楼主: Tozy
树莓派安装Homebridge详细教程
发表于 2017-10-14 10:00:42 | 显示全部楼层
學習了,謝謝
发表于 2017-10-14 21:14:57 | 显示全部楼层
最后这里报错了,我是哪里错了啊,请问TOZY
发表于 2017-10-15 09:43:42 | 显示全部楼层
感谢分享,安装总是不成功,参考下。
发表于 2017-10-16 02:13:10 | 显示全部楼层
感谢楼主,成功带我入坑
发表于 2017-10-16 15:36:48 | 显示全部楼层
谢谢分享!
发表于 2017-10-17 14:39:55 | 显示全部楼层
谢谢大哥,万分感激
发表于 2017-10-18 09:48:32 | 显示全部楼层
学习了,感谢分享
发表于 2017-10-18 13:04:22 | 显示全部楼层
我用hassbian的2017-9-13的版本安装的,然后到这一步直接报错,重新刷试了3次,或者换成清华大学的源也试过,都是报这一样的错误啊!麻烦,看下我到底哪里错了啊?
pi@hassbian:~ $ sudo apt-get install samba-common-bin
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
samba-common-bin : Depends: samba-common (= 2:4.2.14+dfsg-0+deb8u8) but 2:4.5.8+dfsg-2+deb9u1 is to be installed
E: Unable to correct problems, you have held broken packages.
pi@hassbian:~ $
发表于 2017-10-18 20:38:47 | 显示全部楼层
bignum好像不能下载安装文件啊,有什么好办法呢,谢了~
发表于 2017-10-19 19:42:59 | 显示全部楼层
多谢楼主,我都成功了。我用博联在HA上也成功添加了开关,可以控制。但是homekit里只添加了homebridge,哪个开关如何添加到homekit里。。。
GMT+8, 2026-1-16 02:57 , Processed in 1.216499 second(s), 19 queries , MemCached On.
