楼主: neroxps
HASSIO 安装一键脚本
 火...   [复制链接]
发表于 2020-3-4 14:30:53 | 显示全部楼层
解决了,把hosts的相关东西删除了就好了
 楼主| 发表于 2020-3-4 14:37:31 | 显示全部楼层
换七牛试试。
发表于 2020-3-4 17:07:04 | 显示全部楼层
这得膜拜一下~收藏先
发表于 2020-3-4 18:14:52 | 显示全部楼层
[Info] Run Hass.io
等待 homeassistant 启动.............................................................................................................................................................................................................................................................................................................fail
########################### Docker images ###########################
REPOSITORY                                 TAG                 IMAGE ID            CREATED             SIZE
homeassistant/raspberrypi3-homeassistant   0.106.5             e32808f25269        3 hours ago         1.06GB
homeassistant/raspberrypi3-homeassistant   latest              e32808f25269        3 hours ago         1.06GB
homeassistant/armv7-hassio-audio           8                   de299567f999        19 hours ago        44.9MB
homeassistant/raspberrypi3-homeassistant   0.106.4             a2247dcaa19c        28 hours ago        1.06GB
homeassistant/armv7-hassio-supervisor      207                 46dd32ca63fe        2 days ago          242MB
homeassistant/armv7-hassio-supervisor      latest              46dd32ca63fe        2 days ago          242MB
homeassistant/armv7-hassio-dns             1                   1b24f5e32994        6 months ago        51.8MB
########################### Docker ps ###########################
CONTAINER ID        IMAGE                                              COMMAND                  CREATED             STATUS                   PORTS               NAMES
908802659b0b        homeassistant/armv7-hassio-audio:8                 "/init"                  5 minutes ago       Up 5 minutes                                 hassio_audio
9ff1ac91f5ed        homeassistant/armv7-hassio-dns:1                   "coredns -conf /conf…"   5 minutes ago       Up 5 minutes                                 hassio_dns
abb4aaa9dfab        homeassistant/raspberrypi3-homeassistant:0.106.4   "/bin/entry.sh pytho…"   5 hours ago         Exited (0) 2 hours ago                       homeassistant
63df0a64c3c5        homeassistant/armv7-hassio-supervisor              "/init"                  5 hours ago         Up 5 minutes                                 hassio_supervisor
########################### hassio log ###########################
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] udev.sh: executing...
[04:49:45] INFO: Update udev informations
[cont-init.d] udev.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
20-03-04 04:49:49 INFO (MainThread) [__main__] Initialize Supervisor setup
20-03-04 04:49:49 INFO (MainThread) [supervisor.docker.network] Can't find Supervisor network, create new network
20-03-04 04:49:49 INFO (MainThread) [supervisor.bootstrap] Create Home Assistant configuration folder /data/homeassistant
20-03-04 04:49:49 INFO (MainThread) [supervisor.bootstrap] Create Supervisor SSL/TLS folder /data/ssl
20-03-04 04:49:49 INFO (MainThread) [supervisor.bootstrap] Create Supervisor Add-on data folder /data/addons/data
20-03-04 04:49:49 INFO (MainThread) [supervisor.bootstrap] Create Supervisor Add-on local repository folder /data/addons/local
20-03-04 04:49:49 INFO (MainThread) [supervisor.bootstrap] Create Supervisor Add-on git repositories folder /data/addons/git
20-03-04 04:49:49 INFO (MainThread) [supervisor.bootstrap] Create Supervisor temp folder /data/tmp
20-03-04 04:49:49 INFO (MainThread) [supervisor.bootstrap] Create Supervisor backup folder /data/backup
20-03-04 04:49:49 INFO (MainThread) [supervisor.bootstrap] Create Supervisor share folder /data/share
20-03-04 04:49:49 INFO (MainThread) [supervisor.bootstrap] Create Supervisor Apparmor folder /data/apparmor
20-03-04 04:49:49 INFO (MainThread) [supervisor.bootstrap] Create Supervisor DNS folder /data/dns
20-03-04 04:49:49 INFO (MainThread) [supervisor.bootstrap] Create Supervisor audio folder /data/audio
20-03-04 04:49:51 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attach to Supervisor homeassistant/armv7-hassio-supervisor with version 207
20-03-04 04:49:51 INFO (SyncWorker_0) [supervisor.docker.supervisor] Connect Supervisor to hassio Network
20-03-04 04:49:52 INFO (MainThread) [__main__] Setup Supervisor
20-03-04 04:49:52 INFO (MainThread) [supervisor.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
20-03-04 04:49:52 INFO (MainThread) [supervisor.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
20-03-04 04:49:52 WARNING (MainThread) [supervisor.dbus.rauc] Host has no rauc support. OTA updates have been disabled.
20-03-04 04:49:52 WARNING (MainThread) [supervisor.dbus.nmi_dns] No DnsManager support on the host. Local DNS functions have been disabled.
20-03-04 04:49:52 INFO (MainThread) [supervisor.host.info] Update local host information
20-03-04 04:49:52 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-03-04 04:49:52 INFO (MainThread) [supervisor.host.services] Update service information
20-03-04 04:49:52 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-03-04 04:49:52 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
20-03-04 04:49:52 INFO (MainThread) [supervisor.host.apparmor] Load AppArmor Profiles: set()
20-03-04 04:49:52 INFO (MainThread) [supervisor.host.apparmor] AppArmor is not enabled on host
20-03-04 04:49:53 INFO (MainThread) [supervisor.dns] No CoreDNS plugin Docker image homeassistant/armv7-hassio-dns found.
20-03-04 04:49:53 INFO (MainThread) [supervisor.dns] Setup CoreDNS plugin
20-03-04 04:49:53 INFO (SyncWorker_5) [supervisor.docker.interface] Pull image homeassistant/armv7-hassio-dns tag 1.
20-03-04 04:49:53 INFO (MainThread) [supervisor.audio] No Audio plugin Docker image homeassistant/armv7-hassio-audio found.
