查看: 166677|回复: 209
[智能音箱] 拆解新买的小爱音箱Pro, 更新固化开机启动 SSH 教学
发表于 2019-11-29 14:33:54 | 显示全部楼层 |阅读模式
2019/12/03 更新固化开机启动 SSH 教学
https://bbs.hassbian.com/forum.p ... tid=8754&pid=283801
小爱音箱固件及破解板固件下载
https://bbs.hassbian.com/forum.p ... 8754&pid=368909
前天买了小爱音箱刚好逛到这个论坛,
看到这麽多改造的教学手有点痒,
於是就自己把新买的音箱拆开看看,
把音箱底部的胶条拿掉后可以看到固定的螺丝,
把螺丝卸掉然後用螺丝刀插入上方中间的孔可以拔出底盖
移除底盘后长这样, 卸掉固定电源座的两个螺丝可以将音箱主体拔出
音箱本体, 把固定板子的四个螺丝卸下来可以将板子拆下来
板子背面
板子左下角为 TTL 的接口
接上 TTL 接可以查看开机纪录,
未升级前出厂版本 1.52.7 开机登入不需密码,
AXG:BL1:d1dbf2:a4926f;FEAT:E0DC318C:2000;POC:F;EMMC:800;NAND:0;READ:0;0.0;CHK:0;
sdio debug board detected
TE: 23919
BL2 Built : 18:30:39, Aug 28 2018. axg g56303a2-dirty - liang.yang@droid11-sz
set vcck to 1140 mv
set vddee to 1070 mv
Board ID = 1
CPU clk: 1200MHz
DDR low power enabled
DDR3 chl: Rank0 16bit @ 792MHz
bist_test rank: 0 2b 07 50 2e 0a 52 29 03 4f 34 0f 5a 00 00 00 00 00 00 00 00 00 00 00 00 612   - PASS
Rank0: 256MB(auto)-2T-11
AddrBus test pass!
NAND init
page0 page0->bbt:
0000000000000000000000000000000000000000000000000000000000000000
page0 bbt:
Load FIP HDR from NAND, src: 0x0000c000, des: 0x01700000, size: 0x00004000
Load BL3x from NAND, src: 0x00010000, des: 0x01704000, size: 0x00080000
NOTICE:  BL31: v1.3(release):a1a8551
NOTICE:  BL31: Built : 15:59:55, Nov  9 2017
NOTICE:  BL31: AXG normal boot!
NOTICE:  BL31: BL33 decompress pass
[Image: axg_v1.1.3268-b93dd79 2017-12-01 14:22:18 huan.biao@droid12]
OPS=0x43
49 ef 5 94 ca 20 c5 2e b9 78 ca 5f bl30:axg ver: 9 mode: 0
bl30:axg thermal0
[0.014483 Inits done]
secure task start!
high task start!
low task start!
ERROR:   Error initializing runtime service opteed_fast
U-Boot 2015.01 (Oct 14 2019 - 03:47:57), Build: jenkins-Mico_lx06_ota_publish-133
DRAM:  256 MiB
Relocation Offset is: 0ef17000
register usb cfg[0][1] = 000000000ff89588
NAND:  nand id: 0x98 0xf1
128MiB, SLC, page size: 2048, OOB size: 64
NAND device id: 98 f1 80 15 f2 16
NAND device: Manufacturer ID: 0x98, Chip ID: 0x98 (Toshiba A revision NAND 1Gib TC58BVG0S3HTA00 )
oob avail size 6
Creating 1 MTD partitions on "A revision NAND 1Gib TC58BVG0S3HTA00 ":
0x000000000000-0x000000200000 : "bootloader"
A revision NAND 1Gib TC58BVG0S3HTA00  initialized ok
nand id: 0x98 0xf1
PLANE change!
aml_nand_init :oobmul=1,oobfree.length=8,oob_size=64
oob avail size 8
bbt_start=20 env_start=24 key_start=32 dtb_start=40
nbbt: info size=0x400 max_scan_blk=24, start_blk=20
nbbt : phy_blk_addr=20, ec=0, phy_page_addr=0, timestamp=1
nbbt free list:
blockN=21, ec=-1, dirty_flag=0
blockN=22, ec=-1, dirty_flag=0
blockN=23, ec=-1, dirty_flag=0
aml_nand_scan_rsv_info 1251: page_num=1
aml_nand_scan_rsv_info 1254
nbbt valid addr: 280000
aml_nand_bbt_check 1389 bbt is valid, reading.
