楼主: neroxps
HASSIO 安装一键脚本
 火...   [复制链接]
发表于 2020-3-30 11:06:32 | 显示全部楼层
neroxps 发表于 2020-3-30 10:18
给 hassio 日志看看
只有这个,homeassistant没挂上
20-03-30 02:57:36 WARNING (MainThread) [supervisor.audio] Error on install Audio plugin. Retry in 30sec
20-03-30 02:57:36 WARNING (MainThread) [supervisor.cli] Error on install cli plugin. Retry in 30sec
20-03-30 02:58:06 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-03-30 02:58:17 WARNING (MainThread) [supervisor.updater] Can't fetch versions from https://version.home-assistant.io/stable.json:
20-03-30 02:58:17 WARNING (MainThread) [supervisor.audio] Error on install Audio plugin. Retry in 30sec
20-03-30 02:58:17 WARNING (MainThread) [supervisor.cli] Error on install cli plugin. Retry in 30sec
20-03-30 02:58:47 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-03-30 02:58:58 WARNING (MainThread) [supervisor.updater] Can't fetch versions from https://version.home-assistant.io/stable.json:
20-03-30 02:58:58 WARNING (MainThread) [supervisor.audio] Error on install Audio plugin. Retry in 30sec
20-03-30 02:58:58 WARNING (MainThread) [supervisor.cli] Error on install cli plugin. Retry in 30sec
20-03-30 02:59:28 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-03-30 02:59:39 WARNING (MainThread) [supervisor.updater] Can't fetch versions from https://version.home-assistant.io/stable.json:
20-03-30 02:59:39 WARNING (MainThread) [supervisor.audio] Error on install Audio plugin. Retry in 30sec
20-03-30 02:59:39 WARNING (MainThread) [supervisor.cli] Error on install cli plugin. Retry in 30sec
20-03-30 03:00:09 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-03-30 03:00:20 WARNING (MainThread) [supervisor.updater] Can't fetch versions from https://version.home-assistant.io/stable.json:
20-03-30 03:00:20 WARNING (MainThread) [supervisor.audio] Error on install Audio plugin. Retry in 30sec
20-03-30 03:00:20 WARNING (MainThread) [supervisor.cli] Error on install cli plugin. Retry in 30sec
20-03-30 03:00:50 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-03-30 03:01:01 WARNING (MainThread) [supervisor.updater] Can't fetch versions from https://version.home-assistant.io/stable.json:
20-03-30 03:01:01 WARNING (MainThread) [supervisor.audio] Error on install Audio plugin. Retry in 30sec
20-03-30 03:01:01 WARNING (MainThread) [supervisor.cli] Error on install cli plugin. Retry in 30sec
20-03-30 03:01:31 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-03-30 03:01:42 WARNING (MainThread) [supervisor.updater] Can't fetch versions from https://version.home-assistant.io/stable.json:
20-03-30 03:01:42 WARNING (MainThread) [supervisor.audio] Error on install Audio plugin. Retry in 30sec
20-03-30 03:01:42 WARNING (MainThread) [supervisor.cli] Error on install cli plugin. Retry in 30sec
20-03-30 03:02:12 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-03-30 03:02:23 WARNING (MainThread) [supervisor.updater] Can't fetch versions from https://version.home-assistant.io/stable.json:
20-03-30 03:02:23 WARNING (MainThread) [supervisor.audio] Error on install Audio plugin. Retry in 30sec
20-03-30 03:02:23 WARNING (MainThread) [supervisor.cli] Error on install cli plugin. Retry in 30sec
20-03-30 03:02:53 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-03-30 03:03:04 WARNING (MainThread) [supervisor.updater] Can't fetch versions from https://version.home-assistant.io/stable.json:
20-03-30 03:03:04 WARNING (MainThread) [supervisor.audio] Error on install Audio plugin. Retry in 30sec
20-03-30 03:03:04 WARNING (MainThread) [supervisor.cli] Error on install cli plugin. Retry in 30sec
20-03-30 03:03:34 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-03-30 03:03:45 WARNING (MainThread) [supervisor.updater] Can't fetch versions from https://version.home-assistant.io/stable.json:
20-03-30 03:03:45 WARNING (MainThread) [supervisor.audio] Error on install Audio plugin. Retry in 30sec
20-03-30 03:03:45 WARNING (MainThread) [supervisor.cli] Error on install cli plugin. Retry in 30sec
20-03-30 03:04:15 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-03-30 03:04:26 WARNING (MainThread) [supervisor.updater] Can't fetch versions from https://version.home-assistant.io/stable.json:
20-03-30 03:04:26 WARNING (MainThread) [supervisor.audio] Error on install Audio plugin. Retry in 30sec
20-03-30 03:04:26 WARNING (MainThread) [supervisor.cli] Error on install cli plugin. Retry in 30sec
 楼主| 发表于 2020-3-30 11:25:29 | 显示全部楼层
20-03-30 02:57:36 WARNING (MainThread) [supervisor.audio] Error on  ...
无法获取到版本
发表于 2020-3-30 11:28:10 | 显示全部楼层
neroxps 发表于 2020-3-30 11:25
20-03-30 03:04:26 WARNING (MainThread) [supervisor.updater] Can't fetch versions from https://vers ...
