楼主: neroxps
HASSIO 安装一键脚本
 火...   [复制链接]
发表于 2019-4-20 22:47:43 | 显示全部楼层
neroxps 发表于 2018-8-11 08:31
N1 要先刷好系统,我没N1 不知道N1情况如何
楼主  我是N1  求指导
19-04-20 14:53:56 ERROR (MainThread) [hassio.utils.gdbus] DBus return error: b'Error: GDBus.Errorrg.free                              desktop.DBus.Error.ServiceUnknown: The name de.pengutronix.rauc was not provided by any .service files\n'
19-04-20 14:53:56 WARNING (MainThread) [hassio.dbus.rauc] Can't connect to rauc
19-04-20 14:53:56 INFO (MainThread) [hassio.host.info] Update local host information
19-04-20 14:53:56 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /o                              rg/freedesktop/hostname1
19-04-20 14:53:56 INFO (MainThread) [hassio.host.services] Update service information
19-04-20 14:53:56 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits o                              n /org/freedesktop/systemd1
19-04-20 14:53:56 INFO (MainThread) [hassio.host.apparmor] Load AppArmor Profiles: set()
19-04-20 14:53:56 INFO (MainThread) [hassio.host.apparmor] AppArmor is not enabled on host
19-04-20 14:53:56 INFO (SyncWorker_1) [hassio.docker.interface] Attach to homeassistant/qemux86-64-homeass                              istant with version 0.91.4
19-04-20 14:53:56 INFO (MainThread) [hassio.addons.git] Clone add-on https://github.com/home-assistant/has                              sio-addons repository
19-04-20 14:53:56 INFO (MainThread) [hassio.addons.git] Clone add-on https://github.com/hassio-addons/repo                              sitory repository
########################### homeassistant log ###########################
Error: No such container: homeassistant
homeassistant 启动超时,请检查上方日志....
发表于 2019-4-21 00:44:29 | 显示全部楼层
大神,帮忙看下这个问题,我的环境如下:
- Raspberry 3b+
- 系统 Raspbian Stretch Lite
试了好多次,始终卡在最后一步,等待 homeassistant 启动,然后超时
开始 hassio 安装流程。(如出现 [Warning] 请忽略,无须理会)
[Info] Install supervisor Docker container
[Info] Install supervisor startup scripts
[Info] Install AppArmor scripts
[Info] Run Hass.io
等待 homeassistant 启动.............................................................................................................................................................................................................................................................................................................fail
########################### Docker images ###########################
REPOSITORY                                 TAG                 IMAGE ID            CREATED             SIZE
homeassistant/raspberrypi3-homeassistant   0.91.4              6399c8a1ec10        4 days ago          957MB
homeassistant/raspberrypi3-homeassistant   latest              6399c8a1ec10        4 days ago          957MB
homeassistant/armhf-hassio-supervisor      160                 eed6fd9bb646        4 days ago          181MB
homeassistant/armhf-hassio-supervisor      latest              eed6fd9bb646        4 days ago          181MB
frosthe/ddns-client-aliyun                 latest              d7b718d6167c        3 months ago        247MB
netdata/netdata                            latest              a300f2f2cc86        4 months ago        103MB
funkyfuture/rpi-syncthing                  latest              3e94e03f496a        4 months ago        25MB
certbot/certbot                            latest              f54c06951c6d        4 months ago        103MB
linuxserver/deluge                         latest              022c12966a55        5 months ago        241MB
alpine                                     latest              8e425eb51aaf        7 months ago        4.01MB
########################### Docker ps ###########################
CONTAINER ID        IMAGE                                   COMMAND               CREATED             STATUS              PORTS               NAMES
5b869990a0dc        homeassistant/armhf-hassio-supervisor   "python3 -m hassio"   5 minutes ago       Up 5 minutes                            hassio_supervisor
########################### hassio log ###########################
19-04-20 16:31:40 INFO (MainThread) [__main__] Initialize Hass.io setup
19-04-20 16:31:43 INFO (MainThread) [__main__] Setup HassIO
