楼主: neroxps
HASSIO 安装一键脚本
 火...   [复制链接]
发表于 2020-3-21 17:04:48 | 显示全部楼层
更新版本要怎么操作呢?N1
发表于 2020-3-23 09:01:44 | 显示全部楼层
################# 发到论坛时,请把上方日志也一并粘贴发送 ################
Distributor ID: Debian
Description:    Debian GNU/Linux 9.12 (stretch)
Release:        9.12
Codename:       stretch
Linux version 4.18.7-aml-s9xxx (root@vbox) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #7 SMP PREEMPT Fri Oct 12 11:05:04 MSK 2018
Linux aml 4.18.7-aml-s9xxx #7 SMP PREEMPT Fri Oct 12 11:05:04 MSK 2018 aarch64 GNU/Linux
\033[0;31m[ERROR]: 安装curl失败,请将检查上方安装错误信息。\033[0m
大神帮忙看下
 楼主| 发表于 2020-3-23 09:47:40 | 显示全部楼层
一般是网络问题
发表于 2020-3-23 11:13:47 | 显示全部楼层
一般是网络问题 ...
收到 感谢大神  我多试几次
发表于 2020-3-23 20:21:27 | 显示全部楼层
开始 hassio 安装流程。(如出现 [Warning] 请忽略,无须理会)
[Warning] No NetworkManager support on host.
[Info] Install supervisor Docker container
[Info] Install supervisor startup scripts
[Info] Install AppArmor scripts
[Info] Run Hass.io
等待 homeassistant 启动.............................................................................................................................................................................................................................................................................................................fail
########################### Docker images ###########################
REPOSITORY                                TAG                 IMAGE ID            CREATED             SIZE
homeassistant/raspberrypi-homeassistant   0.107.5             370d858dea29        34 hours ago        1.2GB
homeassistant/raspberrypi-homeassistant   latest              370d858dea29        34 hours ago        1.2GB
portainer/portainer                       linux-arm           b8b5ab8daaea        3 days ago          62MB
homeassistant/armhf-hassio-audio          9                   ddc58f1467e5        12 days ago         52.6MB
homeassistant/armhf-hassio-supervisor     209                 e3a7ae3e353d        2 weeks ago         255MB
homeassistant/armhf-hassio-supervisor     latest              e3a7ae3e353d        2 weeks ago         255MB
homeassistant/armhf-hassio-dns            1                   eec1cac70916        7 months ago        53.6MB
########################### Docker ps ###########################
CONTAINER ID        IMAGE                                             COMMAND                  CREATED             STATUS                          PORTS               NAMES
eb8b0956142f        homeassistant/armhf-hassio-audio:9                "/init"                  9 minutes ago       Up 18 seconds                                       hassio_audio
369c185f4515        homeassistant/armhf-hassio-dns:1                  "coredns -conf /conf…"   9 minutes ago       Up About a minute                                   hassio_dns
35caf91557f8        homeassistant/raspberrypi-homeassistant:0.107.5   "/init"                  41 minutes ago      Exited (255) 12 minutes ago                         homeassistant
b4a21c416d98        homeassistant/armhf-hassio-supervisor             "/init"                  2 hours ago         Up 10 minutes                                       hassio_supervisor
7ffb2c16ee45        portainer/portainer:linux-arm                     "/portainer"             3 hours ago         Restarting (1) 22 seconds ago                       great_kapitsa
########################### hassio log ###########################
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] udev.sh: executing...
