楼主: neroxps
HASSIO 安装一键脚本
 火...   [复制链接]
 楼主| 发表于 2019-1-12 08:32:32 | 显示全部楼层
jyz_0501 发表于 2019-1-12 07:02
Distributor ID: Raspbian
Desc ...
把上面的docker 安装过程也贴出来看看?
感觉一般都是网络问题?
我就是六神
活跃会员教程狂人灌水之王
发表于 2019-1-12 08:40:45 | 显示全部楼层
感觉一般都是网络问题?
笑哭  我没存  下次安装时再发出来吧  试了两遍都这样
发表于 2019-1-15 01:56:40 | 显示全部楼层
大佬 这是什么情况呢?
等待 homeassistant 启动.............................................................................................................................................................................................................................................................................................................fail
########################### Docker images ###########################
REPOSITORY                               TAG                 IMAGE ID            CREATED             SIZE
homeassistant/qemux86-64-homeassistant   0.85.1              bb0b0f50a624        30 hours ago        1.23GB
homeassistant/qemux86-64-homeassistant   latest              bb0b0f50a624        30 hours ago        1.23GB
homeassistant/amd64-hassio-supervisor    141                 4eba388a150f        4 weeks ago         198MB
homeassistant/amd64-hassio-supervisor    latest              4eba388a150f        4 weeks ago         198MB
########################### Docker ps ###########################
CONTAINER ID        IMAGE                                    COMMAND                  CREATED             STATUS              PORTS               NAMES
61966e3787fd        homeassistant/qemux86-64-homeassistant   "/bin/entry.sh pytho…"   18 minutes ago      Up 8 minutes                            homeassistant
62eb2fba4fb5        homeassistant/amd64-hassio-supervisor    "python3 -m hassio"      18 minutes ago      Up 18 minutes                           hassio_supervisor
########################### hassio log ###########################
19-01-14 17:30:54 INFO (MainThread) [__main__] Initialize Hass.io setup
19-01-14 17:30:54 INFO (MainThread) [__main__] Setup HassIO
19-01-14 17:30:54 INFO (SyncWorker_0) [hassio.docker.supervisor] Attach to Supervisor homeassistant/amd64-hassio-supervisor with version 141
19-01-14 17:30:55 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.systemd1 on /org/freedesktop/systemd1
19-01-14 17:30:55 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
19-01-14 17:30:55 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.hostname1 on /org/freedesktop/hostname1
19-01-14 17:30:55 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
19-01-14 17:30:55 INFO (MainThread) [hassio.utils.gdbus] Introspect de.pengutronix.rauc on /
19-01-14 17:30:55 ERROR (MainThread) [hassio.utils.gdbus] DBus return error: b'Error: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name de.pengutronix.rauc was not provided by any .service files\n'
19-01-14 17:30:55 WARNING (MainThread) [hassio.dbus.rauc] Can't connect to rauc
19-01-14 17:30:55 INFO (MainThread) [hassio.host.info] Update local host information
19-01-14 17:30:55 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
19-01-14 17:30:55 INFO (MainThread) [hassio.host.services] Update service information
19-01-14 17:30:55 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
19-01-14 17:30:55 INFO (MainThread) [hassio.host.apparmor] Load AppArmor Profiles: {'hassio-supervisor'}
19-01-14 17:30:55 INFO (MainThread) [hassio.host.services] Reload local service hassio-apparmor.service
19-01-14 17:30:55 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ReloadOrRestartUnit on /org/freedesktop/systemd1
19-01-14 17:30:55 INFO (SyncWorker_0) [hassio.docker.interface] Attach to image homeassistant/qemux86-64-homeassistant with version 0.85.1
19-01-14 17:30:55 INFO (MainThread) [hassio.addons.git] Load add-on /data/addons/git/a0d7b954 repository
19-01-14 17:30:55 INFO (MainThread) [hassio.addons.git] Load add-on /data/addons/core repository
19-01-14 17:30:55 INFO (MainThread) [hassio.addons] Load add-ons: 51 all - 51 new - 0 remove
19-01-14 17:30:55 INFO (MainThread) [hassio.updater] Fetch update data from [url=https://s3.amazonaws.com/hassio-version/stable.json]https://s3.amazonaws.com/hassio-version/stable.json[/url]
19-01-14 17:30:57 INFO (MainThread) [hassio.snapshots] Found 0 snapshot files
19-01-14 17:30:57 INFO (MainThread) [hassio.discovery] Load 0 messages
19-01-14 17:30:57 INFO (MainThread) [__main__] Run Hass.io
19-01-14 17:30:57 INFO (MainThread) [hassio.misc.dns] Start DNS port forwarding for host add-ons
