楼主: 冬瓜HA
树莓派3、4、5之冬瓜HAOS的16.3.2版推出
 火.. [复制链接]
发表于 2024-8-20 20:45:39 | 显示全部楼层
冬瓜HA 发表于 2024-8-20 12:23
addons不同,加载方式不同。原则上,addons上有sda之类的,就可以配置挂载U盘之类的 ...
就是冬瓜精选里的nextcloud,先感谢哈,上次成功安上MariaDB了,Nextcloud也跑起来了,但系统里只显示内存卡,没有外接的硬盘或优盘……
发表于 2024-8-21 22:01:53 | 显示全部楼层
冬瓜HA 发表于 2024-8-20 19:57
冬瓜HAOS:树莓派3、4、5更新至12.4.1!!!
冬瓜大佬,请教一下,我是在树莓派4b上直接安装的12.4.1,不是升级上来的。遇到了这样的问题。首先是:[supervisor.core] System running in a unsupported environment! 不知道这个有没有影响,忽略了这个。
其次:[supervisor.addons.addon] Watchdog found addon Advanced SSH & Web Terminal is failed, restarting...
2024-08-21 21:44:25.545 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished name='Task-1227' coro=<Addon.watchdog_container() done, defined at /usr/src/supervisor/supervisor/addons/addon.py:1429> exception=AddonsJobError('Rate limit exceeded, more than 10 calls in 0:30:00')>
  File "/usr/src/supervisor/supervisor/addons/addon.py", line 1443, in watchdog_container
    await self._restart_after_problem(event.state)
  File "/usr/src/supervisor/supervisor/jobs/decorator.py", line 290, in wrapper
    raise on_condition(
supervisor.exceptions.AddonsJobError: Rate limit exceeded, more than 10 calls in 0:30:00
2024-08-21 21:46:33.952 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f9a34fb90>: Failed to establish a new connection: [Errno 101] Network unreachable')': /api/5370612/envelope/
2024-08-21 21:48:49.121 WARNING (sentry-sdk.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f9be9ccb0>: Failed to establish a new connection: [Errno 101] Network unreachable')': /api/5370612/envelope/
2024-08-21 21:49:10.410 INFO (SyncWorker_3) [supervisor.docker.manager] Cleaning addon_fb59d657_ssh application
2024-08-21 21:49:11.041 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on m.fashgh.com/hassio-addons/ssh/aarch64 with version 18.0.0
2024-08-21 21:49:11.111 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.32.1:63249 ssl:default [Connect call failed ('172.30.32.1', 63249)]
2024-08-21 21:49:13.089 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.32.1:63249 ssl:default [Connect call failed ('172.30.32.1', 63249)]
 楼主| 发表于 2024-8-22 18:38:14 | 显示全部楼层
cpz001 发表于 2024-8-21 22:01
冬瓜大佬,请教一下,我是在树莓派4b上直接安装的12.4.1,不是升级上来的。遇到了这样的问题。首先是:[su ...
重启就行
 楼主| 发表于 2024-8-22 18:47:48 | 显示全部楼层
没影响,重启就行了。
发表于 2024-8-25 00:44:46 | 显示全部楼层
微信截图_20240825004303.png 微信截图_20240825004319.png 微信截图_20240825004241.png 机子正常启动着的,但就是打不开页面了……
 楼主| 发表于 2024-8-25 10:23:53 | 显示全部楼层
要等一会,不行你su logs帖上来
发表于 2024-8-25 12:49:46 | 显示全部楼层
发表于 2024-8-25 14:01:54 | 显示全部楼层
冬瓜HA 发表于 2024-8-25 10:23
要等一会,不行你su logs帖上来
等了一整天了,哈,logs截图上来了
发表于 2024-8-25 14:02:59 | 显示全部楼层
就主页面打不开,插件是正常的,我的Nextcloud可以打开……
 楼主| 发表于 2024-8-25 21:07:14 | 显示全部楼层
不应该这样久的。如果不行,你私信我,我远程帮你看一下
GMT+8, 2026-1-13 08:59 , Processed in 0.107601 second(s), 13 queries , MemCached On.
