楼主: neroxps
HASSIO 安装一键脚本
 火...   [复制链接]
发表于 2020-5-19 13:26:08 | 显示全部楼层
20-05-19 05:03:38 WARNING (MainThread) [supervisor.tasks] Watchdog found a problem with PulseAudio plugin!20-05-19 05:03:38 INFO (MainThread) [supervisor.plugins.audio] Start Audio plugin20-05-19 05:03:38 WARNING (MainThread) [supervisor.tasks] Watchdog found a problem with CoreDNS plugin!20-05-19 05:03:38 INFO (MainThread) [supervisor.plugins.dns] Start CoreDNS plugin20-05-19 05:03:39 ERROR (SyncWorker_2) [supervisor.docker] Can't create container from hassio_audio: 400 Client Error: Bad Request ("create no/audio: "no/audio" includes invalid characters for a local volume name, only "[a-zA-Z0-9][a-zA-Z0-9_.-]" are allowed. If you intended to pass a host directory, use absolute path")20-05-19 05:03:39 ERROR (MainThread) [supervisor.plugins.audio] Can't start Audio plugin20-05-19 05:03:39 ERROR (MainThread) [supervisor.tasks] Watchdog PulseAudio reanimation fails!20-05-19 05:03:39 ERROR (SyncWorker_0) [supervisor.docker] Can't create container from hassio_dns: 400 Client Error: Bad Request ("create no/dns: "no/dns" includes invalid characters for a local volume name, only "[a-zA-Z0-9][a-zA-Z0-9_.-]" are allowed. If you intended to pass a host directory, use absolute path")20-05-19 05:03:39 ERROR (MainThread) [supervisor.plugins.dns] Can't start CoreDNS plugin20-05-19 05:03:39 ERROR (MainThread) [supervisor.tasks] Watchdog CoreDNS reanimation fails!20-05-19 05:03:58 WARNING (MainThread) [supervisor.tasks] Watchdog found a problem with CoreDNS plugin!20-05-19 05:03:58 INFO (MainThread) [supervisor.plugins.dns] Start CoreDNS plugin20-05-19 05:03:59 ERROR (SyncWorker_3) [supervisor.docker] Can't create container from hassio_dns: 400 Client Error: Bad Request ("create no/dns: "no/dns" includes invalid characters for a local volume name, only "[a-zA-Z0-9][a-zA-Z0-9_.-]" are allowed. If you intended to pass a host directory, use absolute path")20-05-19 05:03:59 ERROR (MainThread) [supervisor.plugins.dns] Can't start CoreDNS plugin20-05-19 05:03:59 ERROR (MainThread) [supervisor.tasks] Watchdog CoreDNS reanimation fails!20-05-19 05:04:08 WARNING (MainThread) [supervisor.tasks] Watchdog found a problem with PulseAudio plugin!20-05-19 05:04:08 INFO (MainThread) [supervisor.plugins.audio] Start Audio plugin20-05-19 05:04:09 ERROR (SyncWorker_4) [supervisor.docker] Can't create container from hassio_audio: 400 Client Error: Bad Request ("create no/audio: "no/audio" includes invalid characters for a local volume name, only "[a-zA-Z0-9][a-zA-Z0-9_.-]" are allowed. If you intended to pass a host directory, use absolute path")20-05-19 05:04:09 ERROR (MainThread) [supervisor.plugins.audio] Can't start Audio plugin20-05-19 05:04:09 ERROR (MainThread) [supervisor.tasks] Watchdog PulseAudio reanimation fails!20-05-19 05:04:18 WARNING (MainThread) [supervisor.tasks] Watchdog found a problem with CoreDNS plugin!20-05-19 05:04:18 INFO (MainThread) [supervisor.plugins.dns] Start CoreDNS plugin20-05-19 05:04:19 ERROR (SyncWorker_0) [supervisor.docker] Can't create container from hassio_dns: 400 Client Error: Bad Request ("create no/dns: "no/dns" includes invalid characters for a local volume name, only "[a-zA-Z0-9][a-zA-Z0-9_.-]" are allowed. If you intended to pass a host directory, use absolute path")20-05-19 05:04:19 ERROR (MainThread) [supervisor.plugins.dns] Can't start CoreDNS plugin20-05-19 05:04:19 ERROR (MainThread) [supervisor.tasks] Watchdog CoreDNS reanimation fails!20-05-19 05:04:38 WARNING (MainThread) [supervisor.tasks] Watchdog found a problem with CoreDNS plugin!20-05-19 05:04:38 INFO (MainThread) [supervisor.plugins.dns] Start CoreDNS plugin20-05-19 05:04:38 WARNING (MainThread) [supervisor.tasks] Watchdog found a problem with PulseAudio plugin!20-05-19 05:04:38 INFO (MainThread) [supervisor.plugins.audio] Start Audio plugin20-05-19 05:04:39 ERROR (SyncWorker_2) [supervisor.docker] Can't create container from hassio_dns: 400 Client Error: Bad Request ("create no/dns: "no/dns" includes invalid characters for a local volume name, only "[a-zA-Z0-9][a-zA-Z0-9_.-]" are allowed. If you intended to pass a host directory, use absolute path")20-05-19 05:04:39 ERROR (MainThread) [supervisor.plugins.dns] Can't start CoreDNS plugin20-05-19 05:04:39 ERROR (MainThread) [supervisor.tasks] Watchdog CoreDNS reanimation fails!20-05-19 05:04:39 ERROR (SyncWorker_4) [supervisor.docker] Can't create container from hassio_audio: 400 Client Error: Bad Request ("create no/audio: "no/audio" includes invalid characters for a local volume name, only "[a-zA-Z0-9][a-zA-Z0-9_.-]" are allowed. If you intended to pass a host directory, use absolute path")20-05-19 05:04:39 ERROR (MainThread) [supervisor.plugins.audio] Can't start Audio plugin20-05-19 05:04:39 ERROR (MainThread) [supervisor.tasks] Watchdog PulseAudio reanimation fails!20-05-19 05:04:58 WARNING (MainThread) [supervisor.tasks] Watchdog found a problem with CoreDNS plugin!20-05-19 05:04:58 INFO (MainThread) [supervisor.plugins.dns] Start CoreDNS plugin20-05-19 05:04:59 ERROR (SyncWorker_0) [supervisor.docker] Can't create container from hassio_dns: 400 Client Error: Bad Request ("create no/dns: "no/dns" includes invalid characters for a local volume name, only "[a-zA-Z0-9][a-zA-Z0-9_.-]" are allowed. If you intended to pass a host directory, use absolute path")20-05-19 05:04:59 ERROR (MainThread) [supervisor.plugins.dns] Can't start CoreDNS plugin20-05-19 05:04:59 ERROR (MainThread) [supervisor.tasks] Watchdog CoreDNS reanimation fails!20-05-19 05:05:08 WARNING (MainThread) [supervisor.tasks] Watchdog found a problem with PulseAudio plugin!20-05-19 05:05:08 INFO (MainThread) [supervisor.plugins.audio] Start Audio plugin20-05-19 05:05:09 ERROR (SyncWorker_3) [supervisor.docker] Can't create container from hassio_audio: 400 Client Error: Bad Request ("create no/audio: "no/audio" includes invalid characters for a local volume name, only "[a-zA-Z0-9][a-zA-Z0-9_.-]" are allowed. If you intended to pass a host directory, use absolute path")20-05-19 05:05:09 ERROR (MainThread) [supervisor.plugins.audio] Can't start Audio plugin20-05-19 05:05:09 ERROR (MainThread) [supervisor.tasks] Watchdog PulseAudio reanimation fails!20-05-19 05:05:18 WARNING (MainThread) [supervisor.tasks] Watchdog found a problem with CoreDNS plugin!20-05-19 05:05:18 INFO (MainThread) [supervisor.plugins.dns] Start CoreDNS plugin20-05-19 05:05:19 ERROR (SyncWorker_3) [supervisor.docker] Can't create container from hassio_dns: 400 Client Error: Bad Request ("create no/dns: "no/dns" includes invalid characters for a local volume name, only "[a-zA-Z0-9][a-zA-Z0-9_.-]" are allowed. If you intended to pass a host directory, use absolute path")20-05-19 05:05:19 ERROR (MainThread) [supervisor.plugins.dns] Can't start CoreDNS plugin20-05-19 05:05:19 ERROR (MainThread) [supervisor.tasks] Watchdog CoreDNS reanimation fails!20-05-19 05:05:38 WARNING (MainThread) [supervisor.tasks] Watchdog found a problem with CoreDNS plugin!20-05-19 05:05:38 INFO (MainThread) [supervisor.plugins.dns] Start CoreDNS plugin20-05-19 05:05:38 WARNING (MainThread) [supervisor.tasks] Watchdog found a problem with PulseAudio plugin!20-05-19 05:05:38 INFO (MainThread) [supervisor.plugins.audio] Start Audio plugin20-05-19 05:05:39 ERROR (SyncWorker_1) [supervisor.docker] Can't create container from hassio_audio: 400 Client Error: Bad Request ("create no/audio: "no/audio" includes invalid characters for a local volume name, only "[a-zA-Z0-9][a-zA-Z0-9_.