楼主: neroxps
HASSIO 安装一键脚本
 火...   [复制链接]
发表于 2021-2-18 03:27:46 | 显示全部楼层
现在系统Python版本还是 3.6.9
很多插件已经不让安装了,如何升级呢?
更新系统提示:
21-02-17 19:12:42 WARNING (MainThread) [supervisor.jobs] 'HomeAssistantCore.update' blocked from execution, system is not healthy
 楼主| 发表于 2021-2-19 08:43:30 | 显示全部楼层
很多插件已经不让安装了,如何升级呢?
更新系统提示:
和系统python无关
supervisor 主要是以下几个点
Docker CE >= 19.03
Systemd >= 239
NetworkManager >= 1.14.6
AppArmor == 2.13.x (built into the kernel)
Debian Linux Debian 10 aka Buster (no derivatives)
发表于 2021-2-19 16:26:18 | 显示全部楼层
树莓派4,装的是Debian-Pi-Aarch64 ★ 全新树莓派64位系统 这个版本的系统
脚本一件安装报这个错误,请大佬们指教
[info] 切换系统网络源.....
[warn] 备份系统源文件为 /etc/apt/sources.list.bak
Hit:1 http://mirrors.tuna.tsinghua.edu.cn/debian buster InRelease
Hit:2 http://mirrors.tuna.tsinghua.edu.cn/debian buster-updates InRelease
Hit:3 http://mirrors.tuna.tsinghua.edu.cn/debian buster-backports InRelease
Hit:4 http://mirrors.tuna.tsinghua.edu.cn/debian-security buster/updates InRelease
Get:5 http://mirrors.tuna.tsinghua.edu.cn/raspberrypi buster InRelease [32.8 kB]
Err:5 http://mirrors.tuna.tsinghua.edu.cn/raspberrypi buster InRelease
  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 82B129927FA3303E
Reading package lists... Done
W: GPG error: http://mirrors.tuna.tsinghua.edu.cn/raspberrypi buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 82B129927FA3303E
E: The repository 'http://mirrors.tuna.tsinghua.edu.cn/raspberrypi buster InRelease' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
################# 发到论坛时,请把上方日志也一并粘贴发送 ################
########################### Script Version: 2021.01.07.0###########################
Linux version 5.4.83-OPENFANS+20210102-v8 (root@raspbian) (gcc version 10.2.0 (GCC)) #1 SMP Sat Jan 2 21:52:54 CST 2021
Linux raspbian 5.4.83-OPENFANS+20210102-v8 #1 SMP Sat Jan 2 21:52:54 CST 2021 aarch64 GNU/Linux
[ERROR]: 系统源切换错误,请检查网络连接是否正常,脚本退出
 楼主| 发表于 2021-2-19 23:07:51 | 显示全部楼层
脚本一件安装报这个错误,请大佬 ...
不要用wifi
发表于 2021-2-23 17:53:09 | 显示全部楼层
懵懂的小白白 发表于 2021-2-17 11:06
下载一直下载不了,会卡在这里
解决了吗?我也是这样
发表于 2021-2-24 10:48:36 | 显示全部楼层
wangsibo520 发表于 2021-2-23 17:53
解决了吗?我也是这样
没有,直接换了hassos
发表于 2021-2-27 08:23:24 | 显示全部楼层
受教了!!!!
发表于 2021-3-3 22:03:24 | 显示全部楼层
+ sh -c apt-get install -y -qq --no-install-recommends docker-ce >/dev/null
E: Failed to fetch https://mirrors.aliyun.com/docke ... an-buster_arm64.deb  404  Not Found [IP: 61.147.223.248 443]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
########################### Script Version: 2021.02.23.0###########################
Distributor ID: Debian
Description:    Debian GNU/Linux 10 (buster)
Release:        10
Codename:       buster
Linux version 5.10.11-v8+ (dom@buildbot) (aarch64-linux-gnu-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1399 SMP PREEMPT Thu Jan 28 12:14:03 GMT 2021
Linux raspberrypi 5.10.11-v8+ #1399 SMP PREEMPT Thu Jan 28 12:14:03 GMT 2021 aarch64 GNU/Linux
Docker 安装失败,请检查上方安装错误信息。 你也可以选择通过搜索引擎,搜索你系统安装docker的方法,安装后重新执行脚本。
[warn]  相关问题可以访问https://bbs.iobroker.cn或者加QQ群776817275咨询
发表于 2021-3-3 23:16:10 | 显示全部楼层
E: 无法下载 https://mirrors.aliyun.com/docke ... an-buster_armhf.deb  404  Not Found [IP: 115.223.15.230 443]
E: 有几个软件包无法下载,要不运行 apt-get update 或者加上 --fix-missing 的选项再试试?
Distributor ID: Raspbian
Description:    Raspbian GNU/Linux 10 (buster)
Release:        10
Codename:       buster
Linux version 5.10.11-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1399 SMP Thu Jan 28 12:09:48 GMT 2021
Linux raspberrypi 5.10.11-v7l+ #1399 SMP Thu Jan 28 12:09:48 GMT 2021 armv7l GNU/Linux
树莓派4b,看了下这俩网页确实404了
发表于 2021-3-4 01:59:14 | 显示全部楼层
应该是不同源的信息没有同步,我看aliyun的源还没有20.10.5的包,但是清华源是有的。
可以手动编辑install.sh,在195行后面追加一行,替换掉aliyun的docker路径,然后运行应该就可以了。即把:
docker_install(){
    download_file 'https://get.docker.com' 'get-docker.sh'
    sed -i 's/DEFAULT_CHANNEL_VALUE="test"/DEFAULT_CHANNEL_VALUE="stable"/' get-docker.sh
    chmod u+x get-docker.sh
    ./get-docker.sh --mirror Aliyun
改成:
docker_install(){
    sed -i 's/DOWNLOAD_URL="https:\/\/mirrors.aliyun.com/DOWNLOAD_URL="https:\/\/mirrors.tuna.tsinghua.edu.cn/' ./get-docker.sh
参与人数 1金钱 +20 收起 理由
neroxps + 20
GMT+8, 2025-12-11 16:38 , Processed in 0.164791 second(s), 14 queries , MemCached On.