aml_nand_read_rsv_info:397,read nbbt info to 280000
nenv: info size=0x10000 max_scan_blk=32, start_blk=24
nenv : phy_blk_addr=24, ec=19, phy_page_addr=0, timestamp=39
nenv free list:
blockN=25, ec=18, dirty_flag=1
blockN=26, ec=-1, dirty_flag=0
blockN=27, ec=-1, dirty_flag=0
blockN=28, ec=-1, dirty_flag=0
blockN=29, ec=-1, dirty_flag=0
blockN=30, ec=-1, dirty_flag=0
blockN=31, ec=-1, dirty_flag=0
aml_nand_scan_rsv_info 1251: page_num=32
nenv valid addr: 300000
nkey: info size=0x8000 max_scan_blk=40, start_blk=32
nkey : phy_blk_addr=32, ec=0, phy_page_addr=0, timestamp=1
nkey free list:
blockN=33, ec=-1, dirty_flag=0
blockN=34, ec=-1, dirty_flag=0
blockN=35, ec=-1, dirty_flag=0
blockN=36, ec=-1, dirty_flag=0
blockN=37, ec=-1, dirty_flag=0
blockN=38, ec=-1, dirty_flag=0
blockN=39, ec=-1, dirty_flag=0
aml_nand_scan_rsv_info 1251: page_num=16
nkey valid addr: 418000
ndtb: info size=0x20000 max_scan_blk=44, start_blk=40
ndtb : phy_blk_addr=40, ec=0, phy_page_addr=0, timestamp=1
ndtb free list:
blockN=41, ec=-1, dirty_flag=0
blockN=42, ec=-1, dirty_flag=0
blockN=43, ec=-1, dirty_flag=0
aml_nand_scan_rsv_info 1251: page_num=64
ndtb valid addr: 500000
tpl: off 8388608, size 8388608
 NAND bbt detect factory Bad block at 6000000
aml_nand_add_partition:1794 factory bad addr=300
Creating 6 MTD partitions on "A revision NAND 1Gib TC58BVG0S3HTA00 ":
0x000000800000-0x000001000000 : "tpl"
0x000001000000-0x000001600000 : "boot0"
0x000001600000-0x000001c00000 : "boot1"
0x000001c00000-0x000004400000 : "system0"
0x000004400000-0x000006c20000 : "system1"
0x000006c20000-0x000008000000 : "data"
aml_key_init 170
MMC:
uboot env amlnf_env_read : ####
aml_nand_read_rsv_info:397,read nenv info to 300000
In:    serial
Out:   serial
Err:   serial
[store]To run cmd[amlnf dtb_read 0x1000000 0x20000]
sub cmd dtb
new argv[1] dtb_read
do_dtb_ops(): argc 4
arg 0: amlnf
arg 1: dtb_read
arg 2: 0x1000000
arg 3: 0x20000
do_dtb_ops() read
amlnf_dtb_read: ####
aml_nand_read_rsv_info:397,read ndtb info to 500000
do_dtb_ops(): 131072 bytes read : OK
      Amlogic multi-dtb tool
      Single dtb detected
amlkey_init() enter!
amlnf_key_read key data len too much
aml_nand_read_rsv_info:397,read nkey info to 418000
[EFUSE_MSG]keynum is 4
Hit Enter or space or Ctrl+C key to stop autoboot -- :  0
Saving Environment to aml-storage...
uboot env amlnf_env_save : ####
aml_nand_save_rsv_info:656, nenv: valid=1, pages=32
aml_nand_save_rsv_info:716,save info to 310000
aml_nand_write_rsv:520,write info to 310000
save_power_post ...
## Booting Android Image at 0x01080000 ...
reloc_addr =f0344e0
copy done
load dtb from 0x1000000 ......
      Single dtb detected
   Uncompressing Kernel Image ... OK
   kernel loaded at 0x01080000, end = 0x0185c808
   Loading Ramdisk to 0eea8000, end 0f005332 ... OK
   Loading Device Tree to 000000000ee9c000, end 000000000eea7036 ... OK
Starting kernel ...
uboot time: 1546948 us
domain-0 init dvfs: 4
[    0.290790@1] ff803000.serial: clock gate not found
[    0.298189@1] amlogic-new-usb3 ffe09080.usb3phy: This phy has no usb port
[    1.196193@1] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
LED AW20054
LX06
curr_boot is boot0
Booting from boot0
/dev/mtdblock4 is ready now.