以前安装homeassistant/qemux86-64-homeassistant都会挂上,现在只下载无法挂上去
 楼主| 发表于 2020-3-30 12:18:22 | 显示全部楼层
什么叫挂上??
发表于 2020-3-31 11:36:35 | 显示全部楼层
大大求助 ,安装提示成功,然后进去后发现hassio dns 容器没有启动,sonoff tuya 插件无法使用
直接继续用   ./install.sh    安装后出现错误  下面的信息反复出现,
20-03-31 03:13:04 WARNING (MainThread) [supervisor.tasks] Watchdog found a problem with CoreDNS plugin!
20-03-31 03:13:04 ERROR (MainThread) [supervisor.tasks] CoreDNS plugin is in fails state / Reset config
20-03-31 03:13:04 INFO (MainThread) [supervisor.dns] Start CoreDNS plugin
20-03-31 03:13:04 INFO (SyncWorker_4) [supervisor.docker.interface] Clean hassio_dns application
20-03-31 03:13:05 INFO (SyncWorker_4) [supervisor.docker.dns] Start DNS homeassistant/aarch64-hassio-dns with version 1 - 172.30.32.3
下面是完整的错误日志 有点长
########################### Docker images ###########################
REPOSITORY                                TAG                 IMAGE ID              CREATED             SIZE
homeassistant/aarch64-hassio-supervisor   214                 d448493e9821          17 hours ago        348MB
homeassistant/aarch64-hassio-supervisor   latest              d448493e9821          17 hours ago        348MB
homeassistant/aarch64-hassio-cli          24                  c20ab8fabc33          35 hours ago        44.4MB
homeassistant/aarch64-hassio-cli          latest              c20ab8fabc33          35 hours ago        44.4MB
homeassistant/qemuarm-64-homeassistant    0.107.7             fffe89912371          5 days ago          1.35GB
homeassistant/qemuarm-64-homeassistant    latest              fffe89912371          5 days ago          1.35GB
portainer/portainer                       latest              4211f12ec84c          11 days ago         68MB
homeassistant/aarch64-hassio-audio        9                   3a402a339d1e          2 weeks ago         57.7MB
homeassistant/aarch64-hassio-dns          1                   e5edbd61b477          7 months ago        59.8MB
########################### Docker ps ###########################
CONTAINER ID        IMAGE                                     COMMAND                    CREATED             STATUS                      PORTS                      NAMES
20252569df9d        homeassistant/aarch64-hassio-dns:1        "coredns -conf /co  nf…"   16 seconds ago      Exited (1) 14 seconds ago                              hassio_dns
05307a77cd0b        homeassistant/aarch64-hassio-cli:24       "/init /bin/bash -  c …"   5 minutes ago       Up 5 minutes                                           hassio_cli
da3e7520952e        homeassistant/aarch64-hassio-audio:9      "/init"                    5 minutes ago       Up 5 minutes                                           hassio_audio
286aa0f7d8e4        homeassistant/aarch64-hassio-supervisor   "/init"                    7 minutes ago       Up 5 minutes                                           hassio_supervisor
7b8766b8e66b        portainer/portainer                       "/portainer"               4 hours ago         Up 5 minutes                0.0.0.0:9001->9000/tcp     docker-portainer
########################### hassio log ###########################
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] udev.sh: executing...
[03:05:30] INFO: Update udev informations
[cont-init.d] udev.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
20-03-31 03:05:34 INFO (MainThread) [__main__] Initialize Supervisor setup
20-03-31 03:05:34 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attach to S  upervisor homeassistant/aarch64-hassio-supervisor with version 214
20-03-31 03:05:34 INFO (SyncWorker_0) [supervisor.docker.supervisor] Connect Sup  ervisor to hassio Network
20-03-31 03:05:35 INFO (MainThread) [__main__] Setup Supervisor
20-03-31 03:05:35 INFO (MainThread) [supervisor.utils.gdbus] Connect to dbus: or  g.freedesktop.systemd1 - /org/freedesktop/systemd1
20-03-31 03:05:35 INFO (MainThread) [supervisor.utils.gdbus] Connect to dbus: or  g.freedesktop.hostname1 - /org/freedesktop/hostname1
20-03-31 03:05:35 WARNING (MainThread) [supervisor.dbus.rauc] Host has no rauc s  upport. OTA updates have been disabled.
