楼主: neroxps
HASSIO 安装一键脚本
 火...   [复制链接]
发表于 2019-7-24 23:34:18 | 显示全部楼层
您好,麻烦问一下在安装阶段出问题Unit hassio-supervisor.service could not be found.
这是log开始 hassio 安装流程。(如出现 [Warning] 请忽略,无须理会)
[Warning] No AppArmor support on host.
[Warning] No NetworkManager support on host.
Distributor ID: Raspbian
Description:    Raspbian GNU/Linux 10 (buster)
Release:        10
Codename:       buster
Linux version 4.19.57-v7+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1244 SMP Thu Jul 4 18:45:25 BST 2019
Linux raspberrypi 4.19.57-v7+ #1244 SMP Thu Jul 4 18:45:25 BST 2019 armv7l GNU/Linux
安装 hassio 失败,请将上方安装信息发送到论坛询问。脚本退出...
发表于 2019-7-25 09:54:28 | 显示全部楼层
neroxps 发表于 2019-7-22 17:36
[md]
请把你的配置文件夹备份后清空,重启系统,如果问题没有解决,再运行以下命令发上来求助
清除hassio文件后 执行下边的命令
docker ps
docker ps -a
docker logs hassio_supervisor
执行最后一项提示下面的错误
pi@raspberrypi:~ $ docker logs hassio_supervisor
19-07-25 00:22:49 INFO (MainThread) [__main__] Initialize Hass.io setup
19-07-25 00:22:49 INFO (MainThread) [hassio.docker.network] Can't find Hass.io network, create new network
19-07-25 00:22:50 INFO (MainThread) [hassio.bootstrap] Create Home Assistant configuration folder /data/homeassistant
19-07-25 00:22:50 INFO (MainThread) [hassio.bootstrap] Create Hass.io SSL/TLS folder /data/ssl
19-07-25 00:22:50 INFO (MainThread) [hassio.bootstrap] Create Hass.io Add-on data folder /data/addons/data
19-07-25 00:22:50 INFO (MainThread) [hassio.bootstrap] Create Hass.io Add-on local repository folder /data/addons/local
19-07-25 00:22:50 INFO (MainThread) [hassio.bootstrap] Create Hass.io Add-on git repositories folder /data/addons/git
19-07-25 00:22:50 INFO (MainThread) [hassio.bootstrap] Create Hass.io temp folder /data/tmp
19-07-25 00:22:50 INFO (MainThread) [hassio.bootstrap] Create Hass.io backup folder /data/backup
19-07-25 00:22:50 INFO (MainThread) [hassio.bootstrap] Create Hass.io share folder /data/share
19-07-25 00:22:50 INFO (MainThread) [hassio.bootstrap] Create Hass.io Apparmor folder /data/apparmor
19-07-25 00:22:50 INFO (MainThread) [__main__] Setup HassIO
19-07-25 00:22:50 INFO (SyncWorker_0) [hassio.docker.supervisor] Attach to Supervisor homeassistant/armv7-hassio-supervisor with version 170
19-07-25 00:22:50 INFO (SyncWorker_0) [hassio.docker.supervisor] Connect Supervisor to Hass.io Network
19-07-25 00:22:51 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.systemd1 on /org/freedesktop/systemd1
19-07-25 00:22:51 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
19-07-25 00:22:51 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.hostname1 on /org/freedesktop/hostname1
19-07-25 00:22:52 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
19-07-25 00:22:52 INFO (MainThread) [hassio.utils.gdbus] Introspect de.pengutronix.rauc on /
19-07-25 00:22:52 ERROR (MainThread) [hassio.utils.gdbus] DBus return error: b'Error: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name de.pengutronix.rauc was not provided by any .service files\n'
19-07-25 00:22:52 WARNING (MainThread) [hassio.dbus.rauc] Can't connect to rauc
19-07-25 00:22:52 INFO (MainThread) [hassio.host.info] Update local host information
19-07-25 00:22:52 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
19-07-25 00:22:52 INFO (MainThread) [hassio.host.services] Update service information
19-07-25 00:22:52 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
19-07-25 00:22:52 INFO (MainThread) [hassio.host.apparmor] Load AppArmor Profiles: set()
19-07-25 00:22:52 INFO (MainThread) [hassio.host.apparmor] AppArmor is not enabled on host
19-07-25 00:22:52 INFO (SyncWorker_2) [hassio.docker.interface] Attach to homeassistant/raspberrypi3-homeassistant with version 0.96.4
19-07-25 00:22:52 INFO (MainThread) [hassio.store.git] Clone add-on https://github.com/home-assistant/hassio-addons repository
19-07-25 00:22:52 INFO (MainThread) [hassio.store.git] Clone add-on https://github.com/hassio-addons/repository repository
19-07-25 00:23:02 INFO (MainThread) [hassio.store] Load add-ons from store: 59 all - 59 new - 0 remove
19-07-25 00:23:02 INFO (MainThread) [hassio.addons] Found 0 installed add-ons
19-07-25 00:23:02 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json
19-07-25 00:23:13 WARNING (MainThread) [hassio.updater] Can't fetch versions from https://version.home-assistant.io/stable.json:
19-07-25 00:23:13 INFO (MainThread) [hassio.snapshots] Found 0 snapshot files
19-07-25 00:23:13 INFO (MainThread) [hassio.discovery] Load 0 messages
19-07-25 00:23:13 INFO (MainThread) [hassio.ingress] Load 0 ingress session
19-07-25 00:23:13 INFO (MainThread) [__main__] Run Hass.io
19-07-25 00:23:13 INFO (MainThread) [hassio.misc.dns] Start DNS port forwarding for host add-ons
19-07-25 00:23:13 INFO (MainThread) [hassio.api] Start API on 172.30.32.2
19-07-25 00:23:13 INFO (MainThread) [hassio.addons] Phase 'initialize' start 0 add-ons
19-07-25 00:23:13 INFO (MainThread) [hassio.addons] Phase 'system' start 0 add-ons
19-07-25 00:23:13 INFO (MainThread) [hassio.addons] Phase 'services' start 0 add-ons
19-07-25 00:23:15 INFO (MainThread) [__main__] Stopping Hass.io
19-07-25 00:23:15 INFO (MainThread) [hassio.api] Stop API on 172.30.32.2
19-07-25 00:23:15 INFO (MainThread) [hassio.misc.dns] Stop DNS forwarding
19-07-25 00:23:15 INFO (MainThread) [hassio.core] Hass.io is down
19-07-25 00:23:15 INFO (MainThread) [__main__] Close Hass.io
19-07-25 00:23:15 INFO (SyncWorker_5) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.96.4
19-07-25 00:23:15 ERROR (SyncWorker_5) [concurrent.futures] exception calling callback for <Future at 0x72cd7cb0 state=finished returned NoneType>
  File "/usr/local/lib/python3.7/concurrent/futures/_base.py", line 324, in _invoke_callbacks
    callback(self)
  File "/usr/local/lib/python3.7/asyncio/futures.py", line 362, in _call_set_state
    dest_loop.call_soon_threadsafe(_set_state, destination, source)
  File "uvloop/loop.pyx", line 1261, in uvloop.loop.Loop.call_soon_threadsafe
  File "uvloop/loop.pyx", line 604, in uvloop.loop.Loop._call_soon
  File "uvloop/loop.pyx", line 608, in uvloop.loop.Loop._call_soon_handle
  File "uvloop/loop.pyx", line 637, in uvloop.loop.Loop._check_closed
RuntimeError: Event loop is closed
19-07-25 00:23:15 ERROR (MainThread) [asyncio] Task was destroyed but it is pending!