[10:40:23] INFO: Update udev informations
[cont-init.d] udev.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
20-03-23 10:41:17 INFO (MainThread) [__main__] Initialize Supervisor setup
20-03-23 10:41:22 INFO (MainThread) [supervisor.docker.network] Can't find Supervisor network, create new network
20-03-23 10:41:26 INFO (MainThread) [supervisor.bootstrap] Create Home Assistant configuration folder /data/homeassistant
20-03-23 10:41:26 INFO (MainThread) [supervisor.bootstrap] Create Supervisor SSL/TLS folder /data/ssl
20-03-23 10:41:26 INFO (MainThread) [supervisor.bootstrap] Create Supervisor Add-on data folder /data/addons/data
20-03-23 10:41:26 INFO (MainThread) [supervisor.bootstrap] Create Supervisor Add-on local repository folder /data/addons/local
20-03-23 10:41:26 INFO (MainThread) [supervisor.bootstrap] Create Supervisor Add-on git repositories folder /data/addons/git
20-03-23 10:41:26 INFO (MainThread) [supervisor.bootstrap] Create Supervisor temp folder /data/tmp
20-03-23 10:41:26 INFO (MainThread) [supervisor.bootstrap] Create Supervisor backup folder /data/backup
20-03-23 10:41:26 INFO (MainThread) [supervisor.bootstrap] Create Supervisor share folder /data/share
20-03-23 10:41:26 INFO (MainThread) [supervisor.bootstrap] Create Supervisor DNS folder /data/dns
20-03-23 10:41:26 INFO (MainThread) [supervisor.bootstrap] Create Supervisor audio folder /data/audio
20-03-23 10:41:30 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attach to Supervisor homeassistant/armhf-hassio-supervisor with version 209
20-03-23 10:41:30 INFO (SyncWorker_0) [supervisor.docker.supervisor] Connect Supervisor to hassio Network
20-03-23 10:44:09 INFO (MainThread) [__main__] Setup Supervisor
20-03-23 10:44:10 INFO (MainThread) [supervisor.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
20-03-23 10:44:12 INFO (MainThread) [supervisor.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
20-03-23 10:44:13 WARNING (MainThread) [supervisor.dbus.rauc] Host has no rauc support. OTA updates have been disabled.
20-03-23 10:44:13 WARNING (MainThread) [supervisor.dbus.nmi_dns] No DnsManager support on the host. Local DNS functions have been disabled.
20-03-23 10:44:13 INFO (MainThread) [supervisor.host.info] Update local host information
20-03-23 10:44:13 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-03-23 10:44:13 INFO (MainThread) [supervisor.host.services] Update service information
20-03-23 10:44:13 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-03-23 10:44:15 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
20-03-23 10:44:15 INFO (MainThread) [supervisor.host.apparmor] Load AppArmor Profiles: {'hassio-supervisor'}
20-03-23 10:44:15 INFO (MainThread) [supervisor.host.services] Reload local service hassio-apparmor.service
20-03-23 10:44:15 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ReloadOrRestartUnit on /org/freedesktop/systemd1
20-03-23 10:44:16 INFO (MainThread) [supervisor.dns] No CoreDNS plugin Docker image homeassistant/armhf-hassio-dns found.
20-03-23 10:44:16 INFO (MainThread) [supervisor.dns] Setup CoreDNS plugin
20-03-23 10:44:16 INFO (SyncWorker_3) [supervisor.docker.interface] Pull image homeassistant/armhf-hassio-dns tag 1.
20-03-23 10:44:16 INFO (MainThread) [supervisor.audio] No Audio plugin Docker image homeassistant/armhf-hassio-audio found.
20-03-23 10:44:16 INFO (MainThread) [supervisor.audio] Setup Audio plugin
20-03-23 10:44:16 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-03-23 10:44:21 INFO (SyncWorker_4) [supervisor.docker.interface] Pull image homeassistant/armhf-hassio-audio tag 9.
20-03-23 10:45:02 ERROR (SyncWorker_3) [supervisor.docker.interface] Can't install homeassistant/armhf-hassio-dns:1 -> 404 Client Error: Not Found ("no such image: homeassistant/armhf-hassio-dns:1: No such image: homeassistant/armhf-hassio-dns:1").
20-03-23 10:45:02 WARNING (MainThread) [supervisor.dns] Error on install CoreDNS plugin. Retry in 30sec
20-03-23 10:45:14 ERROR (SyncWorker_4) [supervisor.docker.interface] Can't install homeassistant/armhf-hassio-audio:9 -> 404 Client Error: Not Found ("no such image: homeassistant/armhf-hassio-audio:9: No such image: homeassistant/armhf-hassio-audio:9").
20-03-23 10:45:14 WARNING (MainThread) [supervisor.audio] Error on install Audio plugin. Retry in 30sec
20-03-23 10:45:32 INFO (SyncWorker_0) [supervisor.docker.interface] Pull image homeassistant/armhf-hassio-dns tag 1.
s6-svscanctl: fatal: unable to control /var/run/s6/services: supervisor not listening
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
[fix-attrs.d] done.
[10:49:13] INFO: Update udev informations
[cont-init.d] done.
[services.d] done.