20-03-04 04:49:53 INFO (MainThread) [supervisor.audio] Setup Audio plugin
20-03-04 04:49:53 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-03-04 04:49:56 INFO (SyncWorker_2) [supervisor.docker.interface] Pull image homeassistant/armv7-hassio-audio tag 8.
20-03-04 04:51:11 INFO (MainThread) [supervisor.audio] Audio plugin now installed
20-03-04 04:51:11 INFO (MainThread) [supervisor.audio] Start Audio plugin
20-03-04 04:51:16 INFO (SyncWorker_4) [supervisor.docker.audio] Start Audio homeassistant/armv7-hassio-audio with version 8 - 172.30.32.4
20-03-04 04:51:44 INFO (MainThread) [supervisor.dns] CoreDNS plugin now installed
20-03-04 04:51:44 INFO (MainThread) [supervisor.dns] Start CoreDNS plugin
20-03-04 04:51:44 INFO (MainThread) [supervisor.misc.forwarder] Start DNS port forwarding to 172.30.32.3
20-03-04 04:51:50 INFO (SyncWorker_3) [supervisor.docker.dns] Start DNS homeassistant/armv7-hassio-dns with version 1 - 172.30.32.3
20-03-04 04:51:50 INFO (SyncWorker_8) [supervisor.docker.interface] Attach to homeassistant/raspberrypi3-homeassistant with version 0.106.4
20-03-04 04:51:50 INFO (MainThread) [supervisor.store.git] Clone add-on https://github.com/hassio-addons/repository repository
20-03-04 04:51:50 INFO (MainThread) [supervisor.store.git] Clone add-on https://github.com/home-assistant/hassio-addons repository
20-03-04 05:00:55 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/home-assistant/hassio-addons repository: Cmd('git') failed due to: exit code(128)
  cmdline: git clone --depth=1 --recursive --shallow-submodules -v https://github.com/home-assistant/hassio-addons /data/addons/core
  stderr: 'Cloning into '/data/addons/core'...
POST git-upload-pack (192 bytes)
POST git-upload-pack (201 bytes)
error: RPC failed; curl 56 OpenSSL SSL_read: Connection reset by peer
fatal: the remote end hung up unexpectedly
fatal: early EOF
fatal: index-pack failed
20-03-04 05:00:55 ERROR (MainThread) [supervisor.store] Can't load from repository core
20-03-04 05:00:55 INFO (MainThread) [supervisor.store] Load add-ons from store: 44 all - 44 new - 0 remove
20-03-04 05:00:55 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
20-03-04 05:00:55 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-03-04 05:00:56 INFO (MainThread) [supervisor.snapshots] Found 0 snapshot files
20-03-04 05:00:56 INFO (MainThread) [supervisor.discovery] Load 0 messages
20-03-04 05:00:56 INFO (MainThread) [supervisor.ingress] Load 0 ingress session
20-03-04 05:00:56 INFO (MainThread) [supervisor.secrets] Load Home Assistant secrets: 0
20-03-04 05:00:56 INFO (MainThread) [__main__] Run Supervisor
20-03-04 05:00:56 INFO (MainThread) [supervisor.api] Start API on 172.30.32.2
20-03-04 05:00:56 INFO (MainThread) [supervisor.addons] Phase 'initialize' start 0 add-ons
20-03-04 05:00:56 INFO (MainThread) [supervisor.addons] Phase 'system' start 0 add-ons
20-03-04 05:00:56 INFO (MainThread) [supervisor.addons] Phase 'services' start 0 add-ons
20-03-04 05:00:57 INFO (SyncWorker_11) [supervisor.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.106.4
20-03-04 05:01:33 INFO (MainThread) [supervisor.homeassistant] Detect a running Home Assistant instance
20-03-04 05:01:33 INFO (MainThread) [supervisor.addons] Phase 'application' start 0 add-ons
20-03-04 05:01:33 INFO (MainThread) [supervisor.tasks] All core tasks are scheduled
20-03-04 05:01:33 INFO (MainThread) [supervisor.hwmon] Start Supervisor hardware monitor
20-03-04 05:01:33 INFO (MainThread) [supervisor.core] Supervisor is up and running
20-03-04 05:01:33 INFO (MainThread) [supervisor.host.info] Update local host information
20-03-04 05:01:33 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-03-04 05:01:33 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-03-04 05:01:33 INFO (MainThread) [supervisor.host.services] Update service information
20-03-04 05:01:33 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-03-04 05:01:33 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
20-03-04 07:01:33 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-03-04 07:08:13 INFO (MainThread) [supervisor.host.info] Update local host information
20-03-04 07:08:13 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-03-04 07:08:13 INFO (MainThread) [supervisor.host.services] Update service information
20-03-04 07:08:13 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-03-04 07:08:13 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
20-03-04 07:49:20 INFO (MainThread) [__main__] Stopping Supervisor
20-03-04 07:49:20 INFO (MainThread) [supervisor.hwmon] Stop Supervisor hardware monitor
20-03-04 07:49:20 INFO (MainThread) [supervisor.api] Stop API on 172.30.32.2
20-03-04 07:49:20 INFO (MainThread) [supervisor.misc.forwarder] Stop DNS forwarding
20-03-04 07:49:20 INFO (MainThread) [supervisor.core] Supervisor is down
20-03-04 07:49:20 INFO (MainThread) [__main__] Close Supervisor
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
s6-svscanctl: fatal: unable to control /var/run/s6/services: supervisor not listening
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
[fix-attrs.d] done.
[07:49:42] INFO: Update udev informations
[cont-init.d] done.
[services.d] done.