-]" are allowed. If you intended to pass a host directory, use absolute path")20-05-19 05:05:39 ERROR (MainThread) [supervisor.plugins.audio] Can't start Audio plugin20-05-19 05:05:39 ERROR (MainThread) [supervisor.tasks] Watchdog PulseAudio reanimation fails!20-05-19 05:05:39 ERROR (SyncWorker_4) [supervisor.docker] Can't create container from hassio_dns: 400 Client Error: Bad Request ("create no/dns: "no/dns" includes invalid characters for a local volume name, only "[a-zA-Z0-9][a-zA-Z0-9_.-]" are allowed. If you intended to pass a host directory, use absolute path")20-05-19 05:05:39 ERROR (MainThread) [supervisor.plugins.dns] Can't start CoreDNS plugin20-05-19 05:05:39 ERROR (MainThread) [supervisor.tasks] Watchdog CoreDNS reanimation fails!20-05-19 05:05:58 WARNING (MainThread) [supervisor.tasks] Watchdog found a problem with CoreDNS plugin!20-05-19 05:05:58 INFO (MainThread) [supervisor.plugins.dns] Start CoreDNS plugin20-05-19 05:05:58 ERROR (SyncWorker_0) [supervisor.docker] Can't create container from hassio_dns: 400 Client Error: Bad Request ("create no/dns: "no/dns" includes invalid characters for a local volume name, only "[a-zA-Z0-9][a-zA-Z0-9_.-]" are allowed. If you intended to pass a host directory, use absolute path")20-05-19 05:05:59 ERROR (MainThread) [supervisor.plugins.dns] Can't start CoreDNS plugin20-05-19 05:05:59 ERROR (MainThread) [supervisor.tasks] Watchdog CoreDNS reanimation fails!20-05-19 05:06:08 WARNING (MainThread) [supervisor.tasks] Watchdog found a problem with PulseAudio plugin!20-05-19 05:06:08 INFO (MainThread) [supervisor.plugins.audio] Start Audio plugin20-05-19 05:06:09 ERROR (SyncWorker_4) [supervisor.docker] Can't create container from hassio_audio: 400 Client Error: Bad Request ("create no/audio: "no/audio" includes invalid characters for a local volume name, only "[a-zA-Z0-9][a-zA-Z0-9_.-]" are allowed. If you intended to pass a host directory, use absolute path")20-05-19 05:06:09 ERROR (MainThread) [supervisor.plugins.audio] Can't start Audio plugin20-05-19 05:06:09 ERROR (MainThread) [supervisor.tasks] Watchdog PulseAudio reanimation fails!20-05-19 05:06:18 WARNING (MainThread) [supervisor.tasks] Watchdog found a problem with CoreDNS plugin!20-05-19 05:06:18 INFO (MainThread) [supervisor.plugins.dns] Start CoreDNS plugin20-05-19 05:06:18 ERROR (SyncWorker_3) [supervisor.docker] Can't create container from hassio_dns: 400 Client Error: Bad Request ("create no/dns: "no/dns" includes invalid characters for a local volume name, only "[a-zA-Z0-9][a-zA-Z0-9_.-]" are allowed. If you intended to pass a host directory, use absolute path")20-05-19 05:06:18 ERROR (MainThread) [supervisor.plugins.dns] Can't start CoreDNS plugin20-05-19 05:06:18 ERROR (MainThread) [supervisor.tasks] Watchdog CoreDNS reanimation fails!20-05-19 05:06:38 WARNING (MainThread) [supervisor.tasks] Watchdog found a problem with CoreDNS plugin!20-05-19 05:06:38 INFO (MainThread) [supervisor.plugins.dns] Start CoreDNS plugin20-05-19 05:06:38 WARNING (MainThread) [supervisor.tasks] Watchdog found a problem with PulseAudio plugin!20-05-19 05:06:38 INFO (MainThread) [supervisor.plugins.audio] Start Audio plugin20-05-19 05:06:39 ERROR (SyncWorker_3) [supervisor.docker] Can't create container from hassio_audio: 400 Client Error: Bad Request ("create no/audio: "no/audio" includes invalid characters for a local volume name, only "[a-zA-Z0-9][a-zA-Z0-9_.-]" are allowed. If you intended to pass a host directory, use absolute path")20-05-19 05:06:39 ERROR (MainThread) [supervisor.plugins.audio] Can't start Audio plugin20-05-19 05:06:39 ERROR (MainThread) [supervisor.tasks] Watchdog PulseAudio reanimation fails!20-05-19 05:06:39 ERROR (SyncWorker_4) [supervisor.docker] Can't create container from hassio_dns: 400 Client Error: Bad Request ("create no/dns: "no/dns" includes invalid characters for a local volume name, only "[a-zA-Z0-9][a-zA-Z0-9_.-]" are allowed. If you intended to pass a host directory, use absolute path")20-05-19 05:06:39 ERROR (MainThread) [supervisor.plugins.dns] Can't start CoreDNS plugin20-05-19 05:06:39 ERROR (MainThread) [supervisor.tasks] Watchdog CoreDNS reanimation fails!20-05-19 05:06:58 WARNING (MainThread) [supervisor.tasks] Watchdog found a problem with CoreDNS plugin!20-05-19 05:06:58 INFO (MainThread) [supervisor.plugins.dns] Start CoreDNS plugin20-05-19 05:06:58 ERROR (SyncWorker_3) [supervisor.docker] Can't create container from hassio_dns: 400 Client Error: Bad Request ("create no/dns: "no/dns" includes invalid characters for a local volume name, only "[a-zA-Z0-9][a-zA-Z0-9_.-]" are allowed. If you intended to pass a host directory, use absolute path")20-05-19 05:06:58 ERROR (MainThread) [supervisor.plugins.dns] Can't start CoreDNS plugin20-05-19 05:06:58 ERROR (MainThread) [supervisor.tasks] Watchdog CoreDNS reanimation fails!20-05-19 05:07:08 WARNING (MainThread) [supervisor.tasks] Watchdog found a problem with PulseAudio plugin!20-05-19 05:07:08 INFO (MainThread) [supervisor.plugins.audio] Start Audio plugin20-05-19 05:07:09 ERROR (SyncWorker_3) [supervisor.docker] Can't create container from hassio_audio: 400 Client Error: Bad Request ("create no/audio: "no/audio" includes invalid characters for a local volume name, only "[a-zA-Z0-9][a-zA-Z0-9_.-]" are allowed. If you intended to pass a host directory, use absolute path")20-05-19 05:07:09 ERROR (MainThread) [supervisor.plugins.audio] Can't start Audio plugin20-05-19 05:07:09 ERROR (MainThread) [supervisor.tasks] Watchdog PulseAudio reanimation fails!20-05-19 05:07:18 WARNING (MainThread) [supervisor.tasks] Watchdog found a problem with CoreDNS plugin!20-05-19 05:07:18 INFO (MainThread) [supervisor.plugins.dns] Start CoreDNS plugin20-05-19 05:07:19 ERROR (SyncWorker_3) [supervisor.docker] Can't create container from hassio_dns: 400 Client Error: Bad Request ("create no/dns: "no/dns" includes invalid characters for a local volume name, only "[a-zA-Z0-9][a-zA-Z0-9_.-]" are allowed. If you intended to pass a host directory, use absolute path")20-05-19 05:07:19 ERROR (MainThread) [supervisor.plugins.dns] Can't start CoreDNS plugin20-05-19 05:07:19 ERROR (MainThread) [supervisor.tasks] Watchdog CoreDNS reanimation fails!20-05-19 05:07:38 WARNING (MainThread) [supervisor.tasks] Watchdog found a problem with CoreDNS plugin!20-05-19 05:07:38 INFO (MainThread) [supervisor.plugins.dns] Start CoreDNS plugin20-05-19 05:07:38 WARNING (MainThread) [supervisor.tasks] Watchdog found a problem with PulseAudio plugin!20-05-19 05:07:38 INFO (MainThread) [supervisor.plugins.audio] Start Audio plugin20-05-19 05:07:39 ERROR (SyncWorker_2) [supervisor.docker] Can't create container from hassio_dns: 400 Client Error: Bad Request ("create no/dns: "no/dns" includes invalid characters for a local volume name, only "[a-zA-Z0-9][a-zA-Z0-9_.-]" are allowed. If you intended to pass a host directory, use absolute path")20-05-19 05:07:39 ERROR (MainThread) [supervisor.plugins.dns] Can't start CoreDNS plugin20-05-19 05:07:39 ERROR (MainThread) [supervisor.tasks] Watchdog CoreDNS reanimation fails!20-05-19 05:07:39 ERROR (SyncWorker_4) [supervisor.docker] Can't create container from hassio_audio: 400 Client Error: Bad Request ("create no/audio: "no/audio" includes invalid characters for a local volume name, only "[a-zA-Z0-9][a-zA-Z0-9_.