19-01-14 17:30:57 INFO (MainThread) [hassio.core] Ignore Hass.io auto updates on dev channel
19-01-14 17:30:57 INFO (MainThread) [hassio.api] Start API on 172.30.32.2
19-01-14 17:30:57 INFO (MainThread) [hassio.addons] Startup initialize run 0 add-ons
19-01-14 17:30:57 INFO (MainThread) [hassio.addons] Startup system run 0 add-ons
19-01-14 17:30:57 INFO (MainThread) [hassio.addons] Startup services run 0 add-ons
19-01-14 17:30:57 INFO (SyncWorker_1) [hassio.docker.homeassistant] Start homeassistant homeassistant/qemux86-64-homeassistant with version 0.85.1
19-01-14 17:40:58 WARNING (MainThread) [hassio.homeassistant] Don't wait anymore of Home Assistant startup!
19-01-14 17:40:58 INFO (MainThread) [hassio.addons] Startup application run 1 add-ons
19-01-14 17:40:58 ERROR (MainThread) [hassio.addons.addon] Add-on core_configurator have wrong options: Missing required option 'password'. Got {'username': 'admin', 'password': None, 'ssl': False, 'certfile': 'fullchain.pem', 'keyfile': 'privkey.pem', 'allowed_networks': ['192.168.0.0/16', '172.30.0.0/16'], 'banned_ips': ['8.8.8.8'], 'banlimit': 0, 'ignore_pattern': ['__pycache__'], 'dirsfirst': False, 'enforce_basepath': False, 'notify_service': 'persistent_notification.create'}
19-01-14 17:41:03 INFO (MainThread) [hassio.tasks] All core tasks are scheduled
19-01-14 17:41:03 INFO (MainThread) [hassio.core] Hass.io is up and running
########################### homeassistant log ###########################
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.loader] Loaded websocket_api from homeassistant.components.websocket_api
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.bootstrap] Home Assistant core initialized
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.loader] Loaded frontend from homeassistant.components.frontend
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.loader] Loaded api from homeassistant.components.api
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.loader] Loaded http from homeassistant.components.http
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.loader] Loaded system_log from homeassistant.components.system_log
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.loader] Loaded auth from homeassistant.components.auth
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.loader] Loaded onboarding from homeassistant.components.onboarding
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.loader] Loaded lovelace from homeassistant.components.lovelace
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.loader] Loaded history from homeassistant.components.history
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.loader] Loaded recorder from homeassistant.components.recorder
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.loader] Loaded introduction from homeassistant.components.introduction
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.setup] Setting up introduction
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.components.introduction]
        Hello, and welcome to Home Assistant!
        We'll hope that we can make all your dreams come true.
        Here are some resources to get started:
         - Configuring Home Assistant:
           [url=https://home-assistant.io/getting-started/configuration/]https://home-assistant.io/getting-started/configuration/[/url]
         - Available components:
           [url=https://home-assistant.io/components/]https://home-assistant.io/components/[/url]
         - Troubleshooting your configuration:
           [url=https://home-assistant.io/getting-started/troubleshooting-configuration/]https://home-assistant.io/getting-started/troubleshooting-configuration/[/url]
         - Getting help:
           [url=https://home-assistant.io/help/]https://home-assistant.io/help/[/url]
        This message is generated by the introduction component. You can
        disable it in configuration.yaml.
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.loader] Loaded persistent_notification from homeassistant.components.persistent_notification
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.setup] Setup of domain introduction took 0.0 seconds.
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.setup] Setting up http
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.0 seconds.
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.setup] Setting up lovelace
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.setup] Setup of domain lovelace took 0.0 seconds.