20-03-04 07:49:49 INFO (MainThread) [__main__] Initialize Supervisor setup
20-03-04 07:49:50 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attach to Supervisor homeassistant/armv7-hassio-supervisor with version 207
20-03-04 07:49:50 INFO (MainThread) [__main__] Setup Supervisor
20-03-04 07:49:50 INFO (MainThread) [supervisor.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
20-03-04 07:49:50 INFO (MainThread) [supervisor.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
20-03-04 07:49:50 WARNING (MainThread) [supervisor.dbus.rauc] Host has no rauc support. OTA updates have been disabled.
20-03-04 07:49:50 WARNING (MainThread) [supervisor.dbus.nmi_dns] No DnsManager support on the host. Local DNS functions have been disabled.
20-03-04 07:49:50 INFO (MainThread) [supervisor.host.info] Update local host information
20-03-04 07:49:50 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-03-04 07:49:50 INFO (MainThread) [supervisor.host.services] Update service information
20-03-04 07:49:50 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-03-04 07:49:51 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
20-03-04 07:49:51 INFO (MainThread) [supervisor.host.apparmor] Load AppArmor Profiles: set()
20-03-04 07:49:51 INFO (MainThread) [supervisor.host.apparmor] AppArmor is not enabled on host
20-03-04 07:49:51 INFO (SyncWorker_0) [supervisor.docker.interface] Attach to homeassistant/armv7-hassio-audio with version 8
20-03-04 07:49:51 INFO (SyncWorker_1) [supervisor.docker.interface] Attach to homeassistant/armv7-hassio-dns with version 1
20-03-04 07:49:51 INFO (MainThread) [supervisor.audio] Start Audio plugin
20-03-04 07:49:51 INFO (MainThread) [supervisor.dns] Start CoreDNS plugin
20-03-04 07:49:51 INFO (MainThread) [supervisor.misc.forwarder] Start DNS port forwarding to 172.30.32.3
20-03-04 07:49:51 INFO (SyncWorker_7) [supervisor.docker.interface] Clean hassio_audio application
20-03-04 07:49:51 INFO (SyncWorker_3) [supervisor.docker.interface] Clean hassio_dns application
20-03-04 07:49:55 INFO (SyncWorker_7) [supervisor.docker.audio] Start Audio homeassistant/armv7-hassio-audio with version 8 - 172.30.32.4
20-03-04 07:49:55 INFO (SyncWorker_3) [supervisor.docker.dns] Start DNS homeassistant/armv7-hassio-dns with version 1 - 172.30.32.3
20-03-04 07:49:55 INFO (SyncWorker_2) [supervisor.docker.interface] Attach to homeassistant/raspberrypi3-homeassistant with version 0.106.4
20-03-04 07:49:56 INFO (MainThread) [supervisor.store.git] Load add-on /data/addons/git/a0d7b954 repository
20-03-04 07:49:56 INFO (MainThread) [supervisor.store.git] Clone add-on https://github.com/home-assistant/hassio-addons repository
[fix-attrs.d] done.
[07:51:54] INFO: Update udev informations
[cont-init.d] done.
[services.d] done.
20-03-04 07:51:58 INFO (MainThread) [__main__] Initialize Supervisor setup
20-03-04 07:51:59 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attach to Supervisor homeassistant/armv7-hassio-supervisor with version 207
20-03-04 07:51:59 INFO (MainThread) [__main__] Setup Supervisor
20-03-04 07:51:59 INFO (MainThread) [supervisor.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
20-03-04 07:51:59 INFO (MainThread) [supervisor.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
20-03-04 07:51:59 WARNING (MainThread) [supervisor.dbus.rauc] Host has no rauc support. OTA updates have been disabled.
20-03-04 07:51:59 WARNING (MainThread) [supervisor.dbus.nmi_dns] No DnsManager support on the host. Local DNS functions have been disabled.
20-03-04 07:51:59 INFO (MainThread) [supervisor.host.info] Update local host information
20-03-04 07:51:59 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-03-04 07:52:00 INFO (MainThread) [supervisor.host.services] Update service information
20-03-04 07:52:00 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-03-04 07:52:00 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
20-03-04 07:52:00 INFO (MainThread) [supervisor.host.apparmor] Load AppArmor Profiles: set()
20-03-04 07:52:00 INFO (MainThread) [supervisor.host.apparmor] AppArmor is not enabled on host
20-03-04 07:52:00 INFO (SyncWorker_0) [supervisor.docker.interface] Attach to homeassistant/armv7-hassio-audio with version 8
20-03-04 07:52:00 INFO (SyncWorker_1) [supervisor.docker.interface] Attach to homeassistant/armv7-hassio-dns with version 1
20-03-04 07:52:00 INFO (MainThread) [supervisor.audio] Start Audio plugin
20-03-04 07:52:00 INFO (MainThread) [supervisor.dns] Start CoreDNS plugin
20-03-04 07:52:00 INFO (MainThread) [supervisor.misc.forwarder] Start DNS port forwarding to 172.30.32.3
20-03-04 07:52:00 INFO (SyncWorker_0) [supervisor.docker.interface] Clean hassio_audio application
20-03-04 07:52:00 INFO (SyncWorker_8) [supervisor.docker.interface] Clean hassio_dns application
20-03-04 07:52:03 INFO (SyncWorker_8) [supervisor.docker.dns] Start DNS homeassistant/armv7-hassio-dns with version 1 - 172.30.32.3
20-03-04 07:52:03 INFO (SyncWorker_0) [supervisor.docker.audio] Start Audio homeassistant/armv7-hassio-audio with version 8 - 172.30.32.4
20-03-04 07:52:03 INFO (SyncWorker_1) [supervisor.docker.interface] Attach to homeassistant/raspberrypi3-homeassistant with version 0.106.4
20-03-04 07:52:03 INFO (MainThread) [supervisor.store.git] Clone add-on https://github.com/home-assistant/hassio-addons repository
20-03-04 07:52:03 INFO (MainThread) [supervisor.store.git] Load add-on /data/addons/git/a0d7b954 repository
20-03-04 07:55:29 INFO (MainThread) [supervisor.store] Load add-ons from store: 64 all - 64 new - 0 remove
20-03-04 07:55:29 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
20-03-04 07:55:29 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-03-04 07:55:38 INFO (MainThread) [supervisor.snapshots] Found 0 snapshot files