19-04-20 16:31:43 INFO (SyncWorker_0) [hassio.docker.supervisor] Attach to Supervisor homeassistant/armhf-hassio-supervisor with version 160
19-04-20 16:31:43 INFO (SyncWorker_0) [hassio.docker.supervisor] Connect Supervisor to Hass.io Network
19-04-20 16:31:56 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.systemd1 on /org/freedesktop/systemd1
19-04-20 16:31:56 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
19-04-20 16:31:56 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.hostname1 on /org/freedesktop/hostname1
19-04-20 16:31:56 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
19-04-20 16:31:56 INFO (MainThread) [hassio.utils.gdbus] Introspect de.pengutronix.rauc on /
19-04-20 16:31:56 ERROR (MainThread) [hassio.utils.gdbus] DBus return error: b'Error: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name de.pengutronix.rauc was not provided by any .service files\n'
19-04-20 16:31:56 WARNING (MainThread) [hassio.dbus.rauc] Can't connect to rauc
19-04-20 16:31:56 INFO (MainThread) [hassio.host.info] Update local host information
19-04-20 16:31:56 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
19-04-20 16:31:56 INFO (MainThread) [hassio.host.services] Update service information
19-04-20 16:31:56 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
19-04-20 16:31:56 INFO (MainThread) [hassio.host.apparmor] Load AppArmor Profiles: {'hassio-supervisor'}
19-04-20 16:31:56 INFO (MainThread) [hassio.host.services] Reload local service hassio-apparmor.service
19-04-20 16:31:56 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ReloadOrRestartUnit on /org/freedesktop/systemd1
19-04-20 16:31:56 INFO (SyncWorker_0) [hassio.docker.interface] Attach to homeassistant/raspberrypi3-homeassistant with version 0.91.4
19-04-20 16:31:57 INFO (MainThread) [hassio.addons.git] Load add-on /data/addons/core repository
19-04-20 16:31:57 INFO (MainThread) [hassio.addons.git] Load add-on /data/addons/git/a0d7b954 repository
19-04-20 16:31:57 INFO (MainThread) [hassio.addons] Load add-ons: 56 all - 56 new - 0 remove
19-04-20 16:31:57 INFO (MainThread) [hassio.updater] Fetch update data from [url]https://s3.amazonaws.com/hassio-version/stable.json[/url]
19-04-20 16:32:02 INFO (MainThread) [hassio.snapshots] Found 0 snapshot files
19-04-20 16:32:02 INFO (MainThread) [hassio.discovery] Load 0 messages
19-04-20 16:32:02 INFO (MainThread) [hassio.ingress] Load 0 ingress session
19-04-20 16:32:02 INFO (MainThread) [__main__] Run Hass.io
19-04-20 16:32:02 INFO (MainThread) [hassio.misc.dns] Start DNS port forwarding for host add-ons
19-04-20 16:32:02 INFO (MainThread) [hassio.api] Start API on 172.30.32.2
19-04-20 16:32:02 INFO (MainThread) [hassio.addons] Startup initialize run 0 add-ons
19-04-20 16:32:02 INFO (MainThread) [hassio.core] Hass.io reboot detected
19-04-20 16:32:02 INFO (MainThread) [hassio.tasks] All core tasks are scheduled
19-04-20 16:32:02 INFO (MainThread) [hassio.core] Hass.io is up and running
docker image 如下:
root@hassio:~# docker image ls -a
Docker container 如下:
root@hassio:~# docker container ls -a
5b869990a0dc        homeassistant/armhf-hassio-supervisor   "python3 -m hassio"   12 minutes ago      Up 12 minutes                           hassio_supervisor
还需要其他什么信息帮忙 troubleshooting,大神可以告诉我
发表于 2019-4-21 20:48:20 | 显示全部楼层
树莓派顺利安装好啦
 楼主| 发表于 2019-4-22 08:45:13 | 显示全部楼层
hejiaxun 发表于 2019-4-21 00:44
大神,帮忙看下这个问题,我的环境如下:
- Raspberry 3b+
hassio 的日志中没有启动homeassistant的相关日志,可能是由于网络问题无法从s3 中拉取版本的list导致的,重启多试几次。
发表于 2019-4-22 21:46:03 | 显示全部楼层
[info]: 安装 Docker 引擎.....
curl: (7) Failed to connect to raw.githubusercontent.com port 443: Connection timed out
[ERROR]: 下载 https://raw.githubusercontent.co ... l/master/install.sh 失败,请检查网络与其连接是否正常。
 楼主| 发表于 2019-4-23 08:34:18 | 显示全部楼层
Evilsay 发表于 2019-4-22 21:46
: 安装 Docker 引擎.....
curl: (7) Failed to connect to raw.githubusercontent.com port 443: Connectio ...
报错信息写的很清楚了。你连不上github
发表于 2019-4-23 08:55:29 | 显示全部楼层
我知道,后来又连上了,抽风。不知道有没有方法规避
 楼主| 发表于 2019-4-23 09:29:33 | 显示全部楼层
把库丢到国内咯,但···如果没有自动化方案,我不想折腾···每次更新都要维护两个库.
发表于 2019-4-23 14:49:39 | 显示全部楼层
这个简单哎!!!
发表于 2019-4-23 16:23:05 | 显示全部楼层
neroxps 发表于 2019-4-23 09:29
把库丢到国内咯,但···如果没有自动化方案,我不想折腾···每次更新都要维护两个库. ...
手动撸个镜像站
GMT+8, 2025-12-16 09:59 , Processed in 1.366514 second(s), 18 queries , MemCached On.