20-03-23 10:49:51 INFO (MainThread) [__main__] Initialize Supervisor setup
20-03-23 10:49:53 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attach to Supervisor homeassistant/armhf-hassio-supervisor with version 209
20-03-23 10:49:54 INFO (MainThread) [__main__] Setup Supervisor
20-03-23 10:49:54 INFO (MainThread) [supervisor.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
20-03-23 10:49:55 INFO (MainThread) [supervisor.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
20-03-23 10:49:56 WARNING (MainThread) [supervisor.dbus.rauc] Host has no rauc support. OTA updates have been disabled.
20-03-23 10:49:56 WARNING (MainThread) [supervisor.dbus.nmi_dns] No DnsManager support on the host. Local DNS functions have been disabled.
20-03-23 10:49:56 INFO (MainThread) [supervisor.host.info] Update local host information
20-03-23 10:49:56 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-03-23 10:49:56 INFO (MainThread) [supervisor.host.services] Update service information
20-03-23 10:49:56 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-03-23 10:49:57 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
20-03-23 10:49:58 INFO (MainThread) [supervisor.host.apparmor] Load AppArmor Profiles: {'hassio-supervisor'}
20-03-23 10:49:58 INFO (MainThread) [supervisor.host.services] Reload local service hassio-apparmor.service
20-03-23 10:49:58 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ReloadOrRestartUnit on /org/freedesktop/systemd1
20-03-23 10:49:58 INFO (MainThread) [supervisor.dns] No CoreDNS plugin Docker image homeassistant/armhf-hassio-dns found.
20-03-23 10:49:58 INFO (MainThread) [supervisor.dns] Setup CoreDNS plugin
20-03-23 10:49:58 INFO (SyncWorker_3) [supervisor.docker.interface] Pull image homeassistant/armhf-hassio-dns tag 1.
20-03-23 10:49:59 INFO (MainThread) [supervisor.audio] No Audio plugin Docker image homeassistant/armhf-hassio-audio found.
20-03-23 10:49:59 INFO (MainThread) [supervisor.audio] Setup Audio plugin
20-03-23 10:49:59 INFO (SyncWorker_4) [supervisor.docker.interface] Pull image homeassistant/armhf-hassio-audio tag 9.
20-03-23 10:53:12 INFO (MainThread) [supervisor.audio] Audio plugin now installed
20-03-23 10:53:12 INFO (MainThread) [supervisor.audio] Start Audio plugin
[fix-attrs.d] done.
[11:10:40] INFO: Update udev informations
[cont-init.d] done.
[services.d] done.
20-03-23 11:11:53 INFO (MainThread) [__main__] Initialize Supervisor setup
20-03-23 11:11:56 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attach to Supervisor homeassistant/armhf-hassio-supervisor with version 209
20-03-23 11:11:57 INFO (MainThread) [__main__] Setup Supervisor
20-03-23 11:11:57 INFO (MainThread) [supervisor.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
20-03-23 11:11:59 INFO (MainThread) [supervisor.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
20-03-23 11:12:00 WARNING (MainThread) [supervisor.dbus.rauc] Host has no rauc support. OTA updates have been disabled.
20-03-23 11:12:00 WARNING (MainThread) [supervisor.dbus.nmi_dns] No DnsManager support on the host. Local DNS functions have been disabled.
20-03-23 11:12:00 INFO (MainThread) [supervisor.host.info] Update local host information
20-03-23 11:12:00 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-03-23 11:12:01 INFO (MainThread) [supervisor.host.services] Update service information
20-03-23 11:12:01 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-03-23 11:12:03 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
20-03-23 11:12:03 INFO (MainThread) [supervisor.host.apparmor] Load AppArmor Profiles: {'hassio-supervisor'}
20-03-23 11:12:03 INFO (MainThread) [supervisor.host.services] Reload local service hassio-apparmor.service
20-03-23 11:12:03 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ReloadOrRestartUnit on /org/freedesktop/systemd1
20-03-23 11:12:09 INFO (MainThread) [supervisor.dns] No CoreDNS plugin Docker image homeassistant/armhf-hassio-dns found.
20-03-23 11:12:09 INFO (MainThread) [supervisor.dns] Setup CoreDNS plugin
20-03-23 11:12:09 INFO (SyncWorker_1) [supervisor.docker.interface] Attach to homeassistant/armhf-hassio-audio with version 9
20-03-23 11:12:09 INFO (SyncWorker_3) [supervisor.docker.interface] Pull image homeassistant/armhf-hassio-dns tag 1.