20-03-04 07:55:38 INFO (MainThread) [supervisor.discovery] Load 0 messages
20-03-04 07:55:38 INFO (MainThread) [supervisor.ingress] Load 0 ingress session
20-03-04 07:55:38 INFO (MainThread) [supervisor.secrets] Load Home Assistant secrets: 1
20-03-04 07:55:38 INFO (MainThread) [__main__] Run Supervisor
20-03-04 07:55:38 INFO (MainThread) [supervisor.api] Start API on 172.30.32.2
20-03-04 07:55:38 INFO (MainThread) [supervisor.addons] Phase 'initialize' start 0 add-ons
20-03-04 07:55:38 INFO (MainThread) [supervisor.core] Supervisor reboot detected
20-03-04 07:55:38 INFO (MainThread) [supervisor.tasks] All core tasks are scheduled
20-03-04 07:55:38 INFO (MainThread) [supervisor.hwmon] Start Supervisor hardware monitor
20-03-04 07:55:38 INFO (MainThread) [supervisor.core] Supervisor is up and running
20-03-04 07:55:38 INFO (MainThread) [supervisor.host.info] Update local host information
20-03-04 07:55:38 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-03-04 07:55:39 INFO (MainThread) [supervisor.host.services] Update service information
20-03-04 07:55:39 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-03-04 07:55:39 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
20-03-04 09:55:38 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-03-04 10:02:18 INFO (MainThread) [supervisor.host.info] Update local host information
20-03-04 10:02:18 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-03-04 10:02:19 INFO (MainThread) [supervisor.host.services] Update service information
20-03-04 10:02:19 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-03-04 10:02:19 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
20-03-04 10:03:05 INFO (MainThread) [__main__] Stopping Supervisor
20-03-04 10:03:05 INFO (MainThread) [supervisor.hwmon] Stop Supervisor hardware monitor
20-03-04 10:03:05 INFO (MainThread) [supervisor.api] Stop API on 172.30.32.2
20-03-04 10:03:05 INFO (MainThread) [supervisor.misc.forwarder] Stop DNS forwarding
20-03-04 10:03:05 INFO (MainThread) [supervisor.core] Supervisor is down
20-03-04 10:03:05 INFO (MainThread) [__main__] Close Supervisor
[fix-attrs.d] done.
[10:03:26] INFO: Update udev informations
[cont-init.d] done.
[services.d] done.
20-03-04 10:03:31 INFO (MainThread) [__main__] Initialize Supervisor setup
20-03-04 10:03:31 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attach to Supervisor homeassistant/armv7-hassio-supervisor with version 207
20-03-04 10:03:32 INFO (MainThread) [__main__] Setup Supervisor
20-03-04 10:03:32 INFO (MainThread) [supervisor.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
20-03-04 10:03:32 INFO (MainThread) [supervisor.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
20-03-04 10:03:32 WARNING (MainThread) [supervisor.dbus.rauc] Host has no rauc support. OTA updates have been disabled.
20-03-04 10:03:32 WARNING (MainThread) [supervisor.dbus.nmi_dns] No DnsManager support on the host. Local DNS functions have been disabled.
20-03-04 10:03:32 INFO (MainThread) [supervisor.host.info] Update local host information
20-03-04 10:03:32 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-03-04 10:03:32 INFO (MainThread) [supervisor.host.services] Update service information
20-03-04 10:03:33 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-03-04 10:03:33 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
20-03-04 10:03:33 INFO (MainThread) [supervisor.host.apparmor] Load AppArmor Profiles: set()
20-03-04 10:03:33 INFO (MainThread) [supervisor.host.apparmor] AppArmor is not enabled on host
20-03-04 10:03:33 INFO (SyncWorker_2) [supervisor.docker.interface] Attach to homeassistant/armv7-hassio-dns with version 1
20-03-04 10:03:33 INFO (SyncWorker_4) [supervisor.docker.interface] Attach to homeassistant/armv7-hassio-audio with version 8
20-03-04 10:03:33 INFO (MainThread) [supervisor.dns] Start CoreDNS plugin
20-03-04 10:03:33 INFO (SyncWorker_1) [supervisor.docker.interface] Clean hassio_dns application
20-03-04 10:03:33 INFO (MainThread) [supervisor.misc.forwarder] Start DNS port forwarding to 172.30.32.3
20-03-04 10:03:33 INFO (MainThread) [supervisor.audio] Start Audio plugin
20-03-04 10:03:33 INFO (SyncWorker_3) [supervisor.docker.interface] Clean hassio_audio application
20-03-04 10:03:37 INFO (SyncWorker_3) [supervisor.docker.audio] Start Audio homeassistant/armv7-hassio-audio with version 8 - 172.30.32.4
20-03-04 10:03:37 INFO (SyncWorker_1) [supervisor.docker.dns] Start DNS homeassistant/armv7-hassio-dns with version 1 - 172.30.32.3
20-03-04 10:03:37 INFO (SyncWorker_6) [supervisor.docker.interface] Attach to homeassistant/raspberrypi3-homeassistant with version 0.106.4
20-03-04 10:03:38 INFO (MainThread) [supervisor.store.git] Load add-on /data/addons/git/a0d7b954 repository
20-03-04 10:03:38 INFO (MainThread) [supervisor.store.git] Load add-on /data/addons/core repository
20-03-04 10:03:39 INFO (MainThread) [supervisor.store] Load add-ons from store: 64 all - 64 new - 0 remove
20-03-04 10:03:39 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
20-03-04 10:03:39 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-03-04 10:03:44 INFO (MainThread) [supervisor.snapshots] Found 0 snapshot files
20-03-04 10:03:44 INFO (MainThread) [supervisor.discovery] Load 0 messages
20-03-04 10:03:44 INFO (MainThread) [supervisor.ingress] Load 0 ingress session
20-03-04 10:03:44 INFO (MainThread) [supervisor.secrets] Load Home Assistant secrets: 1
20-03-04 10:03:44 INFO (MainThread) [__main__] Run Supervisor
20-03-04 10:03:44 INFO (MainThread) [supervisor.api] Start API on 172.30.32.2
20-03-04 10:03:44 INFO (MainThread) [supervisor.addons] Phase 'initialize' start 0 add-ons