20-03-31 03:05:35 INFO (MainThread) [supervisor.utils.gdbus] Connect to dbus: or  g.freedesktop.NetworkManager - /org/freedesktop/NetworkManager/DnsManager
20-03-31 03:05:35 INFO (MainThread) [supervisor.host.info] Update local host inf  ormation
20-03-31 03:05:35 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedeskto  p.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-03-31 03:05:35 INFO (MainThread) [supervisor.host.services] Update service in  formation
20-03-31 03:05:35 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedeskto  p.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-03-31 03:05:35 INFO (MainThread) [supervisor.host.network] Update local netwo  rk DNS information
20-03-31 03:05:35 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedeskto  p.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
20-03-31 03:05:35 INFO (MainThread) [supervisor.host.sound] Update PulseAudio in  formation
20-03-31 03:05:35 INFO (MainThread) [supervisor.host.apparmor] Load AppArmor Pro  files: set()
20-03-31 03:05:35 INFO (MainThread) [supervisor.host.apparmor] AppArmor is not e  nabled on host
20-03-31 03:05:36 INFO (SyncWorker_2) [supervisor.docker.interface] Attach to ho  meassistant/aarch64-hassio-audio with version 9
20-03-31 03:05:36 INFO (SyncWorker_1) [supervisor.docker.interface] Attach to ho  meassistant/aarch64-hassio-dns with version 1
20-03-31 03:05:36 INFO (SyncWorker_0) [supervisor.docker.interface] Attach to ho  meassistant/aarch64-hassio-cli with version 24
20-03-31 03:05:36 INFO (MainThread) [supervisor.audio] Start Audio plugin
20-03-31 03:05:36 INFO (MainThread) [supervisor.dns] Start CoreDNS plugin
20-03-31 03:05:36 INFO (MainThread) [supervisor.misc.forwarder] Start DNS port f  orwarding to 172.30.32.3
20-03-31 03:05:36 INFO (MainThread) [supervisor.cli] Start cli plugin
20-03-31 03:05:37 INFO (SyncWorker_9) [supervisor.docker.audio] Start Audio home  assistant/aarch64-hassio-audio with version 9 - 172.30.32.4
20-03-31 03:05:38 INFO (SyncWorker_10) [supervisor.docker.dns] Start DNS homeass  istant/aarch64-hassio-dns with version 1 - 172.30.32.3
20-03-31 03:05:38 INFO (MainThread) [supervisor.dns] Updated /etc/resolv.conf
20-03-31 03:05:39 INFO (SyncWorker_3) [supervisor.docker.cli] Start CLI homeassi  stant/aarch64-hassio-cli with version 24 - 172.30.32.4
20-03-31 03:05:39 INFO (SyncWorker_2) [supervisor.docker.interface] Attach to ho  meassistant/qemuarm-64-homeassistant with version 0.107.7
20-03-31 03:05:39 INFO (MainThread) [supervisor.store.git] Load add-on /data/add  ons/git/a0d7b954 repository
20-03-31 03:05:39 INFO (MainThread) [supervisor.store.git] Load add-on /data/add  ons/core repository
20-03-31 03:05:39 INFO (MainThread) [supervisor.store] Load add-ons from store:   65 all - 65 new - 0 remove
20-03-31 03:05:39 INFO (MainThread) [supervisor.addons] Found 0 installed add-on  s
20-03-31 03:05:39 INFO (MainThread) [supervisor.updater] Fetch update data from   https://version.home-assistant.io/stable.json
20-03-31 03:05:40 INFO (MainThread) [supervisor.snapshots] Found 0 snapshot file  s
20-03-31 03:05:40 INFO (MainThread) [supervisor.discovery] Load 0 messages
20-03-31 03:05:40 INFO (MainThread) [supervisor.ingress] Load 0 ingress session
20-03-31 03:05:40 INFO (MainThread) [supervisor.secrets] Load Home Assistant sec  rets: 1
20-03-31 03:05:40 INFO (MainThread) [__main__] Run Supervisor
20-03-31 03:05:40 INFO (MainThread) [supervisor.api] Start API on 172.30.32.2
20-03-31 03:05:40 INFO (MainThread) [supervisor.addons] Phase 'initialize' start   0 add-ons
20-03-31 03:05:40 INFO (MainThread) [supervisor.core] Supervisor reboot detected
20-03-31 03:05:40 INFO (MainThread) [supervisor.tasks] All core tasks are schedu  led
20-03-31 03:05:40 INFO (MainThread) [supervisor.hwmon] Started Supervisor hardwa  re monitor
20-03-31 03:05:40 INFO (MainThread) [supervisor.core] Supervisor is up and runni  ng
20-03-31 03:05:40 INFO (MainThread) [supervisor.host.info] Update local host inf  ormation
20-03-31 03:05:40 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedeskto  p.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-03-31 03:05:40 INFO (MainThread) [supervisor.host.services] Update service in  formation
20-03-31 03:05:40 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedeskto  p.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-03-31 03:05:41 INFO (MainThread) [supervisor.host.network] Update local netwo  rk DNS information
20-03-31 03:05:41 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedeskto  p.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
20-03-31 03:06:00 WARNING (MainThread) [supervisor.tasks] Watchdog found a probl  em with CoreDNS plugin!
20-03-31 03:06:00 ERROR (MainThread) [supervisor.tasks] CoreDNS plugin is in fai  ls state / Reset config
20-03-31 03:06:00 INFO (MainThread) [supervisor.dns] Start CoreDNS plugin
20-03-31 03:06:00 INFO (SyncWorker_5) [supervisor.docker.interface] Clean hassio  _dns application
20-03-31 03:06:02 INFO (SyncWorker_5) [supervisor.docker.dns] Start DNS homeassi  stant/aarch64-hassio-dns with version 1 - 172.30.32.3
20-03-31 03:06:20 WARNING (MainThread) [supervisor.tasks] Watchdog found a probl  em with CoreDNS plugin!
