楼主: snowwolf725
[智能音箱] 拆解新买的小爱音箱Pro, 更新固化开机启动 SSH 教学
发表于 2023-11-29 14:23:03 | 显示全部楼层
学习了,感谢分享
发表于 2024-3-1 16:26:29 | 显示全部楼层
学习了,感谢分享
发表于 2024-4-6 17:20:52 | 显示全部楼层
可以在failsave模式下进行升级吗
发表于 2024-4-18 03:07:01 | 显示全部楼层
发表于 2024-4-24 00:05:57 | 显示全部楼层
求助,小米音响pro 1.88.51稳定版可以降级吗,求教程
发表于 2024-4-29 16:10:45 | 显示全部楼层
学习中,期待可以用的哦!
发表于 2024-4-30 03:39:52 | 显示全部楼层
接入ttl老是出现Bluetooth command failed。。。。有大神知道什么情况么?
发表于 2024-4-30 10:38:02 | 显示全部楼层
谢谢报告,看来只能走绿板方式来定制了。
发表于 2024-6-22 00:05:45 | 显示全部楼层
lx06#run bootcmd
[KM]Error:f[keymanage_dts_get_key_device]L80:/unify not parsed yet!
[KM]Error:f[_get_km_ops_by_name]L231:key deviceid not know device 4
[KM]Error:f[key_manage_query_exist]L546:There isn't dts cfg for key[deviceid]
[KM]Error:f[key_manage_query_size]L503:Fail in query key exist
Switch to boot1 system, because of NOT found SN Code ...
Saving Environment to aml-storage...
uboot env amlnf_env_save : ####
aml_nand_save_rsv_info:656, nenv: valid=1, pages=32
aml_nand_save_rsv_info:716,save info to 310000
aml_nand_write_rsv:520,write info to 310000
[burnup]Rd:Up sz 0x3f2037 to align 0x1000
save_power_post ...
## Booting Android Image at 0x01080000 ...
reloc_addr =f0344e0
copy done
load dtb from 0x1000000 ......
      Amlogic multi-dtb tool
      Single dtb detected
   Uncompressing Kernel Image ... OK
   kernel loaded at 0x01080000, end = 0x0185c808
libfdt fdt_path_offset() returned FDT_ERR_BADSTRUCTURE
[rsvmem] fdt get prop fail.
   Loading Ramdisk to 0eea7000, end 0f00449e ... OK
   Loading Device Tree to 000000000ee9b000, end 000000000eea6036 ... OK
fdt_find_or_add_subnode: chosen: FDT_ERR_BADSTRUCTURE
ERROR: /chosen node create failed
- must RESET the board to recover.
用论坛固件刷废了。。。。2个系统的都挂了,不知道哪的问题
发表于 2024-6-22 00:07:03 | 显示全部楼层
lx06#run bootcmd
save_power_post ...
reloc_addr =f0344e0
copy done
      Single dtb detected
GMT+8, 2026-1-15 05:07 , Processed in 1.287364 second(s), 12 queries , MemCached On.
