tue Sep 24 18:45:11 BST 2019 armv7l GNU/Linux
[ERROR]: 系统源切换错误,请检查网络连接是否正常,脚本退出
相关问题可以访问https://bbs.iobroker.cn或者加QQ群776817275咨询
--2020-02-08 20:23:33--  https://code.aliyun.com/neroxps/ ... w/master/install.sh
Saving to: ‘install.sh.7’
install.sh.7                        [ <=>                                                  ]  22.91K  --.-KB/s    in 0.04s
2020-02-08 20:23:33 (605 KB/s) - ‘install.sh.7’ saved [23463]
请输入 y or n(默认 yes):
(2). 找到该系统中有以下用户名
    [1]: pi
    : 跳过
2. 七牛云 docker 镜像源
请选择 docker 加速器(默认:七牛云):3
输入数字 (1-11):9
你选择了 raspberrypi3
# 3. 是否将 Docker 源切换至国内源:     是,切换源选择:163源
Hit:1 http://mirrors.ustc.edu.cn/raspbian/raspbian buster InRelease
Hit:2 http://mirrors.ustc.edu.cn/archive.raspberrypi.org/debian buster InRelease
Ign:3 http://mirrors.aliyun.com/debian stretch InRelease
Get:4 http://mirrors.aliyun.com/debian stretch Release [118 kB]
Get:5 http://mirrors.aliyun.com/debian stretch Release.gpg [2,365 B]
Ign:5 http://mirrors.aliyun.com/debian stretch Release.gpg
Hit:6 https://download.docker.com/linux/debian buster InRelease
Release:        10
Codename:        buster
--2020-02-08 20:24:21--  https://code.aliyun.com/neroxps/ ... w/master/install.sh
Saving to: ‘install.sh.8’
install.sh.8                        [ <=>                                                  ]  22.91K  --.-KB/s    in 0.03s
2020-02-08 20:24:21 (670 KB/s) - ‘install.sh.8’ saved [23463]
请输入 y or n(默认 yes):n
(2). 找到该系统中有以下用户名
    [1]: pi
    : 跳过
请输入 yes 或者 no(默认:yes):n
输入数字 (1-11):9
你选择了 raspberrypi3
# 1. 是否将系统源切换为中科大(USTC)源: 否
# 3. 是否将 Docker 源切换至国内源:     否
[info]: 跳过切换系统源。
[info]: 安装 hassio 必要依赖.....
Building dependency tree
Reading state information... Done
jq is already the newest version (1.5+dfsg-1.3).
socat is already the newest version (1.7.3.1-2+deb9u1).
avahi-daemon is already the newest version (0.7-4+b1).
curl is already the newest version (7.64.0-4).
net-tools is already the newest version (1.60+git20180626.aebd88e-1).
The following package was automatically installed and is no longer required:
  libssl1.0.0
Use 'apt autoremove' to remove it.
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
[info]: 安装 Docker 引擎.....
Release:        10
Codename:        buster
\033[0;31m[ERROR]: Docker 安装失败,请检查上方安装错误信息。 你也可以选择通过搜索引擎,搜索你系统安装docker的方法,安装后重新执行脚本。\033[0m
root@raspberrypi:~# ^C
root@raspberrypi:~#
 楼主| 发表于 2020-2-9 19:06:16 | 显示全部楼层
zhenxiwen 发表于 2020-2-8 20:27
Xshell  (Build N/A)
不要切换源试试,新的树莓派系统可能切换源有问题,我没有树莓派也没法测试。
theo
发表于 2020-2-9 21:14:28 | 显示全部楼层
牛逼牛逼牛逼!感谢分享!
发表于 2020-2-10 09:33:21 | 显示全部楼层
大佬,N1使用U盘安装ARMBIAN debian9 使用一键脚本,HASSIO正常安装,可是总是出现HA无法访问都问题,reboot一下又可以了,请帮忙分析一下问题,谢谢!
20-02-10 01:11:00 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant Docker!
20-02-10 01:11:00 INFO (SyncWorker_14) [hassio.docker.interface] Start homeassistant/qemuarm-64-homeassistant
20-02-10 01:11:26 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation in progress
20-02-10 01:12:32 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation done
20-02-10 01:13:12 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
发表于 2020-2-10 09:34:30 | 显示全部楼层
HASSIO日志
发表于 2020-2-13 23:35:04 | 显示全部楼层
neroxps 发表于 2020-2-9 19:06
不要切换源试试,新的树莓派系统可能切换源有问题,我没有树莓派也没法测试。 ...