20-03-31 03:06:20 ERROR (MainThread) [supervisor.tasks] CoreDNS plugin is in fai  ls state / Reset config
20-03-31 03:06:20 INFO (MainThread) [supervisor.dns] Start CoreDNS plugin
20-03-31 03:06:21 INFO (SyncWorker_10) [supervisor.docker.interface] Clean hassi  o_dns application
20-03-31 03:06:22 INFO (SyncWorker_10) [supervisor.docker.dns] Start DNS homeass  istant/aarch64-hassio-dns with version 1 - 172.30.32.3
20-03-31 03:06:40 WARNING (MainThread) [supervisor.tasks] Watchdog found a probl  em with CoreDNS plugin!
20-03-31 03:06:40 ERROR (MainThread) [supervisor.tasks] CoreDNS plugin is in fai  ls state / Reset config
20-03-31 03:06:40 INFO (MainThread) [supervisor.dns] Start CoreDNS plugin
20-03-31 03:06:40 INFO (SyncWorker_16) [supervisor.docker.interface] Clean hassi  o_dns application
20-03-31 03:06:42 INFO (SyncWorker_16) [supervisor.docker.dns] Start DNS homeass  istant/aarch64-hassio-dns with version 1 - 172.30.32.3
20-03-31 03:07:00 WARNING (MainThread) [supervisor.tasks] Watchdog found a probl  em with CoreDNS plugin!
20-03-31 03:07:00 ERROR (MainThread) [supervisor.tasks] CoreDNS plugin is in fai  ls state / Reset config
20-03-31 03:07:00 INFO (MainThread) [supervisor.dns] Start CoreDNS plugin
20-03-31 03:07:00 INFO (SyncWorker_5) [supervisor.docker.interface] Clean hassio  _dns application
20-03-31 03:07:02 INFO (SyncWorker_5) [supervisor.docker.dns] Start DNS homeassi  stant/aarch64-hassio-dns with version 1 - 172.30.32.3
20-03-31 03:07:20 WARNING (MainThread) [supervisor.tasks] Watchdog found a probl  em with CoreDNS plugin!
20-03-31 03:07:20 ERROR (MainThread) [supervisor.tasks] CoreDNS plugin is in fai  ls state / Reset config
20-03-31 03:07:20 INFO (MainThread) [supervisor.dns] Start CoreDNS plugin
20-03-31 03:07:20 INFO (SyncWorker_3) [supervisor.docker.interface] Clean hassio  _dns application
20-03-31 03:07:22 INFO (SyncWorker_3) [supervisor.docker.dns] Start DNS homeassi  stant/aarch64-hassio-dns with version 1 - 172.30.32.3
20-03-31 03:07:39 INFO (MainThread) [__main__] Stopping Supervisor
20-03-31 03:07:39 INFO (MainThread) [supervisor.hwmon] Stop Supervisor hardware   monitor
20-03-31 03:07:39 INFO (MainThread) [supervisor.api] Stop API on 172.30.32.2
20-03-31 03:07:39 INFO (MainThread) [supervisor.misc.forwarder] Stop DNS forward  ing
20-03-31 03:07:39 INFO (MainThread) [supervisor.core] Supervisor is down
20-03-31 03:07:39 INFO (MainThread) [__main__] Close Supervisor
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
s6-svscanctl: fatal: unable to control /var/run/s6/services: supervisor not list  ening
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
[fix-attrs.d] done.
[03:07:53] INFO: Update udev informations
[cont-init.d] done.
[services.d] done.
20-03-31 03:07:57 INFO (MainThread) [__main__] Initialize Supervisor setup
20-03-31 03:07:58 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attach to S  upervisor homeassistant/aarch64-hassio-supervisor with version 214
20-03-31 03:07:58 INFO (MainThread) [__main__] Setup Supervisor
20-03-31 03:07:58 INFO (MainThread) [supervisor.utils.gdbus] Connect to dbus: or  g.freedesktop.systemd1 - /org/freedesktop/systemd1
20-03-31 03:07:58 INFO (MainThread) [supervisor.utils.gdbus] Connect to dbus: or  g.freedesktop.hostname1 - /org/freedesktop/hostname1
20-03-31 03:07:58 WARNING (MainThread) [supervisor.dbus.rauc] Host has no rauc s  upport. OTA updates have been disabled.