task: <Task pending coro=<HassIO.start() running at /usr/src/hassio/hassio/core.py:113> wait_for=<Future pending cb=[_chain_future.<locals>._call_check_cancel() at /usr/local/lib/python3.7/asyncio/futures.py:348, <TaskWakeupMethWrapper object at 0x72cd7df0>()]>>
19-07-25 00:23:52 INFO (MainThread) [__main__] Initialize Hass.io setup
19-07-25 00:23:52 INFO (MainThread) [__main__] Setup HassIO
19-07-25 00:23:53 INFO (SyncWorker_0) [hassio.docker.supervisor] Attach to Supervisor homeassistant/armv7-hassio-supervisor with version 170
19-07-25 00:23:53 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.systemd1 on /org/freedesktop/systemd1
19-07-25 00:23:53 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
19-07-25 00:23:53 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.hostname1 on /org/freedesktop/hostname1
19-07-25 00:23:53 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
19-07-25 00:23:53 INFO (MainThread) [hassio.utils.gdbus] Introspect de.pengutronix.rauc on /
19-07-25 00:23:53 ERROR (MainThread) [hassio.utils.gdbus] DBus return error: b'Error: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name de.pengutronix.rauc was not provided by any .service files\n'
19-07-25 00:23:53 WARNING (MainThread) [hassio.dbus.rauc] Can't connect to rauc
19-07-25 00:23:53 INFO (MainThread) [hassio.host.info] Update local host information
19-07-25 00:23:53 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
19-07-25 00:23:53 INFO (MainThread) [hassio.host.services] Update service information
19-07-25 00:23:53 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
19-07-25 00:23:53 INFO (MainThread) [hassio.host.apparmor] Load AppArmor Profiles: set()
19-07-25 00:23:53 INFO (MainThread) [hassio.host.apparmor] AppArmor is not enabled on host
19-07-25 00:23:53 INFO (SyncWorker_1) [hassio.docker.interface] Attach to homeassistant/raspberrypi3-homeassistant with version 0.96.4
19-07-25 00:23:53 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/git/a0d7b954 repository
19-07-25 00:23:53 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/core repository
19-07-25 00:23:54 INFO (MainThread) [hassio.store] Load add-ons from store: 59 all - 59 new - 0 remove
19-07-25 00:23:54 INFO (MainThread) [hassio.addons] Found 0 installed add-ons
19-07-25 00:23:54 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json
19-07-25 00:23:54 INFO (MainThread) [hassio.snapshots] Found 0 snapshot files
19-07-25 00:23:54 INFO (MainThread) [hassio.discovery] Load 0 messages
19-07-25 00:23:54 INFO (MainThread) [hassio.ingress] Load 0 ingress session
19-07-25 00:23:54 INFO (MainThread) [__main__] Run Hass.io
19-07-25 00:23:54 INFO (MainThread) [hassio.misc.dns] Start DNS port forwarding for host add-ons
19-07-25 00:23:54 INFO (MainThread) [hassio.api] Start API on 172.30.32.2
19-07-25 00:23:54 INFO (MainThread) [hassio.addons] Phase 'initialize' start 0 add-ons
19-07-25 00:23:54 INFO (MainThread) [hassio.addons] Phase 'system' start 0 add-ons
19-07-25 00:23:54 INFO (MainThread) [hassio.addons] Phase 'services' start 0 add-ons
19-07-25 00:23:54 INFO (SyncWorker_4) [hassio.docker.interface] Start homeassistant/raspberrypi3-homeassistant
19-07-25 00:24:00 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
19-07-25 00:24:00 INFO (MainThread) [hassio.addons] Phase 'application' start 0 add-ons
19-07-25 00:24:00 INFO (MainThread) [hassio.tasks] All core tasks are scheduled
19-07-25 00:24:00 INFO (MainThread) [hassio.core] Hass.io is up and running
19-07-25 00:41:15 INFO (MainThread) [__main__] Initialize Hass.io setup
19-07-25 00:41:18 INFO (MainThread) [__main__] Setup HassIO
19-07-25 00:41:18 INFO (SyncWorker_0) [hassio.docker.supervisor] Attach to Supervisor homeassistant/armv7-hassio-supervisor with version 170
19-07-25 00:41:18 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.systemd1 on /org/freedesktop/systemd1
19-07-25 00:41:18 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
19-07-25 00:41:18 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.hostname1 on /org/freedesktop/hostname1
19-07-25 00:41:18 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
19-07-25 00:41:18 INFO (MainThread) [hassio.utils.gdbus] Introspect de.pengutronix.rauc on /
19-07-25 00:41:18 ERROR (MainThread) [hassio.utils.gdbus] DBus return error: b'Error: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name de.pengutronix.rauc was not provided by any .service files\n'
19-07-25 00:41:18 WARNING (MainThread) [hassio.dbus.rauc] Can't connect to rauc
19-07-25 00:41:18 INFO (MainThread) [hassio.host.info] Update local host information
19-07-25 00:41:18 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
19-07-25 00:41:18 INFO (MainThread) [hassio.host.services] Update service information
19-07-25 00:41:18 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
19-07-25 00:41:18 INFO (MainThread) [hassio.host.apparmor] Load AppArmor Profiles: set()
19-07-25 00:41:18 INFO (MainThread) [hassio.host.apparmor] AppArmor is not enabled on host
19-07-25 00:41:18 INFO (SyncWorker_1) [hassio.docker.interface] Attach to homeassistant/raspberrypi3-homeassistant with version 0.96.4
19-07-25 00:41:19 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/core repository
19-07-25 00:41:19 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/git/a0d7b954 repository
19-07-25 00:41:19 INFO (MainThread) [hassio.store] Load add-ons from store: 59 all - 59 new - 0 remove
19-07-25 00:41:19 INFO (MainThread) [hassio.addons] Found 0 installed add-ons
19-07-25 00:41:19 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json
19-07-25 00:41:19 INFO (MainThread) [hassio.snapshots] Found 0 snapshot files
19-07-25 00:41:19 INFO (MainThread) [hassio.discovery] Load 0 messages
19-07-25 00:41:19 INFO (MainThread) [hassio.ingress] Load 0 ingress session
19-07-25 00:41:19 INFO (MainThread) [__main__] Run Hass.io
19-07-25 00:41:19 INFO (MainThread) [hassio.misc.dns] Start DNS port forwarding for host add-ons
19-07-25 00:41:19 INFO (MainThread) [hassio.api] Start API on 172.30.32.2
19-07-25 00:41:19 INFO (MainThread) [hassio.addons] Phase 'initialize' start 0 add-ons
19-07-25 00:41:19 INFO (MainThread) [hassio.addons] Phase 'system' start 0 add-ons
19-07-25 00:41:19 INFO (MainThread) [hassio.addons] Phase 'services' start 0 add-ons
19-07-25 00:41:19 INFO (SyncWorker_1) [hassio.docker.interface] Start homeassistant/raspberrypi3-homeassistant
19-07-25 00:41:25 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
19-07-25 00:41:25 INFO (MainThread) [hassio.addons] Phase 'application' start 0 add-ons
19-07-25 00:41:25 INFO (MainThread) [hassio.tasks] All core tasks are scheduled
19-07-25 00:41:25 INFO (MainThread) [hassio.core] Hass.io is up and running
19-07-25 01:36:21 INFO (MainThread) [__main__] Initialize Hass.io setup
19-07-25 01:36:21 INFO (MainThread) [__main__] Setup HassIO
19-07-25 01:36:21 INFO (SyncWorker_0) [hassio.docker.supervisor] Attach to Supervisor homeassistant/armv7-hassio-supervisor with version 170
19-07-25 01:36:21 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.systemd1 on /org/freedesktop/systemd1
19-07-25 01:36:22 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
19-07-25 01:36:22 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.hostname1 on /org/freedesktop/hostname1
19-07-25 01:36:22 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
19-07-25 01:36:22 INFO (MainThread) [hassio.utils.gdbus] Introspect de.pengutronix.rauc on /
19-07-25 01:36:22 ERROR (MainThread) [hassio.utils.gdbus] DBus return error: b'Error: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name de.pengutronix.rauc was not provided by any .service files\n'
19-07-25 01:36:22 WARNING (MainThread) [hassio.dbus.rauc] Can't connect to rauc
19-07-25 01:36:22 INFO (MainThread) [hassio.host.info] Update local host information
19-07-25 01:36:22 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
19-07-25 01:36:22 INFO (MainThread) [hassio.host.services] Update service information
19-07-25 01:36:22 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
19-07-25 01:36:22 INFO (MainThread) [hassio.host.apparmor] Load AppArmor Profiles: set()
19-07-25 01:36:22 INFO (MainThread) [hassio.host.apparmor] AppArmor is not enabled on host
19-07-25 01:36:22 INFO (SyncWorker_1) [hassio.docker.interface] Attach to homeassistant/raspberrypi3-homeassistant with version 0.96.4
19-07-25 01:36:23 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/core repository
19-07-25 01:36:23 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/git/a0d7b954 repository
19-07-25 01:36:23 INFO (MainThread) [hassio.store] Load add-ons from store: 59 all - 59 new - 0 remove
19-07-25 01:36:23 INFO (MainThread) [hassio.addons] Found 0 installed add-ons
19-07-25 01:36:23 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json
19-07-25 01:36:23 INFO (MainThread) [hassio.snapshots] Found 0 snapshot files
19-07-25 01:36:23 INFO (MainThread) [hassio.discovery] Load 0 messages
19-07-25 01:36:23 INFO (MainThread) [hassio.ingress] Load 0 ingress session
19-07-25 01:36:23 INFO (MainThread) [__main__] Run Hass.io
19-07-25 01:36:23 INFO (MainThread) [hassio.misc.dns] Start DNS port forwarding for host add-ons
19-07-25 01:36:23 INFO (MainThread) [hassio.api] Start API on 172.30.32.2
19-07-25 01:36:23 INFO (MainThread) [hassio.addons] Phase 'initialize' start 0 add-ons
19-07-25 01:36:23 INFO (MainThread) [hassio.addons] Phase 'system' start 0 add-ons
19-07-25 01:36:23 INFO (MainThread) [hassio.addons] Phase 'services' start 0 add-ons
19-07-25 01:36:23 INFO (SyncWorker_0) [hassio.docker.interface] Start homeassistant/raspberrypi3-homeassistant
19-07-25 01:36:29 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
19-07-25 01:36:29 INFO (MainThread) [hassio.addons] Phase 'application' start 0 add-ons
19-07-25 01:36:29 INFO (MainThread) [hassio.tasks] All core tasks are scheduled
19-07-25 01:36:29 INFO (MainThread) [hassio.core] Hass.io is up and running
19-07-25 01:46:07 INFO (MainThread) [__main__] Stopping Hass.io
19-07-25 01:46:07 INFO (MainThread) [hassio.api] Stop API on 172.30.32.2
19-07-25 01:46:07 ERROR (MainThread) [hassio.utils.json] Can't write /data/ingress.json: [Errno 2] No such file or directory: '/data/ingress.json'
19-07-25 01:46:07 INFO (MainThread) [hassio.misc.dns] Stop DNS forwarding
19-07-25 01:46:07 INFO (MainThread) [hassio.core] Hass.io is down
19-07-25 01:46:07 INFO (MainThread) [__main__] Close Hass.io
19-07-25 01:46:51 INFO (MainThread) [__main__] Initialize Hass.io setup
19-07-25 01:46:51 INFO (MainThread) [hassio.bootstrap] Create Home Assistant configuration folder /data/homeassistant
19-07-25 01:46:51 INFO (MainThread) [hassio.bootstrap] Create Hass.io SSL/TLS folder /data/ssl
19-07-25 01:46:51 INFO (MainThread) [hassio.bootstrap] Create Hass.io Add-on data folder /data/addons/data
19-07-25 01:46:51 INFO (MainThread) [hassio.bootstrap] Create Hass.io Add-on local repository folder /data/addons/local
19-07-25 01:46:51 INFO (MainThread) [hassio.bootstrap] Create Hass.io Add-on git repositories folder /data/addons/git
