楼主: neroxps
HASSIO 安装一键脚本
 火...   [复制链接]
发表于 2019-6-10 21:32:15 | 显示全部楼层
[info]: 切换系统网络源.....
Get:1 http://mirrors.ustc.edu.cn/raspbian/raspbian stretch InRelease [15.0 kB]
Hit:2 http://mirrors.ustc.edu.cn/archive.raspberrypi.org/debian stretch InRelease
Hit:3 http://archive.raspberrypi.org/debian stretch InRelease
Get:4 https://mirrors.aliyun.com/docker-ce/linux/raspbian stretch InRelease [31.1 kB]
Fetched 46.0 kB in 2s (21.7 kB/s)
Reading package lists... Done
Building dependency tree
Reading state information... Done
22 packages can be upgraded. Run 'apt list --upgradable' to see them.
[info]: 安装 hassio 必要依赖.....
avahi-daemon is already the newest version (0.6.32-2).
curl is already the newest version (7.52.1-5+deb9u9).
jq is already the newest version (1.5+dfsg-1.3).
net-tools is already the newest version (1.60+git20161116.90da8a0-1).
socat is already the newest version (1.7.3.1-2+deb9u1).
0 upgraded, 0 newly installed, 0 to remove and 22 not upgraded.
/usr/bin/docker
[info]: 发现系统已安装 docker,跳过 docker 安装
[info]: 切换 Docker 源为国内源....
[info]: 切换国内源完成
[info]: 安装 hassio......
从 hub.docker.com 下载 homeassistant/raspberrypi3-homeassistant:0.94.1......
0.94.1: Pulling from homeassistant/raspberrypi3-homeassistant
Digest: sha256:73ebc43b9025eecaede3005456365e1486afacbd4f99640d26c65cc3cb829d98
Status: Image is up to date for homeassistant/raspberrypi3-homeassistant:0.94.1
开始 hassio 安装流程。(如出现 [Warning] 请忽略,无须理会)
[Warning] No AppArmor support on host.
[Warning] No NetworkManager support on host.
[Info] Install supervisor Docker container
Error response from daemon: Get https://registry-1.docker.io/v2/: net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)
Unit hassio-supervisor.service could not be found.
Distributor ID: Raspbian
Description:    Raspbian GNU/Linux 9.8 (stretch)
Release:        9.8
Codename:       stretch
Linux version 4.14.98-v7+ (dom@dom-XPS-13-9370) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1200 SMP Tue Feb 12 20:27:48 GMT 2019
Linux raspberrypi 4.14.98-v7+ #1200 SMP Tue Feb 12 20:27:48 GMT 2019 armv7l GNU/Linux
安装 hassio 失败,请将上方安装信息发送到论坛询问。脚本退出...
发表于 2019-6-11 00:00:44 | 显示全部楼层
root@raspberrypi:/home/pi# [ERROR]: 系统源切换错误,请检查网络连接是否正常,脚本退出
这个怎么解决,死了几次
发表于 2019-6-11 00:14:05 | 显示全部楼层
Release:        9.8
Codename:       stretch
请问这是什么问题
Xoen
发表于 2019-6-11 00:57:10 | 显示全部楼层
neroxps 发表于 2019-6-8 08:47
有时候刚刚push容器上hub,国内源会滞后一天到半天。所以等等咯。
谢谢dalao
Xoen
发表于 2019-6-11 01:37:22 | 显示全部楼层
大佬,这个docker咋肥事啊QAQ 用的是Microsoft store里面的Ubuntu
(1). 是否将系统源切换为中科大(USTC)源(目前支持 Debian Ubuntu Raspbian 三款系统)
请输入 y or n(默认 yes):n
(2). 在你系统内找到 xoen 用户,是否将其添加至 docker 用户组。
请输入 yes 或者 no (默认 yes):
将xoen用户添加至 docker 用户组。
(3).是否需要替换 docker 默认源?