-]" are allowed. If you intended to pass a host directory, use absolute path")20-05-19 05:07:39 ERROR (MainThread) [supervisor.plugins.audio] Can't start Audio plugin20-05-19 05:07:39 ERROR (MainThread) [supervisor.tasks] Watchdog PulseAudio reanimation fails!20-05-19 05:07:58 WARNING (MainThread) [supervisor.tasks] Watchdog found a problem with CoreDNS plugin!20-05-19 05:07:58 INFO (MainThread) [supervisor.plugins.dns] Start CoreDNS plugin20-05-19 05:07:59 ERROR (SyncWorker_1) [supervisor.docker] Can't create container from hassio_dns: 400 Client Error: Bad Request ("create no/dns: "no/dns" includes invalid characters for a local volume name, only "[a-zA-Z0-9][a-zA-Z0-9_.-]" are allowed. If you intended to pass a host directory, use absolute path")20-05-19 05:07:59 ERROR (MainThread) [supervisor.plugins.dns] Can't start CoreDNS plugin20-05-19 05:07:59 ERROR (MainThread) [supervisor.tasks] Watchdog CoreDNS reanimation fails!20-05-19 05:08:08 WARNING (MainThread) [supervisor.tasks] Watchdog found a problem with PulseAudio plugin!20-05-19 05:08:08 INFO (MainThread) [supervisor.plugins.audio] Start Audio plugin20-05-19 05:08:09 ERROR (SyncWorker_0) [supervisor.docker] Can't create container from hassio_audio: 400 Client Error: Bad Request ("create no/audio: "no/audio" includes invalid characters for a local volume name, only "[a-zA-Z0-9][a-zA-Z0-9_.-]" are allowed. If you intended to pass a host directory, use absolute path")20-05-19 05:08:09 ERROR (MainThread) [supervisor.plugins.audio] Can't start Audio plugin20-05-19 05:08:09 ERROR (MainThread) [supervisor.tasks] Watchdog PulseAudio reanimation fails!20-05-19 05:08:18 WARNING (MainThread) [supervisor.tasks] Watchdog found a problem with CoreDNS plugin!20-05-19 05:08:18 INFO (MainThread) [supervisor.plugins.dns] Start CoreDNS plugin20-05-19 05:08:19 ERROR (SyncWorker_2) [supervisor.docker] Can't create container from hassio_dns: 400 Client Error: Bad Request ("create no/dns: "no/dns" includes invalid characters for a local volume name, only "[a-zA-Z0-9][a-zA-Z0-9_.-]" are allowed. If you intended to pass a host directory, use absolute path")20-05-19 05:08:19 ERROR (MainThread) [supervisor.plugins.dns] Can't start CoreDNS plugin20-05-19 05:08:19 ERROR (MainThread) [supervisor.tasks] Watchdog CoreDNS reanimation fails!20-05-19 05:08:38 WARNING (MainThread) [supervisor.tasks] Watchdog found a problem with CoreDNS plugin!20-05-19 05:08:38 INFO (MainThread) [supervisor.plugins.dns] Start CoreDNS plugin20-05-19 05:08:38 WARNING (MainThread) [supervisor.tasks] Watchdog found a problem with PulseAudio plugin!20-05-19 05:08:38 INFO (MainThread) [supervisor.plugins.audio] Start Audio plugin20-05-19 05:08:39 ERROR (SyncWorker_4) [supervisor.docker] Can't create container from hassio_dns: 400 Client Error: Bad Request ("create no/dns: "no/dns" includes invalid characters for a local volume name, only "[a-zA-Z0-9][a-zA-Z0-9_.-]" are allowed. If you intended to pass a host directory, use absolute path")20-05-19 05:08:39 ERROR (MainThread) [supervisor.plugins.dns] Can't start CoreDNS plugin20-05-19 05:08:39 ERROR (MainThread) [supervisor.tasks] Watchdog CoreDNS reanimation fails!20-05-19 05:08:39 ERROR (SyncWorker_2) [supervisor.docker] Can't create container from hassio_audio: 400 Client Error: Bad Request ("create no/audio: "no/audio" includes invalid characters for a local volume name, only "[a-zA-Z0-9][a-zA-Z0-9_.-]" are allowed. If you intended to pass a host directory, use absolute path")20-05-19 05:08:39 ERROR (MainThread) [supervisor.plugins.audio] Can't start Audio plugin20-05-19 05:08:39 ERROR (MainThread) [supervisor.tasks] Watchdog PulseAudio reanimation fails!20-05-19 05:08:58 WARNING (MainThread) [supervisor.tasks] Watchdog found a problem with CoreDNS plugin!20-05-19 05:08:58 INFO (MainThread) [supervisor.plugins.dns] Start CoreDNS plugin20-05-19 05:08:59 ERROR (SyncWorker_2) [supervisor.docker] Can't create container from hassio_dns: 400 Client Error: Bad Request ("create no/dns: "no/dns" includes invalid characters for a local volume name, only "[a-zA-Z0-9][a-zA-Z0-9_.-]" are allowed. If you intended to pass a host directory, use absolute path")20-05-19 05:08:59 ERROR (MainThread) [supervisor.plugins.dns] Can't start CoreDNS plugin20-05-19 05:08:59 ERROR (MainThread) [supervisor.tasks] Watchdog CoreDNS reanimation fails!20-05-19 05:09:08 WARNING (MainThread) [supervisor.tasks] Watchdog found a problem with PulseAudio plugin!20-05-19 05:09:08 INFO (MainThread) [supervisor.plugins.audio] Start Audio plugin20-05-19 05:09:09 ERROR (SyncWorker_1) [supervisor.docker] Can't create container from hassio_audio: 400 Client Error: Bad Request ("create no/audio: "no/audio" includes invalid characters for a local volume name, only "[a-zA-Z0-9][a-zA-Z0-9_.-]" are allowed. If you intended to pass a host directory, use absolute path")20-05-19 05:09:09 ERROR (MainThread) [supervisor.plugins.audio] Can't start Audio plugin20-05-19 05:09:09 ERROR (MainThread) [supervisor.tasks] Watchdog PulseAudio reanimation fails!20-05-19 05:09:18 WARNING (MainThread) [supervisor.tasks] Watchdog found a problem with CoreDNS plugin!20-05-19 05:09:18 INFO (MainThread) [supervisor.plugins.dns] Start CoreDNS plugin20-05-19 05:09:18 ERROR (SyncWorker_1) [supervisor.docker] Can't create container from hassio_dns: 400 Client Error: Bad Request ("create no/dns: "no/dns" includes invalid characters for a local volume name, only "[a-zA-Z0-9][a-zA-Z0-9_.-]" are allowed. If you intended to pass a host directory, use absolute path")20-05-19 05:09:18 ERROR (MainThread) [supervisor.plugins.dns] Can't start CoreDNS plugin20-05-19 05:09:18 ERROR (MainThread) [supervisor.tasks] Watchdog CoreDNS reanimation fails!20-05-19 05:09:38 WARNING (MainThread) [supervisor.tasks] Watchdog found a problem with CoreDNS plugin!20-05-19 05:09:38 INFO (MainThread) [supervisor.plugins.dns] Start CoreDNS plugin20-05-19 05:09:38 WARNING (MainThread) [supervisor.tasks] Watchdog found a problem with PulseAudio plugin!20-05-19 05:09:38 INFO (MainThread) [supervisor.plugins.audio] Start Audio plugin20-05-19 05:09:39 ERROR (SyncWorker_3) [supervisor.docker] Can't create container from hassio_dns: 400 Client Error: Bad Request ("create no/dns: "no/dns" includes invalid characters for a local volume name, only "[a-zA-Z0-9][a-zA-Z0-9_.-]" are allowed. If you intended to pass a host directory, use absolute path")20-05-19 05:09:39 ERROR (MainThread) [supervisor.plugins.dns] Can't start CoreDNS plugin20-05-19 05:09:39 ERROR (MainThread) [supervisor.tasks] Watchdog CoreDNS reanimation fails!20-05-19 05:09:39 ERROR (SyncWorker_1) [supervisor.docker] Can't create container from hassio_audio: 400 Client Error: Bad Request ("create no/audio: "no/audio" includes invalid characters for a local volume name, only "[a-zA-Z0-9][a-zA-Z0-9_.-]" are allowed. If you intended to pass a host directory, use absolute path")20-05-19 05:09:39 ERROR (MainThread) [supervisor.plugins.audio] Can't start Audio plugin20-05-19 05:09:39 ERROR (MainThread) [supervisor.tasks] Watchdog PulseAudio reanimation fails!########################### homeassistant log ###########################Error: No such container: homeassistant########################### END ########################### homeassistant 启动超时,请检查上方日志....或者重启操作系统 相关问题可以访问https://bbs.iobroker.cn或者加QQ群776817275咨询
我是虚拟机的Ubuntu系统下脚本安装,选择的普通pc机版本,提示homeassistant启动超时,是什么原因阿?不胜感激
发表于 2020-5-20 00:31:00 | 显示全部楼层
登陆过一次HA之后再登陆就是404not found了,日志我也看不出什么问题,可以帮我看看吗?谢谢
2020-05-19 21:55:18 INFO (MainThread) [custom_components.molohub] Begin stop molohub!