19-07-25 01:46:51 INFO (MainThread) [hassio.bootstrap] Create Hass.io temp folder /data/tmp
19-07-25 01:46:51 INFO (MainThread) [hassio.bootstrap] Create Hass.io backup folder /data/backup
19-07-25 01:46:51 INFO (MainThread) [hassio.bootstrap] Create Hass.io share folder /data/share
19-07-25 01:46:51 INFO (MainThread) [hassio.bootstrap] Create Hass.io Apparmor folder /data/apparmor
19-07-25 01:46:52 INFO (MainThread) [__main__] Setup HassIO
19-07-25 01:46:52 INFO (SyncWorker_0) [hassio.docker.supervisor] Attach to Supervisor homeassistant/armv7-hassio-supervisor with version 170
19-07-25 01:46:52 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.systemd1 on /org/freedesktop/systemd1
19-07-25 01:46:53 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
19-07-25 01:46:53 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.hostname1 on /org/freedesktop/hostname1
19-07-25 01:46:53 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
19-07-25 01:46:53 INFO (MainThread) [hassio.utils.gdbus] Introspect de.pengutronix.rauc on /
19-07-25 01:46:53 ERROR (MainThread) [hassio.utils.gdbus] DBus return error: b'Error: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name de.pengutronix.rauc was not provided by any .service files\n'
19-07-25 01:46:53 WARNING (MainThread) [hassio.dbus.rauc] Can't connect to rauc
19-07-25 01:46:53 INFO (MainThread) [hassio.host.info] Update local host information
19-07-25 01:46:53 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
19-07-25 01:46:53 INFO (MainThread) [hassio.host.services] Update service information
19-07-25 01:46:53 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
19-07-25 01:46:53 INFO (MainThread) [hassio.host.apparmor] Load AppArmor Profiles: set()
19-07-25 01:46:53 INFO (MainThread) [hassio.host.apparmor] AppArmor is not enabled on host
19-07-25 01:46:53 INFO (SyncWorker_0) [hassio.docker.interface] Attach to homeassistant/raspberrypi3-homeassistant with version 0.96.4
19-07-25 01:46:53 INFO (MainThread) [hassio.store.git] Clone add-on https://github.com/hassio-addons/repository repository
19-07-25 01:46:53 INFO (MainThread) [hassio.store.git] Clone add-on https://github.com/home-assistant/hassio-addons repository
19-07-25 01:47:09 INFO (MainThread) [hassio.store] Load add-ons from store: 59 all - 59 new - 0 remove
19-07-25 01:47:09 INFO (MainThread) [hassio.addons] Found 0 installed add-ons
19-07-25 01:47:10 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json
19-07-25 01:47:10 INFO (MainThread) [hassio.snapshots] Found 0 snapshot files
19-07-25 01:47:10 INFO (MainThread) [hassio.discovery] Load 0 messages
19-07-25 01:47:10 INFO (MainThread) [hassio.ingress] Load 0 ingress session
19-07-25 01:47:10 INFO (MainThread) [__main__] Run Hass.io
19-07-25 01:47:10 INFO (MainThread) [hassio.misc.dns] Start DNS port forwarding for host add-ons
19-07-25 01:47:10 INFO (MainThread) [hassio.api] Start API on 172.30.32.2
19-07-25 01:47:10 INFO (MainThread) [hassio.addons] Phase 'initialize' start 0 add-ons
19-07-25 01:47:10 INFO (MainThread) [hassio.addons] Phase 'system' start 0 add-ons
19-07-25 01:47:10 INFO (MainThread) [hassio.addons] Phase 'services' start 0 add-ons
19-07-25 01:47:10 INFO (SyncWorker_1) [hassio.docker.interface] Start homeassistant/raspberrypi3-homeassistant
19-07-25 01:47:16 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
19-07-25 01:47:16 INFO (MainThread) [hassio.addons] Phase 'application' start 0 add-ons
19-07-25 01:47:16 INFO (MainThread) [hassio.tasks] All core tasks are scheduled
19-07-25 01:47:16 INFO (MainThread) [hassio.core] Hass.io is up and running
19-07-25 01:47:29 ERROR (MainThread) [hassio.api.security] Invalid token for access /homeassistant/options
19-07-25 01:47:29 ERROR (MainThread) [hassio.api.security] Invalid token for access /supervisor/options
19-07-25 01:47:29 ERROR (MainThread) [hassio.api.security] Invalid token for access /homeassistant/info
19-07-25 01:47:29 ERROR (MainThread) [hassio.api.security] Invalid token for access /ingress/panels
19-07-25 01:47:33 ERROR (MainThread) [hassio.api.security] Invalid token for access /discovery
请问应该怎么解决,谢谢
 楼主| 发表于 2019-7-25 09:57:56 | 显示全部楼层
youquan 发表于 2019-7-25 09:54
清除hassio文件后 执行下边的命令
执行最后一项提示下面的错误
请问应该怎么解决,谢谢
docker ps
这句没有东西出来吗?
 楼主| 发表于 2019-7-25 10:00:20 | 显示全部楼层
这是log开始 hassi ...
mount
看看是不是SD卡只读了?
发表于 2019-7-25 10:02:37 | 显示全部楼层
neroxps 发表于 2019-7-25 09:57
docker ps
这句没有东西出来吗?
docker ps是下边的提示
root@raspberrypi:/home/pi# docker ps
CONTAINER ID        IMAGE                                      COMMAND                  CREATED             STATUS              PORTS                    NAMES
ee03949ac7ef        homeassistant/raspberrypi3-homeassistant   "/bin/entry.sh pytho…"   2 hours ago         Up 14 minutes                                homeassistant
b79dd9498a9f        homeassistant/armv7-hassio-supervisor      "/bin/entry.sh pytho…"   2 hours ago         Up 14 minutes                                hassio_supervisor
791fc48dab08        portainer/portainer:linux-arm              "/portainer"             4 days ago          Up 14 minutes       0.0.0.0:9000->9000/tcp   pensive_mestorf
docker ps -a的提示
root@raspberrypi:/home/pi# docker ps -aCONTAINER ID        IMAGE                                      COMMAND                  CREATED             STATUS              PORTS                    NAMESee03949ac7ef        homeassistant/raspberrypi3-homeassistant   "/bin/entry.sh pytho…"   2 hours ago         Up 17 minutes                                homeassistantb79dd9498a9f        homeassistant/armv7-hassio-supervisor      "/bin/entry.sh pytho…"   2 hours ago         Up 17 minutes                                hassio_supervisorea678edebf19        portainer/portainer:linux-arm              "/portainer"             4 days ago          Created                                      infallible_murdock791fc48dab08        portainer/portainer:linux-arm              "/portainer"             4 days ago          Up 18 minutes       0.0.0.0:9000->9000/tcp   pensive_mestorf
 楼主| 发表于 2019-7-25 10:11:09 | 显示全部楼层
youquan 发表于 2019-7-25 10:02
docker ps是下边的提示
ha 都启动两个小时了啊~
netstat -natp | grep 8123
这个命令看端口是否打开
docker logs homeassistant
这个看 ha 的日志
发表于 2019-7-25 10:17:54 | 显示全部楼层
neroxps 发表于 2019-7-25 10:11
ha 都启动两个小时了啊~
root@raspberrypi:/home/pi# netstat -natp | grep 8123
tcp        0      0 0.0.0.0:8123            0.0.0.0:*               LISTEN      429/python3
tcp        0      0 192.168.1.103:8123      192.168.1.100:61142     ESTABLISHED 429/python3
tcp        0      0 192.168.1.103:8123      192.168.1.100:61141     ESTABLISHED 429/python3
root@raspberrypi:/home/pi# docker logs homeassistant
2019-07-25 08:24:16 INFO (SyncWorker_3) [homeassistant.loader] Loaded script from homeassistant.components.script
2019-07-25 08:24:16 INFO (SyncWorker_4) [homeassistant.loader] Loaded automation from homeassistant.components.automation
2019-07-25 08:24:16 INFO (SyncWorker_0) [homeassistant.loader] Loaded default_config from homeassistant.components.default_config
2019-07-25 08:24:16 INFO (SyncWorker_9) [homeassistant.loader] Loaded hassio from homeassistant.components.hassio
2019-07-25 08:24:16 INFO (SyncWorker_10) [homeassistant.loader] Loaded group from homeassistant.components.group
2019-07-25 08:24:16 INFO (SyncWorker_3) [homeassistant.loader] Loaded http from homeassistant.components.http
2019-07-25 08:24:16 INFO (SyncWorker_5) [homeassistant.loader] Loaded tts from homeassistant.components.tts
2019-07-25 08:24:16 INFO (SyncWorker_6) [homeassistant.loader] Loaded homeassistant from homeassistant.components.homeassistant
2019-07-25 08:24:16 INFO (SyncWorker_2) [homeassistant.loader] Loaded persistent_notification from homeassistant.components.persistent_notification
2019-07-25 08:24:16 INFO (SyncWorker_12) [homeassistant.loader] Loaded panel_custom from homeassistant.components.panel_custom
2019-07-25 08:24:16 INFO (SyncWorker_11) [homeassistant.loader] Loaded webhook from homeassistant.components.webhook
2019-07-25 08:24:16 INFO (MainThread) [homeassistant.setup] Setting up homeassistant
2019-07-25 08:24:16 INFO (MainThread) [homeassistant.setup] Setup of domain homeassistant took 0.0 seconds.
2019-07-25 08:24:16 INFO (MainThread) [homeassistant.setup] Setting up persistent_notification
2019-07-25 08:24:16 INFO (MainThread) [homeassistant.setup] Setup of domain persistent_notification took 0.0 seconds.
2019-07-25 08:24:16 INFO (SyncWorker_0) [homeassistant.loader] Loaded frontend from homeassistant.components.frontend
2019-07-25 08:24:16 INFO (SyncWorker_13) [homeassistant.loader] Loaded cloud from homeassistant.components.cloud
2019-07-25 08:24:16 INFO (SyncWorker_4) [homeassistant.loader] Loaded api from homeassistant.components.api
2019-07-25 08:24:16 INFO (SyncWorker_10) [homeassistant.loader] Loaded config from homeassistant.components.config
2019-07-25 08:24:16 INFO (SyncWorker_15) [homeassistant.loader] Loaded auth from homeassistant.components.auth
2019-07-25 08:24:16 INFO (SyncWorker_7) [homeassistant.loader] Loaded lovelace from homeassistant.components.lovelace
2019-07-25 08:24:16 INFO (SyncWorker_5) [homeassistant.loader] Loaded onboarding from homeassistant.components.onboarding
2019-07-25 08:24:16 INFO (SyncWorker_2) [homeassistant.loader] Loaded system_log from homeassistant.components.system_log
2019-07-25 08:24:16 INFO (SyncWorker_11) [homeassistant.loader] Loaded websocket_api from homeassistant.components.websocket_api
2019-07-25 08:24:16 INFO (SyncWorker_8) [homeassistant.loader] Loaded history from homeassistant.components.history
2019-07-25 08:24:16 INFO (SyncWorker_9) [homeassistant.loader] Loaded recorder from homeassistant.components.recorder
2019-07-25 08:24:16 INFO (SyncWorker_13) [homeassistant.loader] Loaded logbook from homeassistant.components.logbook
2019-07-25 08:24:16 INFO (SyncWorker_14) [homeassistant.loader] Loaded map from homeassistant.components.map
2019-07-25 08:24:16 INFO (SyncWorker_4) [homeassistant.loader] Loaded mobile_app from homeassistant.components.mobile_app
2019-07-25 08:24:16 INFO (SyncWorker_3) [homeassistant.loader] Loaded person from homeassistant.components.person
2019-07-25 08:24:16 INFO (SyncWorker_16) [homeassistant.loader] Loaded ssdp from homeassistant.components.ssdp
2019-07-25 08:24:16 INFO (SyncWorker_6) [homeassistant.loader] Loaded sun from homeassistant.components.sun
2019-07-25 08:24:16 INFO (SyncWorker_12) [homeassistant.loader] Loaded system_health from homeassistant.components.system_health
2019-07-25 08:24:16 INFO (SyncWorker_17) [homeassistant.loader] Loaded updater from homeassistant.components.updater
2019-07-25 08:24:16 INFO (SyncWorker_18) [homeassistant.loader] Loaded zeroconf from homeassistant.components.zeroconf
2019-07-25 08:24:16 INFO (MainThread) [homeassistant.bootstrap] Setting up {'system_log'}
2019-07-25 08:24:17 INFO (MainThread) [homeassistant.setup] Setting up http
2019-07-25 08:24:17 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.0 seconds.