都试过了,结果一样。不是新的,是pi3.
berrypi3
[info]: 跳过切换系统源。
Get:4 http://mirrors.aliyun.com/debian stretch Release.gpg [2,410 B]
N: Uproot@raspberrypi:/home/pi# root@raspberrypi:/home/pi# wget https://code.aliyun.com/neroxps/hassio_install/r        aw/master/install.sh
bash: root@raspberrypi:/home/pi#: No such file or directory
root@raspberrypi:/home/pi# --2020-02-13 15:45:20--  https://code.aliyun.com/neroxps/hassio_install/raw/mast        er/install.sh
bash: --2020-02-13: command not found
root@raspberrypi:/home/pi# Resolving code.aliyun.com (code.aliyun.com)... 120.55.150.20
bash: syntax error near unexpected token `('
root@raspberrypi:/home/pi# Connecting to code.aliyun.com (code.aliyun.com)|120.55.150.20|:443... connected.
root@raspberrypi:/home/pi# HTTP request sent, awaiting response... 200 OK
bash: HTTP: command not found
root@raspberrypi:/home/pi# Length: unspecified [text/plain]
bash: Length:: command not found
root@raspberrypi:/home/pi# Saving to: ‘install.sh.2’
bash: Saving: command not found
#root@raspberrypi:/home/pi# install.sh.2            [ <=>                ]  22.91K  --.-KB/s    in 0.04s
bash: =: No such file or directory
root@raspberrypi:/home/pi# 2020-02-13 15:45:21 (596 KB/s) - ‘install.sh.2’ saved [23463]
root@raspberrypi:/home/pi# root@raspberrypi:/home/pi# chmod a+x install.sh
root@raspberrypi:/home/pi# root@raspberrypi:/home/pi# ./install.sh
root@raspberrypi:/home/pi# (1). 是否将系统源切换为中科大(USTC)源(目前支持 Debian Ubuntu Raspbian 三款系统)
bash: syntax error near unexpected token `.'
root@raspberrypi:/home/pi# 请输入 y or n(默认 yes):n
bash: syntax error near unexpected token `)'
root@raspberrypi:/home/pi# (2). 找到该系统中有以下用户名
root@raspberrypi:/home/pi# 如下方列表未显示你的用户名,请切换回你用户账号后输入 sudo usermod -aG docker $USER 添加用户到 docker 用户组。
bash: 如下方列表未显示你的用户名,请切换回你用户账号后输入: command not found
root@raspberrypi:/home/pi#     [1]: pi
bash: [1]:: command not found
root@raspberrypi:/home/pi#     [2]: systemd-coredump
bash: [2]:: command not found
root@raspberrypi:/home/pi#     : 跳过
bash: :: command not found
root@raspberrypi:/home/pi# 请输入你需要使用 docker 的用户名序号,以加入 docker 用户组:1
bash: 请输入你需要使用: command not found
root@raspberrypi:/home/pi# 将pi用户添加至 docker 用户组。
bash: 将pi用户添加至: command not found
root@raspberrypi:/home/pi# (3).是否需要替换 docker 默认源?
bash: syntax error near unexpected token `.是否需要替换'
root@raspberrypi:/home/pi# 请输入 yes 或者 no(默认:yes):n
bash: 请输入: command not found
▒root@raspberrypi:/home/pi#
root@raspberrypi:/home/pi# (4).请选择你设备类型(默认:qemux86)
bash: syntax error near unexpected token `.请选择你设备类型(默认:qemux86)'
root@raspberrypi:/home/pi#     [1]: intel-nuc: 英特尔的nuc小主机
root@raspberrypi:/home/pi#     [2]: odroid-c2: 韩国odroid-c2
root@raspberrypi:/home/pi#     [3]: odroid-xu: 韩国odroid-xu
bash: [3]:: command not found
root@raspberrypi:/home/pi#     [4]: orangepi-prime: 香橙派
bash: [4]:: command not found
root@raspberrypi:/home/pi#     [5]: qemuarm: 通用arm设备(例如斐讯N1)
root@raspberrypi:/home/pi#     [6]: qemux86: 通用X86(普通的PC机电脑)
bash: [6]:: command not found
root@raspberrypi:/home/pi#     [7]: raspberrypi: 树莓派一代
bash: [7]:: command not found
root@raspberrypi:/home/pi#     [8]: raspberrypi2: 树莓派二代
bash: [8]:: command not found
root@raspberrypi:/home/pi#     [9]: raspberrypi3: 树莓派三代
bash: [9]:: command not found
root@raspberrypi:/home/pi#     [10]: raspberrypi4: 树莓派四代
bash: [10]:: command not found
root@raspberrypi:/home/pi#     [11]: tinker: 华硕tinker
bash: [11]:: command not found
root@raspberrypi:/home/pi# 输入数字 (1-11):9
bash: syntax error near unexpected token `1-11'
