楼主: neroxps
HASSIO 安装一键脚本
 火...   [复制链接]
发表于 2020-5-5 15:42:17 | 显示全部楼层
应该是一些原因导致docker无法启动,我卸载docker后重新安装,然后手动安装ha就可以启动了。
感谢回复。
发表于 2020-5-5 16:45:59 | 显示全部楼层
Ubuntu 18.04 清华源会安装失败,手动配置中科大源可以安装成功,提示package 不存在
cat /etc/issue
Ubuntu 18.04.2 LTS \n \l
 楼主| 发表于 2020-5-6 10:10:43 | 显示全部楼层
cat /etc/issue
Ubun ...
我这边测试没问题,清华源失败的日志有吗?
发表于 2020-5-6 14:44:35 | 显示全部楼层
太棒了,然后我请问一个问题,mqtt是不是也需要装在docker里边
发表于 2020-5-6 20:56:45 | 显示全部楼层
Ign:24 http://mirrors.tuna.tsinghua.edu.cn/ubuntu focal-updates/main armhf Packages
Ign:29 http://mirrors.tuna.tsinghua.edu.cn/ubuntu focal-updates/universe armhf Packages
Ign:30 http://mirrors.tuna.tsinghua.edu.cn/ubuntu focal-updates/universe arm64 Packages
Err:36 http://mirrors.tuna.tsinghua.edu.cn/ubuntu focal-backports/universe armhf Packages
  404  Not Found [IP: 101.6.8.193 80]
Ign:37 http://mirrors.tuna.tsinghua.edu.cn/ubuntu focal-backports/universe arm64 Packages
Err:41 http://mirrors.tuna.tsinghua.edu.cn/ubuntu focal-security/main arm64 Packages
Ign:42 http://mirrors.tuna.tsinghua.edu.cn/ubuntu focal-security/main armhf Packages
Ign:47 http://mirrors.tuna.tsinghua.edu.cn/ubuntu focal-security/universe armhf Packages
Ign:48 http://mirrors.tuna.tsinghua.edu.cn/ubuntu focal-security/universe arm64 Packages
Fetched 6671 kB in 5s (1379 kB/s)
Reading package lists... Done
E: Failed to fetch http://mirrors.tuna.tsinghua.edu ... nary-armhf/Packages  404  Not Found [IP: 101.6.8.193 80]
E: Failed to fetch http://mirrors.tuna.tsinghua.edu ... nary-arm64/Packages  404  Not Found [IP: 101.6.8.193 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
################# 发到论坛时,请把上方日志也一并粘贴发送 ################
Distributor ID:        Ubuntu
Description:        Ubuntu 18.04.2 LTS
Release:        18.04
Codename:        bionic
Linux version 5.0.2-aml-s905 (root@vbox) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05)) #5.77 SMP PREEMPT Mon Apr 1 17:23:16 MSK 2019
Linux SmartHome 5.0.2-aml-s905 #5.77 SMP PREEMPT Mon Apr 1 17:23:16 MSK 2019 aarch64 aarch64 aarch64 GNU/Linux
[ERROR]: 系统源切换错误,请检查网络连接是否正常,脚本退出
相关问题可以访问https://bbs.iobroker.cn或者加QQ群776817275咨询
 楼主| 发表于 2020-5-7 10:31:56 | 显示全部楼层
Ign:29 http:// ...
欸,是不是树莓派的Ubuntu源不一样的?没树莓派 不知道啥情况。
哦 原来 Ubuntu 的 arm 源是 ubuntu-ports
我修复下
发表于 2020-5-7 14:48:46 | 显示全部楼层
哦 原来 Ubuntu 的 arm 源是 ubuntu-ports ...
看来是找打原因了
发表于 2020-5-8 08:23:13 | 显示全部楼层
[info]: 安装 hassio 必要依赖.....