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
s6-svscanctl: fatal: unable to control /var/run/s6/services: supervisor not listening
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] udev.sh: executing...
[21:56:30] INFO: Update udev information
[cont-init.d] udev.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
2020-05-19 21:56:36 INFO (MainThread) [homeassistant.bootstrap] Config directory: /config
2020-05-19 21:56:36 INFO (SyncWorker_6) [homeassistant.loader] Loaded homeassistant from homeassistant.components.homeassistant
2020-05-19 21:56:36 INFO (SyncWorker_0) [homeassistant.loader] Loaded persistent_notification from homeassistant.components.persistent_notification
2020-05-19 21:56:36 INFO (MainThread) [homeassistant.setup] Setting up homeassistant
2020-05-19 21:56:36 INFO (MainThread) [homeassistant.setup] Setup of domain homeassistant took 0.0 seconds.
2020-05-19 21:56:36 INFO (MainThread) [homeassistant.setup] Setting up persistent_notification
2020-05-19 21:56:36 INFO (MainThread) [homeassistant.setup] Setup of domain persistent_notification took 0.0 seconds.
2020-05-19 21:56:37 INFO (SyncWorker_0) [homeassistant.loader] Loaded group from homeassistant.components.group
2020-05-19 21:56:37 INFO (SyncWorker_10) [homeassistant.loader] Loaded hassio from homeassistant.components.hassio
2020-05-19 21:56:37 INFO (SyncWorker_15) [homeassistant.loader] Loaded script from homeassistant.components.script
2020-05-19 21:56:37 INFO (SyncWorker_17) [homeassistant.loader] Loaded shell_command from homeassistant.components.shell_command
2020-05-19 21:56:37 INFO (SyncWorker_11) [homeassistant.loader] Loaded scene from homeassistant.components.scene
2020-05-19 21:56:37 INFO (SyncWorker_4) [homeassistant.loader] Loaded met from homeassistant.components.met
2020-05-19 21:56:37 INFO (SyncWorker_7) [homeassistant.loader] Loaded input_select from homeassistant.components.input_select
2020-05-19 21:56:37 INFO (SyncWorker_5) [homeassistant.loader] Loaded automationfrom homeassistant.components.automation
2020-05-19 21:56:37 INFO (SyncWorker_9) [homeassistant.loader] Loaded tts from homeassistant.components.tts
2020-05-19 21:56:37 WARNING (MainThread) [homeassistant.loader] You are using acustom integration for molohub which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-05-19 21:56:37 INFO (MainThread) [homeassistant.loader] Loaded molohub from custom_components.molohub
2020-05-19 21:56:37 INFO (SyncWorker_6) [homeassistant.loader] Loaded http from homeassistant.components.http
2020-05-19 21:56:37 INFO (MainThread) [homeassistant.setup] Setting up scene
2020-05-19 21:56:37 INFO (MainThread) [homeassistant.components.scene] Setting up scene.homeassistant
2020-05-19 21:56:37 INFO (MainThread) [homeassistant.setup] Setting up met
2020-05-19 21:56:37 INFO (MainThread) [homeassistant.setup] Setup of domain met took 0.0 seconds.
2020-05-19 21:56:37 INFO (MainThread) [homeassistant.setup] Setting up molohub
2020-05-19 21:56:37 INFO (SyncWorker_2) [custom_components.molohub] Begin setup molohub!
2020-05-19 21:56:37 ERROR (MainThread) [homeassistant.config] Unknown error calling group CONFIG_SCHEMA
  File "/usr/src/homeassistant/homeassistant/config.py", line 732, in async_process_component_config
    return component.CONFIG_SCHEMA(config)  # type: ignore
  File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 272, in __call__
    return self._compiled([], data)
  File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 594, in validate_dict
    return base_validate(path, iteritems(data), out)
  File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 386, in validate_mapping
    cval = cvalue(key_path, value)
  File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 817, in validate_callable
    return schema(data)
  File "/usr/local/lib/python3.7/site-packages/voluptuous/validators.py", line 205, in _run
    return self._exec(self._compiled, value, path)
  File "/usr/local/lib/python3.7/site-packages/voluptuous/validators.py", line 285, in _exec
    v = func(path, v)
    v = func(path, v)
    return schema(data)
  File "/usr/local/lib/python3.7/site-packages/voluptuous/validators.py", line 250, in _exec
    return func(path, v)
    return schema(data)
  File "/usr/src/homeassistant/homeassistant/helpers/config_validation.py", line241, in entity_ids
    return [entity_id(ent_id) for ent_id in value]
TypeError: 'bool' object is not iterable
2020-05-19 21:56:37 ERROR (MainThread) [homeassistant.setup] Setup failed for group: Invalid config.
2020-05-19 21:56:37 INFO (MainThread) [homeassistant.setup] Setting up script
2020-05-19 21:56:37 INFO (MainThread) [homeassistant.setup] Setup of domain script took 0.0 seconds.
2020-05-19 21:56:37 INFO (MainThread) [homeassistant.setup] Setting up http
2020-05-19 21:56:37 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.0 seconds.
2020-05-19 21:56:37 INFO (MainThread) [homeassistant.setup] Setting up shell_command
2020-05-19 21:56:37 INFO (MainThread) [homeassistant.setup] Setup of domain shell_command took 0.0 seconds.
2020-05-19 21:56:37 INFO (MainThread) [homeassistant.setup] Setting up input_select
2020-05-19 21:56:37 INFO (MainThread) [homeassistant.setup] Setup of domain molohub took 0.1 seconds.
2020-05-19 21:56:37 INFO (MainThread) [homeassistant.setup] Setup of domain scene took 0.2 seconds.
2020-05-19 21:56:37 INFO (SyncWorker_12) [homeassistant.loader] Loaded weather from homeassistant.components.weather
2020-05-19 21:56:37 INFO (MainThread) [homeassistant.setup] Setting up weather
2020-05-19 21:56:37 INFO (MainThread) [homeassistant.setup] Setup of domain weather took 0.0 seconds.
2020-05-19 21:56:37 INFO (MainThread) [homeassistant.components.weather] Setting up weather.met
2020-05-19 21:56:37 INFO (MainThread) [homeassistant.setup] Setup of domain input_select took 0.1 seconds.
2020-05-19 21:56:37 INFO (MainThread) [homeassistant.setup] Setting up automation
2020-05-19 21:56:37 INFO (MainThread) [homeassistant.setup] Setup of domain automation took 0.0 seconds.
2020-05-19 21:56:37 INFO (MainThread) [homeassistant.setup] Setting up hassio
2020-05-19 21:56:37 INFO (SyncWorker_4) [homeassistant.loader] Loaded media_player from homeassistant.components.media_player
2020-05-19 21:56:37 INFO (SyncWorker_5) [homeassistant.loader] Loaded google_translate from homeassistant.components.google_translate
2020-05-19 21:56:38 INFO (MainThread) [homeassistant.setup] Setting up tts
2020-05-19 21:56:38 INFO (MainThread) [homeassistant.setup] Setup of domain ttstook 0.0 seconds.