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.setup] Setting up recorder
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.setup] Setting up system_log
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.setup] Setup of domain system_log took 0.0 seconds.
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.setup] Setting up auth
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.setup] Setup of domain auth took 0.0 seconds.
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.setup] Setting up onboarding
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.setup] Setting up api
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.setup] Setting up websocket_api
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.0 seconds.
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.setup] Setup of domain api took 0.0 seconds.
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.setup] Setup of domain onboarding took 0.0 seconds.
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.setup] Setting up frontend
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.setup] Setup of domain frontend took 0.4 seconds.
2019-01-14 17:31:00 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=11 from 2019-01-14 13:14:46.336191)
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 0.6 seconds.
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.setup] Setting up history
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.setup] Setup of domain history took 0.0 seconds.
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.loader] Loaded tts from homeassistant.components.tts
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.loader] Loaded tts.google from homeassistant.components.tts.google
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.loader] Loaded automation from homeassistant.components.automation
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.loader] Loaded group from homeassistant.components.group
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.loader] Loaded config from homeassistant.components.config
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.loader] Loaded conversation from homeassistant.components.conversation
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.setup] Setting up group
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.setup] Setup of domain group took 0.0 seconds.
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.loader] Loaded script from homeassistant.components.script
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.loader] Loaded cast from homeassistant.components.cast
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.setup] Setting up cast
2019-01-14 17:31:00 INFO (MainThread) [homeassistant.setup] Setup of domain cast took 0.0 seconds.
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.loader] Loaded cloud from homeassistant.components.cloud
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.loader] Loaded logbook from homeassistant.components.logbook
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.loader] Loaded sensor from homeassistant.components.sensor
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.loader] Loaded sensor.yr from homeassistant.components.sensor.yr
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.setup] Setting up sensor
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.loader] Loaded updater from homeassistant.components.updater
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.setup] Setting up updater
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.loader] Loaded sun from homeassistant.components.sun
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.setup] Setting up sun
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.setup] Setup of domain sun took 0.0 seconds.
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.loader] Loaded map from homeassistant.components.map
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.setup] Setting up map
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.setup] Setup of domain map took 0.0 seconds.
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.loader] Loaded discovery from homeassistant.components.discovery
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.setup] Setting up discovery
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.setup] Setup of domain discovery took 0.0 seconds.
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.yr
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.loader] Loaded media_player from homeassistant.components.media_player
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.setup] Setup of domain updater took 0.1 seconds.
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.setup] Setting up tts
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.setup] Setting up automation
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.setup] Setup of domain automation took 0.0 seconds.
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.setup] Setting up config
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.setup] Setting up conversation
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.setup] Setup of domain conversation took 0.0 seconds.
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.setup] Setting up script
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.setup] Setup of domain script took 0.0 seconds.
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.setup] Setting up cloud
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.setup] Setup of domain cloud took 0.0 seconds.
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.setup] Setting up logbook
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.setup] Setup of domain logbook took 0.0 seconds.
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.loader] Loaded config.customize from homeassistant.components.config.customize
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.loader] Loaded config.device_registry from homeassistant.components.config.device_registry
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.loader] Loaded config.entity_registry from homeassistant.components.config.entity_registry
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.loader] Loaded config.automation from homeassistant.components.config.automation
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.loader] Loaded config.group from homeassistant.components.config.group
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.loader] Loaded config.auth_provider_homeassistant from homeassistant.components.config.auth_provider_homeassistant
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.loader] Loaded config.auth from homeassistant.components.config.auth
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.loader] Loaded config.config_entries from homeassistant.components.config.config_entries
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.loader] Loaded config.hassbian from homeassistant.components.config.hassbian
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.loader] Loaded config.core from homeassistant.components.config.core
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.loader] Loaded config.script from homeassistant.components.config.script
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.setup] Setting up media_player
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.setup] Setup of domain media_player took 0.0 seconds.
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.loader] Loaded media_player.cast from homeassistant.components.media_player.cast
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.setup] Setup of domain config took 0.1 seconds.
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.components.media_player] Setting up media_player.cast
2019-01-14 17:31:01 INFO (MainThread) [homeassistant.setup] Setup of domain tts took 0.1 seconds.