root@raspberrypi:/home/pi# 你选择了 raspberrypi3
bash: 你选择了: command not found
root@raspberrypi:/home/pi# (5).是否需要设置 hassio 数据保存路径(默认:/usr/share/hassio)
bash: syntax error near unexpected token `.是否需要设置'
root@raspberrypi:/home/pi# 请输入 yes 或 no (默认:no):
root@raspberrypi:/home/pi# hassio 数据路径为默认路径: /usr/share/hassio
bash: hassio: command not found
root@raspberrypi:/home/pi#  ################################################################################
root@raspberrypi:/home/pi#  # 1. 是否将系统源切换为中科大(USTC)源: 否
root@raspberrypi:/home/pi#  # 2. 是否将用户添加至 Docker 用户组:   是,添加用户为 pi
root@raspberrypi:/home/pi#  # 3. 是否将 Docker 源切换至国内源:     否
root@raspberrypi:/home/pi#  # 4. 您的设备类型为:                   raspberrypi3
root@raspberrypi:/home/pi#  # 5. 您的 hassio 数据路径为:           /usr/share/hassio
root@raspberrypi:/home/pi# 请确认以上信息,继续请按任意键,如需修改请输入 Ctrl+C 结束任务重新执行脚本。
bash: 请确认以上信息,继续请按任意键,如需修改请输入: command not found
root@raspberrypi:/home/pi# [info]: 跳过切换系统源。
bash: [info]:: command not found
root@raspberrypi:/home/pi# [info]: 安装 hassio 必要依赖.....
root@raspberrypi:/home/pi# Hit:1 http://mirrors.aliyun.com/raspbian/raspbian stretch InRelease
bash: Hit:1: command not found
root@raspberrypi:/home/pi# Ign:2 http://mirrors.aliyun.com/debian stretch InRelease
bash: Ign:2: command not found
root@raspberrypi:/home/pi# Get:3 http://mirrors.aliyun.com/debian stretch Release [118 kB]
bash: Get:3: command not found
root@raspberrypi:/home/pi# Get:4 http://mirrors.aliyun.com/debian stretch Release.gpg [2,410 B]
bash: Get:4: command not found
root@raspberrypi:/home/pi# Ign:4 http://mirrors.aliyun.com/debian stretch Release.gpg
bash: Ign:4: command not found
root@raspberrypi:/home/pi# Reading package lists... Done
bash: Reading: command not found
root@raspberrypi:/home/pi# W: GPG error: http://mirrors.aliyun.com/debian stretch Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 7638D0442B90D010 NO_PUBKEY 04EE7237B7D453EC NO_PUBKEY EF0F382A1A7B6500
bash: W:: command not found
root@raspberrypi:/home/pi# N: See apt-secure(8) manpage for repository creation and user configuration details.
root@raspberrypi:/home/pi# Building dependency tree
bash: Building: command not found
root@raspberrypi:/home/pi# Reading state information... Done
root@raspberrypi:/home/pi# jq is already the newest version (1.5+dfsg-1.3).
root@raspberrypi:/home/pi# socat is already the newest version (1.7.3.1-2+deb9u1).
root@raspberrypi:/home/pi# avahi-daemon is already the newest version (0.7-4+b1).
root@raspberrypi:/home/pi# curl is already the newest version (7.64.0-4).
root@raspberrypi:/home/pi# net-tools is already the newest version (1.60+git20180626.aebd88e-1).
root@raspberrypi:/home/pi# 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
bash: 0: command not found
root@raspberrypi:/home/pi# [info]: 安装 Docker 引擎.....
root@raspberrypi:/home/pi# # Executing docker install script, commit: f45d7c11389849ff46a6b4d94e0dd1ffebca32c1
root@raspberrypi:/home/pi# + sh -c apt-get update -qq >/dev/null
bash: +: command not found
> Release:        10
> Codename:       buster
> Linux version 4.19.97-v7+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1294 SMP Thu Jan 30 13:15:58 GMT 2020
> Linux raspberrypi 4.19.97-v7+ #1294 SMP Thu Jan 30 13:15:58 GMT 2020 armv7l GNU/Linux
发表于 2020-2-14 00:15:13 | 显示全部楼层
请问下,更新失败后重新运行脚本安装的话,已经下载并解压缩过的文件会自动清理吗?
 楼主| 发表于 2020-2-14 14:40:45 | 显示全部楼层
不会
GMT+8, 2025-10-28 09:35 , Processed in 1.126934 second(s), 11 queries , MemCached On.