2020-05-19 21:56:38 INFO (MainThread) [homeassistant.setup] Setup of domain hassio took 0.6 seconds.
/config/custom_components/molohub/utils.py:62: YAMLLoadWarning: calling yaml.load() without Loader=... is deprecated, as the default Loader is unsafe. Please read https://msg.pyyaml.org/load for full details.
  config_data = yaml.load(file_obj)
2020-05-19 21:56:40 INFO (Thread-3) [custom_components.molohub] server online, wait for authorize
2020-05-19 21:56:45 INFO (MainThread) [homeassistant.bootstrap] Home Assistant initialized in 8.79s
2020-05-19 21:56:45 INFO (MainThread) [homeassistant.core] Starting Home Assistant
2020-05-19 21:56:45 INFO (MainThread) [homeassistant.core] Timer:starting
发表于 2020-5-21 04:53:08 | 显示全部楼层
有一些软件包无法被安装。如果您用的是 unstable 发行版,这也许是
因为系统无法达到您要求的状态造成的。该版本中可能会有一些您需要的软件
包尚未被创建或是它们已被从新到(Incoming)目录移出。
下列信息可能会对解决问题有所帮助:
下列软件包有未满足的依赖关系:
apparmor-utils : 依赖: apparmor (>= 2.6.1-4ubuntu1) 但是它将不会被安装
                  依赖: libapparmor-perl 但是它将不会被安装
                  依赖: python3-apparmor (= 2.11.0-3+deb9u2) 但是它将不会被安装
E: 无法修正错误,因为您要求某些软件包保持现状,就是它们破坏了软件包间的依赖关系。
################# 发到论坛时,请把上方日志也一并粘贴发送 ################
Distributor ID:        Ubuntu
Description:        Ubuntu 18.04.3 LTS
Release:        18.04
Codename:        bionic
Linux version 5.5.0-rc6-aml-s9xxx (root@vbox) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #rc1.037 SMP PREEMPT Wed Feb 5 17:28:41 MSK 2020
Linux aml 5.5.0-rc6-aml-s9xxx #rc1.037 SMP PREEMPT Wed Feb 5 17:28:41 MSK 2020 aarch64 aarch64 aarch64 GNU/Linux
\033[0;31m[ERROR]: 安装curl失败,请将检查上方安装错误信息。\033[0m
大哥 这个怎么解决啊!
发表于 2020-5-24 11:17:17 | 显示全部楼层
折腾了好久,最后在安装hasssio的时候出现了问题,麻烦您看看怎么解决。
[info]: 跳过切换系统源。
[info]: 安装 hassio 必要依赖.....
Hit:1 http://mirrors.tuna.tsinghua.edu.cn/armbian stretch InRelease
Hit:2 https://mirror.azure.cn/docker-ce/linux/debian stretch InRelease
Ign:3 https://mirrors.tuna.tsinghua.edu.cn/debian stretch InRelease
Hit:4 https://mirrors.tuna.tsinghua.edu.cn/debian stretch-updates InRelease
Hit:5 https://mirrors.tuna.tsinghua.edu.cn/debian stretch-backports InRelease
Hit:6 https://mirrors.tuna.tsinghua.edu.cn/debian-security stretch/updates InRelease
Hit:7 https://mirrors.tuna.tsinghua.edu.cn/debian stretch Release
Reading package lists... Done
Building dependency tree
Reading state information... Done
129 packages can be upgraded. Run 'apt list --upgradable' to see them.
apparmor-utils is already the newest version (2.11.0-3+deb9u2).
avahi-daemon is already the newest version (0.6.32-2).
jq is already the newest version (1.5+dfsg-1.3).
net-tools is already the newest version (1.60+git20161116.90da8a0-1).
qrencode is already the newest version (3.4.4-1+b2).
socat is already the newest version (1.7.3.1-2+deb9u1).
curl is already the newest version (7.52.1-5+deb9u10).
0 upgraded, 0 newly installed, 0 to remove and 129 not upgraded.
/usr/bin/docker
[info]: 发现系统已安装 docker,跳过 docker 安装
[info]: 跳过切换 Docker 源....
[info]: 安装 hassio......
下载 hassio_install.sh 官方脚本 第1次
######################################################################## 100.0%
从 hub.docker.com 下载 homeassistant/qemuarm-64-homeassistant:0.110.1......
0.110.1: Pulling from homeassistant/qemuarm-64-homeassistant
29e5d40040c1: Already exists
ef81adb98757: Already exists
157f24b65599: Already exists
8b86f8b104d5: Already exists
24fca548cd3b: Already exists
745c2c0d2a54: Already exists
aabeb9ecb136: Already exists
54141838f73a: Already exists
0db6006b412e: Already exists
4e6824da7f6a: Already exists
bf0c70d61d9b: Already exists
44f488bdfd82: Already exists
bbea8b483297: Already exists
c9b94a745608: Already exists
e25af0e03f31: Already exists
8d0f0b1202f0: Already exists
449a4850641b: Already exists
22b1d540d95d: Pull complete
e3b66d5e0b77: Pull complete
ea9b72919f49: Pull complete
6ce72dbb4cbf: Pull complete
d1963b906825: Pull complete
493afe7490c7: Pull complete
5d1880dce7e7: Pull complete
Digest: sha256:28499a20f5ca3393368a51c616aadad5a88daeca98458f311919433677896905
Status: Downloaded newer image for homeassistant/qemuarm-64-homeassistant:0.110.1
docker.io/homeassistant/qemuarm-64-homeassistant:0.110.1
开始 hassio 安装流程。(如出现 [Warning] 请忽略,无须理会)
[Info] Install supervisor Docker container
[Info] Install supervisor startup scripts
Created symlink /etc/systemd/system/multi-user.target.wants/hassio-supervisor.service -> /etc/systemd/system/hassio-supervisor.service.
[Info] Install AppArmor scripts
Created symlink /etc/systemd/system/multi-user.target.wants/hassio-apparmor.service -> /etc/systemd/system/hassio-apparmor.service.
[Info] Run Hass.io
[Info] Install cli 'ha'
等待 homeassistant 启动(由于 hassio 启动需要从 github pull addons 的库,所以启动速度视 pull 速度而定。).........................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................fail
########################### Docker images ###########################
REPOSITORY                                TAG                 IMAGE ID            CREATED             SIZE
homeassistant/qemuarm-64-homeassistant    0.110.1             a5f24583470a        2 days ago          1.39GB
homeassistant/qemuarm-64-homeassistant    latest              a5f24583470a        2 days ago          1.39GB
homeassistant/aarch64-hassio-supervisor   222                 e5a3b4f95de9        2 weeks ago         388MB
homeassistant/aarch64-hassio-supervisor   latest              e5a3b4f95de9        2 weeks ago         388MB
homeassistant/aarch64-hassio-dns          9                   0f808e80607a        6 weeks ago         75.3MB
homeassistant/aarch64-hassio-cli          25                  58334140878b        6 weeks ago         44.5MB
homeassistant/aarch64-hassio-cli          latest              58334140878b        6 weeks ago         44.5MB
homeassistant/aarch64-hassio-multicast    2                   881075aad65b        6 weeks ago         34.8MB
homeassistant/aarch64-hassio-audio        14                  4df97665705b        7 weeks ago         110MB
########################### Docker ps ###########################
CONTAINER ID        IMAGE                                      COMMAND                  CREATED             STATUS              PORTS               NAMES
bf4ff442ed04        homeassistant/aarch64-hassio-audio:14      "/init"                  7 minutes ago       Up 5 minutes                            hassio_audio
9466e74490b9        homeassistant/aarch64-hassio-cli:25        "/init /bin/bash -c …"   7 minutes ago       Up 4 minutes                            hassio_cli
c18e8cc8f01d        homeassistant/aarch64-hassio-dns:9         "/init coredns -conf…"   7 minutes ago       Up 5 minutes                            hassio_dns
11d6d8d087f3        homeassistant/aarch64-hassio-multicast:2   "/init"                  7 minutes ago       Up 5 minutes                            hassio_multicast
34d155e7113c        homeassistant/aarch64-hassio-supervisor    "/init"                  10 minutes ago      Up 9 minutes                            hassio_supervisor
########################### hassio log ###########################
[fix-attrs.d] done.