20-03-04 10:03:44 INFO (MainThread) [supervisor.core] Supervisor reboot detected
20-03-04 10:03:44 INFO (MainThread) [supervisor.tasks] All core tasks are scheduled
20-03-04 10:03:44 INFO (MainThread) [supervisor.hwmon] Start Supervisor hardware monitor
20-03-04 10:03:44 INFO (MainThread) [supervisor.core] Supervisor is up and running
20-03-04 10:03:44 INFO (MainThread) [supervisor.host.info] Update local host information
20-03-04 10:03:44 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-03-04 10:03:45 INFO (MainThread) [supervisor.host.services] Update service information
20-03-04 10:03:45 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-03-04 10:03:45 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
########################### homeassistant log ###########################
Unable to find configuration. Creating default one in /config
2020-03-04 13:01:11 INFO (MainThread) [homeassistant.bootstrap] Config directory: /config
2020-03-04 13:01:11 INFO (SyncWorker_0) [homeassistant.loader] Loaded homeassistant from homeassistant.components.homeassistant
2020-03-04 13:01:11 INFO (SyncWorker_4) [homeassistant.loader] Loaded persistent_notification from homeassistant.components.persistent_notification
2020-03-04 13:01:11 INFO (MainThread) [homeassistant.setup] Setting up homeassistant
2020-03-04 13:01:11 INFO (MainThread) [homeassistant.setup] Setup of domain homeassistant took 0.0 seconds.
2020-03-04 13:01:11 INFO (MainThread) [homeassistant.setup] Setting up persistent_notification
2020-03-04 13:01:11 INFO (MainThread) [homeassistant.setup] Setup of domain persistent_notification took 0.0 seconds.
2020-03-04 13:01:11 INFO (SyncWorker_2) [homeassistant.loader] Loaded hassio from homeassistant.components.hassio
2020-03-04 13:01:11 INFO (SyncWorker_11) [homeassistant.loader] Loaded http from homeassistant.components.http
2020-03-04 13:01:11 INFO (SyncWorker_1) [homeassistant.loader] Loaded scene from homeassistant.components.scene
2020-03-04 13:01:11 INFO (SyncWorker_9) [homeassistant.loader] Loaded script from homeassistant.components.script
2020-03-04 13:01:11 INFO (SyncWorker_10) [homeassistant.loader] Loaded default_config from homeassistant.components.default_config
2020-03-04 13:01:11 INFO (SyncWorker_8) [homeassistant.loader] Loaded group from homeassistant.components.group
2020-03-04 13:01:11 INFO (SyncWorker_5) [homeassistant.loader] Loaded automation from homeassistant.components.automation
2020-03-04 13:01:11 INFO (SyncWorker_4) [homeassistant.loader] Loaded tts from homeassistant.components.tts
2020-03-04 13:01:11 INFO (SyncWorker_7) [homeassistant.loader] Loaded panel_custom from homeassistant.components.panel_custom
2020-03-04 13:01:11 INFO (SyncWorker_13) [homeassistant.loader] Loaded device_automation from homeassistant.components.device_automation
2020-03-04 13:01:11 INFO (SyncWorker_14) [homeassistant.loader] Loaded frontend from homeassistant.components.frontend
2020-03-04 13:01:11 INFO (SyncWorker_2) [homeassistant.loader] Loaded webhook from homeassistant.components.webhook
2020-03-04 13:01:11 INFO (SyncWorker_14) [homeassistant.loader] Loaded api from homeassistant.components.api
2020-03-04 13:01:11 INFO (SyncWorker_11) [homeassistant.loader] Loaded cloud from homeassistant.components.cloud
2020-03-04 13:01:11 INFO (SyncWorker_16) [homeassistant.loader] Loaded auth from homeassistant.components.auth
2020-03-04 13:01:11 INFO (SyncWorker_9) [homeassistant.loader] Loaded config from homeassistant.components.config
2020-03-04 13:01:11 INFO (SyncWorker_8) [homeassistant.loader] Loaded lovelace from homeassistant.components.lovelace
2020-03-04 13:01:11 INFO (SyncWorker_4) [homeassistant.loader] Loaded onboarding from homeassistant.components.onboarding
2020-03-04 13:01:11 INFO (SyncWorker_6) [homeassistant.loader] Loaded person from homeassistant.components.person
2020-03-04 13:01:11 INFO (SyncWorker_18) [homeassistant.loader] Loaded search from homeassistant.components.search
2020-03-04 13:01:11 INFO (SyncWorker_13) [homeassistant.loader] Loaded websocket_api from homeassistant.components.websocket_api
2020-03-04 13:01:11 INFO (SyncWorker_3) [homeassistant.loader] Loaded system_log from homeassistant.components.system_log
2020-03-04 13:01:11 INFO (SyncWorker_2) [homeassistant.loader] Loaded history from homeassistant.components.history
2020-03-04 13:01:11 INFO (SyncWorker_14) [homeassistant.loader] Loaded recorder from homeassistant.components.recorder
2020-03-04 13:01:11 INFO (SyncWorker_11) [homeassistant.loader] Loaded logbook from homeassistant.components.logbook
2020-03-04 13:01:11 INFO (SyncWorker_16) [homeassistant.loader] Loaded map from homeassistant.components.map
2020-03-04 13:01:11 INFO (SyncWorker_9) [homeassistant.loader] Loaded mobile_app from homeassistant.components.mobile_app
2020-03-04 13:01:11 INFO (SyncWorker_7) [homeassistant.loader] Loaded ssdp from homeassistant.components.ssdp
2020-03-04 13:01:12 INFO (SyncWorker_0) [homeassistant.loader] Loaded sun from homeassistant.components.sun
2020-03-04 13:01:12 INFO (SyncWorker_17) [homeassistant.loader] Loaded system_health from homeassistant.components.system_health
2020-03-04 13:01:12 INFO (SyncWorker_19) [homeassistant.loader] Loaded updater from homeassistant.components.updater
2020-03-04 13:01:12 INFO (SyncWorker_15) [homeassistant.loader] Loaded zeroconf from homeassistant.components.zeroconf
2020-03-04 13:01:12 INFO (SyncWorker_12) [homeassistant.loader] Loaded zone from homeassistant.components.zone
2020-03-04 13:01:12 INFO (MainThread) [homeassistant.bootstrap] Setting up {'system_log'}
2020-03-04 13:01:12 INFO (MainThread) [homeassistant.setup] Setting up http
2020-03-04 13:01:12 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.0 seconds.
