楼主: neroxps
HASSIO 安装一键脚本
 火...   [复制链接]
发表于 2018-8-28 22:55:42 | 显示全部楼层
牛逼了,我的大大。
发表于 2018-8-29 14:17:41 | 显示全部楼层
Reading package lists... Done
Building dependency tree
Reading state information... Done
avahi-daemon is already the newest version (0.6.32-2).
curl is already the newest version (7.52.1-5+deb9u6).
The following NEW packages will be installed:
  jq libjq1 libonig4 socat
0 upgraded, 4 newly installed, 0 to remove and 0 not upgraded.
Need to get 127 kB/625 kB of archives.
After this operation, 1,822 kB of additional disk space will be used.
Err:1 http://mirrors.opencas.cn/raspbian/raspbian stretch/main armhf libonig4 armhf 6.1.3-2
  Cannot initiate the connection to mirrors.opencas.cn:80 (2001:cc0:2020:4075::211). - connect (101: Network is unreachable)
E: Failed to fetch http://mirrors.opencas.cn/raspbi ... 4_6.1.3-2_armhf.deb  Cannot initiate the connection to mirrors.opencas.cn:80 (2001:cc0:2020:4075::211). - connect (101: Network is unreachable)
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
[ERROR]: 安装curl失败,请将检查上方安装错误信息。
发表于 2018-8-29 15:37:21 | 显示全部楼层
neroxps 发表于 2018-8-28 18:51
看样子是docker 运行失败。手动运行
sudo systemctl start docker && sudo systemctl status docker
按论坛其他帖子一步步操作,到这一步有问题,
应该是docker没装上
发表于 2018-8-29 20:55:43 | 显示全部楼层
真好用
发表于 2018-8-29 21:52:58 | 显示全部楼层
正好需要重新安裝
來試試新的安裝方式
謝謝大大滴分享
发表于 2018-8-30 16:13:30 | 显示全部楼层
这个必须收藏一下
发表于 2018-8-30 16:36:41 | 显示全部楼层
沙发,来看看
发表于 2018-8-30 21:38:32 | 显示全部楼层
请问 N1 安装,【历史】【地图】打不开是什么原因。
发表于 2018-8-30 21:43:47 | 显示全部楼层
浏览器原因,哈哈。
发表于 2018-8-30 23:20:24 | 显示全部楼层
是不是不能用了
GMT+8, 2025-12-13 06:19 , Processed in 1.319012 second(s), 13 queries , MemCached On.