[02:58:49] INFO: Update udev informations
[cont-init.d] done.
[services.d] done.
20-05-24 02:58:58 INFO (MainThread) [supervisor.bootstrap] Use the old homeassistant repository for machine extraction
20-05-24 02:58:58 INFO (MainThread) [__main__] Initialize Supervisor setup
20-05-24 02:58:58 INFO (MainThread) [supervisor.docker.network] Can't find Supervisor network, create new network
20-05-24 02:59:02 INFO (MainThread) [supervisor.bootstrap] Create Home Assistant configuration folder /data/homeassistant
20-05-24 02:59:02 INFO (MainThread) [supervisor.bootstrap] Create Supervisor SSL/TLS folder /data/ssl
20-05-24 02:59:02 INFO (MainThread) [supervisor.bootstrap] Create Supervisor Add-on data folder /data/addons/data
20-05-24 02:59:02 INFO (MainThread) [supervisor.bootstrap] Create Supervisor Add-on local repository folder /data/addons/local
20-05-24 02:59:02 INFO (MainThread) [supervisor.bootstrap] Create Supervisor Add-on git repositories folder /data/addons/git
20-05-24 02:59:02 INFO (MainThread) [supervisor.bootstrap] Create Supervisor temp folder /data/tmp
20-05-24 02:59:02 INFO (MainThread) [supervisor.bootstrap] Create Supervisor backup folder /data/backup
20-05-24 02:59:02 INFO (MainThread) [supervisor.bootstrap] Create Supervisor share folder /data/share
20-05-24 02:59:02 INFO (MainThread) [supervisor.bootstrap] Create Supervisor DNS folder /data/dns
20-05-24 02:59:02 INFO (MainThread) [supervisor.bootstrap] Create Supervisor audio folder /data/audio
20-05-24 02:59:02 INFO (MainThread) [supervisor.bootstrap] Setup coresys for machine: qemuarm-64
20-05-24 02:59:02 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attach to Supervisor homeassistant/aarch64-hassio-supervisor with version 222
20-05-24 02:59:02 INFO (SyncWorker_0) [supervisor.docker.supervisor] Connect Supervisor to hassio Network
20-05-24 02:59:09 INFO (MainThread) [__main__] Setup Supervisor
20-05-24 02:59:09 INFO (MainThread) [supervisor.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
20-05-24 02:59:09 INFO (MainThread) [supervisor.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
20-05-24 02:59:09 WARNING (MainThread) [supervisor.dbus.rauc] Host has no rauc support. OTA updates have been disabled.
20-05-24 02:59:09 INFO (MainThread) [supervisor.utils.gdbus] Connect to dbus: org.freedesktop.NetworkManager - /org/freedesktop/NetworkManager/DnsManager
20-05-24 02:59:09 INFO (MainThread) [supervisor.host.info] Update local host information
20-05-24 02:59:09 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-05-24 02:59:09 INFO (MainThread) [supervisor.host.services] Update service information
20-05-24 02:59:09 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-05-24 02:59:10 INFO (MainThread) [supervisor.host.network] Update local network DNS information
20-05-24 02:59:10 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
20-05-24 02:59:10 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
20-05-24 02:59:10 INFO (MainThread) [supervisor.host.apparmor] Load AppArmor Profiles: {'hassio-supervisor'}
20-05-24 02:59:10 INFO (MainThread) [supervisor.host.services] Reload local service hassio-apparmor.service
20-05-24 02:59:10 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ReloadOrRestartUnit on /org/freedesktop/systemd1
20-05-24 02:59:10 INFO (MainThread) [supervisor.plugins.audio] No Audio plugin Docker image homeassistant/aarch64-hassio-audio found.
20-05-24 02:59:10 INFO (MainThread) [supervisor.plugins.audio] Setup Audio plugin
20-05-24 02:59:10 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-05-24 02:59:10 INFO (MainThread) [supervisor.plugins.multicast] No Multicast plugin Docker image homeassistant/aarch64-hassio-multicast found.
20-05-24 02:59:10 INFO (MainThread) [supervisor.plugins.multicast] Setup Multicast plugin
20-05-24 02:59:10 INFO (MainThread) [supervisor.plugins.dns] No CoreDNS plugin Docker image homeassistant/aarch64-hassio-dns found.
20-05-24 02:59:10 INFO (MainThread) [supervisor.plugins.dns] Setup CoreDNS plugin
20-05-24 02:59:10 INFO (MainThread) [supervisor.plugins.cli] No cli plugin Docker image homeassistant/aarch64-hassio-cli found.
20-05-24 02:59:10 INFO (MainThread) [supervisor.plugins.cli] Setup cli plugin
20-05-24 02:59:11 INFO (SyncWorker_3) [supervisor.docker.interface] Pull image homeassistant/aarch64-hassio-audio tag 14.
20-05-24 02:59:11 INFO (SyncWorker_6) [supervisor.docker.interface] Pull image homeassistant/aarch64-hassio-multicast tag 2.
20-05-24 02:59:11 INFO (SyncWorker_2) [supervisor.docker.interface] Pull image homeassistant/aarch64-hassio-dns tag 9.
20-05-24 02:59:11 INFO (SyncWorker_1) [supervisor.docker.interface] Pull image homeassistant/aarch64-hassio-cli tag 25.
20-05-24 03:00:26 INFO (MainThread) [supervisor.plugins.multicast] Multicast plugin now installed
20-05-24 03:00:26 INFO (MainThread) [supervisor.plugins.dns] CoreDNS plugin now installed
20-05-24 03:00:27 INFO (MainThread) [supervisor.plugins.multicast] Start Multicast plugin
20-05-24 03:00:27 INFO (MainThread) [supervisor.plugins.dns] Start CoreDNS plugin
20-05-24 03:00:27 INFO (MainThread) [supervisor.misc.forwarder] Start DNS port forwarding to 172.30.32.3
20-05-24 03:00:35 INFO (SyncWorker_1) [supervisor.docker.interface] Tag image homeassistant/aarch64-hassio-cli with version 25 as latest
20-05-24 03:00:37 INFO (MainThread) [supervisor.plugins.cli] cli plugin now installed
20-05-24 03:00:37 INFO (MainThread) [supervisor.plugins.cli] Start cli plugin
20-05-24 03:00:37 INFO (MainThread) [supervisor.plugins.audio] Audio plugin now installed
20-05-24 03:00:37 INFO (MainThread) [supervisor.plugins.audio] Start Audio plugin
20-05-24 03:02:11 INFO (SyncWorker_0) [supervisor.docker.multicast] Start Multicast homeassistant/aarch64-hassio-multicast with version 2 - Host
20-05-24 03:02:57 INFO (SyncWorker_7) [supervisor.docker.dns] Start DNS homeassistant/aarch64-hassio-dns with version 9 - 172.30.32.3
20-05-24 03:02:58 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
20-05-24 03:03:00 INFO (SyncWorker_4) [supervisor.docker.audio] Start Audio homeassistant/aarch64-hassio-audio with version 14 - 172.30.32.4
20-05-24 03:03:07 INFO (SyncWorker_8) [supervisor.docker.cli] Start CLI homeassistant/aarch64-hassio-cli with version 25 - 172.30.32.5
20-05-24 03:03:07 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-05-24 03:03:09 INFO (SyncWorker_14) [supervisor.docker.interface] Attach to homeassistant/qemuarm-64-homeassistant with version 0.110.1
20-05-24 03:03:09 WARNING (MainThread) [supervisor.hassos] No Home Assistant Operating-System found!