2019-01-14 17:31:01 INFO (SyncWorker_9) [pychromecast] Querying device status
2019-01-14 17:31:06 ERROR (MainThread) [homeassistant.components.sensor.yr] Retrying in 18 minutes: Cannot connect to host aa015h6buqvih86i1.api.met.no:443 ssl:None [Try again]
2019-01-14 17:31:06 INFO (MainThread) [homeassistant.setup] Setup of domain sensor took 5.1 seconds.
2019-01-14 17:31:17 ERROR (SyncWorker_9) [pychromecast.socket_client] Failed to connect, retrying in 5.0s
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.loader] Loaded websocket_api from homeassistant.components.websocket_api
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.bootstrap] Home Assistant core initialized
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.loader] Loaded history from homeassistant.components.history
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.loader] Loaded recorder from homeassistant.components.recorder
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.loader] Loaded http from homeassistant.components.http
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.loader] Loaded frontend from homeassistant.components.frontend
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.loader] Loaded api from homeassistant.components.api
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.loader] Loaded system_log from homeassistant.components.system_log
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.loader] Loaded auth from homeassistant.components.auth
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.loader] Loaded onboarding from homeassistant.components.onboarding
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.loader] Loaded lovelace from homeassistant.components.lovelace
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.loader] Loaded introduction from homeassistant.components.introduction
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setting up introduction
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.components.introduction]
         - Getting help:
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.loader] Loaded persistent_notification from homeassistant.components.persistent_notification
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setup of domain introduction took 0.0 seconds.
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setting up http
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.0 seconds.
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setting up recorder
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setting up lovelace
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setup of domain lovelace took 0.0 seconds.
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setting up system_log
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setup of domain system_log took 0.0 seconds.
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setting up auth
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setup of domain auth took 0.0 seconds.
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setting up onboarding
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setting up api
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setting up websocket_api
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.0 seconds.
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setup of domain api took 0.0 seconds.
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setup of domain onboarding took 0.0 seconds.
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setting up frontend
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setup of domain frontend took 0.4 seconds.
2019-01-14 17:40:43 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=12 from 2019-01-14 17:31:00.334358)
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 0.5 seconds.
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setting up history
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setup of domain history took 0.0 seconds.
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.loader] Loaded map from homeassistant.components.map
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setting up map
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setup of domain map took 0.0 seconds.
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.loader] Loaded sensor from homeassistant.components.sensor
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.loader] Loaded sensor.yr from homeassistant.components.sensor.yr
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setting up sensor
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.loader] Loaded conversation from homeassistant.components.conversation
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.loader] Loaded discovery from homeassistant.components.discovery
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setting up discovery
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setup of domain discovery took 0.0 seconds.
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.loader] Loaded logbook from homeassistant.components.logbook
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.loader] Loaded cast from homeassistant.components.cast
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setting up cast
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setup of domain cast took 0.0 seconds.
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.loader] Loaded updater from homeassistant.components.updater
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setting up updater
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.loader] Loaded group from homeassistant.components.group
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setting up group
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setup of domain group took 0.0 seconds.
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.loader] Loaded automation from homeassistant.components.automation
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.loader] Loaded cloud from homeassistant.components.cloud
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.loader] Loaded script from homeassistant.components.script
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.loader] Loaded tts from homeassistant.components.tts
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.loader] Loaded tts.google from homeassistant.components.tts.google
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.loader] Loaded config from homeassistant.components.config
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.loader] Loaded sun from homeassistant.components.sun
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setting up sun
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setup of domain sun took 0.0 seconds.
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.yr
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.loader] Loaded media_player from homeassistant.components.media_player
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setup of domain updater took 0.1 seconds.
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setting up conversation
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setup of domain conversation took 0.0 seconds.
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setting up logbook
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setup of domain logbook took 0.0 seconds.
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setting up automation
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setup of domain automation took 0.0 seconds.
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setting up cloud
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setup of domain cloud took 0.0 seconds.
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setting up script
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setup of domain script took 0.0 seconds.
