楼主: snowwolf725
[智能音箱] 拆解新买的小爱音箱Pro, 更新固化开机启动 SSH 教学
发表于 2022-10-28 23:47:51 来自手机 | 显示全部楼层
内测版固件不推送升级固件怎么办
发表于 2022-11-12 15:47:53 | 显示全部楼层
大佬的固件可以直接用uboot 刷机升级嘛  我刷完不开机了
发表于 2022-11-12 18:43:33 | 显示全部楼层
BL2 Built : 18:30:39, Aug 28 2018. axg g56303a2-dirty - liang.yang@droid11-sz
set vcck to 1140 mv
set vddee to 1070 mv
Board ID = 1
CPU clk: 1200MHz
DDR low power enabled
DDR3 chl: Rank0 16bit @ 792MHz
bist_test rank: 0 2b 03 54 34 0f 5a 27 00 4e 39 13 60 00 00 00 00 00 00 00 00 00 00 00 00 601   - PASS
Rank0: 256MB(auto)-2T-11
AddrBus test pass!
NAND init
page0 page0->bbt:
0000000000000000000000000000000000000000000000000000000000000000
page0 bbt:
Load FIP HDR from NAND, src: 0x0000c000, des: 0x01700000, size: 0x00004000
Load BL3x from NAND, src: 0x00010000, des: 0x01704000, size: 0x00080000
NOTICE:  BL31: v1.3(release):a1a8551
NOTICE:  BL31: Built : 15:59:55, Nov  9 2017
NOTICE:  BL31: AXG normal boot!
NOTICE:  BL31: BL33 decompress pass
[Image: axg_v1.1.3268-b93dd79 2017-12-01 14:22:18 huan.biao@droid12]
OPS=0x43
4f 69 2c 84 5f 2 1f 92 f 43 43 df bl30:axg ver: 9 mode: 0
bl30:axg thermal0
[0.014441 Inits done]
secure task start!
high task start!
low task start!
ERROR:   Error initializing runtime service opteed_fast
U-Boot 2015.01 (May 14 2019 - 03:38:52)
DRAM:  256 MiB
Relocation Offset is: 0ef17000
register usb cfg[0][1] = 000000000ff89538
NAND:  nand id: 0x98 0xf1
128MiB, SLC, page size: 2048, OOB size: 64
NAND device id: 98 f1 80 15 f2 16
NAND device: Manufacturer ID: 0x98, Chip ID: 0x98 (Toshiba A revision NAND 1Gib TC58BVG0S3HTA00 )
oob avail size 6
Creating 1 MTD partitions on "A revision NAND 1Gib TC58BVG0S3HTA00 ":
0x000000000000-0x000000200000 : "bootloader"
A revision NAND 1Gib TC58BVG0S3HTA00  initialized ok
nand id: 0x98 0xf1
PLANE change!
aml_nand_init obmul=1,oobfree.length=8,oob_size=64
oob avail size 8
bbt_start=20 env_start=24 key_start=32 dtb_start=40
nbbt: info size=0x400 max_scan_blk=24, start_blk=20
nbbt : phy_blk_addr=20, ec=0, phy_page_addr=0, timestamp=1
nbbt free list:
blockN=21, ec=-1, dirty_flag=0
blockN=22, ec=-1, dirty_flag=0
blockN=23, ec=-1, dirty_flag=0
aml_nand_scan_rsv_info 1251: page_num=1
aml_nand_scan_rsv_info 1254
nbbt valid addr: 280000
aml_nand_bbt_check 1389 bbt is valid, reading.
aml_nand_read_rsv_info:397,read nbbt info to 280000
nenv: info size=0x10000 max_scan_blk=32, start_blk=24
nenv : phy_blk_addr=25, ec=100, phy_page_addr=0, timestamp=210
nenv free list:
blockN=24, ec=103, dirty_flag=1
blockN=26, ec=-1, dirty_flag=0
blockN=27, ec=-1, dirty_flag=0
blockN=28, ec=-1, dirty_flag=0
blockN=29, ec=-1, dirty_flag=0
blockN=30, ec=-1, dirty_flag=0
blockN=31, ec=-1, dirty_flag=0
aml_nand_scan_rsv_info 1251: page_num=32
nenv valid addr: 330000
nkey: info size=0x8000 max_scan_blk=40, start_blk=32
nkey : phy_blk_addr=32, ec=1, phy_page_addr=0, timestamp=3
nkey free list:
blockN=33, ec=0, dirty_flag=1
blockN=34, ec=-1, dirty_flag=0
blockN=35, ec=-1, dirty_flag=0
blockN=36, ec=-1, dirty_flag=0
blockN=37, ec=-1, dirty_flag=0
blockN=38, ec=-1, dirty_flag=0
blockN=39, ec=-1, dirty_flag=0
aml_nand_scan_rsv_info 1251: page_num=16
nkey valid addr: 408000
ndtb: info size=0x20000 max_scan_blk=44, start_blk=40
ndtb : phy_blk_addr=40, ec=0, phy_page_addr=0, timestamp=2
ndtb free list:
blockN=41, ec=-1, dirty_flag=0
blockN=42, ec=-1, dirty_flag=0
blockN=43, ec=-1, dirty_flag=0
aml_nand_scan_rsv_info 1251: page_num=64
ndtb valid addr: 500000
tpl: off 8388608, size 8388608
NAND bbt detect factory Bad block at 6000000
aml_nand_add_partition:1794 factory bad addr=300
Creating 6 MTD partitions on "A revision NAND 1Gib TC58BVG0S3HTA00 ":
0x000000800000-0x000001000000 : "tpl"
0x000001000000-0x000001800000 : "boot0"
0x000001800000-0x000002000000 : "boot1"
0x000002000000-0x000004400000 : "system0"
0x000004400000-0x000006820000 : "system1"
0x000006820000-0x000008000000 : "data"
aml_key_init 170
MMC:
uboot env amlnf_env_read : ####
aml_nand_read_rsv_info:397,read nenv info to 330000
In:    serial
Out:   serial
Err:   serial
[store]To run cmd[amlnf dtb_read 0x1000000 0x20000]
sub cmd dtb
new argv[1] dtb_read
do_dtb_ops(): argc 4
arg 0: amlnf
arg 1: dtb_read
arg 2: 0x1000000
arg 3: 0x20000
do_dtb_ops() read
amlnf_dtb_read: ####
aml_nand_read_rsv_info:397,read ndtb info to 500000
do_dtb_ops(): 131072 bytes read : OK
      Amlogic multi-dtb tool
      Single dtb detected
amlkey_init() enter!
