楼主: Tozy
树莓派安装Homebridge详细教程
发表于 2017-8-1 21:49:12 | 显示全部楼层
楼主好,我运行homebridge的时候出现了下面的警告,username 和 host 我都确认过填的是我自己pi的MAC地址 及 IP 地址。一晚上都在折腾这个,实在没招了故来求助
pi@hassbian:~ $ homebridge
*** WARNING *** The program 'nodejs' uses the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** Please fix your application to use the native API of Avahi!
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=nodejs>
*** WARNING *** The program 'nodejs' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** For more information see <http://0pointer.de/avahi-compat? ... =DNSServiceRegister>
[8/1/2017, 1:39:59 PM] Loaded plugin: homebridge-homeassistant
[8/1/2017, 1:39:59 PM] Registering platform 'homebridge-homeassistant.HomeAssistant'
[8/1/2017, 1:39:59 PM] ---
/usr/lib/node_modules/homebridge/lib/server.js:205
      throw new Error('Not a valid username: ' + username + '. Must be 6 pairs of colon-' +
Error: Not a valid username: x:x:x:x:x:x. Must be 6 pairs of colon-separated hexadecimal chars (A-F 0-9), like a MAC address.
    at Server._loadConfig (/usr/lib/node_modules/homebridge/lib/server.js:205:13)
    at new Server (/usr/lib/node_modules/homebridge/lib/server.js:52:38)
    at module.exports (/usr/lib/node_modules/homebridge/lib/cli.js:26:16)
    at Object.<anonymous> (/usr/lib/node_modules/homebridge/bin/homebridge:17:22)
    at Module._compile (module.js:570:32)
    at Object.Module._extensions..js (module.js:579:10)
    at Module.load (module.js:487:32)
    at tryModuleLoad (module.js:446:12)
    at Function.Module._load (module.js:438:3)
    at Module.runMain (module.js:604:10)
发表于 2017-8-12 20:23:48 | 显示全部楼层
lidicn 发表于 2017-7-7 20:18
系统刷完之后,插到树莓派开机,等ha自动安装完毕,下面就是我个人的一些步骤。另外,上面我提到过重刷了无 ...
请问一下 怎么重启HA服务?
amos
发表于 2017-8-14 11:26:11 来自手机 | 显示全部楼层
这几天按老高的方法,我居然一次性成功安装了。不过后面的给sonoff开关刷固件,连接siri费了很多时间
发表于 2017-8-15 00:28:31 | 显示全部楼层
谢谢分享~~~
TvvT 手机认证
发表于 2017-8-18 10:20:56 | 显示全部楼层
感谢分享。。。。。。。。。。。。。
发表于 2017-8-27 18:27:38 | 显示全部楼层
设置自启动不正确 怎么破 求助
发表于 2017-8-31 00:19:16 | 显示全部楼层
不知道是不是网络抽风,换了几个固件,ha都始终还是装不起来
发表于 2017-9-3 00:10:13 | 显示全部楼层
把config文件删掉就行啦
发表于 2017-9-10 11:27:14 | 显示全部楼层
我按照楼主的刷了以后miio装不上。。痛苦
发表于 2017-9-10 20:03:43 | 显示全部楼层
Tozy 发表于 2017-7-28 13:25
你这个是bignum下载出错了,网络问题,重试就好了
好像不是网络错误,是bignum-v0.12.5-node-v51-linux-arm.tar.gz这个文件直接这样下载不了。
GMT+8, 2026-1-16 03:15 , Processed in 0.766167 second(s), 20 queries , MemCached On.