2019-07-25 08:24:17 INFO (MainThread) [homeassistant.setup] Setting up system_log
2019-07-25 08:24:17 INFO (MainThread) [homeassistant.setup] Setup of domain system_log took 0.0 seconds.
2019-07-25 08:24:17 INFO (MainThread) [homeassistant.setup] Setting up recorder
2019-07-25 08:24:18 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 1.3 seconds.
2019-07-25 08:24:18 INFO (MainThread) [homeassistant.setup] Setting up sun
2019-07-25 08:24:18 INFO (MainThread) [homeassistant.setup] Setup of domain sun took 0.1 seconds.
2019-07-25 08:24:18 INFO (MainThread) [homeassistant.setup] Setting up person
2019-07-25 08:24:19 INFO (MainThread) [homeassistant.setup] Setting up ssdp
2019-07-25 08:24:19 INFO (MainThread) [homeassistant.setup] Setup of domain ssdp took 0.0 seconds.
2019-07-25 08:24:19 INFO (MainThread) [homeassistant.setup] Setting up lovelace
2019-07-25 08:24:20 INFO (MainThread) [homeassistant.setup] Setup of domain lovelace took 0.0 seconds.
2019-07-25 08:24:20 INFO (MainThread) [homeassistant.setup] Setting up group
2019-07-25 08:24:20 INFO (MainThread) [homeassistant.setup] Setup of domain group took 0.0 seconds.
2019-07-25 08:24:20 INFO (MainThread) [homeassistant.setup] Setting up updater
2019-07-25 08:24:20 INFO (MainThread) [homeassistant.setup] Setup of domain updater took 0.0 seconds.
2019-07-25 08:24:20 INFO (MainThread) [homeassistant.setup] Setting up config
2019-07-25 08:24:20 INFO (MainThread) [homeassistant.setup] Setting up history
2019-07-25 08:24:20 INFO (MainThread) [homeassistant.setup] Setup of domain history took 0.0 seconds.
2019-07-25 08:24:20 INFO (MainThread) [homeassistant.setup] Setting up system_health
2019-07-25 08:24:20 INFO (MainThread) [homeassistant.setup] Setup of domain system_health took 0.0 seconds.
2019-07-25 08:24:20 INFO (MainThread) [homeassistant.setup] Setting up websocket_api
2019-07-25 08:24:20 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.0 seconds.
2019-07-25 08:24:20 INFO (MainThread) [homeassistant.setup] Setting up script
2019-07-25 08:24:20 INFO (MainThread) [homeassistant.setup] Setup of domain script took 0.0 seconds.
2019-07-25 08:24:20 INFO (SyncWorker_10) [homeassistant.loader] Loaded google_translate from homeassistant.components.google_translate
2019-07-25 08:24:21 INFO (MainThread) [homeassistant.setup] Setting up api
2019-07-25 08:24:21 INFO (MainThread) [homeassistant.setup] Setting up auth
2019-07-25 08:24:21 INFO (MainThread) [homeassistant.setup] Setup of domain auth took 0.0 seconds.
2019-07-25 08:24:21 INFO (MainThread) [homeassistant.setup] Setting up webhook
2019-07-25 08:24:21 INFO (MainThread) [homeassistant.setup] Setup of domain webhook took 0.0 seconds.
2019-07-25 08:24:21 INFO (MainThread) [homeassistant.setup] Setting up tts
2019-07-25 08:24:21 INFO (MainThread) [homeassistant.setup] Setup of domain api took 0.2 seconds.
2019-07-25 08:24:21 INFO (SyncWorker_7) [homeassistant.components.tts] Create cache dir /config/tts.
2019-07-25 08:24:21 INFO (MainThread) [homeassistant.setup] Setup of domain person took 2.8 seconds.
2019-07-25 08:24:21 INFO (MainThread) [homeassistant.setup] Setup of domain config took 1.5 seconds.
2019-07-25 08:24:21 INFO (MainThread) [homeassistant.setup] Setting up onboarding
2019-07-25 08:24:22 INFO (MainThread) [homeassistant.setup] Setting up mobile_app
2019-07-25 08:24:22 INFO (MainThread) [homeassistant.setup] Setting up cloud
2019-07-25 08:24:23 INFO (MainThread) [homeassistant.setup] Setting up automation
2019-07-25 08:24:23 INFO (MainThread) [homeassistant.setup] Setup of domain automation took 0.0 seconds.
2019-07-25 08:24:24 INFO (MainThread) [homeassistant.setup] Setting up zeroconf
2019-07-25 08:24:24 INFO (MainThread) [homeassistant.setup] Setup of domain mobile_app took 1.5 seconds.
2019-07-25 08:24:24 INFO (MainThread) [homeassistant.setup] Setup of domain tts took 2.6 seconds.
2019-07-25 08:24:24 INFO (SyncWorker_9) [homeassistant.loader] Loaded notify from homeassistant.components.notify
2019-07-25 08:24:24 INFO (MainThread) [homeassistant.setup] Setup of domain onboarding took 2.6 seconds.
2019-07-25 08:24:24 INFO (MainThread) [homeassistant.setup] Setting up notify
2019-07-25 08:24:24 INFO (MainThread) [homeassistant.setup] Setup of domain notify took 0.0 seconds.
2019-07-25 08:24:24 INFO (MainThread) [homeassistant.setup] Setting up frontend
2019-07-25 08:24:24 INFO (MainThread) [homeassistant.setup] Setup of domain frontend took 0.0 seconds.
2019-07-25 08:24:24 INFO (MainThread) [homeassistant.components.notify] Setting up notify.mobile_app
2019-07-25 08:24:24 INFO (MainThread) [homeassistant.setup] Setup of domain cloud took 1.7 seconds.
2019-07-25 08:24:24 INFO (MainThread) [homeassistant.setup] Setting up logbook
2019-07-25 08:24:24 INFO (MainThread) [homeassistant.setup] Setup of domain logbook took 0.0 seconds.
2019-07-25 08:24:24 INFO (MainThread) [homeassistant.setup] Setting up panel_custom
2019-07-25 08:24:24 INFO (MainThread) [homeassistant.setup] Setup of domain panel_custom took 0.0 seconds.
2019-07-25 08:24:24 INFO (MainThread) [homeassistant.setup] Setting up map
2019-07-25 08:24:24 INFO (MainThread) [homeassistant.setup] Setup of domain map took 0.0 seconds.
2019-07-25 08:24:24 INFO (MainThread) [homeassistant.setup] Setting up hassio
2019-07-25 08:24:24 INFO (MainThread) [homeassistant.setup] Setup of domain hassio took 0.1 seconds.
2019-07-25 08:24:24 INFO (MainThread) [homeassistant.setup] Setup of domain zeroconf took 0.9 seconds.
2019-07-25 08:24:26 INFO (MainThread) [homeassistant.setup] Setting up default_config
2019-07-25 08:24:26 INFO (SyncWorker_7) [homeassistant.loader] Loaded stream from homeassistant.components.stream
2019-07-25 08:24:26 INFO (MainThread) [homeassistant.setup] Setting up stream
2019-07-25 08:24:26 INFO (MainThread) [homeassistant.setup] Setup of domain stream took 0.0 seconds.
2019-07-25 08:24:26 INFO (MainThread) [homeassistant.setup] Setup of domain default_config took 0.1 seconds.
2019-07-25 08:24:28 INFO (MainThread) [homeassistant.bootstrap] Home Assistant initialized in 11.94s
2019-07-25 08:24:28 INFO (MainThread) [homeassistant.core] Starting Home Assistant
2019-07-25 08:24:28 INFO (MainThread) [homeassistant.core] Timer:starting
2019-07-25 08:24:28 ERROR (MainThread) [homeassistant.components.http] Failed to create HTTP server at port 8123: [Errno 98] error while attempting to bind on address ('0.0.0.0', 8123): address in use
2019-07-25 08:41:33 INFO (SyncWorker_3) [homeassistant.loader] Loaded automation from homeassistant.components.automation
2019-07-25 08:41:33 INFO (SyncWorker_2) [homeassistant.loader] Loaded group from homeassistant.components.group
2019-07-25 08:41:33 INFO (SyncWorker_1) [homeassistant.loader] Loaded hassio from homeassistant.components.hassio
2019-07-25 08:41:33 INFO (SyncWorker_0) [homeassistant.loader] Loaded tts from homeassistant.components.tts
2019-07-25 08:41:33 INFO (SyncWorker_8) [homeassistant.loader] Loaded homeassistant from homeassistant.components.homeassistant
2019-07-25 08:41:33 INFO (SyncWorker_4) [homeassistant.loader] Loaded default_config from homeassistant.components.default_config
2019-07-25 08:41:33 INFO (SyncWorker_5) [homeassistant.loader] Loaded script from homeassistant.components.script
2019-07-25 08:41:33 INFO (SyncWorker_7) [homeassistant.loader] Loaded persistent_notification from homeassistant.components.persistent_notification
2019-07-25 08:41:33 INFO (SyncWorker_9) [homeassistant.loader] Loaded webhook from homeassistant.components.webhook
2019-07-25 08:41:33 INFO (SyncWorker_13) [homeassistant.loader] Loaded http from homeassistant.components.http
2019-07-25 08:41:33 INFO (MainThread) [homeassistant.setup] Setting up homeassistant
2019-07-25 08:41:33 INFO (MainThread) [homeassistant.setup] Setup of domain homeassistant took 0.0 seconds.
2019-07-25 08:41:33 INFO (MainThread) [homeassistant.setup] Setting up persistent_notification
2019-07-25 08:41:33 INFO (MainThread) [homeassistant.setup] Setup of domain persistent_notification took 0.0 seconds.