20-05-24 03:03:09 INFO (MainThread) [supervisor.store.git] Clone add-on https://github.com/hassio-addons/repository repository
20-05-24 03:03:09 INFO (MainThread) [supervisor.store.git] Clone add-on https://github.com/home-assistant/hassio-addons repository
发表于 2020-5-31 10:33:04 | 显示全部楼层
求助,重启后,就失去了web访问,求解决这个问题的方向,configuration.yaml没有问题。
pi@raspberrypi:~ $ sudo netstat -plnt
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      510/sshd
tcp6       0      0 :::22                   :::*                    LISTEN      510/sshd
pi@raspberrypi:~ $ service hassio-supervisor status
● hassio-supervisor.service - Hass.io supervisor
   Loaded: loaded (/etc/systemd/system/hassio-supervisor.service; enabled; vendor preset: enabled)
   Active: active (running) since Sun 2020-05-31 10:06:56 CST; 19min ago
  Process: 773 ExecStartPre=/usr/bin/docker stop hassio_supervisor (code=exited, status=0/SUCCESS)
 Main PID: 827 (bash)
    Tasks: 14 (limit: 2200)
   Memory: 60.8M
   CGroup: /system.slice/hassio-supervisor.service
           ├─827 bash /usr/sbin/hassio-supervisor
           ├─854 bash /usr/sbin/hassio-supervisor
           └─855 docker start --attach hassio_supervisor
May 31 10:17:37 raspberrypi hassio-supervisor[827]: 20-05-31 02:17:37 INFO (MainThread) [supervisor.addons] Phase 'application' start 0 add-ons
May 31 10:17:37 raspberrypi hassio-supervisor[827]: 20-05-31 02:17:37 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
May 31 10:17:37 raspberrypi hassio-supervisor[827]: 20-05-31 02:17:37 INFO (MainThread) [supervisor.misc.hwmon] Started Supervisor hardware monitor
May 31 10:17:37 raspberrypi hassio-supervisor[827]: 20-05-31 02:17:37 INFO (MainThread) [supervisor.core] Supervisor is up and running
May 31 10:17:37 raspberrypi hassio-supervisor[827]: 20-05-31 02:17:37 INFO (MainThread) [supervisor.host.info] Update local host information
May 31 10:17:37 raspberrypi hassio-supervisor[827]: 20-05-31 02:17:37 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
May 31 10:17:37 raspberrypi hassio-supervisor[827]: 20-05-31 02:17:37 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
May 31 10:17:38 raspberrypi hassio-supervisor[827]: 20-05-31 02:17:38 INFO (MainThread) [supervisor.host.services] Update service information
May 31 10:17:38 raspberrypi hassio-supervisor[827]: 20-05-31 02:17:38 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
May 31 10:17:38 raspberrypi hassio-supervisor[827]: 20-05-31 02:17:38 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
pi@raspberrypi:~ $ service hassio-apparmor status
● hassio-apparmor.service - Hass.io AppArmor
   Loaded: loaded (/etc/systemd/system/hassio-apparmor.service; enabled; vendor preset: enabled)
   Active: active (exited) since Sun 2020-05-31 10:07:10 CST; 19min ago
  Process: 1410 ExecStart=/usr/sbin/hassio-apparmor (code=exited, status=0/SUCCESS)
 Main PID: 1410 (code=exited, status=0/SUCCESS)
May 31 10:07:10 raspberrypi systemd[1]: Starting Hass.io AppArmor...
May 31 10:07:10 raspberrypi hassio-apparmor[1410]: Warning: unable to find a suitable fs in /proc/mounts, is it mounted?
May 31 10:07:10 raspberrypi hassio-apparmor[1410]: Use --subdomainfs to override.
May 31 10:07:10 raspberrypi hassio-apparmor[1410]: [Error]: Can't load profile /usr/share/hassio/apparmor/hassio-supervisor
May 31 10:07:10 raspberrypi systemd[1]: Started Hass.io AppArmor.
<blockquote>pi@raspberrypi:~ $ docker logs -f hassio_supervisor --tail 50
pi@raspberrypi:~ $ docker logs -f homeassistant --tail 20
2020-05-31 10:08:39 INFO (SyncWorker_12) [xiaomi_gateway] Found 4 devices
2020-05-31 10:08:40 INFO (MainThread) [homeassistant.setup] Setup of domain hassio took 0.5 seconds.
2020-05-31 10:08:45 INFO (SyncWorker_12) [xiaomi_gateway] Gateway discovery finished in 5 seconds
2020-05-31 10:08:45 INFO (SyncWorker_12) [xiaomi_gateway] Creating Multicast Socket
2020-05-31 10:08:45 INFO (SyncWorker_2) [homeassistant.loader] Loaded switch from homeassistant.components.switch
2020-05-31 10:08:45 INFO (SyncWorker_16) [homeassistant.loader] Loaded cover from homeassistant.components.cover
2020-05-31 10:08:45 INFO (SyncWorker_2) [homeassistant.loader] Loaded lock from homeassistant.components.lock
2020-05-31 10:08:45 INFO (MainThread) [homeassistant.setup] Setting up switch
2020-05-31 10:08:45 INFO (MainThread) [homeassistant.setup] Setup of domain switch took 0.0 seconds.
2020-05-31 10:08:45 INFO (MainThread) [homeassistant.setup] Setting up cover
2020-05-31 10:08:45 INFO (MainThread) [homeassistant.setup] Setup of domain cover took 0.0 seconds.
2020-05-31 10:08:45 INFO (MainThread) [homeassistant.setup] Setting up lock
2020-05-31 10:08:45 INFO (MainThread) [homeassistant.setup] Setup of domain lock took 0.0 seconds.
2020-05-31 10:08:45 INFO (MainThread) [homeassistant.setup] Setup of domain xiaomi_aqara took 5.4 seconds.
2020-05-31 10:08:45 INFO (MainThread) [homeassistant.components.cover] Setting up cover.xiaomi_aqara
2020-05-31 10:08:45 INFO (MainThread) [homeassistant.components.lock] Setting up lock.xiaomi_aqara
2020-05-31 10:08:45 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.xiaomi_aqara
2020-05-31 10:08:45 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.xiaomi_aqara
2020-05-31 10:08:45 INFO (MainThread) [homeassistant.components.light] Setting up light.xiaomi_aqara
2020-05-31 10:08:45 INFO (MainThread) [homeassistant.components.switch] Setting up switch.xiaomi_aqara
pi@raspberrypi:~ $ docker ps -a
0359fc8e3b34        homeassistant/armv7-hassio-multicast:2             "/init"                  31 minutes ago      Up 31 minutes                           hassio_multicast
abf0311eb3ae        homeassistant/armv7-hassio-dns:9                   "/init coredns -conf…"   31 minutes ago      Up 31 minutes                           hassio_dns
1d07e76c3c9c        homeassistant/armv7-hassio-audio:14                "/init"                  31 minutes ago      Up 31 minutes                           hassio_audio
c86b6e08d382        homeassistant/armv7-hassio-cli:25                  "/init /bin/bash -c …"   31 minutes ago      Up 31 minutes                           hassio_cli
601ef7ca5dc8        homeassistant/raspberrypi3-homeassistant:0.110.3   "/init"                  35 hours ago        Up 31 minutes                           homeassistant
d5015387e8a7        homeassistant/armv7-hassio-supervisor              "/init"                  38 hours ago        Up 31 minutes                           hassio_supervisor
 楼主| 发表于 2020-5-31 16:36:43 | 显示全部楼层
日志没看出什么问题,找 error
发表于 2020-6-1 14:21:30 | 显示全部楼层
麻烦大佬抽空看看我的问题如何解决,万分感谢!
我的是 debian OMV
20-06-01 06:03:24 INFO (MainThread) [supervisor.bootstrap] Use the old homeassistant repository for machine extraction
20-06-01 06:03:24 INFO (MainThread) [__main__] Initialize Supervisor setup
20-06-01 06:03:24 INFO (MainThread) [supervisor.docker.network] Can't find Supervisor network, create new network
20-06-01 06:03:24 INFO (MainThread) [supervisor.bootstrap] Setup coresys for machine: qemux86-64
20-06-01 06:03:24 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attach to Supervisor homeassistant/amd64-hassio-supervisor with version 225
20-06-01 06:03:24 INFO (SyncWorker_0) [supervisor.docker.supervisor] Connect Supervisor to hassio Network
20-06-01 06:03:24 ERROR (MainThread) [supervisor.docker] Docker logging driver json-file is not supported!
20-06-01 06:03:24 INFO (MainThread) [__main__] Setup Supervisor
20-06-01 06:03:24 INFO (MainThread) [supervisor.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
20-06-01 06:03:24 INFO (MainThread) [supervisor.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
20-06-01 06:03:24 WARNING (MainThread) [supervisor.dbus.rauc] Host has no rauc support. OTA updates have been disabled.
20-06-01 06:03:24 INFO (MainThread) [supervisor.utils.gdbus] Connect to dbus: org.freedesktop.NetworkManager - /org/freedesktop/NetworkManager/DnsManager
20-06-01 06:03:24 INFO (MainThread) [supervisor.host.info] Update local host information
20-06-01 06:03:24 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-06-01 06:03:24 INFO (MainThread) [supervisor.host.services] Update service information
20-06-01 06:03:24 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-06-01 06:03:24 INFO (MainThread) [supervisor.host.network] Update local network DNS information
20-06-01 06:03:24 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
20-06-01 06:03:24 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
20-06-01 06:03:24 INFO (MainThread) [supervisor.host.apparmor] Load AppArmor Profiles: {'hassio-supervisor'}
20-06-01 06:03:24 INFO (MainThread) [supervisor.host.services] Reload local service hassio-apparmor.service
20-06-01 06:03:24 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ReloadOrRestartUnit on /org/freedesktop/systemd1
20-06-01 06:03:25 INFO (MainThread) [supervisor.plugins.dns] No CoreDNS plugin Docker image homeassistant/amd64-hassio-dns found.