[    2.588301@0] meson-pinctrl pinctrl@ff634480: function 'gpioa_20' not supported
[    2.590102@0] meson-pinctrl pinctrl@ff634480: invalid function gpioa_20 in map table
Press the [f] key and hit [enter] to enter failsafe mode
Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level
Please press Enter to activate this console.
[    9.867249@2] name: mac_wifi, size 17
[    9.884224@3] name: mac_bt, size 17
ledserver[1246]: current model lx06.
ledserver[1246]: LEDSBAK EXISITS
crond[1283]: crond (busybox 1.27.2) started, log level 5
[   12.673565@1] wlan: Loading MWLAN driver
[   12.674501@1] vendor=0x02DF device=0x9145 class=0 function=1
[   12.677592@1] SDIO: max_segs=1024 max_seg_size=131072
[   12.682519@1] rx_work=1 cpu_num=4
[   12.689843@2] Request firmware: mrvl/sdsd8977_combo_v2.bin
[   14.988585@1] WLAN FW is active
[   15.103121@1] get_channel when STA is not connected
[   15.105345@1] get_channel when AP is not started
[   15.108381@0] wlan: version = SD8977-16.84.9.p6-C4X16C544.P3-GPL-(FP84)
[   15.114713@0] wlan: Driver loaded successfully
[   15.544367@3] BT: Loading driver
[   15.546108@1] BT FW is active(0)
[   15.546148@1] BT: FW already downloaded!
[   15.555877@2] get_channel when STA is not connected
[   15.556503@2] get_channel when STA is not connected
[   15.561417@2] get_channel when STA is not connected
[   15.565363@2] get_channel when STA is not connected
[   15.570813@3] get_channel when STA is not connected
[   15.571440@2] BT: Driver loaded successfully
[   15.733067@2] wlan: wlan0 START SCAN
BusyBox v1.27.2 () built-in shell (ash)
  _____  _              __     __ __  ___  ___
 |     ||_| ___  ___   |  |   |  |  ||   ||  _|
 | | | || ||  _|| . |  |  |__ |-   -|| | || . |
 |_|_|_||_||___||___|  |_____||__|__||___||___|
      ROM Type:release / Ver:1.52.7
=== WARNING! =====================================
There is no root password defined on this device!
Use the "passwd" command to set up a new password
in order to prevent unauthorized SSH logins.
root@mico:/#
升级到最新版 1.58.13 预设 TTL 登入需要密码
https://bbs.hassbian.com/thread-8667-1-1.html
参考这篇的方式自己算出密码可以透过 TTL 登入,
TE: 24140
set vcck to 1140 mv
Board ID = 1
CPU clk: 1200MHz
bist_test rank: 0 2d 08 52 2f 0a 54 28 02 4f 35 0f 5b 00 00 00 00 00 00 00 00 00 00 00 00 607   - PASS
AddrBus test pass!
NAND init
page0 page0->bbt:
page0 bbt:
OPS=0x43
bl30:axg thermal0
[0.014521 Inits done]
secure task start!
high task start!
low task start!
DRAM:  256 MiB
oob avail size 6
nand id: 0x98 0xf1
PLANE change!
oob avail size 8
nbbt free list:
nenv : phy_blk_addr=24, ec=9, phy_page_addr=0, timestamp=19
nenv free list:
blockN=25, ec=8, dirty_flag=1
nkey free list:
ndtb free list:
aml_key_init 170
MMC:
In:    serial
Out:   serial
Err:   serial
sub cmd dtb
arg 0: amlnf
arg 1: dtb_read
arg 2: 0x1000000
arg 3: 0x20000
do_dtb_ops() read
      Single dtb detected
InUsbBurn
noSof
HAVE SN Code ...