2020-03-04 13:01:12 INFO (MainThread) [homeassistant.setup] Setting up system_log
2020-03-04 13:01:12 INFO (MainThread) [homeassistant.setup] Setup of domain system_log took 0.0 seconds.
2020-03-04 13:01:13 INFO (MainThread) [homeassistant.setup] Setting up recorder
2020-03-04 13:01:13 INFO (MainThread) [homeassistant.setup] Setting up webhook
2020-03-04 13:01:13 INFO (MainThread) [homeassistant.setup] Setup of domain webhook took 0.0 seconds.
2020-03-04 13:01:13 INFO (SyncWorker_9) [homeassistant.loader] Loaded alexa from homeassistant.components.alexa
2020-03-04 13:01:13 INFO (SyncWorker_4) [homeassistant.loader] Loaded google_assistant from homeassistant.components.google_assistant
2020-03-04 13:01:13 INFO (SyncWorker_6) [homeassistant.loader] Loaded camera from homeassistant.components.camera
2020-03-04 13:01:13 INFO (SyncWorker_18) [homeassistant.loader] Loaded media_player from homeassistant.components.media_player
2020-03-04 13:01:24 INFO (MainThread) [homeassistant.setup] Setting up cloud
2020-03-04 13:01:24 WARNING (MainThread) [homeassistant.setup] Setup of recorder is taking over 10 seconds.
2020-03-04 13:01:24 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 10.8 seconds.
2020-03-04 13:01:24 INFO (MainThread) [homeassistant.setup] Setup of domain cloud took 0.1 seconds.
2020-03-04 13:01:24 INFO (MainThread) [homeassistant.setup] Setting up lovelace
2020-03-04 13:01:24 INFO (MainThread) [homeassistant.setup] Setup of domain lovelace took 0.0 seconds.
2020-03-04 13:01:24 INFO (MainThread) [homeassistant.setup] Setting up scene
2020-03-04 13:01:24 INFO (MainThread) [homeassistant.components.scene] Setting up scene.homeassistant
2020-03-04 13:01:24 INFO (MainThread) [homeassistant.setup] Setting up zone
2020-03-04 13:01:24 INFO (MainThread) [homeassistant.setup] Setting up sun
2020-03-04 13:01:24 INFO (MainThread) [homeassistant.setup] Setup of domain sun took 0.2 seconds.
2020-03-04 13:01:24 INFO (MainThread) [homeassistant.setup] Setting up updater
2020-03-04 13:01:24 INFO (MainThread) [homeassistant.setup] Setting up ssdp
2020-03-04 13:01:24 INFO (MainThread) [homeassistant.setup] Setup of domain ssdp took 0.0 seconds.
2020-03-04 13:01:24 INFO (MainThread) [homeassistant.setup] Setting up group
2020-03-04 13:01:24 INFO (MainThread) [homeassistant.setup] Setup of domain group took 0.0 seconds.
2020-03-04 13:01:25 INFO (MainThread) [homeassistant.setup] Setting up person
2020-03-04 13:01:25 INFO (MainThread) [homeassistant.setup] Setting up device_automation
2020-03-04 13:01:25 INFO (MainThread) [homeassistant.setup] Setup of domain device_automation took 0.0 seconds.
2020-03-04 13:01:25 INFO (MainThread) [homeassistant.setup] Setting up websocket_api
2020-03-04 13:01:25 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.0 seconds.
2020-03-04 13:01:25 INFO (MainThread) [homeassistant.setup] Setting up system_health
2020-03-04 13:01:25 INFO (MainThread) [homeassistant.setup] Setup of domain system_health took 0.0 seconds.
2020-03-04 13:01:25 INFO (MainThread) [homeassistant.setup] Setting up config
2020-03-04 13:01:25 INFO (MainThread) [homeassistant.setup] Setting up api
2020-03-04 13:01:25 INFO (MainThread) [homeassistant.setup] Setting up history
2020-03-04 13:01:25 INFO (MainThread) [homeassistant.setup] Setup of domain history took 0.0 seconds.
2020-03-04 13:01:25 INFO (MainThread) [homeassistant.setup] Setting up script
2020-03-04 13:01:25 INFO (MainThread) [homeassistant.setup] Setup of domain script took 0.0 seconds.
2020-03-04 13:01:25 INFO (MainThread) [homeassistant.setup] Setup of domain scene took 1.0 seconds.
2020-03-04 13:01:25 INFO (MainThread) [homeassistant.setup] Setting up auth
2020-03-04 13:01:25 INFO (MainThread) [homeassistant.setup] Setup of domain auth took 0.0 seconds.
2020-03-04 13:01:25 INFO (MainThread) [homeassistant.setup] Setting up search
2020-03-04 13:01:25 INFO (MainThread) [homeassistant.setup] Setup of domain search took 0.0 seconds.