20-03-23 11:12:09 INFO (MainThread) [supervisor.audio] Start Audio plugin
20-03-23 11:12:10 INFO (SyncWorker_2) [supervisor.docker.interface] Clean hassio_audio application
20-03-23 11:12:38 ERROR (SyncWorker_3) [supervisor.docker.interface] Can't install homeassistant/armhf-hassio-dns:1 -> 500 Server Error: Internal Server Error ("Get https://registry-1.docker.io/v2/: net/http: TLS handshake timeout").
20-03-23 11:12:38 WARNING (MainThread) [supervisor.dns] Error on install CoreDNS plugin. Retry in 30sec
20-03-23 11:13:03 INFO (SyncWorker_2) [supervisor.docker.audio] Start Audio homeassistant/armhf-hassio-audio with version 9 - 172.30.32.4
20-03-23 11:13:08 INFO (SyncWorker_0) [supervisor.docker.interface] Pull image homeassistant/armhf-hassio-dns tag 1.
20-03-23 11:14:10 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install homeassistant/armhf-hassio-dns:1 -> 404 Client Error: Not Found ("no such image: homeassistant/armhf-hassio-dns:1: No such image: homeassistant/armhf-hassio-dns:1").
20-03-23 11:14:10 WARNING (MainThread) [supervisor.dns] Error on install CoreDNS plugin. Retry in 30sec
[fix-attrs.d] done.
[11:16:54] INFO: Update udev informations
[cont-init.d] done.
[services.d] done.
20-03-23 11:17:38 INFO (MainThread) [__main__] Initialize Supervisor setup
20-03-23 11:17:40 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attach to Supervisor homeassistant/armhf-hassio-supervisor with version 209
20-03-23 11:17:42 INFO (MainThread) [__main__] Setup Supervisor
20-03-23 11:17:46 INFO (MainThread) [supervisor.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
20-03-23 11:17:49 ERROR (MainThread) [supervisor.utils.gdbus] DBus return error: Error: Timeout was reached
20-03-23 11:17:49 WARNING (MainThread) [supervisor.dbus.hostname] Can't connect to hostname
20-03-23 11:17:49 WARNING (MainThread) [supervisor.dbus.rauc] Host has no rauc support. OTA updates have been disabled.
20-03-23 11:17:49 WARNING (MainThread) [supervisor.dbus.nmi_dns] No DnsManager support on the host. Local DNS functions have been disabled.
20-03-23 11:17:49 INFO (MainThread) [supervisor.host.services] Update service information
20-03-23 11:17:49 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-03-23 11:17:57 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
20-03-23 11:17:57 INFO (MainThread) [supervisor.host.apparmor] Load AppArmor Profiles: {'hassio-supervisor'}
20-03-23 11:17:57 INFO (MainThread) [supervisor.host.services] Reload local service hassio-apparmor.service
20-03-23 11:17:57 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ReloadOrRestartUnit on /org/freedesktop/systemd1
20-03-23 11:17:58 INFO (MainThread) [supervisor.dns] No CoreDNS plugin Docker image homeassistant/armhf-hassio-dns found.
20-03-23 11:17:58 INFO (MainThread) [supervisor.dns] Setup CoreDNS plugin
20-03-23 11:17:58 INFO (SyncWorker_3) [supervisor.docker.interface] Pull image homeassistant/armhf-hassio-dns tag 1.
20-03-23 11:17:58 INFO (SyncWorker_0) [supervisor.docker.interface] Attach to homeassistant/armhf-hassio-audio with version 9
20-03-23 11:17:59 INFO (MainThread) [supervisor.audio] Start Audio plugin
20-03-23 11:17:59 INFO (SyncWorker_2) [supervisor.docker.interface] Clean hassio_audio application
20-03-23 11:18:38 ERROR (SyncWorker_3) [supervisor.docker.interface] Can't install homeassistant/armhf-hassio-dns:1 -> 404 Client Error: Not Found ("no such image: homeassistant/armhf-hassio-dns:1: No such image: homeassistant/armhf-hassio-dns:1").
20-03-23 11:18:38 WARNING (MainThread) [supervisor.dns] Error on install CoreDNS plugin. Retry in 30sec
20-03-23 11:18:55 INFO (SyncWorker_2) [supervisor.docker.audio] Start Audio homeassistant/armhf-hassio-audio with version 9 - 172.30.32.4
20-03-23 11:19:08 INFO (SyncWorker_1) [supervisor.docker.interface] Pull image homeassistant/armhf-hassio-dns tag 1.