2019-07-25 08:41:33 INFO (SyncWorker_12) [homeassistant.loader] Loaded panel_custom from homeassistant.components.panel_custom
2019-07-25 08:41:33 INFO (SyncWorker_3) [homeassistant.loader] Loaded cloud from homeassistant.components.cloud
2019-07-25 08:41:33 INFO (SyncWorker_6) [homeassistant.loader] Loaded config from homeassistant.components.config
2019-07-25 08:41:33 INFO (SyncWorker_1) [homeassistant.loader] Loaded frontend from homeassistant.components.frontend
2019-07-25 08:41:33 INFO (SyncWorker_11) [homeassistant.loader] Loaded api from homeassistant.components.api
2019-07-25 08:41:33 INFO (SyncWorker_14) [homeassistant.loader] Loaded auth from homeassistant.components.auth
2019-07-25 08:41:33 INFO (SyncWorker_7) [homeassistant.loader] Loaded lovelace from homeassistant.components.lovelace
2019-07-25 08:41:33 INFO (SyncWorker_13) [homeassistant.loader] Loaded onboarding from homeassistant.components.onboarding
2019-07-25 08:41:33 INFO (SyncWorker_10) [homeassistant.loader] Loaded system_log from homeassistant.components.system_log
2019-07-25 08:41:33 INFO (SyncWorker_2) [homeassistant.loader] Loaded websocket_api from homeassistant.components.websocket_api
2019-07-25 08:41:33 INFO (SyncWorker_0) [homeassistant.loader] Loaded history from homeassistant.components.history
2019-07-25 08:41:33 INFO (SyncWorker_3) [homeassistant.loader] Loaded recorder from homeassistant.components.recorder
2019-07-25 08:41:33 INFO (SyncWorker_8) [homeassistant.loader] Loaded logbook from homeassistant.components.logbook
2019-07-25 08:41:33 INFO (SyncWorker_1) [homeassistant.loader] Loaded map from homeassistant.components.map
2019-07-25 08:41:33 INFO (SyncWorker_19) [homeassistant.loader] Loaded mobile_app from homeassistant.components.mobile_app
2019-07-25 08:41:33 INFO (SyncWorker_5) [homeassistant.loader] Loaded person from homeassistant.components.person
2019-07-25 08:41:33 INFO (SyncWorker_9) [homeassistant.loader] Loaded ssdp from homeassistant.components.ssdp
2019-07-25 08:41:33 INFO (SyncWorker_15) [homeassistant.loader] Loaded sun from homeassistant.components.sun
2019-07-25 08:41:33 INFO (SyncWorker_16) [homeassistant.loader] Loaded system_health from homeassistant.components.system_health
2019-07-25 08:41:33 INFO (SyncWorker_12) [homeassistant.loader] Loaded updater from homeassistant.components.updater
2019-07-25 08:41:33 INFO (SyncWorker_17) [homeassistant.loader] Loaded zeroconf from homeassistant.components.zeroconf
2019-07-25 08:41:33 INFO (MainThread) [homeassistant.bootstrap] Setting up {'system_log'}
2019-07-25 08:41:33 INFO (MainThread) [homeassistant.setup] Setting up http
2019-07-25 08:41:33 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.0 seconds.
2019-07-25 08:41:33 INFO (MainThread) [homeassistant.setup] Setting up system_log
2019-07-25 08:41:33 INFO (MainThread) [homeassistant.setup] Setup of domain system_log took 0.0 seconds.
2019-07-25 08:41:33 INFO (MainThread) [homeassistant.setup] Setting up recorder
2019-07-25 08:41:34 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=1 from 2019-07-25 00:24:17.197667)
2019-07-25 08:41:34 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 1.2 seconds.
2019-07-25 08:41:34 INFO (MainThread) [homeassistant.setup] Setting up person
2019-07-25 08:41:34 INFO (MainThread) [homeassistant.setup] Setting up lovelace
2019-07-25 08:41:35 INFO (MainThread) [homeassistant.setup] Setup of domain lovelace took 0.1 seconds.
2019-07-25 08:41:35 INFO (MainThread) [homeassistant.setup] Setting up updater
2019-07-25 08:41:35 INFO (MainThread) [homeassistant.setup] Setup of domain updater took 0.0 seconds.
2019-07-25 08:41:35 INFO (MainThread) [homeassistant.setup] Setting up sun
2019-07-25 08:41:35 INFO (MainThread) [homeassistant.setup] Setup of domain sun took 0.1 seconds.
2019-07-25 08:41:35 INFO (MainThread) [homeassistant.setup] Setting up group
2019-07-25 08:41:35 INFO (MainThread) [homeassistant.setup] Setup of domain group took 0.0 seconds.
2019-07-25 08:41:36 INFO (MainThread) [homeassistant.setup] Setting up ssdp
2019-07-25 08:41:36 INFO (MainThread) [homeassistant.setup] Setup of domain ssdp took 0.0 seconds.
2019-07-25 08:41:36 INFO (MainThread) [homeassistant.setup] Setting up script
2019-07-25 08:41:36 INFO (MainThread) [homeassistant.setup] Setup of domain script took 0.0 seconds.
2019-07-25 08:41:36 INFO (MainThread) [homeassistant.setup] Setting up history
2019-07-25 08:41:36 INFO (MainThread) [homeassistant.setup] Setup of domain history took 0.0 seconds.
2019-07-25 08:41:36 INFO (MainThread) [homeassistant.setup] Setting up webhook
2019-07-25 08:41:36 INFO (MainThread) [homeassistant.setup] Setup of domain webhook took 0.0 seconds.
2019-07-25 08:41:36 INFO (SyncWorker_14) [homeassistant.loader] Loaded google_translate from homeassistant.components.google_translate
2019-07-25 08:41:37 INFO (MainThread) [homeassistant.setup] Setting up api
2019-07-25 08:41:37 INFO (MainThread) [homeassistant.setup] Setting up config
2019-07-25 08:41:37 INFO (MainThread) [homeassistant.setup] Setting up system_health
2019-07-25 08:41:37 INFO (MainThread) [homeassistant.setup] Setup of domain system_health took 0.0 seconds.
2019-07-25 08:41:37 INFO (MainThread) [homeassistant.setup] Setting up websocket_api
2019-07-25 08:41:37 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.0 seconds.
2019-07-25 08:41:37 INFO (MainThread) [homeassistant.setup] Setting up auth
2019-07-25 08:41:38 INFO (MainThread) [homeassistant.setup] Setup of domain auth took 0.0 seconds.
2019-07-25 09:35:20 INFO (MainThread) [homeassistant.setup] Setting up tts
2019-07-25 09:35:20 INFO (MainThread) [homeassistant.setup] Setup of domain api took 0.3 seconds.
2019-07-25 09:35:20 INFO (MainThread) [homeassistant.setup] Setup of domain person took 3.2 seconds.
2019-07-25 09:35:20 INFO (MainThread) [homeassistant.setup] Setting up automation
2019-07-25 09:35:20 INFO (MainThread) [homeassistant.setup] Setup of domain automation took 0.0 seconds.
2019-07-25 09:35:21 INFO (MainThread) [homeassistant.setup] Setting up cloud
2019-07-25 09:35:22 INFO (MainThread) [homeassistant.setup] Setting up mobile_app
2019-07-25 09:35:22 INFO (MainThread) [homeassistant.setup] Setup of domain config took 2.5 seconds.
2019-07-25 09:35:22 INFO (MainThread) [homeassistant.setup] Setting up onboarding
2019-07-25 09:35:22 INFO (MainThread) [homeassistant.setup] Setting up zeroconf
2019-07-25 09:35:22 INFO (MainThread) [homeassistant.setup] Setup of domain mobile_app took 0.2 seconds.
2019-07-25 09:35:22 INFO (MainThread) [homeassistant.setup] Setup of domain tts took 2.5 seconds.
2019-07-25 09:35:22 INFO (SyncWorker_6) [homeassistant.loader] Loaded notify from homeassistant.components.notify
2019-07-25 09:35:22 INFO (MainThread) [homeassistant.setup] Setting up notify
2019-07-25 09:35:22 INFO (MainThread) [homeassistant.setup] Setup of domain notify took 0.0 seconds.
2019-07-25 09:35:22 INFO (MainThread) [homeassistant.components.notify] Setting up notify.mobile_app
2019-07-25 09:35:22 INFO (MainThread) [homeassistant.setup] Setup of domain onboarding took 0.3 seconds.
2019-07-25 09:35:22 INFO (MainThread) [homeassistant.setup] Setup of domain cloud took 1.8 seconds.
2019-07-25 09:35:22 INFO (MainThread) [homeassistant.setup] Setting up frontend
2019-07-25 09:35:22 INFO (MainThread) [homeassistant.setup] Setup of domain frontend took 0.0 seconds.
2019-07-25 09:35:23 INFO (MainThread) [homeassistant.setup] Setting up logbook
2019-07-25 09:35:23 INFO (MainThread) [homeassistant.setup] Setup of domain logbook took 0.0 seconds.
2019-07-25 09:35:23 INFO (MainThread) [homeassistant.setup] Setting up panel_custom
2019-07-25 09:35:23 INFO (MainThread) [homeassistant.setup] Setup of domain panel_custom took 0.0 seconds.
2019-07-25 09:35:23 INFO (MainThread) [homeassistant.setup] Setting up map
2019-07-25 09:35:23 INFO (MainThread) [homeassistant.setup] Setup of domain map took 0.0 seconds.
2019-07-25 09:35:23 INFO (MainThread) [homeassistant.setup] Setting up hassio
2019-07-25 09:35:23 INFO (MainThread) [homeassistant.setup] Setup of domain hassio took 0.1 seconds.
2019-07-25 09:35:23 INFO (MainThread) [homeassistant.setup] Setup of domain zeroconf took 0.9 seconds.
2019-07-25 09:35:24 INFO (MainThread) [homeassistant.setup] Setting up default_config
2019-07-25 09:35:24 INFO (SyncWorker_14) [homeassistant.loader] Loaded stream from homeassistant.components.stream
2019-07-25 09:35:24 INFO (MainThread) [homeassistant.setup] Setting up stream
2019-07-25 09:35:24 INFO (MainThread) [homeassistant.setup] Setup of domain stream took 0.0 seconds.
2019-07-25 09:35:24 INFO (MainThread) [homeassistant.setup] Setup of domain default_config took 0.1 seconds.