Hit:1 http://mirrors.tuna.tsinghua.edu.cn/ubuntu focal InRelease
Hit:2 https://mirror.azure.cn/docker-ce/linux/ubuntu artful InRelease
Hit:3 http://mirrors.tuna.tsinghua.edu.cn/ubuntu focal-updates InRelease
Hit:4 http://mirrors.tuna.tsinghua.edu.cn/ubuntu focal-backports InRelease
Hit:5 http://mirrors.tuna.tsinghua.edu.cn/ubuntu focal-security InRelease
Building dependency tree
Reading state information... Done
436 packages can be upgraded. Run 'apt list --upgradable' to see them.
avahi-daemon is already the newest version (0.7-4ubuntu7).
curl is already the newest version (7.68.0-1ubuntu2).
net-tools is already the newest version (1.60+git20180626.aebd88e-1ubuntu1).
socat is already the newest version (1.7.3.3-2).
jq is already the newest version (1.6-1).
qrencode is already the newest version (4.0.2-2).
0 upgraded, 0 newly installed, 0 to remove and 436 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up docker-ce (18.06.3~ce~3-0~ubuntu) ...
A dependency job for docker.service failed. See 'journalctl -xe' for details.
invoke-rc.d: initscript docker, action "start" failed.
● docker.service - Docker Application Container Engine
   Loaded: loaded (/lib/systemd/system/docker.service; enabled; vendor preset: enabled)
   Active: inactive (dead)
     Docs: https://docs.docker.com
May 07 13:35:23 ubuntu-hassio systemd[1]: Dependency failed for Docker Application Container Engine.
May 07 13:35:23 ubuntu-hassio systemd[1]: docker.service: Job docker.service/start failed with result 'dependency'.
May 07 13:38:12 ubuntu-hassio systemd[1]: Dependency failed for Docker Application Container Engine.
May 07 13:38:12 ubuntu-hassio systemd[1]: docker.service: Job docker.service/start failed with result 'dependency'.
May 07 13:40:13 ubuntu-hassio systemd[1]: Dependency failed for Docker Application Container Engine.
May 07 13:40:13 ubuntu-hassio systemd[1]: docker.service: Job docker.service/start failed with result 'dependency'.
May 07 13:40:48 ubuntu-hassio systemd[1]: Dependency failed for Docker Application Container Engine.
May 07 13:40:48 ubuntu-hassio systemd[1]: docker.service: Job docker.service/start failed with result 'dependency'.
May 08 08:22:41 ubuntu-hassio systemd[1]: Dependency failed for Docker Application Container Engine.
May 08 08:22:41 ubuntu-hassio systemd[1]: docker.service: Job docker.service/start failed with result 'dependency'.
dpkg: error processing package docker-ce (--configure):
subprocess installed post-installation script returned error exit status 1
Errors were encountered while processing:
docker-ce
E: Sub-process /usr/bin/dpkg returned an error code (1)
Description:        Ubuntu 17.10
Release:        17.10
Codename:        artful
Linux version 4.13.0-21-generic (buildd@lgw01-amd64-037) (gcc version 7.2.0 (Ubuntu 7.2.0-8ubuntu3)) #24-Ubuntu SMP Mon Dec 18 17:29:16 UTC 2017
Linux ubuntu-hassio 4.13.0-21-generic #24-Ubuntu SMP Mon Dec 18 17:29:16 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
\033[0;31m[ERROR]: 安装curl失败,请将检查上方安装错误信息。\033[0m
发表于 2020-5-8 12:26:05 | 显示全部楼层
我自己傻逼了...fq就好了
 楼主| 发表于 2020-5-8 16:48:24 | 显示全部楼层
guitengyue 发表于 2020-5-8 12:26
我自己傻逼了...fq就好了
最近 Ubuntu 不知道为啥 用一键脚本还是 apt install docker.io 安装的时候都有可能出错。不知道是不是运营商对 docker 的域名干扰有关,我这边访问 http://get.docker.com 显示非法网站,挟持到公安的反诈骗页面。
GMT+8, 2026-1-15 21:28 , Processed in 1.427925 second(s), 11 queries , MemCached On.