20-03-31 03:07:58 INFO (MainThread) [supervisor.utils.gdbus] Connect to dbus: or  g.freedesktop.NetworkManager - /org/freedesktop/NetworkManager/DnsManager
20-03-31 03:07:58 INFO (MainThread) [supervisor.host.info] Update local host inf  ormation
20-03-31 03:07:58 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedeskto  p.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-03-31 03:07:58 INFO (MainThread) [supervisor.host.services] Update service in  formation
20-03-31 03:07:58 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedeskto  p.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-03-31 03:07:58 INFO (MainThread) [supervisor.host.network] Update local netwo  rk DNS information
20-03-31 03:07:58 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedeskto  p.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
20-03-31 03:07:58 INFO (MainThread) [supervisor.host.sound] Update PulseAudio in  formation
20-03-31 03:07:58 INFO (MainThread) [supervisor.host.apparmor] Load AppArmor Pro  files: set()
20-03-31 03:07:58 INFO (MainThread) [supervisor.host.apparmor] AppArmor is not e  nabled on host
20-03-31 03:07:58 INFO (SyncWorker_2) [supervisor.docker.interface] Attach to ho  meassistant/aarch64-hassio-audio with version 9
20-03-31 03:07:58 INFO (SyncWorker_1) [supervisor.docker.interface] Attach to ho  meassistant/aarch64-hassio-dns with version 1
20-03-31 03:07:58 INFO (SyncWorker_0) [supervisor.docker.interface] Attach to ho  meassistant/aarch64-hassio-cli with version 24
20-03-31 03:07:58 INFO (MainThread) [supervisor.audio] Start Audio plugin
20-03-31 03:07:58 INFO (MainThread) [supervisor.misc.forwarder] Start DNS port f  orwarding to 172.30.32.3
20-03-31 03:07:58 INFO (MainThread) [supervisor.dns] Start CoreDNS plugin
20-03-31 03:07:58 INFO (SyncWorker_9) [supervisor.docker.interface] Clean hassio  _audio application
20-03-31 03:07:58 INFO (MainThread) [supervisor.cli] Start cli plugin
20-03-31 03:07:58 INFO (SyncWorker_10) [supervisor.docker.interface] Clean hassi  o_dns application
20-03-31 03:07:59 INFO (SyncWorker_3) [supervisor.docker.interface] Clean hassio  _cli application
20-03-31 03:08:01 INFO (SyncWorker_3) [supervisor.docker.cli] Start CLI homeassi  stant/aarch64-hassio-cli with version 24 - 172.30.32.4
20-03-31 03:08:01 INFO (SyncWorker_10) [supervisor.docker.dns] Start DNS homeass  istant/aarch64-hassio-dns with version 1 - 172.30.32.3
20-03-31 03:08:01 INFO (MainThread) [supervisor.dns] Updated /etc/resolv.conf
20-03-31 03:08:02 INFO (SyncWorker_9) [supervisor.docker.audio] Start Audio home  assistant/aarch64-hassio-audio with version 9 - 172.30.32.4
20-03-31 03:08:02 INFO (SyncWorker_2) [supervisor.docker.interface] Attach to ho  meassistant/qemuarm-64-homeassistant with version 0.107.7
20-03-31 03:08:02 INFO (MainThread) [supervisor.store.git] Load add-on /data/add  ons/git/a0d7b954 repository
20-03-31 03:08:02 INFO (MainThread) [supervisor.store.git] Load add-on /data/add  ons/core repository
20-03-31 03:08:03 INFO (MainThread) [supervisor.store] Load add-ons from store:   65 all - 65 new - 0 remove
20-03-31 03:08:03 INFO (MainThread) [supervisor.addons] Found 0 installed add-on  s
20-03-31 03:08:03 INFO (MainThread) [supervisor.updater] Fetch update data from   https://version.home-assistant.io/stable.json
20-03-31 03:08:04 INFO (MainThread) [supervisor.snapshots] Found 0 snapshot file  s
20-03-31 03:08:04 INFO (MainThread) [supervisor.discovery] Load 0 messages
20-03-31 03:08:04 INFO (MainThread) [supervisor.ingress] Load 0 ingress session
20-03-31 03:08:04 INFO (MainThread) [supervisor.secrets] Load Home Assistant sec  rets: 1
20-03-31 03:08:04 INFO (MainThread) [__main__] Run Supervisor
20-03-31 03:08:04 INFO (MainThread) [supervisor.api] Start API on 172.30.32.2
20-03-31 03:08:04 INFO (MainThread) [supervisor.addons] Phase 'initialize' start   0 add-ons
20-03-31 03:08:04 INFO (MainThread) [supervisor.core] Supervisor reboot detected
20-03-31 03:08:04 INFO (MainThread) [supervisor.tasks] All core tasks are schedu  led
20-03-31 03:08:04 INFO (MainThread) [supervisor.hwmon] Started Supervisor hardwa  re monitor
20-03-31 03:08:04 INFO (MainThread) [supervisor.core] Supervisor is up and runni  ng
20-03-31 03:08:04 INFO (MainThread) [supervisor.host.info] Update local host inf  ormation
20-03-31 03:08:04 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedeskto  p.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-03-31 03:08:04 INFO (MainThread) [supervisor.host.services] Update service in  formation
20-03-31 03:08:04 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedeskto  p.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-03-31 03:08:04 INFO (MainThread) [supervisor.host.network] Update local netwo  rk DNS information
20-03-31 03:08:04 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedeskto  p.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
20-03-31 03:08:24 WARNING (MainThread) [supervisor.tasks] Watchdog found a probl  em with CoreDNS plugin!