[burnup]Rd:Up sz 0x3f2037 to align 0x1000
save_power_post ...
reloc_addr =f0344e0
copy done
      Single dtb detected
   Loading Ramdisk to 0eea8000, end 0f0054ae ... OK
Starting kernel ...
uboot time: 1804637 us
[    0.295052@3] ff803000.serial: clock gate not found
[    0.302417@3] amlogic-new-usb3 ffe09080.usb3phy: This phy has no usb port
[    1.200534@0] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
LED AW20054
LX06
curr_boot is boot1
Booting from boot1
/dev/mtdblock5 is ready now.
[    2.585896@0] meson-pinctrl pinctrl@ff634480: function 'gpioa_20' not supported
[    2.587582@0] meson-pinctrl pinctrl@ff634480: invalid function gpioa_20 in map table
[    9.802532@2] name: mac_wifi, size 17
[    9.817822@0] name: mac_bt, size 17
ledserver[1245]: current model lx06.
ledserver[1245]: LEDSBAK EXISITS
[   12.661449@1] wlan: Loading MWLAN driver
[   12.662130@0] vendor=0x02DF device=0x9145 class=0 function=1
[   12.665492@0] SDIO: max_segs=1024 max_seg_size=131072
[   12.670397@0] rx_work=1 cpu_num=4
[   12.677638@0] Request firmware: mrvl/sdsd8977_combo_v2.bin
[   14.968238@3] WLAN FW is active
[   15.075150@0] get_channel when STA is not connected
[   15.077559@2] get_channel when AP is not started
[   15.080443@2] wlan: version = SD8977-16.84.9.p17-C4X16C544.P3-GPL-(FP84)
[   15.086106@2] wlan: Driver loaded successfully
[   15.501524@1] BT: Loading driver
[   15.505919@2] BT FW is active(0)
[   15.505956@2] BT: FW already downloaded!
[   15.519064@0] get_channel when STA is not connected
[   15.519646@0] get_channel when STA is not connected
[   15.520630@3] BT: Driver loaded successfully
[   15.528828@0] get_channel when STA is not connected
[   15.532770@0] get_channel when STA is not connected
[   15.538312@1] get_channel when STA is not connected
[   15.668846@1] wlan: wlan0 START SCAN
开机时按 f 并按下 enter 可进入 failsafe 模式
- failsafe -
Generating key, this may take a while...
Public key portion is:
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAAAgQC2DP92+nA0hs7KMFsuE+LlcrLcazqb84TWYuPC7u/2        yqzxcLhIXXJTVYo1hdvtJ7XSYLdZ3FhtQqj9Ab1ofCgaNPp+VyDxx9Hc9+UpLqUpL++FyjaoEFWQMCse        3PXhohKjqxSF+zJkKjG0Cd9jM7Vz+T/snAf7zYNYApu0h9LbdQ== root@(none)
Fingerprint: md5 e0:4f:5b:63:cc:4a:10:73:49:6a:76:97:f1:be:46:58
f
ash: can't access tty; job control turned off
      ROM Type:release / Ver:1.58.13
================= FAILSAFE MODE active ================
special commands:
* firstboot          reset settings to factory defaults
* mount_root     mount root-partition with config files
after mount_root:
* passwd                         change root's password
* /etc/config               directory with config files
for more help see:
http://wiki.openwrt.org/doc/howto/generic.failsafe
root@(none):/etc# cat shadow
root:$1$N0Iz0LLs$kZ5zG/Y2AUWHNE5I3ElWm1:18128:0:99999:7:::
daemon:*:0:0:99999:7:::
ftp:*:0:0:99999:7:::
network:*:0:0:99999:7:::
nobody:*:0:0:99999:7:::
mosquitto:x:0:0:99999:7:::
root@(none):/etc# cat passwd
root:x:0:0:root:/root:/bin/ash
daemon:*:1:1:daemon:/var:/bin/false
ftp:*:55:55:ftp:/home/ftp:/bin/false
network:*:101:101:network:/var:/bin/false
nobody:*:65534:65534:nobody:/var:/bin/false
mosquitto:x:200:200:mosquitto:/var/run/mosquitto:/bin/false
reboot 讯息
root@mico:/data# reboot
root@mico:/data# bluez_mibt_ble_new[2809]: main:
bluez_mibt_ble shutting down...
mediaplayer[1814]: sigterm_handler, somebody killed me, exit!
miio_bt[352]: sig_handler:15
rssi[1890]: failed to reconnect, trying again in 2 seconds
miio_bt[352]: [E][arch_rpc] rpc_agent_ot_message_callback 302: socket
miio_service[3093]: failed to reconnect, trying again in 2 seconds
bluez_mibt_classical[2807]: ------ proxy_removed, 376 ------
bluez_mibt_classical[2807]: Agent unregistered
bluez_mibt_classical[2807]: [DEL] Controller EC:41:18:6D: 撠镨阅?喟拳-1807 [default]
bluez_mibt_classical[2807]: !!!! disconnect disconnect_handler !!
miio_bt[352]: byebye
bl31 reboot reason: 0xd
bl31 reboot reason: 0x1
system cmd  1.