2020-03-04 13:01:25 INFO (MainThread) [homeassistant.setup] Setup of domain api took 0.1 seconds.
2020-03-04 13:01:25 INFO (MainThread) [homeassistant.setup] Setup of domain person took 0.2 seconds.
2020-03-04 13:01:25 INFO (MainThread) [homeassistant.setup] Setting up automation
2020-03-04 13:01:25 INFO (MainThread) [homeassistant.setup] Setup of domain automation took 0.0 seconds.
2020-03-04 13:01:25 INFO (MainThread) [homeassistant.setup] Setup of domain config took 0.2 seconds.
2020-03-04 13:01:25 INFO (MainThread) [homeassistant.setup] Setup of domain zone took 1.2 seconds.
2020-03-04 13:01:25 INFO (MainThread) [homeassistant.setup] Setting up onboarding
2020-03-04 13:01:25 INFO (SyncWorker_16) [homeassistant.loader] Loaded device_tracker from homeassistant.components.device_tracker
2020-03-04 13:01:25 INFO (MainThread) [homeassistant.setup] Setting up zeroconf
2020-03-04 13:01:25 INFO (MainThread) [homeassistant.setup] Setting up mobile_app
2020-03-04 13:01:25 INFO (MainThread) [homeassistant.setup] Setup of domain mobile_app took 0.0 seconds.
2020-03-04 13:01:25 INFO (MainThread) [homeassistant.setup] Setup of domain onboarding took 0.4 seconds.
2020-03-04 13:01:25 INFO (SyncWorker_18) [homeassistant.loader] Loaded notify from homeassistant.components.notify
2020-03-04 13:01:26 INFO (MainThread) [homeassistant.setup] Setting up notify
2020-03-04 13:01:26 INFO (MainThread) [homeassistant.setup] Setup of domain notify took 0.0 seconds.
2020-03-04 13:01:26 INFO (MainThread) [homeassistant.setup] Setup of domain zeroconf took 0.8 seconds.
2020-03-04 13:01:26 INFO (MainThread) [homeassistant.components.notify] Setting up notify.mobile_app
2020-03-04 13:01:26 INFO (MainThread) [homeassistant.setup] Setting up frontend
2020-03-04 13:01:26 INFO (MainThread) [homeassistant.setup] Setup of domain frontend took 0.0 seconds.
2020-03-04 13:01:26 INFO (MainThread) [homeassistant.setup] Setting up panel_custom
2020-03-04 13:01:26 INFO (MainThread) [homeassistant.setup] Setup of domain panel_custom took 0.0 seconds.
2020-03-04 13:01:26 INFO (MainThread) [homeassistant.setup] Setting up map
2020-03-04 13:01:26 INFO (MainThread) [homeassistant.setup] Setup of domain map took 0.0 seconds.
2020-03-04 13:01:26 INFO (MainThread) [homeassistant.setup] Setting up logbook
2020-03-04 13:01:26 INFO (MainThread) [homeassistant.setup] Setup of domain logbook took 0.0 seconds.
2020-03-04 13:01:26 INFO (MainThread) [homeassistant.setup] Setting up hassio
2020-03-04 13:01:26 INFO (MainThread) [homeassistant.setup] Setup of domain hassio took 0.1 seconds.
2020-03-04 13:01:29 ERROR (MainThread) [homeassistant.components.updater] Could not contact Home Assistant Update to check for updates
2020-03-04 13:01:29 ERROR (MainThread) [homeassistant.components.updater] Error fetching Home Assistant update data:
2020-03-04 13:01:29 INFO (MainThread) [homeassistant.setup] Setup of domain updater took 5.0 seconds.
2020-03-04 13:01:29 INFO (SyncWorker_8) [homeassistant.loader] Loaded binary_sensor from homeassistant.components.binary_sensor
2020-03-04 13:01:30 INFO (MainThread) [homeassistant.setup] Setting up default_config
2020-03-04 13:01:30 INFO (MainThread) [homeassistant.setup] Setting up binary_sensor
2020-03-04 13:01:30 INFO (MainThread) [homeassistant.setup] Setup of domain binary_sensor took 0.0 seconds.
2020-03-04 13:01:30 INFO (SyncWorker_7) [homeassistant.loader] Loaded stream from homeassistant.components.stream
2020-03-04 13:01:30 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.updater
2020-03-04 13:01:30 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new binary_sensor.updater entity: binary_sensor.updater
2020-03-04 13:01:30 INFO (MainThread) [homeassistant.setup] Setting up stream
2020-03-04 13:01:30 INFO (MainThread) [homeassistant.setup] Setup of domain stream took 0.0 seconds.
2020-03-04 13:01:30 INFO (MainThread) [homeassistant.setup] Setup of domain default_config took 0.1 seconds.
2020-03-04 13:01:30 INFO (SyncWorker_4) [homeassistant.loader] Loaded google_translate from homeassistant.components.google_translate
2020-03-04 13:01:30 INFO (MainThread) [homeassistant.setup] Setting up tts
2020-03-04 13:01:30 INFO (SyncWorker_6) [homeassistant.components.tts] Create cache dir /config/tts.
2020-03-04 13:01:30 INFO (MainThread) [homeassistant.setup] Setup of domain tts took 0.0 seconds.
2020-03-04 13:01:30 INFO (MainThread) [homeassistant.bootstrap] Home Assistant initialized in 19.37s
2020-03-04 13:01:30 INFO (MainThread) [homeassistant.core] Starting Home Assistant
2020-03-04 13:01:30 INFO (SyncWorker_9) [homeassistant.components.zeroconf] Starting Zeroconf broadcast
2020-03-04 13:01:30 INFO (MainThread) [homeassistant.core] Timer:starting
2020-03-04 15:49:26 INFO (MainThread) [homeassistant.components.stream] Stopped stream workers.