20-03-31 03:08:24 ERROR (MainThread) [supervisor.tasks] CoreDNS plugin is in fai  ls state / Reset config
20-03-31 03:08:24 INFO (MainThread) [supervisor.dns] Start CoreDNS plugin
20-03-31 03:08:24 INFO (SyncWorker_13) [supervisor.docker.interface] Clean hassi  o_dns application
20-03-31 03:08:25 INFO (SyncWorker_13) [supervisor.docker.dns] Start DNS homeass  istant/aarch64-hassio-dns with version 1 - 172.30.32.3
20-03-31 03:08:44 WARNING (MainThread) [supervisor.tasks] Watchdog found a probl  em with CoreDNS plugin!
20-03-31 03:08:44 ERROR (MainThread) [supervisor.tasks] CoreDNS plugin is in fai  ls state / Reset config
20-03-31 03:08:44 INFO (MainThread) [supervisor.dns] Start CoreDNS plugin
20-03-31 03:08:44 INFO (SyncWorker_9) [supervisor.docker.interface] Clean hassio  _dns application
20-03-31 03:08:45 INFO (SyncWorker_9) [supervisor.docker.dns] Start DNS homeassi  stant/aarch64-hassio-dns with version 1 - 172.30.32.3
20-03-31 03:09:04 WARNING (MainThread) [supervisor.tasks] Watchdog found a probl  em with CoreDNS plugin!
20-03-31 03:09:04 ERROR (MainThread) [supervisor.tasks] CoreDNS plugin is in fai  ls state / Reset config
20-03-31 03:09:04 INFO (MainThread) [supervisor.dns] Start CoreDNS plugin
20-03-31 03:09:04 INFO (SyncWorker_8) [supervisor.docker.interface] Clean hassio  _dns application
20-03-31 03:09:05 INFO (SyncWorker_8) [supervisor.docker.dns] Start DNS homeassi  stant/aarch64-hassio-dns with version 1 - 172.30.32.3
20-03-31 03:09:24 WARNING (MainThread) [supervisor.tasks] Watchdog found a probl  em with CoreDNS plugin!
20-03-31 03:09:24 ERROR (MainThread) [supervisor.tasks] CoreDNS plugin is in fai  ls state / Reset config
20-03-31 03:09:24 INFO (MainThread) [supervisor.dns] Start CoreDNS plugin
20-03-31 03:09:24 INFO (SyncWorker_2) [supervisor.docker.interface] Clean hassio  _dns application
20-03-31 03:09:25 INFO (SyncWorker_2) [supervisor.docker.dns] Start DNS homeassi  stant/aarch64-hassio-dns with version 1 - 172.30.32.3
20-03-31 03:09:44 WARNING (MainThread) [supervisor.tasks] Watchdog found a probl  em with CoreDNS plugin!
20-03-31 03:09:44 ERROR (MainThread) [supervisor.tasks] CoreDNS plugin is in fai  ls state / Reset config
20-03-31 03:09:44 INFO (MainThread) [supervisor.dns] Start CoreDNS plugin
20-03-31 03:09:44 INFO (SyncWorker_16) [supervisor.docker.interface] Clean hassi  o_dns application
20-03-31 03:09:45 INFO (SyncWorker_16) [supervisor.docker.dns] Start DNS homeass  istant/aarch64-hassio-dns with version 1 - 172.30.32.3
20-03-31 03:10:04 WARNING (MainThread) [supervisor.tasks] Watchdog found a probl  em with CoreDNS plugin!
20-03-31 03:10:04 ERROR (MainThread) [supervisor.tasks] CoreDNS plugin is in fai  ls state / Reset config
20-03-31 03:10:04 INFO (MainThread) [supervisor.dns] Start CoreDNS plugin
20-03-31 03:10:04 INFO (SyncWorker_8) [supervisor.docker.interface] Clean hassio  _dns application
20-03-31 03:10:05 INFO (SyncWorker_8) [supervisor.docker.dns] Start DNS homeassi  stant/aarch64-hassio-dns with version 1 - 172.30.32.3
20-03-31 03:10:24 WARNING (MainThread) [supervisor.tasks] Watchdog found a probl  em with CoreDNS plugin!
20-03-31 03:10:24 ERROR (MainThread) [supervisor.tasks] CoreDNS plugin is in fai  ls state / Reset config
20-03-31 03:10:24 INFO (MainThread) [supervisor.dns] Start CoreDNS plugin
20-03-31 03:10:24 INFO (SyncWorker_12) [supervisor.docker.interface] Clean hassi  o_dns application
20-03-31 03:10:25 INFO (SyncWorker_12) [supervisor.docker.dns] Start DNS homeass  istant/aarch64-hassio-dns with version 1 - 172.30.32.3
20-03-31 03:10:44 WARNING (MainThread) [supervisor.tasks] Watchdog found a probl  em with CoreDNS plugin!
20-03-31 03:10:44 ERROR (MainThread) [supervisor.tasks] CoreDNS plugin is in fai  ls state / Reset config
20-03-31 03:10:44 INFO (MainThread) [supervisor.dns] Start CoreDNS plugin
20-03-31 03:10:44 INFO (SyncWorker_16) [supervisor.docker.interface] Clean hassi  o_dns application
20-03-31 03:10:45 INFO (SyncWorker_16) [supervisor.docker.dns] Start DNS homeass  istant/aarch64-hassio-dns with version 1 - 172.30.32.3
20-03-31 03:11:04 WARNING (MainThread) [supervisor.tasks] Watchdog found a probl  em with CoreDNS plugin!