参与人数 1金钱 +2 收起 理由
xhuihui + 2 高手,这是高手!
发表于 2019-11-29 15:11:53 | 显示全部楼层
意思就是说可以接入HA了?
发表于 2019-11-29 20:44:20 | 显示全部楼层
坐等更新
发表于 2019-11-30 22:08:47 | 显示全部楼层
哇,厉害!可以接入HA吗?
发表于 2019-11-30 22:46:00 | 显示全部楼层
期待更多
发表于 2019-12-1 11:55:36 | 显示全部楼层
不知道现在小爱除了最初的黑板绿板外。还有什么可以接入ha?比如小爱play可以么?
ygao
发表于 2019-12-1 22:00:45 来自手机 | 显示全部楼层
应该试一下本站的密码破解,进入failsafe,用处不大吧
 楼主| 发表于 2019-12-2 07:30:42 | 显示全部楼层
https://bbs.hassbian.com/thread-11139-1-1.html
不过 / 是 read-only 只有 /data 可以写入,
其余在研究
mico login: root
Password:
root@mico:~# df -h
Filesystem                Size      Used Available Use% Mounted on
/dev/mtdblock5           30.9M     30.9M         0 100% /
tmpfs                   120.9M    384.0K    120.5M   0% /tmp
tmpfs                   512.0K         0    512.0K   0% /dev
/dev/ubi0_0              13.3M      1.2M     11.4M  10% /data
/dev/ubi0_0              13.3M      1.2M     11.4M  10% /etc/shadow
root@mico:~# mount
/dev/mtdblock5 on / type squashfs (ro,noatime)
proc on /proc type proc (rw,nosuid,nodev,noexec,noatime)
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,noatime)
tmpfs on /tmp type tmpfs (rw,nosuid,nodev,noatime)
tmpfs on /dev type tmpfs (rw,nosuid,relatime,size=512k,mode=755)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,mode=600,ptmxmode=000)
debugfs on /sys/kernel/debug type debugfs (rw,noatime)
pstore on /sys/fs/pstore type pstore (rw,relatime)
/dev/ubi0_0 on /data type ubifs (rw,relatime)
/dev/ubi0_0 on /etc/shadow type ubifs (rw,relatime)
root@mico:~# cd /data/
root@mico:/data# ls
ai-crontab       dts_conf         miio             timer
alarm            etc              mipns            upnp-disc
bt               log              notify           voip
console          mdspeech_status  player           wifi
dlna             messagingagent   sound            work_day_db
dnsmasq.time     mibrain          status           workday
root@mico:/data# cd /etc
root@mico:/etc# ls
TZ                       hosts                    profile
asound.conf              hotplug-preinit.json     protocols
asound.state             hotplug.d                rc.button
banner                   hotplug.json             rc.common
banner.failsafe          init.d                   rc.d
bluetooth                inittab                  rc.local
board.d                  iproute2                 resolv.conf
bt                       localtime                services
config                   marvell                  shadow
crontabs                 miio                     shells
dbus-1                   modules-boot.d           ssl
device_info              modules.d                sysctl.conf
diag.sh                  mosquitto                sysctl.d
diracmobile.config.s12a  mtab                     syslog-ng.conf
diracmobile.config.s12c  nsswitch.conf            sysupgrade.conf
dnsmasq.conf             openwrt_release          uci-defaults
dnsmasq.conf.ap          openwrt_version          wifi