20-03-23 11:26:53 INFO (MainThread) [supervisor.dns] CoreDNS plugin now installed
20-03-23 11:26:55 INFO (MainThread) [supervisor.misc.forwarder] Start DNS port forwarding to 172.30.32.3
20-03-23 11:26:56 INFO (MainThread) [supervisor.dns] Start CoreDNS plugin
20-03-23 11:30:14 INFO (SyncWorker_2) [supervisor.docker.dns] Start DNS homeassistant/armhf-hassio-dns with version 1 - 172.30.32.3
20-03-23 11:30:17 INFO (SyncWorker_0) [supervisor.docker.interface] Attach to homeassistant/raspberrypi-homeassistant with version 0.107.5
20-03-23 11:30:18 INFO (MainThread) [supervisor.store.git] Clone add-on https://github.com/hassio-addons/repository repository
20-03-23 11:30:18 INFO (MainThread) [supervisor.store.git] Clone add-on https://github.com/home-assistant/hassio-addons repository
20-03-23 11:35:50 INFO (MainThread) [supervisor.store] Load add-ons from store: 65 all - 65 new - 0 remove
20-03-23 11:35:51 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
20-03-23 11:35:56 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-03-23 11:36:13 WARNING (MainThread) [supervisor.updater] Can't fetch versions from https://version.home-assistant.io/stable.json:
20-03-23 11:36:16 INFO (MainThread) [supervisor.snapshots] Found 0 snapshot files
20-03-23 11:36:16 INFO (MainThread) [supervisor.discovery] Load 0 messages
20-03-23 11:36:16 INFO (MainThread) [supervisor.ingress] Load 0 ingress session
20-03-23 11:36:18 INFO (MainThread) [supervisor.secrets] Load Home Assistant secrets: 0
20-03-23 11:36:18 INFO (MainThread) [__main__] Run Supervisor
20-03-23 11:36:19 INFO (MainThread) [supervisor.api] Start API on 172.30.32.2
20-03-23 11:36:19 INFO (MainThread) [supervisor.addons] Phase 'initialize' start 0 add-ons
20-03-23 11:36:19 INFO (MainThread) [supervisor.addons] Phase 'system' start 0 add-ons
20-03-23 11:36:19 INFO (MainThread) [supervisor.addons] Phase 'services' start 0 add-ons
20-03-23 11:36:24 INFO (MainThread) [supervisor.homeassistant] Update pulse/client.config: /data/tmp/homeassistant_pulse
20-03-23 11:45:39 INFO (SyncWorker_0) [supervisor.docker.homeassistant] Start homeassistant homeassistant/raspberrypi-homeassistant with version 0.107.5
[fix-attrs.d] done.
[11:54:55] INFO: Update udev informations
[cont-init.d] done.
[services.d] done.
20-03-23 11:55:33 INFO (MainThread) [__main__] Initialize Supervisor setup
20-03-23 11:55:36 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attach to Supervisor homeassistant/armhf-hassio-supervisor with version 209
20-03-23 11:55:37 INFO (MainThread) [__main__] Setup Supervisor
20-03-23 11:55:37 INFO (MainThread) [supervisor.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
20-03-23 11:55:38 INFO (MainThread) [supervisor.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
20-03-23 11:55:38 WARNING (MainThread) [supervisor.dbus.rauc] Host has no rauc support. OTA updates have been disabled.
20-03-23 11:55:39 WARNING (MainThread) [supervisor.dbus.nmi_dns] No DnsManager support on the host. Local DNS functions have been disabled.