20-03-31 03:11:04 ERROR (MainThread) [supervisor.tasks] CoreDNS plugin is in fai  ls state / Reset config
20-03-31 03:11:04 INFO (MainThread) [supervisor.dns] Start CoreDNS plugin
20-03-31 03:11:04 INFO (SyncWorker_0) [supervisor.docker.interface] Clean hassio  _dns application
20-03-31 03:11:05 INFO (SyncWorker_0) [supervisor.docker.dns] Start DNS homeassi  stant/aarch64-hassio-dns with version 1 - 172.30.32.3
20-03-31 03:11:24 WARNING (MainThread) [supervisor.tasks] Watchdog found a probl  em with CoreDNS plugin!
20-03-31 03:11:24 ERROR (MainThread) [supervisor.tasks] CoreDNS plugin is in fai  ls state / Reset config
20-03-31 03:11:24 INFO (MainThread) [supervisor.dns] Start CoreDNS plugin
20-03-31 03:11:24 INFO (SyncWorker_14) [supervisor.docker.interface] Clean hassi  o_dns application
20-03-31 03:11:25 INFO (SyncWorker_14) [supervisor.docker.dns] Start DNS homeass  istant/aarch64-hassio-dns with version 1 - 172.30.32.3
20-03-31 03:11:44 WARNING (MainThread) [supervisor.tasks] Watchdog found a probl  em with CoreDNS plugin!
20-03-31 03:11:44 ERROR (MainThread) [supervisor.tasks] CoreDNS plugin is in fai  ls state / Reset config
20-03-31 03:11:44 INFO (MainThread) [supervisor.dns] Start CoreDNS plugin
20-03-31 03:11:44 INFO (SyncWorker_15) [supervisor.docker.interface] Clean hassi  o_dns application
20-03-31 03:11:45 INFO (SyncWorker_15) [supervisor.docker.dns] Start DNS homeass  istant/aarch64-hassio-dns with version 1 - 172.30.32.3
20-03-31 03:12:04 WARNING (MainThread) [supervisor.tasks] Watchdog found a probl  em with CoreDNS plugin!
20-03-31 03:12:04 ERROR (MainThread) [supervisor.tasks] CoreDNS plugin is in fai  ls state / Reset config
20-03-31 03:12:04 INFO (MainThread) [supervisor.dns] Start CoreDNS plugin
20-03-31 03:12:04 INFO (SyncWorker_4) [supervisor.docker.interface] Clean hassio  _dns application
20-03-31 03:12:05 INFO (SyncWorker_4) [supervisor.docker.dns] Start DNS homeassi  stant/aarch64-hassio-dns with version 1 - 172.30.32.3
20-03-31 03:12:24 WARNING (MainThread) [supervisor.tasks] Watchdog found a probl  em with CoreDNS plugin!
20-03-31 03:12:24 ERROR (MainThread) [supervisor.tasks] CoreDNS plugin is in fai  ls state / Reset config
20-03-31 03:12:24 INFO (MainThread) [supervisor.dns] Start CoreDNS plugin
20-03-31 03:12:24 INFO (SyncWorker_16) [supervisor.docker.interface] Clean hassi  o_dns application
20-03-31 03:12:25 INFO (SyncWorker_16) [supervisor.docker.dns] Start DNS homeass  istant/aarch64-hassio-dns with version 1 - 172.30.32.3
20-03-31 03:12:44 WARNING (MainThread) [supervisor.tasks] Watchdog found a probl  em with CoreDNS plugin!
20-03-31 03:12:44 ERROR (MainThread) [supervisor.tasks] CoreDNS plugin is in fai  ls state / Reset config
20-03-31 03:12:44 INFO (MainThread) [supervisor.dns] Start CoreDNS plugin
20-03-31 03:12:44 INFO (SyncWorker_8) [supervisor.docker.interface] Clean hassio  _dns application
20-03-31 03:12:45 INFO (SyncWorker_8) [supervisor.docker.dns] Start DNS homeassi  stant/aarch64-hassio-dns with version 1 - 172.30.32.3
20-03-31 03:13:04 WARNING (MainThread) [supervisor.tasks] Watchdog found a probl  em with CoreDNS plugin!