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setting up tts
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setting up config
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.loader] Loaded config.group from homeassistant.components.config.group
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.loader] Loaded config.hassbian from homeassistant.components.config.hassbian
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.loader] Loaded config.core from homeassistant.components.config.core
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.loader] Loaded config.script from homeassistant.components.config.script
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.loader] Loaded config.customize from homeassistant.components.config.customize
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.loader] Loaded config.auth_provider_homeassistant from homeassistant.components.config.auth_provider_homeassistant
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.loader] Loaded config.device_registry from homeassistant.components.config.device_registry
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.loader] Loaded config.config_entries from homeassistant.components.config.config_entries
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.loader] Loaded config.entity_registry from homeassistant.components.config.entity_registry
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.loader] Loaded config.automation from homeassistant.components.config.automation
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.loader] Loaded config.auth from homeassistant.components.config.auth
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setting up media_player
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setup of domain media_player took 0.0 seconds.
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.loader] Loaded media_player.cast from homeassistant.components.media_player.cast
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.components.media_player] Setting up media_player.cast
2019-01-14 17:40:43 INFO (MainThread) [homeassistant.setup] Setup of domain config took 0.0 seconds.
2019-01-14 17:40:44 INFO (MainThread) [homeassistant.setup] Setup of domain tts took 0.1 seconds.
2019-01-14 17:40:44 INFO (SyncWorker_9) [pychromecast] Querying device status
2019-01-14 17:40:53 WARNING (MainThread) [homeassistant.components.sensor] Setup of platform yr is taking over 10 seconds.
2019-01-14 17:40:53 ERROR (MainThread) [homeassistant.components.sensor.yr] Retrying in 20 minutes:
2019-01-14 17:40:53 INFO (MainThread) [homeassistant.setup] Setup of domain sensor took 10.1 seconds.
2019-01-14 17:41:00 ERROR (SyncWorker_9) [pychromecast.socket_client] Failed to connect, retrying in 5.0s
 homeassistant 启动超时,请检查上方日志....
 楼主| 发表于 2019-1-15 08:57:15 | 显示全部楼层
iNathan 发表于 2019-1-15 01:56
大佬 这是什么情况呢?
[code]等待 homeassistant 启动................................ ...
看日志 web应该是起来的,你访问 8123端口试试
发表于 2019-1-16 00:13:43 | 显示全部楼层
这个真是引起极度舒适,捡起了家里闲置的树莓派,一键脚本输进去,去茶室泡会儿茶就装好了。
发表于 2019-1-16 01:49:41 | 显示全部楼层
大大一生好運
发表于 2019-1-16 13:04:14 | 显示全部楼层
今天想升级HA,可是出错了,然后我删除了/var/lib/docker文件夹,想重新安装一下,可是当重新运行这个脚本的时候出现错误,最后服务启动不起来,楼主老大,帮我看看,谢谢!!
homeassistant/qemuarm-64-homeassistant    0.85.1              2bd4d2af214a        2 days ago          1.15GB
homeassistant/qemuarm-64-homeassistant    latest              2bd4d2af214a        2 days ago          1.15GB
homeassistant/aarch64-hassio-supervisor   141                 6b57892e59a7        5 weeks ago         208MB
homeassistant/aarch64-hassio-supervisor   latest              6b57892e59a7        5 weeks ago         208MB
140c2c49467d        homeassistant/aarch64-hassio-supervisor   "python3 -m hassio"   5 minutes ago       Up 5 minutes                            hassio_supervisor
19-01-16 04:44:21 INFO (MainThread) [__main__] Initialize Hass.io setup