2019-07-25 09:35:25 INFO (MainThread) [homeassistant.bootstrap] Home Assistant initialized in 3232.34s
2019-07-25 09:35:25 INFO (MainThread) [homeassistant.core] Starting Home Assistant
2019-07-25 09:35:25 INFO (MainThread) [homeassistant.core] Timer:starting
2019-07-25 09:35:25 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.100
2019-07-25 09:36:36 INFO (SyncWorker_0) [homeassistant.loader] Loaded automation from homeassistant.components.automation
2019-07-25 09:36:36 INFO (SyncWorker_5) [homeassistant.loader] Loaded default_config from homeassistant.components.default_config
2019-07-25 09:36:36 INFO (SyncWorker_2) [homeassistant.loader] Loaded hassio from homeassistant.components.hassio
2019-07-25 09:36:36 INFO (SyncWorker_1) [homeassistant.loader] Loaded group from homeassistant.components.group
2019-07-25 09:36:36 INFO (SyncWorker_3) [homeassistant.loader] Loaded script from homeassistant.components.script
2019-07-25 09:36:36 INFO (SyncWorker_6) [homeassistant.loader] Loaded homeassistant from homeassistant.components.homeassistant
2019-07-25 09:36:36 INFO (SyncWorker_4) [homeassistant.loader] Loaded tts from homeassistant.components.tts
2019-07-25 09:36:36 INFO (SyncWorker_7) [homeassistant.loader] Loaded persistent_notification from homeassistant.components.persistent_notification
2019-07-25 09:36:36 INFO (SyncWorker_8) [homeassistant.loader] Loaded http from homeassistant.components.http
2019-07-25 09:36:36 INFO (MainThread) [homeassistant.setup] Setting up homeassistant
2019-07-25 09:36:36 INFO (MainThread) [homeassistant.setup] Setup of domain homeassistant took 0.0 seconds.
2019-07-25 09:36:36 INFO (MainThread) [homeassistant.setup] Setting up persistent_notification
2019-07-25 09:36:36 INFO (MainThread) [homeassistant.setup] Setup of domain persistent_notification took 0.0 seconds.
2019-07-25 09:36:36 INFO (SyncWorker_9) [homeassistant.loader] Loaded webhook from homeassistant.components.webhook
2019-07-25 09:36:36 INFO (SyncWorker_10) [homeassistant.loader] Loaded panel_custom from homeassistant.components.panel_custom
2019-07-25 09:36:36 INFO (SyncWorker_10) [homeassistant.loader] Loaded cloud from homeassistant.components.cloud
2019-07-25 09:36:36 INFO (SyncWorker_2) [homeassistant.loader] Loaded frontend from homeassistant.components.frontend
2019-07-25 09:36:36 INFO (SyncWorker_1) [homeassistant.loader] Loaded config from homeassistant.components.config
2019-07-25 09:36:36 INFO (SyncWorker_19) [homeassistant.loader] Loaded api from homeassistant.components.api
2019-07-25 09:36:36 INFO (SyncWorker_4) [homeassistant.loader] Loaded auth from homeassistant.components.auth
2019-07-25 09:36:36 INFO (SyncWorker_13) [homeassistant.loader] Loaded lovelace from homeassistant.components.lovelace
2019-07-25 09:36:36 INFO (SyncWorker_14) [homeassistant.loader] Loaded onboarding from homeassistant.components.onboarding
2019-07-25 09:36:36 INFO (SyncWorker_15) [homeassistant.loader] Loaded system_log from homeassistant.components.system_log
2019-07-25 09:36:36 INFO (SyncWorker_9) [homeassistant.loader] Loaded websocket_api from homeassistant.components.websocket_api
2019-07-25 09:36:36 INFO (SyncWorker_5) [homeassistant.loader] Loaded history from homeassistant.components.history
2019-07-25 09:36:36 INFO (SyncWorker_11) [homeassistant.loader] Loaded recorder from homeassistant.components.recorder
2019-07-25 09:36:36 INFO (SyncWorker_3) [homeassistant.loader] Loaded logbook from homeassistant.components.logbook
2019-07-25 09:36:36 INFO (SyncWorker_18) [homeassistant.loader] Loaded map from homeassistant.components.map
2019-07-25 09:36:36 INFO (SyncWorker_1) [homeassistant.loader] Loaded mobile_app from homeassistant.components.mobile_app
2019-07-25 09:36:36 INFO (SyncWorker_7) [homeassistant.loader] Loaded person from homeassistant.components.person
2019-07-25 09:36:36 INFO (SyncWorker_8) [homeassistant.loader] Loaded ssdp from homeassistant.components.ssdp
2019-07-25 09:36:36 INFO (SyncWorker_12) [homeassistant.loader] Loaded sun from homeassistant.components.sun
2019-07-25 09:36:36 INFO (SyncWorker_0) [homeassistant.loader] Loaded system_health from homeassistant.components.system_health
2019-07-25 09:36:36 INFO (SyncWorker_16) [homeassistant.loader] Loaded updater from homeassistant.components.updater
2019-07-25 09:36:36 INFO (SyncWorker_17) [homeassistant.loader] Loaded zeroconf from homeassistant.components.zeroconf
2019-07-25 09:36:36 INFO (MainThread) [homeassistant.bootstrap] Setting up {'system_log'}
2019-07-25 09:36:36 INFO (MainThread) [homeassistant.setup] Setting up http
2019-07-25 09:36:36 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.0 seconds.
2019-07-25 09:36:36 INFO (MainThread) [homeassistant.setup] Setting up system_log
2019-07-25 09:36:36 INFO (MainThread) [homeassistant.setup] Setup of domain system_log took 0.0 seconds.
2019-07-25 09:36:36 INFO (MainThread) [homeassistant.setup] Setting up recorder
2019-07-25 09:36:37 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=2 from 2019-07-25 00:41:33.735085)
2019-07-25 09:36:37 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 1.1 seconds.
2019-07-25 09:36:37 INFO (MainThread) [homeassistant.setup] Setting up lovelace
2019-07-25 09:36:37 INFO (MainThread) [homeassistant.setup] Setup of domain lovelace took 0.0 seconds.
2019-07-25 09:36:39 INFO (MainThread) [homeassistant.setup] Setting up ssdp
2019-07-25 09:36:39 INFO (MainThread) [homeassistant.setup] Setup of domain ssdp took 0.0 seconds.
2019-07-25 09:36:39 INFO (MainThread) [homeassistant.setup] Setting up updater
2019-07-25 09:36:39 INFO (MainThread) [homeassistant.setup] Setup of domain updater took 0.0 seconds.
2019-07-25 09:36:39 INFO (MainThread) [homeassistant.setup] Setting up sun
2019-07-25 09:36:39 INFO (MainThread) [homeassistant.setup] Setup of domain sun took 0.1 seconds.
2019-07-25 09:36:39 INFO (MainThread) [homeassistant.setup] Setting up person
2019-07-25 09:36:39 INFO (MainThread) [homeassistant.setup] Setting up group
2019-07-25 09:36:39 INFO (MainThread) [homeassistant.setup] Setup of domain group took 0.0 seconds.
2019-07-25 09:36:39 INFO (MainThread) [homeassistant.setup] Setting up auth
2019-07-25 09:36:39 INFO (MainThread) [homeassistant.setup] Setup of domain auth took 0.0 seconds.
2019-07-25 09:36:40 INFO (MainThread) [homeassistant.setup] Setting up api
2019-07-25 09:36:40 INFO (MainThread) [homeassistant.setup] Setting up script
2019-07-25 09:36:40 INFO (MainThread) [homeassistant.setup] Setup of domain script took 0.0 seconds.
2019-07-25 09:36:40 INFO (MainThread) [homeassistant.setup] Setting up webhook
2019-07-25 09:36:40 INFO (MainThread) [homeassistant.setup] Setup of domain webhook took 0.0 seconds.
2019-07-25 09:36:40 INFO (MainThread) [homeassistant.setup] Setting up system_health
2019-07-25 09:36:40 INFO (MainThread) [homeassistant.setup] Setup of domain system_health took 0.0 seconds.
2019-07-25 09:36:40 INFO (SyncWorker_8) [homeassistant.loader] Loaded google_translate from homeassistant.components.google_translate
2019-07-25 09:36:40 INFO (MainThread) [homeassistant.setup] Setting up history
2019-07-25 09:36:40 INFO (MainThread) [homeassistant.setup] Setup of domain history took 0.0 seconds.
2019-07-25 09:36:40 INFO (MainThread) [homeassistant.setup] Setting up config
2019-07-25 09:36:40 INFO (MainThread) [homeassistant.setup] Setting up websocket_api
2019-07-25 09:36:40 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.0 seconds.
2019-07-25 09:36:40 INFO (MainThread) [homeassistant.setup] Setup of domain api took 0.3 seconds.
2019-07-25 09:36:41 INFO (MainThread) [homeassistant.setup] Setting up tts
2019-07-25 09:36:41 INFO (MainThread) [homeassistant.setup] Setup of domain person took 1.6 seconds.
2019-07-25 09:36:41 INFO (MainThread) [homeassistant.setup] Setting up onboarding
2019-07-25 09:36:41 INFO (MainThread) [homeassistant.setup] Setting up mobile_app
2019-07-25 09:36:41 INFO (MainThread) [homeassistant.setup] Setting up automation
2019-07-25 09:36:41 INFO (MainThread) [homeassistant.setup] Setup of domain automation took 0.0 seconds.
2019-07-25 09:36:42 INFO (MainThread) [homeassistant.setup] Setting up cloud
2019-07-25 09:37:28 INFO (MainThread) [homeassistant.setup] Setup of domain config took 2.4 seconds.
2019-07-25 09:37:28 INFO (MainThread) [homeassistant.setup] Setting up zeroconf
2019-07-25 09:37:29 INFO (MainThread) [homeassistant.setup] Setup of domain mobile_app took 1.5 seconds.
2019-07-25 09:37:29 INFO (MainThread) [homeassistant.setup] Setup of domain tts took 2.5 seconds.
2019-07-25 09:37:29 INFO (SyncWorker_2) [homeassistant.loader] Loaded notify from homeassistant.components.notify
2019-07-25 09:37:29 INFO (MainThread) [homeassistant.setup] Setup of domain onboarding took 2.5 seconds.
2019-07-25 09:37:29 INFO (MainThread) [homeassistant.setup] Setup of domain cloud took 1.5 seconds.
2019-07-25 09:37:29 INFO (MainThread) [homeassistant.setup] Setting up notify
2019-07-25 09:37:29 INFO (MainThread) [homeassistant.setup] Setup of domain notify took 0.0 seconds.
2019-07-25 09:37:29 INFO (MainThread) [homeassistant.setup] Setting up frontend
2019-07-25 09:37:29 INFO (MainThread) [homeassistant.setup] Setup of domain frontend took 0.0 seconds.