请输入 yes 或者 no(默认:yes):n
(4).请选择你设备类型(默认:qemux86-64)
    [1]: raspberrypi3-64
    [2]: qemuarm-64
    [3]: qemux86-64
输入数字 (1-3):3
你选择了 qemux86-64
(5).是否需要设置 hassio 数据保存路径(默认:/usr/share/hassio)
请输入 yes 或 no (默认:no):
hassio 数据路径为默认路径: /usr/share/hassio
# 1. 是否将系统源切换为中科大(USTC)源: 否
# 2. 是否将用户添加至 Docker 用户组:   是,添加用户为 xoen
# 3. 是否将 Docker 源切换至国内源:     否
# 4. 您的设备类型为:                   qemux86-64
# 5. 您的 hassio 数据路径为:           /usr/share/hassio
请确认以上信息,继续请按任意键,如需修改请输入 Ctrl+C 结束任务重新执行脚本。
[info]: 跳过切换系统源。
net-tools is already the newest version (1.60+git20161116.90da8a0-1ubuntu1).
socat is already the newest version (1.7.3.2-2ubuntu2).
jq is already the newest version (1.5+dfsg-2).
avahi-daemon is already the newest version (0.7-3.1ubuntu1.2).
curl is already the newest version (7.58.0-2ubuntu3.7).
0 upgraded, 0 newly installed, 0 to remove and 16 not upgraded.
/usr/bin/docker
[info]: 跳过切换 Docker 源....
从 hub.docker.com 下载 homeassistant/qemux86-64-homeassistant:0.94.1......
Cannot connect to the Docker daemon at unix:///var/run/docker.sock. Is the docker daemon running?
[ERROR]: 从 docker 下载 homeassistant/qemux86-64-homeassistant:0.94.1 失败,请检查上方失败信息。
root@Xoen-work:/home/xoen# sudo service docker start
* Starting Docker: docker        [ OK ]
root@Xoen-work:/home/xoen# sudo docker run hello-world
docker: Cannot connect to the Docker daemon at unix:///var/run/docker.sock. Is the docker daemon running?.
See 'docker run --help'.
 楼主| 发表于 2019-6-11 09:54:30 | 显示全部楼层
(1). 是否将系统源切换为中科大(USTC)源 ...
1、 root权限下不需要sudo
2、ubuntu 很早就改 systemd 抛弃 init.d 的service 启动方式,故此docker 启动命令应该是 systemctl start docker。查看 docker 启动状态是 systemctl status docker
3、我不清楚微软商店的ubuntu是否能到可用状态,特别是docker 还要兼容网络问题。今天不用去装修现场,我装个测试下。
Xoen
发表于 2019-6-11 13:33:23 | 显示全部楼层
neroxps 发表于 2019-6-11 09:54
1、 root权限下不需要sudo
2、ubuntu 很早就改 systemd 抛弃 init.d 的service 启动方式,故此docker 启动 ...
嗯嗯,谢谢,,麻烦了
Xoen
发表于 2019-6-11 13:37:10 | 显示全部楼层
1、 root权限下不需要sudo
主要现在就是在找方法把HASSIO装到win10上,,折腾了好几天都没搞上
 楼主| 发表于 2019-6-11 13:40:32 | 显示全部楼层
我测试了,WSL 由于 iptables 还不能支持的原因,导致 docker-ce 根本无法启动,目前网上WSL装docker 的都需要依赖 docker for windows 再开启 tcp 连接来控制 docker 实现的。所以劝你还是放弃吧,windows 虚拟机多好。
Xoen
发表于 2019-6-11 17:20:43 | 显示全部楼层
neroxps 发表于 2019-6-11 13:40
我测试了,WSL 由于 iptables 还不能支持的原因,导致 docker-ce 根本无法启动,目前网上WSL装docker 的 ...
GMT+8, 2025-12-17 07:34 , Processed in 0.361819 second(s), 12 queries , MemCached On.