dnsmasq.conf.sta         opkg                     workday
dropbear                 os-release               xattr.conf
fstab                    passwd
group                    preinit
ygao
发表于 2019-12-2 10:50:38 来自手机 | 显示全部楼层
谢谢报告,看来只能走绿板方式来定制了。
 楼主| 发表于 2019-12-3 14:08:07 | 显示全部楼层
# 2020/12/03 更新教程, 改用 mtd 写入分区, 避免 dd 写入分区错误的情况
开始改造小爱音箱Pro开机自动启动 SSH
TTL登入系统, 然后开启 SSH
mico login: root
Password:
root@mico:~# dropbearkey -t rsa -f /data/dropbear_rsa_host_key
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQDtEcuiRqr+8GcaQVWUYbnw6AresOdhQ6bdig0FvLPn
blvMEeBcKWZDO/kMjGcpNGn719zB8P92wr41LqHM+IP20a9IAbAv03ex+vEVAgz3dpRAlQ7R5ciHg89b
6J0pYOgwP3H5Q3t0YWrEOykmUHFQXpx7d/qQLTPIoj4gZVdrXu408Qw3i3f3RkLATbY+41oxnw6yhKDR
77ZIMwN/8czxftVXPotMA4VOWFMVlgrvT7HpyZcwhArfnlKYZdCdozmk3nw/zpWxePhiHK/Qodcwh64M
FxrSCEoVlfRAvxOq86O2PztbQ5003DBfuwGVv4tu2ZnvXxTz+3WUDFw3j7Ef root@mico
Fingerprint: md5 38:2b:0e:0b:f2:be:b9:39:e0:02:4d:31:5e:af:c9:5a
root@mico:~# dropbear -r /data/dropbear_rsa_host_key
root@mico:~# ifconfig
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:523 errors:0 dropped:0 overruns:0 frame:0
          TX packets:523 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1
          RX bytes:90551 (88.4 KiB)  TX bytes:90551 (88.4 KiB)
wlan0     Link encap:Ethernet  HWaddr EC:41:18:6D:1C:03
          inet addr:192.168.1.145  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::ee41:18ff:fe6d:1c03/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:1072 errors:0 dropped:0 overruns:0 frame:0
          TX packets:607 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:222324 (217.1 KiB)  TX bytes:106862 (104.3 KiB)
先用 mount 或是 df 指令查看下目前系统是用哪个分区启动,
这边会影响到後面是将修改後的固件写入到哪个分区,
如果是 /dev/mtdblock5 表示目前启动的是 system1, 那我们就要将修改的固件写到 system0 分区
(小爱音箱中同时存在两套系统, 避免升级时断电损坏无法开机的情况, 可用另一个分区启动)
mtdblock4 是 system0
mtdblock5 是 system1
root@LX06:~# df -h
/dev/mtdblock5 34.5M 34.5M 0 100% /
tmpfs 120.9M 456.0K 120.4M 0% /tmp
/dev/ubi0_0 13.3M 11.4M 1.2M 91% /data
/dev/ubi0_0 13.3M 11.4M 1.2M 91% /etc/shadow
利用 dd 备份系统到 /tmp/m4.img
root@mico:~# cd /tmp
root@mico:/tmp# dd if=/dev/mtdblock4 of=/tmp/m4.img
81920+0 records in
81920+0 records out
利用 WinSCP 把档案传回, 我这边不知为何无法用 WinSCP 连线小爱音箱, 结果只能用 SCP 传到另一台 Linux 主机
root@mico:/tmp# scp m4.img [email protected]:m4.img
/usr/bin/dbclient: Warning: failed creating /root/.ssh: Read-only file system
Host '192.168.1.5' is not in the trusted hosts file.
(ssh-rsa fingerprint md5 37:40:25:31:18:af:55:bf:8c:6a:5d:74:b6:83:de:6f)
Do you want to continue connecting? (y/n) y
[email protected]'s password:
m4.img        100%   40MB 650.2KB/s   01:03
在 Linux 主机中查看下档案讯息中的 Block size之后打包会用到
这边 Block size 是 131072
snowwolf725@Chin:~$ unsquashfs -s m4.img
Found a valid SQUASHFS 4:0 superblock on m4.img.
Creation or last append time Mon Oct 14 11:17:13 2019
Filesystem size 31654.99 Kbytes (30.91 Mbytes)
Compression xz
xz: error reading stored compressor options from filesystem!