2019-07-25 09:37:29 INFO (MainThread) [homeassistant.components.notify] Setting up notify.mobile_app
2019-07-25 09:37:29 INFO (MainThread) [homeassistant.setup] Setting up logbook
2019-07-25 09:37:29 INFO (MainThread) [homeassistant.setup] Setup of domain logbook took 0.0 seconds.
2019-07-25 09:37:29 INFO (MainThread) [homeassistant.setup] Setting up map
2019-07-25 09:37:29 INFO (MainThread) [homeassistant.setup] Setup of domain map took 0.0 seconds.
2019-07-25 09:37:29 INFO (MainThread) [homeassistant.setup] Setting up panel_custom
2019-07-25 09:37:29 INFO (MainThread) [homeassistant.setup] Setup of domain panel_custom took 0.0 seconds.
2019-07-25 09:37:29 INFO (MainThread) [homeassistant.setup] Setting up hassio
2019-07-25 09:37:29 INFO (MainThread) [homeassistant.setup] Setup of domain hassio took 0.1 seconds.
2019-07-25 09:37:29 INFO (MainThread) [homeassistant.setup] Setup of domain zeroconf took 0.9 seconds.
2019-07-25 09:37:31 INFO (MainThread) [homeassistant.setup] Setting up default_config
2019-07-25 09:37:31 INFO (SyncWorker_7) [homeassistant.loader] Loaded stream from homeassistant.components.stream
2019-07-25 09:37:31 INFO (MainThread) [homeassistant.setup] Setting up stream
2019-07-25 09:37:31 INFO (MainThread) [homeassistant.setup] Setup of domain stream took 0.0 seconds.
2019-07-25 09:37:31 INFO (MainThread) [homeassistant.setup] Setup of domain default_config took 0.1 seconds.
2019-07-25 09:37:31 INFO (MainThread) [homeassistant.bootstrap] Home Assistant initialized in 55.56s
2019-07-25 09:37:31 INFO (MainThread) [homeassistant.core] Starting Home Assistant
2019-07-25 09:37:31 INFO (MainThread) [homeassistant.core] Timer:starting
2019-07-25 09:37:31 ERROR (MainThread) [homeassistant.components.http] Failed to create HTTP server at port 8123: [Errno 98] error while attempting to bind on address ('0.0.0.0', 8123): address in use
2019-07-25 09:46:09 INFO (MainThread) [homeassistant.components.stream] Stopped stream workers.
2019-07-25 09:46:09 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.OperationalError) unable to open database file
(Background on this error at: http://sqlalche.me/e/e3q8)
2019-07-25 09:46:09 WARNING (SyncWorker_2) [zeroconf] Exception occurred:
  File "/usr/local/lib/python3.7/site-packages/zeroconf.py", line 2245, in send
    bytes_sent = s.sendto(packet, 0, (addr, port))
OSError: [Errno 22] Invalid argument
2019-07-25 09:46:09 ERROR (Recorder) [homeassistant.components.recorder] Error in database connectivity: (sqlite3.OperationalError) unable to open database file
(Background on this error at: http://sqlalche.me/e/e3q8). (retrying in 3 seconds)
2019-07-25 09:46:12 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.OperationalError) unable to open database file
2019-07-25 09:46:12 ERROR (Recorder) [homeassistant.components.recorder] Error in database connectivity: (sqlite3.OperationalError) unable to open database file
2019-07-25 09:46:15 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.OperationalError) unable to open database file
2019-07-25 09:46:15 ERROR (Recorder) [homeassistant.components.recorder] Error in database connectivity: (sqlite3.OperationalError) unable to open database file
2019-07-25 09:46:18 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.OperationalError) unable to open database file
2019-07-25 09:46:18 ERROR (Recorder) [homeassistant.components.recorder] Error in database connectivity: (sqlite3.OperationalError) unable to open database file
2019-07-25 09:47:22 INFO (SyncWorker_4) [homeassistant.loader] Loaded script from homeassistant.components.script
2019-07-25 09:47:22 INFO (SyncWorker_2) [homeassistant.loader] Loaded group from homeassistant.components.group
2019-07-25 09:47:22 INFO (SyncWorker_5) [homeassistant.loader] Loaded default_config from homeassistant.components.default_config
2019-07-25 09:47:22 INFO (SyncWorker_8) [homeassistant.loader] Loaded automation from homeassistant.components.automation
2019-07-25 09:47:22 INFO (SyncWorker_7) [homeassistant.loader] Loaded hassio from homeassistant.components.hassio
2019-07-25 09:47:22 INFO (SyncWorker_0) [homeassistant.loader] Loaded tts from homeassistant.components.tts
2019-07-25 09:47:22 INFO (SyncWorker_5) [homeassistant.loader] Loaded homeassistant from homeassistant.components.homeassistant
2019-07-25 09:47:22 INFO (SyncWorker_6) [homeassistant.loader] Loaded http from homeassistant.components.http
2019-07-25 09:47:22 INFO (SyncWorker_4) [homeassistant.loader] Loaded persistent_notification from homeassistant.components.persistent_notification
2019-07-25 09:47:22 INFO (SyncWorker_9) [homeassistant.loader] Loaded webhook from homeassistant.components.webhook
2019-07-25 09:47:22 INFO (MainThread) [homeassistant.setup] Setting up homeassistant
2019-07-25 09:47:22 INFO (MainThread) [homeassistant.setup] Setup of domain homeassistant took 0.0 seconds.
2019-07-25 09:47:22 INFO (SyncWorker_1) [homeassistant.loader] Loaded panel_custom from homeassistant.components.panel_custom
2019-07-25 09:47:22 INFO (MainThread) [homeassistant.setup] Setting up persistent_notification
2019-07-25 09:47:22 INFO (MainThread) [homeassistant.setup] Setup of domain persistent_notification took 0.0 seconds.
2019-07-25 09:47:22 INFO (SyncWorker_3) [homeassistant.loader] Loaded cloud from homeassistant.components.cloud
2019-07-25 09:47:22 INFO (SyncWorker_2) [homeassistant.loader] Loaded frontend from homeassistant.components.frontend
2019-07-25 09:47:22 INFO (SyncWorker_14) [homeassistant.loader] Loaded config from homeassistant.components.config
2019-07-25 09:47:22 INFO (SyncWorker_7) [homeassistant.loader] Loaded api from homeassistant.components.api
2019-07-25 09:47:22 INFO (SyncWorker_11) [homeassistant.loader] Loaded auth from homeassistant.components.auth
2019-07-25 09:47:22 INFO (SyncWorker_5) [homeassistant.loader] Loaded lovelace from homeassistant.components.lovelace
2019-07-25 09:47:22 INFO (SyncWorker_4) [homeassistant.loader] Loaded onboarding from homeassistant.components.onboarding
2019-07-25 09:47:22 INFO (SyncWorker_16) [homeassistant.loader] Loaded system_log from homeassistant.components.system_log
2019-07-25 09:47:22 INFO (SyncWorker_1) [homeassistant.loader] Loaded websocket_api from homeassistant.components.websocket_api
2019-07-25 09:47:22 INFO (SyncWorker_17) [homeassistant.loader] Loaded history from homeassistant.components.history
2019-07-25 09:47:22 INFO (SyncWorker_8) [homeassistant.loader] Loaded recorder from homeassistant.components.recorder
2019-07-25 09:47:22 INFO (SyncWorker_2) [homeassistant.loader] Loaded logbook from homeassistant.components.logbook
2019-07-25 09:47:22 INFO (SyncWorker_19) [homeassistant.loader] Loaded map from homeassistant.components.map
2019-07-25 09:47:22 INFO (SyncWorker_14) [homeassistant.loader] Loaded mobile_app from homeassistant.components.mobile_app
2019-07-25 09:47:22 INFO (SyncWorker_0) [homeassistant.loader] Loaded person from homeassistant.components.person
2019-07-25 09:47:22 INFO (SyncWorker_6) [homeassistant.loader] Loaded ssdp from homeassistant.components.ssdp
2019-07-25 09:47:22 INFO (SyncWorker_9) [homeassistant.loader] Loaded sun from homeassistant.components.sun
2019-07-25 09:47:22 INFO (SyncWorker_12) [homeassistant.loader] Loaded system_health from homeassistant.components.system_health
2019-07-25 09:47:22 INFO (SyncWorker_13) [homeassistant.loader] Loaded updater from homeassistant.components.updater
2019-07-25 09:47:22 INFO (SyncWorker_18) [homeassistant.loader] Loaded zeroconf from homeassistant.components.zeroconf
2019-07-25 09:47:22 INFO (MainThread) [homeassistant.bootstrap] Setting up {'system_log'}
2019-07-25 09:47:22 INFO (MainThread) [homeassistant.setup] Setting up http
2019-07-25 09:47:22 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.0 seconds.
2019-07-25 09:47:22 INFO (MainThread) [homeassistant.setup] Setting up system_log
2019-07-25 09:47:22 INFO (MainThread) [homeassistant.setup] Setup of domain system_log took 0.0 seconds.
2019-07-25 09:47:22 INFO (MainThread) [homeassistant.setup] Setting up recorder
2019-07-25 09:47:23 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 1.3 seconds.
2019-07-25 09:47:23 INFO (MainThread) [homeassistant.setup] Setting up group
2019-07-25 09:47:23 INFO (MainThread) [homeassistant.setup] Setup of domain group took 0.0 seconds.
2019-07-25 09:47:25 INFO (MainThread) [homeassistant.setup] Setting up ssdp
2019-07-25 09:47:25 INFO (MainThread) [homeassistant.setup] Setup of domain ssdp took 0.0 seconds.
2019-07-25 09:47:25 INFO (MainThread) [homeassistant.setup] Setting up lovelace
2019-07-25 09:47:25 INFO (MainThread) [homeassistant.setup] Setup of domain lovelace took 0.0 seconds.
2019-07-25 09:47:25 INFO (MainThread) [homeassistant.setup] Setting up person
2019-07-25 09:47:25 INFO (MainThread) [homeassistant.setup] Setting up sun
2019-07-25 09:47:25 INFO (MainThread) [homeassistant.setup] Setup of domain sun took 0.1 seconds.
2019-07-25 09:47:25 INFO (MainThread) [homeassistant.setup] Setting up updater
2019-07-25 09:47:25 INFO (MainThread) [homeassistant.setup] Setup of domain updater took 0.0 seconds.
2019-07-25 09:47:25 INFO (MainThread) [homeassistant.setup] Setting up config
2019-07-25 09:47:25 INFO (MainThread) [homeassistant.setup] Setting up system_health
2019-07-25 09:47:25 INFO (MainThread) [homeassistant.setup] Setup of domain system_health took 0.0 seconds.