19-01-16 04:44:21 INFO (MainThread) [hassio.docker.network] Can't find Hass.io network, create new network
19-01-16 04:44:21 INFO (MainThread) [__main__] Setup HassIO
19-01-16 04:44:21 INFO (SyncWorker_0) [hassio.docker.supervisor] Attach to Supervisor homeassistant/aarch64-hassio-supervisor with version 141
19-01-16 04:44:22 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.systemd1 on /org/freedesktop/systemd1
19-01-16 04:44:22 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
19-01-16 04:44:22 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.hostname1 on /org/freedesktop/hostname1
19-01-16 04:44:22 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
19-01-16 04:44:22 INFO (MainThread) [hassio.utils.gdbus] Introspect de.pengutronix.rauc on /
19-01-16 04:44:22 ERROR (MainThread) [hassio.utils.gdbus] DBus return error: b'Error: GDBus.Errorrg.freedesktop.DBus.Error.ServiceUnknown: The name de.pengutronix.rauc was not provided by any .service files\n'
19-01-16 04:44:22 WARNING (MainThread) [hassio.dbus.rauc] Can't connect to rauc
19-01-16 04:44:22 INFO (MainThread) [hassio.host.info] Update local host information
19-01-16 04:44:22 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
19-01-16 04:44:22 INFO (MainThread) [hassio.host.services] Update service information
19-01-16 04:44:22 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
19-01-16 04:44:22 INFO (MainThread) [hassio.host.apparmor] Load AppArmor Profiles: {'hassio-supervisor'}
19-01-16 04:44:22 INFO (MainThread) [hassio.host.apparmor] AppArmor is not enabled on host
19-01-16 04:44:22 INFO (SyncWorker_1) [hassio.docker.interface] Attach to image homeassistant/qemuarm-64-homeassistant with version 0.85.1
19-01-16 04:44:22 WARNING (MainThread) [hassio.addons.data] Can't read /data/addons/core/deconz/config.json: value is not allowed @ data['privileged'][0]. Got 'SYS_MODULE'
19-01-16 04:44:23 INFO (MainThread) [hassio.addons.git] Load add-on /data/addons/core repository
19-01-16 04:44:23 INFO (MainThread) [hassio.addons.git] Load add-on /data/addons/git/a0d7b954 repository
19-01-16 04:44:23 WARNING (MainThread) [hassio.addons.data] Can't read /data/addons/core/deconz/config.json: value is not allowed @ data['privileged'][0]. Got 'SYS_MODULE'
19-01-16 04:44:23 INFO (MainThread) [hassio.addons] Load add-ons: 51 all - 51 new - 0 remove
19-01-16 04:44:23 INFO (MainThread) [hassio.updater] Fetch update data from https://s3.amazonaws.com/hassio-version/stable.json
19-01-16 04:44:34 WARNING (MainThread) [hassio.updater] Can't fetch versions from https://s3.amazonaws.com/hassio-version/stable.json:
19-01-16 04:44:34 INFO (MainThread) [hassio.snapshots] Found 0 snapshot files
19-01-16 04:44:34 INFO (MainThread) [hassio.discovery] Load 0 messages
19-01-16 04:44:34 INFO (MainThread) [__main__] Run Hass.io
19-01-16 04:44:34 INFO (MainThread) [hassio.misc.dns] Start DNS port forwarding for host add-ons
19-01-16 04:44:34 INFO (MainThread) [hassio.core] Ignore Hass.io auto updates on dev channel
19-01-16 04:44:34 INFO (MainThread) [hassio.api] Start API on 172.30.32.2
19-01-16 04:44:34 INFO (MainThread) [hassio.addons] Startup initialize run 0 add-ons
19-01-16 04:44:34 INFO (MainThread) [hassio.core] Hass.io reboot detected
19-01-16 04:44:34 INFO (MainThread) [hassio.tasks] All core tasks are scheduled
19-01-16 04:44:34 INFO (MainThread) [hassio.core] Hass.io is up and running
Error: No such container: homeassistant
 楼主| 发表于 2019-1-16 13:57:20 | 显示全部楼层
whhlcj 发表于 2019-1-16 13:04
今天想升级HA,可是出错了,然后我删除了/var/lib/docker文件夹,想重新安装一下,可是当重新运行这个脚本 ...
看日志是正常的
这里是启动homeassistant容器,但为什么启动不成功·····?
重启下试试?
neo
发表于 2019-1-16 15:51:57 | 显示全部楼层
@楼主
装玩了这个需要怎样再安装nodered?
可以一起加到一键脚本里吗?
 楼主| 发表于 2019-1-16 15:59:29 | 显示全部楼层
neo 发表于 2019-1-16 15:51
@楼主
hassio addons 带了 nodered
GMT+8, 2025-12-16 02:08 , Processed in 0.932154 second(s), 17 queries , MemCached On.