20-06-01 06:03:25 INFO (MainThread) [supervisor.plugins.dns] Setup CoreDNS plugin
20-06-01 06:03:25 INFO (SyncWorker_0) [supervisor.docker.interface] Pull image homeassistant/amd64-hassio-dns tag 9.
20-06-01 06:03:25 INFO (MainThread) [supervisor.plugins.multicast] No Multicast plugin Docker image homeassistant/amd64-hassio-multicast found.
20-06-01 06:03:25 INFO (MainThread) [supervisor.plugins.multicast] Setup Multicast plugin
20-06-01 06:03:25 INFO (SyncWorker_3) [supervisor.docker.interface] Pull image homeassistant/amd64-hassio-multicast tag 2.
20-06-01 06:03:25 INFO (MainThread) [supervisor.plugins.cli] No cli plugin Docker image homeassistant/amd64-hassio-cli found.
20-06-01 06:03:25 INFO (MainThread) [supervisor.plugins.cli] Setup cli plugin
20-06-01 06:03:25 INFO (SyncWorker_4) [supervisor.docker.interface] Pull image homeassistant/amd64-hassio-cli tag 25.
20-06-01 06:03:25 INFO (MainThread) [supervisor.plugins.audio] No Audio plugin Docker image homeassistant/amd64-hassio-audio found.
20-06-01 06:03:25 INFO (MainThread) [supervisor.plugins.audio] Setup Audio plugin
20-06-01 06:03:25 INFO (SyncWorker_7) [supervisor.docker.interface] Pull image homeassistant/amd64-hassio-audio tag 14.
20-06-01 06:03:55 INFO (MainThread) [supervisor.plugins.dns] CoreDNS plugin now installed
20-06-01 06:03:55 INFO (MainThread) [supervisor.plugins.dns] Start CoreDNS plugin
20-06-01 06:03:55 INFO (MainThread) [supervisor.misc.forwarder] Start DNS port forwarding to 172.30.32.3
20-06-01 06:03:56 INFO (SyncWorker_8) [supervisor.docker.dns] Start DNS homeassistant/amd64-hassio-dns with version 9 - 172.30.32.3
20-06-01 06:03:56 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
20-06-01 06:03:59 INFO (SyncWorker_4) [supervisor.docker.interface] Tag image homeassistant/amd64-hassio-cli with version 25 as latest
20-06-01 06:03:59 INFO (MainThread) [supervisor.plugins.cli] cli plugin now installed
20-06-01 06:03:59 INFO (MainThread) [supervisor.plugins.cli] Start cli plugin
20-06-01 06:03:59 INFO (SyncWorker_9) [supervisor.docker.cli] Start CLI homeassistant/amd64-hassio-cli with version 25 - 172.30.32.5
20-06-01 06:04:00 INFO (MainThread) [supervisor.plugins.multicast] Multicast plugin now installed
20-06-01 06:04:00 INFO (MainThread) [supervisor.plugins.multicast] Start Multicast plugin
20-06-01 06:04:00 INFO (SyncWorker_16) [supervisor.docker.multicast] Start Multicast homeassistant/amd64-hassio-multicast with version 2 - Host
20-06-01 06:04:15 INFO (MainThread) [supervisor.plugins.audio] Audio plugin now installed
20-06-01 06:04:15 INFO (MainThread) [supervisor.plugins.audio] Start Audio plugin
20-06-01 06:04:16 INFO (SyncWorker_11) [supervisor.docker.audio] Start Audio homeassistant/amd64-hassio-audio with version 14 - 172.30.32.4
20-06-01 06:04:16 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-06-01 06:04:16 INFO (SyncWorker_19) [supervisor.docker.interface] Attach to homeassistant/qemux86-64-homeassistant with version 0.110.4
20-06-01 06:04:16 WARNING (MainThread) [supervisor.hassos] No Home Assistant Operating-System found!
20-06-01 06:04:16 INFO (MainThread) [supervisor.store.git] Load add-on /data/addons/git/a0d7b954 repository
20-06-01 06:04:16 INFO (MainThread) [supervisor.store.git] Load add-on /data/addons/core repository
20-06-01 06:04:16 INFO (MainThread) [supervisor.store] Load add-ons from store: 65 all - 65 new - 0 remove
20-06-01 06:04:16 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
20-06-01 06:04:16 INFO (MainThread) [supervisor.snapshots] Found 0 snapshot files
20-06-01 06:04:16 INFO (MainThread) [supervisor.discovery] Load 0 messages
20-06-01 06:04:16 INFO (MainThread) [supervisor.ingress] Load 0 ingress session
20-06-01 06:04:16 INFO (MainThread) [supervisor.misc.secrets] Load Home Assistant secrets: 0
20-06-01 06:04:16 INFO (MainThread) [__main__] Run Supervisor
20-06-01 06:04:16 INFO (MainThread) [supervisor.api] Start API on 172.30.32.2
20-06-01 06:04:16 INFO (MainThread) [supervisor.addons] Phase 'initialize' start 0 add-ons
20-06-01 06:04:16 INFO (MainThread) [supervisor.core] Supervisor reboot detected
20-06-01 06:04:16 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
20-06-01 06:04:16 INFO (MainThread) [supervisor.misc.hwmon] Started Supervisor hardware monitor
20-06-01 06:04:16 INFO (MainThread) [supervisor.core] Supervisor is up and running
20-06-01 06:04:16 INFO (MainThread) [supervisor.host.info] Update local host information
20-06-01 06:04:16 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-06-01 06:04:17 INFO (MainThread) [supervisor.host.services] Update service information
20-06-01 06:04:17 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-06-01 06:04:17 INFO (MainThread) [supervisor.host.network] Update local network DNS information
20-06-01 06:04:17 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
20-06-01 06:04:17 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
发表于 2020-6-2 02:11:19 | 显示全部楼层
[info]: 切换系统网络源.....
Hit:1 http://mirrors.tuna.tsinghua.edu.cn/raspbian/raspbian buster InRelease
Hit:2 http://mirrors.tuna.tsinghua.edu.cn/raspberrypi buster InRelease
Hit:3 https://download.docker.com/linux/debian buster InRelease
3 packages can be upgraded. Run 'apt list --upgradable' to see them.
avahi-daemon is already the newest version (0.7-4+b1).
curl is already the newest version (7.64.0-4+deb10u1).
jq is already the newest version (1.5+dfsg-2+b1).
net-tools is already the newest version (1.60+git20180626.aebd88e-1).
socat is already the newest version (1.7.3.2-2).
You might want to run 'apt --fix-broken install' to correct these.
The following packages have unmet dependencies:
libraspberrypi0 : Depends: raspberrypi-bootloader (= 1.20200512-2) but 1.20200212-1 is to be installed
qrencode : Depends: libqrencode4 (>= 3.3.0) but it is not going to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
Distributor ID:        Raspbian
Description:        Raspbian GNU/Linux 10 (buster)
Release:        10
Codename:        buster
Linux version 4.19.97-v7l+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1294 SMP Thu Jan 30 13:21:14 GMT 2020
Linux raspberrypi 4.19.97-v7l+ #1294 SMP Thu Jan 30 13:21:14 GMT 2020 armv7l GNU/Linux
 楼主| 发表于 2020-6-2 09:42:02 | 显示全部楼层
xiemuyun 发表于 2020-6-2 02:11
: 切换系统网络源.....
H ...
https://blog.csdn.net/sy373466062/article/details/53991413
wktm 手机认证
发表于 2020-6-2 21:11:14 | 显示全部楼层
esphome 插件 编译完毕每次都是这个情况,MDNS 不知道怎么设置
resolving IP address of esp32cam.local. Is it connected to WiFi?
ERROR (If this error persists, please set a static IP address: https://esphome.io/components/wifi.html#manual-ips)
ERROR Error resolving IP address: Error resolving address with mDNS: Did not respond. Maybe the device is offline., [Errno -5] No address associated with hostname
  求怎么解决这个
GMT+8, 2026-1-7 22:29 , Processed in 0.150026 second(s), 16 queries , MemCached On.