2020-03-04 15:49:26 WARNING (SyncWorker_2) [zeroconf] Exception occurred:
  File "/usr/local/lib/python3.7/site-packages/zeroconf/__init__.py", line 2589, in send
    bytes_sent = s.sendto(packet, 0, (real_addr, port))
OSError: [Errno 101] Network unreachable
homeassistant 启动超时,请检查上方日志....或者重启操作系统
相关问题可以访问https://bbs.iobroker.cn或者加QQ群776817275咨询
发表于 2020-3-4 18:19:21 | 显示全部楼层
docker logs -f hassio_supervisor后有以下错误信息
20-03-04 05:00:55 ERROR (MainThread) [supervisor.store.git] Can't clone https://        github.com/home-assistant/hassio-addons repository: Cmd('git') failed due to: ex        it code(128)
  cmdline: git clone --depth=1 --recursive --shallow-submodules -v https://githu        b.com/home-assistant/hassio-addons /data/addons/core
fatal: early EOF
20-03-04 05:00:55 ERROR (MainThread) [supervisor.store] Can't load from reposito        ry core
发表于 2020-3-4 19:51:12 | 显示全部楼层
把脚本里的apt换成了yum,装了个jq依赖。就好了谢谢版主。-
请问支持CentOS么?——
在脚本里发现了yum。
但是报错了。麻烦版主帮忙看看
 楼主| 发表于 2020-3-5 08:43:54 | 显示全部楼层
请问支持CentOS么?——
不支持
 楼主| 发表于 2020-3-5 08:47:01 | 显示全部楼层
20-03-04 05:00:55 ERROR (MainThread) [supervisor ...
这个是 hassio 向 https://github.com/home-assistant/hassio-addons /data/addons/core pull 库的时候 因为网络问题,pull 超时的日志,不会影响使用,只是没了官方的addons 库。
 楼主| 发表于 2020-3-5 08:47:22 | 显示全部楼层
alonefisher 发表于 2020-3-4 18:14
Run Hass.io
等待 homeassistant 启动.............................................................. ...
没看出有什么问题,可能就是慢,重启下应该可以了
发表于 2020-3-6 21:32:57 | 显示全部楼层
james@james-ubuntu:~$ systemctl status hassio-supervisor
● hassio-supervisor.service - Hass.io supervisor
   Loaded: loaded (/etc/systemd/system/hassio-supervisor.service; enabled; vendo
   Active: active (running) since Fri 2020-03-06 21:12:25 CST; 1s ago
  Process: 7809 ExecStop=/usr/bin/docker stop hassio_supervisor (code=exited, st
  Process: 7914 ExecStartPre=/usr/bin/docker stop hassio_supervisor (code=exited
 Main PID: 7939 (hassio-supervis)
    Tasks: 7 (limit: 2247)
   CGroup: /system.slice/hassio-supervisor.service
           ├─7939 /bin/sh /usr/sbin/hassio-supervisor
           └─7961 docker start --attach hassio_supervisor
3月 06 21:12:27 james-ubuntu hassio-supervisor[7939]:     raise EnvironmentError
3月 06 21:12:27 james-ubuntu hassio-supervisor[7939]: OSError: Could not create
3月 06 21:12:27 james-ubuntu hassio-supervisor[7939]: 20-03-06 13:12:27 ERROR (M
3月 06 21:12:27 james-ubuntu hassio-supervisor[7939]: client_session: <aiohttp.c
3月 06 21:12:27 james-ubuntu hassio-supervisor[7939]: [cont-finish.d] executing
3月 06 21:12:27 james-ubuntu hassio-supervisor[7939]: [cont-finish.d] done.
3月 06 21:12:27 james-ubuntu hassio-supervisor[7939]: [s6-finish] waiting for se
3月 06 21:12:27 james-ubuntu hassio-supervisor[7939]: [s6-finish] sending all pr
3月 06 21:12:30 james-ubuntu hassio-supervisor[7939]: [s6-finish] sending all pr
3月 06 21:12:32 james-ubuntu docker[8359]: hassio_supervisor
lines 1-23...skipping...
   Loaded: loaded (/etc/systemd/system/hassio-supervisor.service; enabled; vendor preset: enabled)
  Process: 7809 ExecStop=/usr/bin/docker stop hassio_supervisor (code=exited, status=0/SUCCESS)
  Process: 7914 ExecStartPre=/usr/bin/docker stop hassio_supervisor (code=exited, status=0/SUCCESS)
3月 06 21:12:27 james-ubuntu hassio-supervisor[7939]:     raise EnvironmentError('Could not create udev monitor')
3月 06 21:12:27 james-ubuntu hassio-supervisor[7939]: OSError: Could not create udev monitor
3月 06 21:12:27 james-ubuntu hassio-supervisor[7939]: 20-03-06 13:12:27 ERROR (MainThread) [asyncio] Unclosed client session
3月 06 21:12:27 james-ubuntu hassio-supervisor[7939]: client_session: <aiohttp.client.ClientSession object at 0x7fdcc85a2110>
3月 06 21:12:27 james-ubuntu hassio-supervisor[7939]: client_session: <aiohttp.client.ClientSession object at 0x7fdcc8366050>
3月 06 21:12:27 james-ubuntu hassio-supervisor[7939]: [cont-finish.d] executing container finish scripts...
3月 06 21:12:27 james-ubuntu hassio-supervisor[7939]: [s6-finish] waiting for services.
3月 06 21:12:27 james-ubuntu hassio-supervisor[7939]: [s6-finish] sending all processes the TERM signal.
3月 06 21:12:30 james-ubuntu hassio-supervisor[7939]: [s6-finish] sending all processes the KILL signal and exiting.
lines 1-23/23 (END)
求助,昨晚开始突然连不上了,重启Ubuntu也没用,一直没有升级过hass,还是0.95.4
GMT+8, 2025-12-17 03:55 , Processed in 0.080400 second(s), 11 queries , MemCached On.