Block size 131072
Filesystem is exportable via NFS
Inodes are compressed
Data is compressed
Fragments are compressed
Always-use-fragments option is not specified
Xattrs are not stored
Duplicates are removed
Number of fragments 127
Number of inodes 1798
Number of ids 1
将档案解开
root@Chin:~# unsquashfs -dest tochang m4.img
Parallel unsquashfs: Using 8 processors
1699 inodes (2067 blocks) to write
[============================================================================================================================================/] 2067/2067 100%
created 1124 files
created 99 directories
created 574 symlinks
created 1 devices
created 0 fifos
修改 /etc/rc.local 添加 /data/init.sh
root@Chin:~# cd tochang/etc/
root@Chin:~/tochang/etc# vi rc.local
/etc/rc.local 修改后内容如下, 加入开机启动 dropbear 这个 ssh 服务及之后扩展用的脚本 /data/init.sh
root@Chin:~/tochang/etc# cat rc.local
# Put your custom commands here that should be executed once
# the system init finished. By default this file does nothing.
/data/init.sh
exit 0
取消自动升级, 把 ota slient 这行用 # 注解掉
root@Chin:~/tochang/etc# cd crontabs/
root@Chin:~/tochang/etc/crontabs# vi root
root@Chin:~/tochang/etc/crontabs# cat root
*/5 * * * * /usr/sbin/easy_logcut size
* * * * * /usr/sbin/network_probe.sh
32 4 * * * /usr/sbin/pns refresh
*/10 * * * * /usr/bin/check_mediaplayer_status
#* 3 * * * /bin/ota slient  # check ota
* 8 * * * /bin/check_linein.sh
重新打包img参数按查看的信息写,不同设备可能与我的不同(小爱音箱Pro 的 block size应该都是131072 )
root@Chin:~/tochang/etc/crontabs# cd
root@Chin:~# mksquashfs tochang m4_crack.img -b 131072 -comp xz -no-xattrs
Parallel mksquashfs: Using 8 processors
Creating 4.0 filesystem on m4_crack.img, block size 131072.
[============================================================================================================================================|] 1492/1492 100%
Exportable Squashfs 4.0 filesystem, xz compressed, data block size 131072
        compressed data, compressed metadata, compressed fragments, no xattrs
        duplicates are removed
Filesystem size 32675.51 Kbytes (31.91 Mbytes)
        48.51% of uncompressed filesystem size (67353.17 Kbytes)
Inode table size 16562 bytes (16.17 Kbytes)
        25.16% of uncompressed inode table size (65831 bytes)
Directory table size 18414 bytes (17.98 Kbytes)
        45.32% of uncompressed directory table size (40632 bytes)
Number of duplicate files found 46
Number of files 1124
Number of symbolic links  574
Number of device nodes 1
Number of fifo nodes 0
Number of socket nodes 0
Number of directories 99
Number of ids (unique uids + gids) 1
Number of uids 1
        root (0)
Number of gids 1
        root (0)
在小爱音箱中把 m4.img 删除, 并把 m4_crack.img 这个改好的档案複製回来
root@mico:/tmp# rm m4.img
root@mico:/tmp# scp [email protected]:m4_crack.img m4_crack.img
m4_crack.img        100%   32MB 573.3KB/s   00:57
再把破解好的 img 写回 system0 分区, 并设置mtdblock4为启动分区
如果是 /dev/mtdblock5 表示目前启动的是 system1 你要要把档案写到 system0
并且使用 boot0 启动系统
相反如果是 /dev/mtdblock4 表示目前启动的是 system0 你要要把档案写到 system1
并且使用 boot1 启动系统
root@mico:/tmp# mtd write m4_crack.img system0
Unlocking system0 ...
Writing from m4_crack.img to system0 ...  [w]
root@mico:/tmp# /usr/bin/fw_env -s boot_part boot0
[ubootenv] update_bootenv_varible name [boot_part]: value [boot0]
[ubootenv] Save ubootenv to /dev/nand_env succeed!
另外如果有什麽需要开机执行的写入到 /data/init.sh, 最后将小爱重开验证改造是否成功,
如果改造成功预设小爱开机后就会启动 SSH 不用透过 TTL 进行连线
root@mico:/tmp# cd /data
root@mico:/data# vi /data/init.sh
root@mico:/data# cat /data/init.sh
root@mico:/data# chmod a+x init.sh
GMT+8, 2025-12-30 02:40 , Processed in 0.064696 second(s), 13 queries , MemCached On.