20-03-23 11:55:39 INFO (MainThread) [supervisor.host.info] Update local host information
20-03-23 11:55:39 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-03-23 11:55:39 INFO (MainThread) [supervisor.host.services] Update service information
20-03-23 11:55:39 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-03-23 11:55:40 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
20-03-23 11:55:40 INFO (MainThread) [supervisor.host.apparmor] Load AppArmor Profiles: {'hassio-supervisor'}
20-03-23 11:55:40 INFO (MainThread) [supervisor.host.services] Reload local service hassio-apparmor.service
20-03-23 11:55:40 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ReloadOrRestartUnit on /org/freedesktop/systemd1
20-03-23 11:55:41 INFO (SyncWorker_1) [supervisor.docker.interface] Attach to homeassistant/armhf-hassio-audio with version 9
20-03-23 11:55:41 INFO (SyncWorker_0) [supervisor.docker.interface] Attach to homeassistant/armhf-hassio-dns with version 1
20-03-23 11:55:44 INFO (MainThread) [supervisor.misc.forwarder] Start DNS port forwarding to 172.30.32.3
20-03-23 11:55:44 INFO (MainThread) [supervisor.audio] Start Audio plugin
20-03-23 11:55:44 INFO (SyncWorker_2) [supervisor.docker.interface] Clean hassio_audio application
20-03-23 11:55:45 INFO (MainThread) [supervisor.dns] Start CoreDNS plugin
20-03-23 11:55:45 INFO (SyncWorker_1) [supervisor.docker.interface] Clean hassio_dns application
20-03-23 11:56:56 INFO (SyncWorker_1) [supervisor.docker.dns] Start DNS homeassistant/armhf-hassio-dns with version 1 - 172.30.32.3
20-03-23 11:56:56 INFO (SyncWorker_2) [supervisor.docker.audio] Start Audio homeassistant/armhf-hassio-audio with version 9 - 172.30.32.4
20-03-23 11:56:57 INFO (SyncWorker_0) [supervisor.docker.interface] Attach to homeassistant/raspberrypi-homeassistant with version 0.107.5
20-03-23 11:57:04 INFO (MainThread) [supervisor.store.git] Load add-on /data/addons/core repository
20-03-23 11:57:05 INFO (MainThread) [supervisor.store.git] Load add-on /data/addons/git/a0d7b954 repository
20-03-23 11:57:10 INFO (MainThread) [supervisor.store] Load add-ons from store: 65 all - 65 new - 0 remove
20-03-23 11:57:10 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
20-03-23 11:57:11 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-03-23 11:57:14 INFO (MainThread) [supervisor.snapshots] Found 0 snapshot files
20-03-23 11:57:14 INFO (MainThread) [supervisor.discovery] Load 0 messages
20-03-23 11:57:14 INFO (MainThread) [supervisor.ingress] Load 0 ingress session
20-03-23 11:57:14 INFO (MainThread) [supervisor.secrets] Load Home Assistant secrets: 0
20-03-23 11:57:14 INFO (MainThread) [__main__] Run Supervisor
20-03-23 11:57:14 INFO (MainThread) [supervisor.api] Start API on 172.30.32.2
20-03-23 11:57:14 INFO (MainThread) [supervisor.addons] Phase 'initialize' start 0 add-ons
20-03-23 11:57:14 INFO (MainThread) [supervisor.addons] Phase 'system' start 0 add-ons
20-03-23 11:57:14 INFO (MainThread) [supervisor.addons] Phase 'services' start 0 add-ons
20-03-23 11:57:14 INFO (SyncWorker_0) [supervisor.docker.interface] Start homeassistant/raspberrypi-homeassistant
20-03-23 12:03:38 INFO (MainThread) [__main__] Stopping Supervisor
20-03-23 12:03:39 INFO (MainThread) [supervisor.api] Stop API on 172.30.32.2
20-03-23 12:03:39 INFO (MainThread) [supervisor.misc.forwarder] Stop DNS forwarding
20-03-23 12:03:39 INFO (MainThread) [supervisor.core] Supervisor is down
20-03-23 12:03:39 INFO (MainThread) [__main__] Close Supervisor
20-03-23 12:03:41 ERROR (MainThread) [asyncio] Task was destroyed but it is pending!
task: <Task pending coro=<Core.start() running at /usr/src/supervisor/supervisor/core.py:127> wait_for=<Future pending cb=[<TaskWakeupMethWrapper object at 0xb2802190>()]>>
s6-svwait: fatal: timed out
[fix-attrs.d] done.
[12:06:55] INFO: Update udev informations
[cont-init.d] done.
[services.d] done.
20-03-23 12:07:59 INFO (MainThread) [__main__] Initialize Supervisor setup
20-03-23 12:08:01 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attach to Supervisor homeassistant/armhf-hassio-supervisor with version 209
20-03-23 12:08:02 INFO (MainThread) [__main__] Setup Supervisor
20-03-23 12:08:02 INFO (MainThread) [supervisor.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
20-03-23 12:08:03 INFO (MainThread) [supervisor.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
20-03-23 12:08:04 WARNING (MainThread) [supervisor.dbus.rauc] Host has no rauc support. OTA updates have been disabled.
20-03-23 12:08:04 WARNING (MainThread) [supervisor.dbus.nmi_dns] No DnsManager support on the host. Local DNS functions have been disabled.
