楼主: 冬瓜HA
树莓派3、4、5之冬瓜HAOS的16.3.2版推出
 火.. [复制链接]
 楼主| 发表于 2024-7-20 01:14:05 | 显示全部楼层
翻滚吧暖菌 发表于 2024-7-19 16:37
不行大佬, 有两个钟了, 页面还是无变化,
私信我吧,我远程看一下。
发表于 2024-7-21 18:02:14 | 显示全部楼层
这个必须要支持!
发表于 2024-7-22 17:46:43 | 显示全部楼层
翻滚吧暖菌 发表于 2024-7-18 16:38
12.4, 看来要换内存卡了, 老版本能启动, 但是似乎也卡在安装上
反馈一下, 我的树莓派4b+A1V30的卡, 显示这个我这边实际上是网络的问题, 公司网络估计有权限, 连接手机wifi重启动就正常了!
发表于 2024-7-23 14:33:49 | 显示全部楼层
树莓派4B,64G卡,刷12.4的系统,卡着不动了
 楼主| 发表于 2024-7-23 14:43:38 | 显示全部楼层
网络关系,没事,断电,重启继续就行
发表于 2024-7-23 16:05:48 | 显示全部楼层
大佬,可以问问这是什么原因嘛,是我哪里操作错误了嘛?
2024-07-23 15:54:53.470 WARNING (MainThread) [supervisor.jobs] 'StoreManager.add_repository' blocked from execution, supervisor needs to be updated first
2024-07-23 15:54:54.873 WARNING (MainThread) [supervisor.jobs] 'AddonManager.install' blocked from execution, supervisor needs to be updated first
2024-07-23 15:54:55.165 WARNING (MainThread) [supervisor.jobs] 'AddonManager.install' blocked from execution, supervisor needs to be updated first
2024-07-23 15:54:55.470 WARNING (MainThread) [supervisor.jobs] 'AddonManager.install' blocked from execution, supervisor needs to be updated first
2024-07-23 15:54:55.744 WARNING (MainThread) [supervisor.jobs] 'AddonManager.install' blocked from execution, supervisor needs to be updated first
2024-07-23 15:54:56.030 WARNING (MainThread) [supervisor.jobs] 'AddonManager.install' blocked from execution, supervisor needs to be updated first
2024-07-23 15:55:04.290 ERROR (MainThread) [supervisor.docker.interface] Can't install ghcr.fastgh.com/home-assistant/aarch64-hassio-supervisor:2024.06.2: 500 Server Error for http+docker://localhost/v1.45/images/create?tag=2024.06.2&fromImage=ghcr.fastgh.com%2Fhome-assistant%2Faarch64-hassio-supervisor&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.fastgh.com/v2/": net/http: TLS handshake timeout")
2024-07-23 15:55:04.291 INFO (MainThread) [supervisor.resolution.module] Create new issue update_failed - supervisor / None
2024-07-23 15:55:04.292 ERROR (MainThread) [supervisor.supervisor] Update of Supervisor failed: Can't install ghcr.fastgh.com/home-assistant/aarch64-hassio-supervisor:2024.06.2: 500 Server Error for http+docker://localhost/v1.45/images/create?tag=2024.06.2&fromImage=ghcr.fastgh.com%2Fhome-assistant%2Faarch64-hassio-supervisor&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.fastgh.com/v2/": net/http: TLS handshake timeout")
2024-07-23 15:55:04.292 CRITICAL (MainThread) [supervisor.core] Can't update Supervisor! This will break some Add-ons or affect future versions of Home Assistant!
树莓派4B,64G卡,刷的也是12.4的系统,进入8123的页面之后,提示“系统不健康 - Supervisor 更新失败”
 楼主| 发表于 2024-7-23 16:34:06 | 显示全部楼层
2024-07-23 15:54:53.470 WARNING (MainThread) [s ...
网络问题
发表于 2024-7-24 09:34:10 | 显示全部楼层
如果想保留树莓派OS,安装是不是就只能装core版,装不了OS版?
 楼主| 发表于 2024-7-24 11:15:10 | 显示全部楼层
ha可以跑supervisor模式,不过得debian才行。否则只你能折腾core
发表于 2024-7-27 19:06:41 | 显示全部楼层
感谢大佬
GMT+8, 2026-1-13 07:35 , Processed in 1.075645 second(s), 13 queries , MemCached On.
