楼主: neroxps
HASSIO 安装一键脚本
 火...   [复制链接]
发表于 2018-8-16 10:06:56 | 显示全部楼层
neroxps 发表于 2018-8-16 09:44
从配置文件那一节开始看。https://bbs.hassbian.com/thread-1921-1-1.html
谢谢回复,受益菲浅。受教了
发表于 2018-8-17 15:54:40 | 显示全部楼层
给大神点个赞   哈哈
发表于 2018-8-20 21:50:39 | 显示全部楼层
[info]: 安装 Docker 引擎.....
curl: (60) SSL certificate problem: certificate is not yet valid
More details here: http://curl.haxx.se/docs/sslcerts.html
curl performs SSL certificate verification by default, using a "bundle"
of Certificate Authority (CA) public keys (CA certs). If the default
bundle file isn't adequate, you can specify an alternate file
using the --cacert option.
If this HTTPS server uses a certificate signed by a CA represented in
the bundle, the certificate verification probably failed due to a
problem with the certificate (it might be expired, or the name might
not match the domain name in the URL).
If you'd like to turn off curl's verification of the certificate, use
the -k (or --insecure) option.
chmod: 无法访问"get-docker.sh": 没有那个文件或目录
./install.sh:行168: ./get-docker.sh: 没有那个文件或目录
[ERROR]: Docker 安装失败,请检查上方安装错误信息。
树莓派 3B 上安装出现如上错误提示,如何解决?
发表于 2018-8-20 22:02:51 | 显示全部楼层
必须收藏。大爱
发表于 2018-8-20 23:10:47 | 显示全部楼层
64和32 在3b+区别大?
 楼主| 发表于 2018-8-21 08:44:29 | 显示全部楼层
tom408881465 发表于 2018-8-20 21:50
: 安装 Docker 引擎.....
More detail ...
感觉像是你连接 get.docker.com受到中间人攻击,curl没法下载安装脚本下来啊。是不是网络有问题呢?
发表于 2018-8-22 20:25:43 | 显示全部楼层
爱你,大佬。
发表于 2018-8-23 08:26:13 | 显示全部楼层
curl: (6) Could not resolve host: get.docker.com
chmod: cannot access 'get-docker.sh': No such file or directory
./install.sh: line 168: ./get-docker.sh: No such file or directory
在域名服务器配置中,添加一个8.8.8.8,就解决了
# nano /etc/resolv.conf
# Generated by NetworkManager
nameserver 8.8.8.8
nameserver 211.155.23.88
nameserver 211.155.27.88
 楼主| 发表于 2018-8-23 08:29:22 | 显示全部楼层
mm苦衷乐 发表于 2018-8-23 08:26
: 安装 Docker 引擎.....
chmod: cannot access 'get-d ...
那可能是你运营商的dns解析不了这个域名。
发表于 2018-8-23 08:34:52 | 显示全部楼层
可能,最后我改了dns
GMT+8, 2025-12-13 06:21 , Processed in 0.054778 second(s), 11 queries , MemCached On.