2019-07-25 09:47:25 INFO (SyncWorker_14) [homeassistant.loader] Loaded google_translate from homeassistant.components.google_translate
2019-07-25 09:47:25 INFO (MainThread) [homeassistant.setup] Setting up webhook
2019-07-25 09:47:25 INFO (MainThread) [homeassistant.setup] Setup of domain webhook took 0.0 seconds.
2019-07-25 09:47:25 INFO (MainThread) [homeassistant.setup] Setting up script
2019-07-25 09:47:25 INFO (MainThread) [homeassistant.setup] Setup of domain script took 0.0 seconds.
2019-07-25 09:47:25 INFO (MainThread) [homeassistant.setup] Setting up websocket_api
2019-07-25 09:47:25 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.0 seconds.
2019-07-25 09:47:26 INFO (MainThread) [homeassistant.setup] Setting up api
2019-07-25 09:47:26 INFO (MainThread) [homeassistant.setup] Setting up auth
2019-07-25 09:47:26 INFO (MainThread) [homeassistant.setup] Setup of domain auth took 0.0 seconds.
2019-07-25 09:47:26 INFO (MainThread) [homeassistant.setup] Setting up history
2019-07-25 09:47:26 INFO (MainThread) [homeassistant.setup] Setup of domain history took 0.0 seconds.
2019-07-25 09:47:26 INFO (MainThread) [homeassistant.setup] Setup of domain person took 1.7 seconds.
2019-07-25 09:47:26 INFO (MainThread) [homeassistant.setup] Setting up tts
2019-07-25 09:47:26 INFO (MainThread) [homeassistant.setup] Setup of domain api took 0.2 seconds.
2019-07-25 09:47:26 INFO (MainThread) [homeassistant.setup] Setup of domain config took 1.6 seconds.
2019-07-25 09:47:26 INFO (SyncWorker_6) [homeassistant.components.tts] Create cache dir /config/tts.
2019-07-25 09:47:26 INFO (MainThread) [homeassistant.setup] Setting up automation
2019-07-25 09:47:26 INFO (MainThread) [homeassistant.setup] Setup of domain automation took 0.0 seconds.
2019-07-25 09:47:27 INFO (MainThread) [homeassistant.setup] Setting up cloud
2019-07-25 09:47:29 INFO (MainThread) [homeassistant.setup] Setting up mobile_app
2019-07-25 09:47:29 INFO (MainThread) [homeassistant.setup] Setting up onboarding
2019-07-25 09:47:29 INFO (MainThread) [homeassistant.setup] Setting up zeroconf
2019-07-25 09:47:29 INFO (MainThread) [homeassistant.setup] Setup of domain mobile_app took 0.2 seconds.
2019-07-25 09:47:29 INFO (MainThread) [homeassistant.setup] Setup of domain tts took 2.3 seconds.
2019-07-25 09:47:29 INFO (SyncWorker_13) [homeassistant.loader] Loaded notify from homeassistant.components.notify
2019-07-25 09:47:29 INFO (MainThread) [homeassistant.setup] Setup of domain onboarding took 0.2 seconds.
2019-07-25 09:47:29 INFO (MainThread) [homeassistant.setup] Setup of domain cloud took 1.6 seconds.
2019-07-25 09:47:29 INFO (MainThread) [homeassistant.setup] Setting up notify
2019-07-25 09:47:29 INFO (MainThread) [homeassistant.setup] Setup of domain notify took 0.0 seconds.
2019-07-25 09:47:29 INFO (MainThread) [homeassistant.setup] Setting up frontend
2019-07-25 09:47:29 INFO (MainThread) [homeassistant.setup] Setup of domain frontend took 0.0 seconds.
2019-07-25 09:47:29 INFO (MainThread) [homeassistant.components.notify] Setting up notify.mobile_app
2019-07-25 09:47:29 INFO (MainThread) [homeassistant.setup] Setting up panel_custom
2019-07-25 09:47:29 INFO (MainThread) [homeassistant.setup] Setup of domain panel_custom took 0.0 seconds.
2019-07-25 09:47:29 INFO (MainThread) [homeassistant.setup] Setting up logbook
2019-07-25 09:47:29 INFO (MainThread) [homeassistant.setup] Setup of domain logbook took 0.0 seconds.
2019-07-25 09:47:29 INFO (MainThread) [homeassistant.setup] Setting up map
2019-07-25 09:47:29 INFO (MainThread) [homeassistant.setup] Setup of domain map took 0.0 seconds.
2019-07-25 09:47:29 INFO (MainThread) [homeassistant.setup] Setting up hassio
2019-07-25 09:47:29 ERROR (MainThread) [homeassistant.components.hassio.handler] /homeassistant/options return code 403.
2019-07-25 09:47:29 ERROR (MainThread) [homeassistant.components.hassio.handler] /supervisor/options return code 403.
2019-07-25 09:47:29 ERROR (MainThread) [homeassistant.components.hassio.handler] /homeassistant/info return code 403.
2019-07-25 09:47:29 WARNING (MainThread) [homeassistant.components.hassio] Can't read last version:
2019-07-25 09:47:29 ERROR (MainThread) [homeassistant.components.hassio.handler] /ingress/panels return code 403.
2019-07-25 09:47:29 ERROR (MainThread) [homeassistant.components.hassio.addon_panel] Can't read panel info:
2019-07-25 09:47:29 INFO (MainThread) [homeassistant.setup] Setup of domain hassio took 0.1 seconds.
2019-07-25 09:47:30 INFO (MainThread) [homeassistant.setup] Setup of domain zeroconf took 0.9 seconds.
2019-07-25 09:47:31 INFO (MainThread) [homeassistant.setup] Setting up default_config
2019-07-25 09:47:31 INFO (SyncWorker_14) [homeassistant.loader] Loaded stream from homeassistant.components.stream
2019-07-25 09:47:31 INFO (MainThread) [homeassistant.setup] Setting up stream
2019-07-25 09:47:31 INFO (MainThread) [homeassistant.setup] Setup of domain stream took 0.0 seconds.
2019-07-25 09:47:31 INFO (MainThread) [homeassistant.setup] Setup of domain default_config took 0.1 seconds.
2019-07-25 09:47:33 INFO (MainThread) [homeassistant.bootstrap] Home Assistant initialized in 11.67s
2019-07-25 09:47:33 INFO (MainThread) [homeassistant.core] Starting Home Assistant
2019-07-25 09:47:33 INFO (MainThread) [homeassistant.core] Timer:starting
2019-07-25 09:47:33 ERROR (MainThread) [homeassistant.components.hassio.handler] /discovery return code 403.
2019-07-25 09:47:33 ERROR (MainThread) [homeassistant.components.hassio.discovery] Can't read discover info:
2019-07-25 09:47:33 ERROR (MainThread) [homeassistant.components.http] Failed to create HTTP server at port 8123: [Errno 98] error while attempting to bind on address ('0.0.0.0', 8123): address in use
2019-07-25 10:07:26 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.OperationalError) unable to open database file
2019-07-25 10:07:26 ERROR (Recorder) [homeassistant.components.recorder] Error in database connectivity: (sqlite3.OperationalError) unable to open database file
2019-07-25 10:07:29 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.OperationalError) unable to open database file
2019-07-25 10:07:29 ERROR (Recorder) [homeassistant.components.recorder] Error in database connectivity: (sqlite3.OperationalError) unable to open database file
2019-07-25 10:07:32 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.OperationalError) unable to open database file
2019-07-25 10:07:32 ERROR (Recorder) [homeassistant.components.recorder] Error in database connectivity: (sqlite3.OperationalError) unable to open database file
2019-07-25 10:07:35 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.OperationalError) unable to open database file
2019-07-25 10:07:35 ERROR (Recorder) [homeassistant.components.recorder] Error in database connectivity: (sqlite3.OperationalError) unable to open database file
2019-07-25 10:07:38 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.OperationalError) unable to open database file
2019-07-25 10:07:38 ERROR (Recorder) [homeassistant.components.recorder] Error in database connectivity: (sqlite3.OperationalError) unable to open database file
2019-07-25 10:07:41 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.OperationalError) unable to open database file
2019-07-25 10:07:41 ERROR (Recorder) [homeassistant.components.recorder] Error in database connectivity: (sqlite3.OperationalError) unable to open database file
2019-07-25 10:07:44 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.OperationalError) unable to open database file
2019-07-25 10:07:44 ERROR (Recorder) [homeassistant.components.recorder] Error in database connectivity: (sqlite3.OperationalError) unable to open database file
2019-07-25 10:07:47 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.OperationalError) unable to open database file
2019-07-25 10:07:47 ERROR (Recorder) [homeassistant.components.recorder] Error in database connectivity: (sqlite3.OperationalError) unable to open database file
2019-07-25 10:07:50 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.OperationalError) unable to open database file
2019-07-25 10:07:50 ERROR (Recorder) [homeassistant.components.recorder] Error in database connectivity: (sqlite3.OperationalError) unable to open database file
2019-07-25 10:07:53 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.OperationalError) unable to open database file
2019-07-25 10:07:53 ERROR (Recorder) [homeassistant.components.recorder] Error in database connectivity: (sqlite3.OperationalError) unable to open database file
2019-07-25 10:07:53 ERROR (Recorder) [homeassistant.components.recorder] Error in database update. Could not save after 11 tries. Giving up
上边就是执行这命令的提示
我安好后打开ip:8213让我创建用户,(这个时候如果创建用户,进去是有hassio小图标的,但是是新用户,别的全没了)我从启动树莓派,然后进去就是以前的账户了,但是没有hassio小房子了
 楼主| 发表于 2019-7-25 10:24:01 | 显示全部楼层
tcp        0      0 0.0.0.0:8123            0 ...
不好意思,说清楚一点?然后进去就是以前的账户是什么意思
发表于 2019-7-25 10:31:31 | 显示全部楼层
安装完hassio打开ip:8123,是个新的账户让我创建用户 进去后能看到hassio小房子,从起树莓派后再进去,就是我以前的账户HomeAssistant,就是说我以前的设置的天气或语音都在,没有hassio小房子了,好像是登入了不同的账户一样,
 楼主| 发表于 2019-7-25 10:32:35 | 显示全部楼层
youquan 发表于 2019-7-25 10:31
安装完hassio打开ip:8123,是个新的账户让我创建用户 进去后能看到hassio小房子,从起树莓派后再进去, ...
树莓派重刷系统的吗?应该是以前你搭建的ha问题把?自己排查下?
GMT+8, 2025-12-19 02:09 , Processed in 0.135045 second(s), 9 queries , MemCached On.