20-03-31 03:13:04 ERROR (MainThread) [supervisor.tasks] CoreDNS plugin is in fai  ls state / Reset config
20-03-31 03:13:04 INFO (SyncWorker_4) [supervisor.docker.interface] Clean hassio  _dns application
20-03-31 03:13:05 INFO (SyncWorker_4) [supervisor.docker.dns] Start DNS homeassi  stant/aarch64-hassio-dns with version 1 - 172.30.32.3
########################### homeassistant log ###########################
Error: No such container: homeassistant
 homeassistant 启动超时,请检查上方日志....或者重启操作系统
 相关问题可以访问https://bbs.iobroker.cn或者加QQ群776817275咨询
root@aml:~#
发表于 2020-3-31 19:39:05 | 显示全部楼层
为何这个天气不能出来,而且开始注册的时候,位置也检测不到的。
发表于 2020-3-31 20:07:13 | 显示全部楼层
root@aml:~# wget https://code.aliyun.com/neroxps/ ... w/master/install.sh
--2020-03-31 12:04:15--  https://code.aliyun.com/neroxps/ ... w/master/install.sh
正在解析主机 code.aliyun.com (code.aliyun.com)... 120.55.150.20
正在连接 code.aliyun.com (code.aliyun.com)|120.55.150.20|:443... 已连接。
已发出 HTTP 请求,正在等待回应... 200 OK
长度:未指定 [text/plain]
正在保存至: “install.sh.3”
install.sh.3            [ <=>                ]  22.12K  --.-KB/s    in 0.01s
2020-03-31 12:04:16 (2.09 MB/s) - “install.sh.3” 已保存 [22653]
root@aml:~# chmod a+x install.sh.3
root@aml:~# ./install.sh.3
(1). 是否将系统源切换为中科大(USTC)源(目前支持 Debian Ubuntu Raspbian 三款系统)
请输入 y or n(默认 yes):y
(2). 找到该系统中有以下用户名
如下方列表未显示你的用户名,请切换回你用户账号后输入 sudo usermod -aG docker $USER 添加用户到 docker 用户组。
    [1]: zqf
    [2]: openmediavault-webgui
    [3]: admin
    : 跳过
请输入你需要使用 docker 的用户名序号,以加入 docker 用户组:1
将zqf用户添加至 docker 用户组。
(3).是否需要替换 docker 默认源?
请输入 yes 或者 no(默认:yes):y
(4).请选择你设备类型(默认:qemux86-64)
    [1]: intel-nuc: 英特尔的nuc小主机
    [2]: odroid-c2: 韩国odroid-c2
    [3]: odroid-xu: 韩国odroid-xu
    [4]: orangepi-prime: 香橙派
    [5]: qemuarm-64: 通用arm设备(例如斐讯N1) 64位系统
    [6]: qemux86-64: 通用X86(普通的PC机电脑)64位系统
    [7]: raspberrypi3-64: 树莓派三代64位系统
    [8]: raspberrypi4-64: 树莓派四代64位系统
    [9]: tinker: 华硕tinker
输入数字 (1-9):5
你选择了 qemuarm-64
(5).是否需要设置 hassio 数据保存路径(默认:/usr/share/hassio)
请输入 yes 或 no (默认:no):n
hassio 数据路径为默认路径: /usr/share/hassio
# 1. 是否将系统源切换为中科大(USTC)源: 是
# 2. 是否将用户添加至 Docker 用户组:   是,添加用户为 zqf
# 3. 是否将 Docker 源切换至国内源:     是,切换源选择:
# 4. 您的设备类型为:                   qemuarm-64
# 5. 您的 hassio 数据路径为:           /usr/share/hassio
请确认以上信息,继续请按任意键,如需修改请输入 Ctrl+C 结束任务重新执行脚本。
[info]: 切换系统网络源.....
################# 发到论坛时,请把上方日志也一并粘贴发送 ################
Distributor ID: Debian
Description:    Debian GNU/Linux 9.12 (stretch)
Release:        9.12
Codename:       stretch
Linux version 4.18.7-aml-s9xxx (root@vbox) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #7 SMP PREEMPT Fri Oct 12 11:05:04 MSK 2018
Linux aml 4.18.7-aml-s9xxx #7 SMP PREEMPT Fri Oct 12 11:05:04 MSK 2018 aarch64 GNU/Linux
\033[0;33m [ERROR]: 由于无法确定系统版本,故请手动切换系统源,切换方法参考中科大源使用方法:http://mirrors.ustc.edu.cn/help/\033[0m
root@aml:~#
求教了
发表于 2020-3-31 22:09:22 | 显示全部楼层
neroxps 发表于 2020-3-30 12:18
什么叫挂上??
就是homeassistant镜像有下载,没安装上。手动装上边栏不显示hassio日志报hassio错误。用ubuntu、debian,树莓派都试过,都是一样homeassistant没装上。安装日志报插件安装错误。
 楼主| 发表于 2020-3-31 22:15:44 | 显示全部楼层
ruianyu 发表于 2020-3-31 22:09
就是homeassistant镜像有下载,没安装上。手动装上边栏不显示hassio日志报hassio错误。用ubuntu、debian ...
明天有空群里找我 Nero
 楼主| 发表于 2020-4-1 08:35:07 | 显示全部楼层
看了下hassio 的代码,感觉是 docker pull 容器下来不行,最近试了下,七牛云的 docker 源很慢,试试换一下源。
cat << EOF > /etc/docker/daemon.json
    "registry-mirrors": [
    "https://dockerhub.azk8s.cn",
    "https://reg-mirror.qiniu.com",
    "https://hub-mirror.c.163.com",
    "https://docker.mirrors.ustc.edu.cn"
EOF
systemctl daemon-reload
root 执行上方命令,重启系统。
GMT+8, 2025-12-27 19:37 , Processed in 1.788765 second(s), 19 queries , MemCached On.