20-03-23 12:08:04 INFO (MainThread) [supervisor.host.info] Update local host information
20-03-23 12:08:04 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-03-23 12:08:04 INFO (MainThread) [supervisor.host.services] Update service information
20-03-23 12:08:04 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-03-23 12:08:06 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
20-03-23 12:08:06 INFO (MainThread) [supervisor.host.apparmor] Load AppArmor Profiles: {'hassio-supervisor'}
20-03-23 12:08:06 INFO (MainThread) [supervisor.host.services] Reload local service hassio-apparmor.service
20-03-23 12:08:06 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ReloadOrRestartUnit on /org/freedesktop/systemd1
20-03-23 12:08:07 INFO (SyncWorker_0) [supervisor.docker.interface] Attach to homeassistant/armhf-hassio-dns with version 1
20-03-23 12:08:07 INFO (SyncWorker_1) [supervisor.docker.interface] Attach to homeassistant/armhf-hassio-audio with version 9
20-03-23 12:08:07 INFO (MainThread) [supervisor.misc.forwarder] Start DNS port forwarding to 172.30.32.3
20-03-23 12:08:07 INFO (MainThread) [supervisor.dns] Start CoreDNS plugin
20-03-23 12:08:07 INFO (MainThread) [supervisor.audio] Start Audio plugin
20-03-23 12:08:08 INFO (SyncWorker_1) [supervisor.docker.interface] Clean hassio_dns application
20-03-23 12:08:08 INFO (SyncWorker_0) [supervisor.docker.interface] Clean hassio_audio application
20-03-23 12:15:48 INFO (SyncWorker_1) [supervisor.docker.dns] Start DNS homeassistant/armhf-hassio-dns with version 1 - 172.30.32.3
20-03-23 12:17:07 INFO (SyncWorker_0) [supervisor.docker.audio] Start Audio homeassistant/armhf-hassio-audio with version 9 - 172.30.32.4
20-03-23 12:17:20 INFO (SyncWorker_4) [supervisor.docker.interface] Attach to homeassistant/raspberrypi-homeassistant with version 0.107.5
########################### homeassistant log ###########################
[fix-attrs.d] done.
[19:45:50] INFO: Update udev information
[cont-init.d] udev.sh: exited 1.
homeassistant 启动超时,请检查上方日志....或者重启操作系统
N大你好,我用这个脚本运行在树莓派b+上,显示等待homeassistant启动,然后显示启动失败,能否告诉我这个怎么解决呢?
 楼主| 发表于 2020-3-23 20:42:49 | 显示全部楼层
[Warning] No NetworkManager support on hos ...
没什么 就是慢等吧。
发表于 2020-3-24 10:11:35 | 显示全部楼层
安装好以后又有一个启动超时是错在什么地方
 楼主| 发表于 2020-3-24 10:54:56 | 显示全部楼层
选错架构。
发表于 2020-3-24 17:33:42 | 显示全部楼层
谢谢了,确实应该选树莓派3的
发表于 2020-3-25 10:59:48 | 显示全部楼层
20-03-25 02:57:39 ERROR (SyncWorker_4) [supervisor.docker] Can't create containe              r from hassio_audio: 409 Client Error: Conflict ("Conflict. The container name "              /hassio_audio" is already in use by container "00294a33e5332b3e9744ea7483b431fc4              71f6cb16bd01f4e026ff6df8a21cc31". You have to remove (or rename) that container               to be able to reuse that name.")
20-03-25 02:57:39 ERROR (MainThread) [supervisor.audio] Can't start Audio plugin
20-03-25 02:58:03 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't insta              ll homeassistant/aarch64-hassio-dns:1 -> 500 Server Error: Internal Server Error               ("readlink /var/lib/docker/overlay2/l/GD2YFQMWLN6MGAM6GXFKY4NI53: no such file               or directory").
20-03-25 02:58:03 WARNING (MainThread) [supervisor.dns] Error on install CoreDNS               plugin. Retry in 30sec
20-03-25 02:58:33 INFO (SyncWorker_1) [supervisor.docker.interface] Pull image h              omeassistant/aarch64-hassio-dns tag 1.
大神,之前安装好了,最近8123登陆不进去,看日志显示这个,是怎么回事呀?
GMT+8, 2025-12-18 21:24 , Processed in 1.421881 second(s), 14 queries , MemCached On.