amlnf_key_read key data len too much
aml_nand_read_rsv_info:397,read nkey info to 408000
[EFUSE_MSG]keynum is 4
InUsbBurn
noSof
Hit Enter or space or Ctrl+C key to stop autoboot -- :  0
HAVE SN Code ...
Saving Environment to aml-storage...
uboot env amlnf_env_save : ####
aml_nand_save_rsv_info:656, nenv: valid=1, pages=32
release_free_node 61: bitmap=1fffff
release_free_node 74: bitmap=1ffff7
aml_nand_save_rsv_info:716,save info to 300000
aml_nand_write_rsv:520,write info to 300000
[burnup]Rd:Up sz 0x3c7027 to align 0x1000
save_power_post ...
## Booting Android Image at 0x01080000 ...
reloc_addr =f0344e0
copy done
load dtb from 0x1000000 ......
      Single dtb detected
   Uncompressing Kernel Image ... OK
   kernel loaded at 0x01080000, end = 0x01809808
   Loading Ramdisk to 0eeac000, end 0f0049aa ... OK
   Loading Device Tree to 000000000eea0000, end 000000000eeab026 ... OK
Starting kernel ...
uboot time: 1776135 us
domain-0 init dvfs: 4
[    0.290092@1] ff803000.serial: clock gate not found
[    0.297485@0] amlogic-new-usb3 ffe09080.usb3phy: This phy has no usb port
[    1.182177@0] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
Booting from boot1
/dev/mtdblock5 is ready now.
[    2.267940@1] meson-pinctrl pinctrl@ff634480: function 'gpioa_20' not supported
[    2.269641@1] meson-pinctrl pinctrl@ff634480: invalid function gpioa_20 in map table
Press the [f] key and hit [enter] to enter failsafe mode
Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level
Please press Enter to activate this console.
aux in now.
        "info": "0"
AS06_SystemInitDone
BusyBox v1.27.2 () built-in shell (ash)
  ______        _____  _______  ____   _____ __     __
|  ____|/\    / ____||__   __|/ __ \ |  __ \\ \   / /
| |__  /  \  | |        | |  | |  | || |__) |\ \_/ /
|  __|/ /\ \ | |        | |  | |  | ||  _  /  \   /
| |  / ____ \| |____    | |  | |__| || | \ \   | |
|_| /_/    \_\\_____|   |_|   \____/ |_|  \_\  |_|
        LX06 Fac Ver:2019-05-14 11:38:58
=== WARNING! =====================================
There is no root password defined on this device!
Use the "passwd" command to set up a new password
in order to prevent unauthorized SSH logins.
发表于 2022-11-13 13:57:32 | 显示全部楼层
大神级别!
blkc
发表于 2022-11-14 14:54:09 | 显示全部楼层
xiamo 发表于 2021-6-30 07:41
感谢大佬的回答,我目前的办法是配置了SSH密钥。用私匙登录就不用密码了。 ...
大佬你好,请问您SSH密钥是怎么配置进去的,我data里写了密钥,登录还是要输入密码
发表于 2022-12-15 18:14:27 | 显示全部楼层
cjx 发表于 2022-9-28 03:53
LX05 login:
LX05 login:
LX05 login:
你好,为什么我卡在这个“[NAND]unknown cmd 0x5413!”不动了,没出现登陆提示0.0
bib
发表于 2023-1-16 11:23:36 | 显示全部楼层
期待更多
发表于 2023-2-14 16:04:46 | 显示全部楼层
谢谢分享!
发表于 2023-3-1 15:36:07 | 显示全部楼层
小白看不懂咧
发表于 2023-4-15 20:14:20 | 显示全部楼层
谢谢报告,看来只能走绿板方式来定制了。
GMT+8, 2026-1-15 05:06 , Processed in 0.438138 second(s), 11 queries , MemCached On.
