楼主: neroxps
HASSIO 安装一键脚本
 火...   [复制链接]
发表于 2021-1-13 09:25:48 | 显示全部楼层
oliverivy 发表于 2021-1-13 09:04
我每次到这一步的时候就会断ssh,我以为ssh进程崩溃了,还真没注意是因为自己ip变了 ...
真的是,并且还是因为mac地址变了
发表于 2021-1-13 09:33:35 | 显示全部楼层
neroxps 发表于 2021-1-11 17:43
信息太少,首先感觉是 DNS 拿不到IP地址.看你的地址好像是IPV6?
我用的ipv4
[warn] 开始 hassio 安装流程。(如出现 [Warning] 请忽略,无须理会)
[warn]
[warn] If you want more control over your own system, run
[warn] Home Assistant as a VM or run Home Assistant Core
[warn] via a Docker container.
[warn]
[warn] If you want to abort, hit ctrl+c within 10 seconds...
[warn]
[warn] ModemManager service is enabled. This might cause issue when using serial devices.
[info] Creating NetworkManager configuration
[warn] Changes are needed to the /etc/network/interfaces file
[info] If you have modified the network on the host manualy, those can now be overwritten
[info] If you do not overwrite this now you need to manually adjust it later
[info] Do you want to proceed with overwriting the /etc/network/interfaces file? [N/y]
[info] Restarting NetworkManager
[info] Wait for networkmanages to start.
[info] Install supervisor Docker container
Get https://registry-1.docker.io/v2/: dial tcp: lookup registry-1.docker.io on [::1]:53: read udp [::1]:40598->[::1]:53: read: connection refused
Unit hassio-supervisor.service could not be found.
################# 发到论坛时,请把上方日志也一并粘贴发送 ################
########################### Script Version: 2021.01.07.0###########################
Linux version 5.4.45-OPENFANS+20200614-v8 (root@raspbian) (gcc version 10.1.0 (GCC)) #1 SMP PREEMPT Sun Jun 14 19:45:16 CST 2020
Linux raspbian 5.4.45-OPENFANS+20200614-v8 #1 SMP PREEMPT Sun Jun 14 19:45:16 CST 2020 aarch64 GNU/Linux
安装 hassio 失败,请将上方安装信息发送到论坛询问。脚本退出...
 楼主| 发表于 2021-1-13 09:37:55 | 显示全部楼层
oliverivy 发表于 2021-1-13 09:25
真的是,并且还是因为mac地址变了
https://huataihuang.gitbooks.io/ ... kmanager_nmcli.html
mac 地址变可以看看这篇文章,我没树莓派 没用wifi
发表于 2021-1-13 22:24:51 | 显示全部楼层
哎,我安装时出这个错误。在安装Hassio依赖的时候
下列【新】软件包将被安装:
  apparmor-utils dns-root-data dnsmasq-base jq libbluetooth3 libjq1
  libmbim-glib4 libmbim-proxy libmm-glib0 libndp0 libnm0 libonig5 libpcap0.8
  libqmi-glib5 libqmi-proxy libqrencode4 libteamdctl0 modemmanager
  network-manager ppp python3-apparmor python3-libapparmor qrencode socat
升级了 0 个软件包,新安装了 24 个软件包,要卸载 0 个软件包,有 119 个软件包未被升级。
需要下载 0 B/7,380 kB 的归档。
解压缩后会消耗 25.1 MB 的额外空间。
正在选中未选择的软件包 libbluetooth3:armhf。
dpkg: 无法恢复的致命错误,中止:
 软件包 piwiz 的文件名列表文件缺少最后结尾的换行符
E: Sub-process /usr/bin/dpkg returned an error code (2)
Distributor ID: Raspbian
Description:    Raspbian GNU/Linux 10 (buster)
Release:        10
Codename:       buster
Linux version 5.4.79-v7+ (dom@buildbot) (gcc version 8.4.0 (Ubuntu/Linaro 8.4.0-3ubuntu1)) #1373 SMP Mon Nov 23 13:22:33 GMT 2020
Linux raspberrypi 5.4.79-v7+ #1373 SMP Mon Nov 23 13:22:33 GMT 2020 armv7l GNU/Linux
安装curl socat jq avahi-daemon net-tools network-manager qrencode apparmor apparmor-utils失败,请将检查上方安装错误信息。
发表于 2021-1-14 13:55:44 | 显示全部楼层
neroxps 发表于 2021-1-13 09:37
https://huataihuang.gitbooks.io/cloud-atlas/content/os/linux/redhat/system_administration/network/ ...
感谢感谢 我用网线就没事了
发表于 2021-1-15 17:04:12 | 显示全部楼层
 # 1. 是否将系统源切换为清华源:       否
 # 2. 是否将用户添加至 Docker 用户组:   否
 # 3. 是否将 Docker 源切换至国内源:     否
 # 4. 您的设备类型为:                   qemux86-64
 # 5. 您的 hassio 数据路径为:           /home/docker/hassio
 # 6. 是否将 github hosts 写入 coreDNS: 否
请确认以上信息,继续请按任意键,如需修改请输入 Ctrl+C 结束任务重新执行脚本。
[info] 跳过切换系统源。
[info] 安装 hassio 必要依赖.....
./install.sh: line 211: apt: command not found
./install.sh: line 212: apt: command not found
Linux version 3.10.0-693.11.6.el7.x86_64 ([email protected]) (gcc version 4.8.5 20150623 (Red Hat 4.8.5-16) (GCC) ) #1 SMP Thu Jan 4 01:06:37 UTC 2018
Linux 10-8-26-70 3.10.0-693.11.6.el7.x86_64 #1 SMP Thu Jan 4 01:06:37 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
后续能支持centos7吗,我目前想把他搭到服务器上
 楼主| 发表于 2021-1-15 17:32:18 | 显示全部楼层
不能~
发表于 2021-1-17 18:49:04 | 显示全部楼层
Distributor ID: Debian
Description:    Debian GNU/Linux 10 (buster)
Release:        10
Codename:       buster
Linux version 5.2.1-aml-g12 (root@vbox) (gcc version 7.4.1 20181213 [linaro-7.4-2019.02 revision 56ec6f6b99cc167ff0c2f8e1a2eed33b1edc85d4] (Linaro GCC 7.4-2019.02)) #5.91 SMP PREEMPT Wed Jul 24 14:57:52 MSK 2019
Linux aml 5.2.1-aml-g12 #5.91 SMP PREEMPT Wed Jul 24 14:57:52 MSK 2019 aarch64 GNU/Linux
 楼主| 发表于 2021-1-17 21:48:36 | 显示全部楼层
发表于 2021-1-20 21:56:28 | 显示全部楼层
这个脚本亲测ubuntu2004安装成功,但是树莓派似乎在设置网卡之后ssh和远程桌面就都断开了,千万注意准备屏幕
GMT+8, 2025-12-13 09:15 , Processed in 0.617131 second(s), 11 queries , MemCached On.
